uus teema   vasta Hinnavaatlus »  Mobiiltelefonid/ GPS seadmed / Muu tehnika »  HTC Wildfire (S) märgi kõik teemad loetuks
mine lehele 1, 2, 3 ... 17, 18, 19  järgmine
eyelids
sõnum 03.09.2010 19:18:06 HTC Wildfire (S) vasta tsitaadiga
link :: HTC koduleht
HTC Wildfire S
2G Network GSM 850 / 900 / 1800 / 1900
3G Network HSDPA 900 / 2100
HSDPA 850 / 1900
SIZE Dimensions 101.3 x 59.4 x 12.4 mm, Weight 105 g
DISPLAY Type TFT capacitive touchscreen, 256K colors 320 x 480 pixels, 3.2 inches
- Gorilla Glass display
- Accelerometer sensor for UI auto-rotate
- Proximity sensor for auto turn-off
- HTC Sense UI
- Touch-sensitive controls
SOUND Alert types Vibration, MP3, WAV ringtones,Loudspeaker, 3.5mm jack
MEMORY
Internal 512 MB ROM, 512 MB RAM
Card slot microSD, up to 32GB, buy memory
CPU 600 MHz processor
DATA GPRS Up to 114 kbps, EDGE Up to 560 kbps, 3G,HSDPA, 7.2 Mbps; HSUPA, 384 Kbps
WLAN Wi-Fi 802.11 b/g/n, Wi-Fi hotspot
Bluetooth Yes, v3.0 with A2DP, EDR
USB microUSB v2.0
CAMERA Primary 5 MP, 2592 x 1944 pixels, autofocus, LED flash, check quality, Features Geo-tagging, Video VGA@24fps
FEATURES OS Android OS, v2.3 (Gingerbread)
Messaging SMS(threaded view), MMS, Email, Push Email, IM
Browser HTML
Radio Stereo FM radio with RDS
GPS with A-GPS support
Engadet review
HTC Wildfire
Protsessor: 528 MHz
Operatsiooni süsteem:
Android™ 2.1 (Éclair) with HTC Sense™
Mälu: ROM: 512 MB, RAM: 384 MB
Mõõtmed: 106.8 mm X 60,4 mm X 12.9 mm
Kaal: 118g koos akuga
Ekraan: 3.2" LCD puutetundlik ekraan, 240 x 320 QVGA
Mobiilivõrgud: HSDPA/WCDMA: 900/2100 MHz
GSM: 850/900/1800/1900 MHz
Opereerimis-nupp: Optiline Trackball ja puutetundlikul ekraanil klahvistik
Ühilduvus: Bluetooth® 2.1 koos EDR Wi-Fi®: IEEE 802.11 b/g HTC ExtUSB™ (5-pin microUSB 2,0) audio 3,5mm heli pistik
Kaamera: 5.0 megapiksline auto fookus, välguga + näotuvastus
GPS: Olemas
Heli: 3,5 mm audio pistik, Sisse ehitatud mikrofon ning kõlarid, toetatavad failitüübid: MP3, AAC(AAC, AAC+, AAC-LC), AMR-NB, WAV, MIDI and Windows Media® Audio 9, FM Raadio
Video: MPEG-4, H.263, H.264 and Windows Media® Video 9
Aku: Aku: 1300 mAh Li-Ion Polymer
Ooteaeg: Kuni 480 h GSM, Kuni 690 h WCDMA
Kõneaeg: Kuni 490 min GSM, Kuni 440 min WCDMA
Mälukaart: microSD™ (SD 2.0 ühenduv) kuni 32 GB
AC Adapter: 100 ~ 240V AC, 50/60Hz; DC väljund: 5V - 1A
Spetsiaal omadused: G-Sensor, Digitaalne kompass
Engadget review
On kellelgi selle antud mudeliga kogemusi ka? Sooviks kommentaare, arvamusi.
viimati muutis eyelids 17.07.2011 14:46:29, muudetud 4 korda
Kommentaarid: 42 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 42
painkillah
painkillah
sõnum 03.09.2010 19:25:58 vasta tsitaadiga
ootaks ka tagasisidet antud seadme kohta - kuigi ekraan on väike, tundub päris asjalik jubin.
DigeBeni
DigeBeni
sõnum 03.09.2010 19:34:42 vasta tsitaadiga
... eks see Desire pesamuna ole icon_smile.gif Samsungil on selles klassis kah päris mitu konkurenti saada i5500, i5800 ja otseloomulikult vana ja ära proovitud i5700. Juhul, kui sellisest klassist midagi valima peaks, siis ilmselt eelistaks i5800, sellel ka ametlik Froyo peale uuendamise võimalus olemas ...
Kommentaarid: 197 loe/lisa Kasutajad arvavad:  :: 2 :: 5 :: 162
K3ndu
K3ndu
sõnum 03.09.2010 20:13:31 vasta tsitaadiga
https://www.hinnavaatlus.ee/products/Arvutiriistvara/Pihuarvutid/144833/
Täitsa HV andmebaasis ka, ja niipalju kui ülevaateid lugesin siis räägiti niipalju ,et raha eest asja küll ja kiirusest puudu ei jää. Jooksutad mitu appi ja liigub ikka nagu paugupill.
Kommentaarid: 127 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 117
Teip
Teip
sõnum 03.09.2010 20:53:18 vasta tsitaadiga
Spekside järgi on tegu viletsa ekraaniga Legendiga Desire sarnases kestas, ehk siis kas vaese mehe Legend või vaese mehe Desire, st ainus põhjus sellise asja ostmiseks saab olla rahapuudus korraliku asja ostmiseks icon_wink.gif
"Without beating around the bush we can say that Wildfire is a cheap HTC smartphone. PR departments ask not to use the word "cheap" and substitute it by "inexpensive", but in the case of HTC Wildfire we have a cheap smartphone."
Kommentaarid: 201 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 184
ponas
sõnum 11.09.2010 20:51:20 vasta tsitaadiga
See telefon sai ostetud seepärast, et Java programmide võimalused on piiratud (SE K660i oli).
Kriitikat ka:
Puutetundliku ekraani peal terve klaviatuuriga kirjutamine nõuab kahe käega tegevust ja klaviatuuri peale vaatamist (miinus neile, kel 12 nupuga klaviatuuri käsitlemine käpas), normaalselt on kirjutada võimalik vaid laiuti, kuid enamikel programmidel puudub võimalus, mis klaviatuuri vaid laiuti näitaks, käsitsi telefoni pöörates võtab teistpidi klaviatuuri panemine telefonil aega sekund-paar.
Netiraadio programm TuneIn kipub aeg-ajalt seiskuma kui see lahti pole ning ekraan ei tööta. Programmi autorid soovitavad telefoni välja lülitada ning siis peaks probleem lahenema, lahenebki, kuid mitte kauaks.
Väga head netibrauserit pole veel leidnud, mille kasutusmugavus oleks võimalikult lihtne ja konkreetne. Kaasas olnud brauser ei luba näiteks soiduplaan.tallinn.ee lehel alla kerida. Opera Minil on aga Flashi võimalused veelgi nadimad kui kaasasolnud brauseril. Seoses sellega tuleb oodata Andoid 2.1->2.2 uuendust, millega peaks tulema full-flash saadavale. Näiteks peatus.ee punktist punkti otsing ei tööta selle flash lite-ga, mis kaasas.
Kaamera on telefoni kohta suhteliselt hea, hädapärasteks ootamatuteks piltideks ja videoteks kõlbab, kuid kui plaan pilti millestki teha, tasuks fotokas siiski kaasa võtta.
GPS töötab, aga head kaardi- või navisofti pole leidnud. Google Maps isegi võibolla ajaks mõnes kohas asja ära, aga samal ajal tahaks näha ka näiteks liikumiskiirust jne. Loodetavasti mingi kaardisoft sellele ikka tuleb.
Mõnevõrra häirib isegi mõningate vidinate rohkus, näiteks seadistasin ma telefoni ära meile vastu võtma, samas kuskil oli vaja veel mingit Google accounti ning nüüd võtab neid samu meile ka sealt veel vastu... Kuid see rohkem seadistamise küsimus.
Youtubest videoid saab vaid osasid videoid vaadata, mõnda avada tahtes on kirjas märge a'la "not availiable for mobile". Samas Youtube videotest huvitab sageli rohkem nt mõni uudisklipp ERR Uudistest, mida ei näita, Reporteri klipid on flashis ning neid näitab vaid hakkides.
Aeg-ajalt tahaks kuulata mõne raadiosaate podcasti, kahjuks enamikel raadiotel on nad erineval kujul. Osadel tuleb tõmmata alla terve mp3, osadel saab kuulata ainult läbi brauseri ja telefoni pleieri (kusjuures pole leidnud varianti, et brauserit backroundi nii panna, et see muusika mängima jääks), osadel vaid brauserit esiplaanil aktiivsena käsitsi hoides (sh peab ekraan kogu aeg töötama, podcast läbi flashi). Muusikamängija töötab muidu hästi, aga samas lugude valimine on esmapilgul minu jaoks suhteliselt keeruliselt arusaadav.
Veebis surfates brauser viib tihti teksti vastavusse ekraani laiusega. Näiteks Postimehel on selle jaoks tehtud versioon, kus paremal ja vasakul tulpa pole, on vaid piltidega uudisepealkirjad keskel. Samas sealt tulbast tahaks aeg-ajalt midagi valida, siis on loetavasse suurusesse suumimine ning pildi liigutamine suhteliselt tülikas.
Probleem on veel ka see, et telefoni võrku ei saa käsitsi valida. Telefon eelistab küll alati koduvõrku (või siis partnervõrku, nt Tele2 võrgud Lätis-Leedus), kuid see toimub vaid piisava levi olemasolul ning ei saa välistada, et seda piisavat levi alati on. Roamingus saab data ära keelata küll, aga mingitel tingimustel see ikka võimalik on jne. Lätis-Leedus Tele2 kliendile Tele2 võrgus kõnede vastuvõtmine tasuta, kui kui seal otsustab parema levi tõttu mõne teise operaaturi kasuks, siis võib see suhteliselt kalliks minna.
Üldiselt see, kas, kuidas ja millised programmid tausal töötavad ja kuidas neid vahetada, on suhteliselt kehv vähemalt Android 2.1 versiooniga.
Võrreldes eelmise telefoniga muidugi suur pluss on see, et helipistik on 3,5mm ja laadimine USB otsa kaudu, kusjuures teine ots läheb kas arvutisse või laadijasse, kahte juhet pole vaja kaasas vedada.
Aku kestab nii 1 ööpäeva ringis esialgu, aga näppimist on ka suht palju olnud. Mitte midagi tehes ja kõik kellad-viled-ühendused maha keerates (selle jaoks mugava toolbari saab desktopi peale tuua) kestaks aku palju-palju.
Kiituseks võib seda öelda, et vaegkuuljatele on see telefon selles mõttes hea, et kõnekuular on väga vali ning mul tuli see peaaegu täiesti maha keerata, et liiga kõvasti poleks.
See mu kui varem puutetundlikku ekraani ja Android telefoni mitte kasutanud isiku esialgne arvamus, kindlasti kui asi käppa saab, kiiksud teada ja soft paremaks saab, peaks päris asjalik telefon olema arvestades hinda alla 4000EEK. Samas kel kogemusi toodud probleemide lahendamisega, ootan huviga!
flake
sõnum 11.09.2010 21:30:58 vasta tsitaadiga
ponas kirjutas:
proovi sellist asja nagu Navigon.
Kommentaarid: 63 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 60
DigeBeni
DigeBeni
sõnum 11.09.2010 21:52:56 vasta tsitaadiga
Tegemist on siiski Androidiliste maailma alumise otsaga, seega riistvaralt ei maksa ülemäära palju jõudlust oodata. Seetõttu ka aeglane ekraani pööramine ja vilets videomaterjali esitus. Mis puutub aga tarkvarasse, siis seda peaks olema Androidi jaoks küll heldelt valida, löö aga Market lahti ja vali mõni parem tarkvarajupp ehk siis puhtalt läbi proovimise asi, mis antud telefoniga hästi töötab, mis mitte. Android on Google sülelaps, seega on üsna loogiline, et erinevad teenused on seotud just läbi Google konto. Tegemist on päris kasuliku omadusega sest läbi selle saad sünkroniseerida oma telefoninumbreid ja kontakte, kalendrit ja näiteks kasvõi näidata oma asukohta teistele kasutajatele. Operaatorit sai minuteada manuaalselt valida küll, kuid kahjuks pole mul hetkel Androidi käepärast, et täpselt järele vaadata. Mälus olevate programmide haldamiseks on jällegi Market see õige koht, kust sobiv programm leida a'la erinevad task killerid, managerid vms. Ühesõnaga puha uurimise, puurimise ja katsetamise asi, ei saa kõike avastamisrõõmu ka ära võtta icon_wink.gif
rundll
rundll
sõnum 12.09.2010 11:19:17 vasta tsitaadiga
kas see asi kuidagi küünega ka toimib, näpu asemel. ei kasvata ise neid, naine tunneb huvi icon_lol.gif
Kommentaarid: 7 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 5
eents
eents
sõnum 12.09.2010 11:37:32 vasta tsitaadiga
ponas kirjutas:
Ei maksa ootama jääda, 2.2 jaoks flash tahab saada ARMv7 prose aga wildfirel on ARMv6
woo456
woo456
sõnum 12.09.2010 15:48:46 vasta tsitaadiga
rundll kirjutas:
Toimib edukalt ka küünega, sest omab resistive ekraani.
rundll
rundll
sõnum 12.09.2010 16:12:24 vasta tsitaadiga
nüüd naine räägib et ei toimi. vb ple mingit seadistust üles leidnud, mingi kalibreerimine või noh midagi taolist....
NATAS999
sõnum 12.09.2010 16:27:28 vasta tsitaadiga
seadistusega pole midagi teha ma arvan. ilmselt liiga väikse pinnaga puutub vastu ekraani. mis materjalist küüned on üldse? silikooni ja lakiga pole ehk mõtet turkida.
muidu mul capacitive ekraan ja nö. küüneseljaga näppida, siis tunneb küll ilusti ära.
"Kuidas on see hea?"
-Auto kirurgia kliinik
TREMAN
sõnum 12.09.2010 20:57:18 vasta tsitaadiga
Oleks ka huvi selle telefoni vastu. Oskate öelda kust seda kõige soodsama hinnaga osta? Esindustes on hind 3990kr, kas leidub ka odavamalt kuskil?
Kommentaarid: 47 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 45
DigeBeni
DigeBeni
sõnum 12.09.2010 21:27:22 vasta tsitaadiga
TREMAN, ma soovitaks pigem Samsung I5700 või I5800 (meie poodides 580 nime all) ...
viimati muutis DigeBeni 13.09.2010 00:21:49, muudetud 1 kord
TREMAN
sõnum 12.09.2010 22:03:17 vasta tsitaadiga
Kas mõtled S8500? I8500 ei leia.
TS2000
sõnum 12.09.2010 22:09:19 vasta tsitaadiga
TREMAN kirjutas:
shogun
sõnum 12.09.2010 23:08:58 vasta tsitaadiga
DigeBeni kirjutas:
Settings-> Wireless&Networks-> Mobile Networks -> Network Operators -> Search Networks...Suht loogiline ju icon_rolleyes.gif
Näppisin Wildfire't mõned päevad tagasi ja enda Desirega ei anna seda küll mitte ühegi nurga alt võrrelda. Ekraan on AMOLEDga võrreldes eelmine sajand ja üsna väike, jõudlust jääb väheks etc. See lisa 3,5k, mis Desire rohkem maksab, on väga väike hind võrreldes sellega, kui suur on telefonide reaalne vahe.
DigeBeni
DigeBeni
sõnum 13.09.2010 00:23:51 vasta tsitaadiga
TS2000 kirjutas:
TREMAN kirjutas:
ponas
sõnum 13.09.2010 02:23:55 vasta tsitaadiga
shogun kirjutas:
DigeBeni kirjutas:
Mu arusaamist mööda see ei välista seda, et kui koduvõrgu levi puudub, ühendub partnervõrguga ning siis võib kõne vastuvõtmine kalliks minna kui mitte operaatori muutust tähele panna. Automaatset/käsitsi võrgu valiku võimalust sel telefonil vist pole, nagu enamustel on, on vaid automaatne, parandage, kui ma eksin.
morik
sõnum 13.09.2010 07:26:41 vasta tsitaadiga
ponas kirjutas:
shogun kirjutas:
DigeBeni kirjutas:
Kui oled search networkiga võrgu valinud, on see käsitsi valik ja enam telefon muid võrke ei otsi.
Kommentaarid: 86 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 78
ämber
sõnum 13.09.2010 19:58:16 vasta tsitaadiga
Nii, et te arvate siis, et seda telefoni ei ole mõtet osta?
DigeBeni
DigeBeni
sõnum 13.09.2010 20:20:20 vasta tsitaadiga
... oleneb sellest, palju sa nutitelefoni funktsionaalsust kasutad icon_rolleyes.gif põmst' saab see telefon suurema osa asjadega kenasti hakkama, kuid nagu arvutilgi, tähendab aeglasem prose ja väiksem ekraan/reso mitmeid mööndusi rakenduste esitusel ja jõudluses. Samas paljudele meeldib väga HTC Sense UI, seega tasub minna poodi ja ikka enne otsustamist ise näppida ...
Paul
Paul
sõnum 13.09.2010 20:37:40 vasta tsitaadiga
ämber kirjutas:
muide teema alguses on spec´ides kirjas, et tegemist on amoled ekraaniga - sellest on asi ikka kaugel, parandage ära.
olles desire-st ja androidist sillas, läksime põhimõtteliselt wildfiret õrnemale poolele ostma, aga olime mõlemad suht üllatunud kui selle ekraani nägime....... no deal. see oli ikka lausa halb üllatus...
ehk siis mine katsu ja vaata seda enne ikka.
ämber
sõnum 13.09.2010 20:42:57 vasta tsitaadiga
Kuna ma ise pole ennem nutitelefoni omanud, rääkimata androidist siis hetkel valingi touchscreen telefonide vahel. Wildfire tundus siiamaani küll väga hea olevat ja sama ütles ka ajakiri DIGI. Nüüd siin päris paljud ütlevad, et telefon pole hea ja mis muu kõik siis mõte läks veits eemale, aga peab vist ikka ise poodi katsuma minema.
uus teema   vasta Hinnavaatlus »  Mobiiltelefonid/ GPS seadmed / Muu tehnika »  HTC Wildfire (S) mine lehele 1, 2, 3 ... 17, 18, 19  järgmine
