MZ
01.09.2010 20:22:01
Mängimisel arvuti jookseb kokku |
Lugu siis selline, et arvuti mängimisel jookseb kokku. Viskab ette sinise ekraani ja kõik.
Muidu netis olles v filme vaadates kõik OK. Hiljem avastasin, et kui webcam käib ja samal ajal mingit videot vaadata (youtube), siis ka jookseb kokku samamoodi.
Ning ka kui Ad-Awarega scani teen, sama lugu.
Kas võib olla tegu ülekuumenemisega? Kaardiks ATI 4850, millel passiivne Accelero S1 peal.
Viimase Catalysti olen ka tõmmanud...milles asi võiks olla ?
Temp näidud sellised:
Hardware monitor AMD Athlon 64 X2 6000+
Temperature 0 57°C (134°F) [0x6A] (Core #0)
Temperature 1 58°C (136°F) [0x6B] (Core #1)
Hardware monitor Radeon HD 4850
Temperature 0 60°C (139°F) (GPU Core)
Hardware monitor ATI Radeon HD 4800 Series
Hardware monitor Maxtor 6G160E0
Temperature 0 43°C (109°F) [0x2B] (Assembly)
Temperature 2 43°C (109°F) [0x2B] (Air Flow)
Hardware monitor SAMSUNG HD753LJ
Temperature 0 38°C (100°F) [0x26] (Assembly)
Temperature 2 33°C (91°F) [0x21] (Air Flow)
Tänud ette ära
| Kommentaarid: 11 loe/lisa |
563 |
MZ
01.09.2010 20:53:23
nüüd vaatasin, aga välja lugeda suurt midagi ei oska. Seal palju erroreid ja criticale näitab.
selgitused seal järgnevad:
Audit events have been dropped by the transport. 0
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
The computer has rebooted from a bugcheck. The bugcheck was: 0x0000007f (0x0000000d, 0x00000000, 0x00000000, 0x00000000). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 090110-27175-01.
The previous system shutdown at 21:10:44 on 1.09.2010 was unexpected.
The avast! Web Scanner service terminated unexpectedly. It has done this 1 time(s).
The avast! Mail Scanner service terminated unexpectedly. It has done this 1 time(s).
The avast! Antivirus service terminated unexpectedly. It has done this 1 time(s).
Faulting application name: AvastSvc.exe, version: 5.0.594.0, time stamp: 0x4c29073c
Faulting module name: RPCRT4.dll, version: 6.1.7600.16385, time stamp: 0x4a5bdade
Exception code: 0xc0000005
jne...mul pea kinni ei võta...
563 |
MZ
01.09.2010 21:32:28
Võtsin Avasti maha ja panin NOD 32 peale. Kui NODiga scannima panin, siis mingi 63% sama asi. Jooksis kokku. Restarti tehes oli txt ees, et U have experienced unexpected error...
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1061
Additional information about the problem:
BCCode: 7f
BCP1: 0000000D
BCP2: 00000000
BCP3: 00000000
BCP4: 00000000
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\090110-30544-01.dmp
C:\Users\Marko\AppData\Local\Temp\WER-46332-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
563 |
MZ
01.09.2010 21:54:54
| Millega, kuidas? Scandisk, defrag?
563 |
Juan Pablo
02.09.2010 09:15:52
| MZ kirjutas: |
| Millega, kuidas? Scandisk, defrag? |
Pane oma arvuti andmed profiili yles.... siis ehk oskaks paremini aidata
aga pregusel vaatlusel paistab vigane ketas olevat
29 |
MZ
Juan Pablo
04.09.2010 12:22:48
kumma ketta peal sul win on?
29 |
MZ
04.09.2010 12:23:25
| 160maxtor
Juan Pablo
04.09.2010 12:45:21
proovi sellega yle lasta
http://www.upload.ee/files/786497/SeaToolsforWindowsSetup-1202.rar.html
teine asi veel et mis toiteplokk sul on ?? äkki on see pudelikaelaks
või siis video on tolmu täis ..... proovi arvuti ära puhastada ja kui see ka ei aita siis tee teisele kettale partition ning lase win sinna peale , ja võta yks mälu pulk ära ja jäta samavärvi pesadesse et jookseks dualis mälud
29 |
MZ
04.09.2010 13:13:06
Lasen praegu. 750 GB ketta lasi ta kiirelt ja muretult. 160, seda siiani teeb. Väga aeglaselt, aga senini mingist errorist pole ka teavitanud.
Toide on 450W Chieftec.
Mõtlesin, et ehk video Artic Cooling S1-le ka ventika peale igaks juhuks...
Juan Pablo
04.09.2010 13:20:27
| MZ kirjutas: |
Mõtlesin, et ehk video Artic Cooling S1-le ka ventika peale igaks juhuks... |
Toitest peaks piisama ma arvan ikkagi et tee partition 750-ile ja lase sinna win peale kuna maxtorid ei ole kunagi hõisanud vastupidavusele
jahutust ära nuyyd lambist vahetama hakka kui ei tea täpset viga.... mõttetu raha raiskamine
29 |
