KrisVr
19.08.2010 02:12:50
FIFA 11 |
• Koduleht: FIFA11
• Arendaja: EA Canada
• Väljaandja: EA Sports
• Väljalaske kuupäev: 1 October 2010(EU)
• Demo: Tõmba siit!
NEW FEATURES (PC)
The physics-based, data-driven technology behind the EA SPORTS football engine has been optimised for PC to deliver true freedom on the pitch with individuality of player control and movement, sophisticated ball touches, and physical interaction between players. FIFA 11 PC will feature the market-leading true 360° dribbling system that gives players precise control of the ball and next-generation animation technology that delivers Skilled Dribbling, enabling skilled dribblers to face defenders and use highly responsive lateral dribbling to skip past them. Plus, Physical Play has been improved using collision sharing, creating a varied, less predictable, and extended fight for possession between players.
•Next Gen Gameplay Engine: The game engine that is used for the PlayStation 3 and Xbox 360 versions of the game will now be used on the PC as well as improved graphics from FIFA 10.
•FIFA World: This will allow the player to customize their online avatar, compete with players from all over the world and fight for positions on the leaderboard.
•Custom Soundtracks: For the first time in the series the player will be able to create their own personalised soundtrack by importing their favourite music into the game. Customised chants can also be imported and a club's anthems and chants can be set to play during introductions, halftime, after goals, or at the end of matches. The player's virtual pro's name can be chanted in the stadium.
•Goalkeeper Intelligence: Goalkeepers now have more urgency and better perception of where to intercept loose balls, resulting in a more responsive and powerful rushing system. Goalkeepers are now more agile and can make more impressive saves. New animation warping technology provides game-realistic goalkeeper positioning and momentum, resulting in more varied scoring opportunities.
•Manual Leaderboard: It has been confirmed that there will be a separate leaderboard this year for players that use the manual control setup.
FIFA 11 TRAILER
viimati muutis KrisVr 15.09.2010 20:43:44, muudetud 2 korda |
| Kommentaarid: 30 loe/lisa |
K3ndu
19.08.2010 08:31:40
Ei tea tuleb sama saast jälle arvutil mis eelnevatel aastatel?
Elame näeme kuna suht jama arvutil ainuke normal mäng Pes2010, võiks nagu vaheldust olla.
119 |
Kristo69
19.08.2010 08:36:44
| new featuresi järgi tundub, et kolin PESilt FIFA peale tagasi. Samas ei saa enne kindel olla kui mäng väljas on.
| Kommentaarid: 22 loe/lisa |
22 |
madness
19.08.2010 08:44:48
| K3ndu kirjutas: |
Elame näeme kuna suht jama arvutil ainuke normal mäng Pes2010, võiks nagu vaheldust olla. |
FIFA 11 PC on põmst sama, mis FIFA 10 konsoolidel + mõned uuendused.
Mitte päris sama mis konsooli FIFA 11 aga oluliselt parem kui eelmine PC FIFA.
| Kommentaarid: 13 loe/lisa |
K3ndu
19.08.2010 08:49:51
| Tõsised geeniused ikka ma ei saa aru kuidas saab konsoolil olla eelis arvuti ees kuna mäng meisterdatakse ju arvuti peal valmis mitte konsooli peal ,et see peaks konsoolil parem olema ja ennem reliisi saama, see kõik on väga veider.
119 |
IvarV
19.08.2010 10:28:49
Tõenäoliselt tuleb PC-le see sama bs mis ikka, vbla parema pildiga.
Ja ei tule kindlasti sama mis fifa 10 konsoolil oli. PC mängudest on nad kogu aeg välja jätnud selle freestyle arena, kõksimise, 90% trikkidest ja kõik need personality+ sarnased asjad.
Olen üsna kindel, et seda be a goalkeeper asja PC versioonis ei ole.
madness
19.08.2010 10:59:43
Q: Last year the PC producer (Luke Didd) showed himself a bit in the official forum. Will you ever come in the official forums talking with the community?
IJ: Yes, I’ll be on the forums. To this point I’ve not been able to given that the game was not announced publically. That said, I’ve obviously spent a lot of time on the forums reading what people said about FIFA 10 on PC (even saw an online petition to bring next gen to PC) so I’m looking forward to contributing to the forums going forward.
Q: What is the main reason why the FIFA 11 PC game will be a FIFA 10 NG porting (+ World Cup improvements) and not directly a FIFA 11 NG porting?
IJ: This is a good question and one that I got asked at pretty much every tour stop. Basically it boils down to the amount of effort required to bring the next gen engine onto PC and the fact that FIFA 11 on console is still in development so it’s very much a moving target. A lot of people seem to think that bringing next gen to PC should be a pretty simple ‘cut and paste’ of the code and BOOM, all done! Not so much. Given the huge effort to achieve this and as mentioned, the fact that the console guys are creating new features that are currently not finished, it was a bit of a moving target to take ALL of the FIFA 11 features. That said, there are some announcements coming out at Gamescom that I think will put to rest a lot of the comparisons as there are a number of features that we can then talk about that will be very much aligned with the console offering. Stay tuned.
Q: Is it true that there will be no 10vs10 in FIFA 11 PC? What's the problem with it? And if there is no 10vs10, how can be used the Virtual Pro player online?
IJ: I can’t really speak about the online offerings at this point. It’s something that we’re announcing later on. One thing to keep in mind though is that based on what you’ve written you sound like you are both an avid PC gamer AND console gamer. I think that the vast majority of our target gamers are hardcore PC gamers and may not necessarily play on console. For these people, they will have a HUGELY improved experience from FIFA 10 PC and can rest assured that we have (hopefully!) done a great job at bringing PC into the next gen realm. I also think that the PC is always going to be a slightly unique experience from the console given its nature. There are going to be features on PC that aren’t even on console. Some of the callouts from the tour that people loved were LAN play, amazingly quick load times, super fast scrolling, the ability to customize the experience resolution wise, and supporting 35 different game pads. And like I said, there’s more news to come.
Q: Will there be the World Cup penalty system in FIFA 11 PC?
IJ: No. We have taken certain gameplay aspects from WC but not the penalty kick system. We could have but chose to focus efforts elsewhere. Did you like the WC implementation? Would be curious to hear your thoughts.
Q: Will there be the possibility to save replays on the HD too or only to send them to easports football world?
IJ: Good question. We’re only doing the EASPORTSfootball upload. Something to think about for next year though.
Q: Is Manager Mode on FIFA 11 PC going to be the same of FIFA 10 NG but with bug fixed? I would like to know especially if you fixed the several bugs in tournament structures (Coca-Cola Championship winner being qualified into Europa League) and the bug of international and important matches being played in day-time instead that in night-time!!! And also the several bugs of transfer market (players with no name, no reasons for transfers being denied and so on).
IJ: Again, something I can’t talk about at this point. We’ll be talking more about game modes at Gamescom. That said, I am very much aware of all the issues you’ve mentioned.
Q: I have tried FIFA 11 NG and I have been very pleased by the new intro cinematics, the new way of doing celebrations and the fact that there will be proper cup celebrations. Please tell me that you are not porting FIFA 10 NG cinematics, but you are inserting FIFA 11 NG ones instead!!!! Please
IJ: We will be using FIFA 11 console cinematics (which obviously will have certain elements from FIFA 10 console in there as well). Again, most of the people who buy this game will likely not all be console gamers as we are targeting the hardcore PC user. I think that if you look at someone who played FIFA 10 on PC and then show them FIFA 11 on PC, they will be very impressed with the improvement.
Q: Is the commentary going to be the next-gen one too or always the same of the previous PC versions?
IJ: Next gen commentary. (uuu..nextgen kommentaatorid! )
Q: Some people are moaning because in FIFA 11 PC new screenshots there are some non-coherent wrinkles from shoulders to sleeves and some think that we are not going to get moving clothes and hair in FIFA 11 PC, but only static wrinkles and so on... Can you say something for this and for this copy-paste glitch (as they call it)?
IJ: I’m not sure where this screenshot came from but since it has the EA watermark it looks like it came from an EA source. That said, how did you feel about the cloth and hair movement in FIFA 10 NG? Because we’ll have that.
Q: You released the recommended hardware specs, what about the minimum ones?
IJ: Min specs (not final):
1. Minimum System Requirements
CPU with Dual core processor (Core duo 2 or better)
Intel Core2Duo @ 1.8Ghz on Windows XP / Windows Vista / Windows 7
1 Gigabyte of RAM (2 GB required for Windows Vista / Windows 7)
DirectX® 9.0c Compatible 3D accelerated 256 MB video card or equivalent
(must support Shader Model 3.0 or above)
DirectX® 9.0c Compatible Sound Card
512Kbps or greater broadband connection for online gameplay
MS compatible mouse
Keyboard
Please note that 16 bit colour is not supported
Install size varies by region (languages in brackets):
North America DD (Eng, Fr, Mx, Br) : about 6.5 GB
And additional space required for saved games and DirectX® 9.0c installation
Required Operating Systems:
Windows XP SP2, Windows Vista, Windows 7
Note that Windows 95, Windows 98, Windows 2000, Windows ME, and Windows NT 4.0 are not supported.
Required Software:
DirectX® 9.0c
Q: Are you aware of the huge communities that edit the PC game and make mods for it? Did you take into consideration their presence when you ported the engine so that they could continue editing the game quite easily? Or do you plan to realize some kind of basic tool to help us with the new game files like it was when you released eagraph editor some ages ago?
IJ: Yep, definitely aware of these folks! For FIFA 11 PC we did not do anything to intentionally block or prevent people from modding. Go for it. That said, there is not a single line of code from FIFA 10 PC and our data structures are different, so the modder will have to become familiar with these before they can edit content. In talking with some technical guys on the team here, the thought is that it may take the community some time to be able to figure this out depending on their skills and desire. We’ve been busy trying to get the game finished and have not had time to work on any editing tool to help these folks and I personally haven’t been involved with this side of things. You’ll have to stay tuned on that.
Q: I would like not to ask you this, but I will for the good of some users: will there be high/normal and low socks on FIFA 11 PC too like in FIFA 11 NG? You know, they find a bit funny that a feature there was in FIFA 10 PC it is not going to be in FIFA 11 PC I sincerely not make a big deal about it at all !!!
IJ: We’ll have answers related to specific visual stuff in a little bit so I can’t speak to this at the moment. This will turn out to be pretty minor compared to a bigger announcement we have for PC!
ME: Thanks for answering and a huge THANKS to you and your team for bringing NEXT-GEN ON PC!!!
IJ: You’re welcome. Hope you like it!
A small note: the answer to cinematics question was very different until yesterday night. Indeed I managed to convince Ian Jarvis to port FIFA 11 NG cinematics instead of awful FIFA 10 NG cinematics |
mingi itaalia veebilehe intervjuu Ian Jarvisega...
KrisVr
19.08.2010 13:21:31
| IvarV kirjutas: |
Olen üsna kindel, et seda be a goalkeeper asja PC versioonis ei ole. |
See ainult konsoolidel jah.
IvarV
19.08.2010 17:41:19
Samas kui nad kasutavad konsoolide graafikamootorit, siis olen rahul enam-vähem, mäng näeb ilus välja siis.
Võiks see 360-degree movement ka tulla.
Ja nad võiksid ära kaotada oma nõmedad EA putsad, tahaks ikka mingi CTR 360-dega mängida, või siis Laser 3-dega. Be a Pro-s ei saanud ju vahetada putsasid.
Lisaks jään ootama ka seda aega, mil nad teevad arvutile sama konrolleri süsteemi, et üks analoog on trikkide jaoks.
madness
IvarV
20.08.2010 15:31:14
Gameplay intervjuu Ian Jarvisega.
Selle järgi ei toetata see aasta hiirega mängimist.
Aga mäng tõotab tulla kõvasti parem kui Fifa 10 PC-l oli (on).
sykrot
15.09.2010 18:32:01
| Kohe demot proovima.. Loodan, et on parem kui pes 2011 .
Kristo69
22 |
KrisVr
15.09.2010 20:42:00
Nonii, täna saab kohe Fifa11 ja PES2011 demo proovida.
RedFusion
15.09.2010 20:53:20
| IvarV kirjutas: |
Selle järgi ei toetata see aasta hiirega mängimist. |
Kui see nii on, siis on küll jama, sest 2 eelmises FIFA-s kasutasin alati mängimisel hiirt ja minumeelest nii palju parem, mugavam mängida.
Küsimus laiale ringile: kuidas Te ise ka eelmiseid FIFA-sid PC peal mänginud olete? Hiirega / ilma hiireta?
| Kommentaarid: 8 loe/lisa |
Makux
15.09.2010 21:14:18
Polegi mänginud juba mitu-mitu aastat Fifasi, sest need kõik kuidagi "aegunud". Graafikat jms parandati, aga gameplay oli dumbed down. Nüüd on lootust mängida vähe korralikumat versiooni.
zpsy
15.09.2010 23:24:57
Kuidas kellele demo meeldis?
Ise panin tõmbama ning homme proovin ära.
| Kommentaarid: 825 loe/lisa |
587 |
KrisVr
15.09.2010 23:37:01
| zpsy, Just tõmbasin peale ja lähen proovin! Loodan igastahes parimat, sest 2010 oli total cräp IMO. Õnneks kui 11 pole midagi erilist, siis PES2011 küll meeldis demo põhjal.
vonets
16.09.2010 11:17:15
| Krt see demo on ikka suht saast minuarust...
| Kommentaarid: 63 loe/lisa |
61 |
KrisVr
16.09.2010 11:33:25
| vonets, Minu meelest ka! Ei saa nagu selist pilti msi vaja, sest enamus asju pole demos sees.
hendrik32
16.09.2010 16:26:42
Mäng ise on hea, demo jääb demo jaoks lahjaks, liiga nuditud.
Aga gameplay ja physixi eest
| Kommentaarid: 16 loe/lisa |
12 |
T1m
16.09.2010 17:07:43
üle pika aja korralik fifa. kõvasti parem kui 10, nagu konsoolidel ikka varsti proovib pes2011 ka ära, siis saab võrrelda.
| Kommentaarid: 44 loe/lisa |
44 |
destiny12
16.09.2010 17:10:55
T1m, Arvuti peal mängisid? See siin arvutimängude teema.
_________________ "Ära mine sinna, kuhu rada viib. Mine selle asemel sinna, kus rada ei ole, ja saa teerajajaks." |
| Kommentaarid: 83 loe/lisa |
77 |
Eliit
16.09.2010 18:27:25
On selgelt näha, et porditud FIFA 10 konsooli versioonist.
Nuppe saab konfigureerida vaid mänguvälisest menüüst, kui muidugi gamepadiga ei mängi. Näha ka mängijate modelitest, mida pole viitsitud uuendada (nt. Higuainil endiselt pikad juuksed).
Aga mis ma siin ikka nurisen, võrreldes viimaste aastate FIFAdega on mäng kõvasti parem. Saavad ka PC inimesed korraliku jalka mängu .
PES ei lähe kohe üldse peale .
destiny12
16.09.2010 18:37:53
Sellest järeldan, et asi on PC peal mängitavaks tehtud?
77 |
