uus teema   vasta Raud »  Kast / Toide / Casemod »  Korpuste teema märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 19, 20, 21 ... 100, 101, 102  järgmine
Heineken
sõnum 06.08.2010 16:31:48 vasta tsitaadiga
tomorrow kirjutas:
Teras on odavam ja tugevam aga ka raskem lõigata ja välimuselt inetum kui Alu.Lisaks ei juhi soojust kaugeltki nii hästi kui Alu.Aga see on minu arvamus.Igaühele oma.
Selle jaoks on ventilaatorid.
Ja kui värvitud, siis mis see välimus siia puutub?
sõnum 06.08.2010 16:36:24 vasta tsitaadiga
Heineken kirjutas:
tomorrow kirjutas:
Loogish, et kogu jahutust selle peale üles ei ehita aga pluss ikka.
Heineken
sõnum 06.08.2010 16:58:41 vasta tsitaadiga
KrisVr
sõnum 12.08.2010 00:34:45 vasta tsitaadiga
Fractal Design Announces Define R3 Line of PC Cases
TechPowerUP
    Fractal Design Announced the Define R3 - the successor to the best selling Define R2. Now available with a bunch of improvements, including improved cable routing, air flow and bigger hole in M/B plate for mounting CPU coolers. The Define R3 case is reaching new heights in combining stylish, contemporary design with maximum functionality and noise absorbing features. The minimalistic, yet stunning front panel design, fitted with noise absorbing material on the inside, creates an aura of exclusivity.
    The patent pending feature ModuVent, in which you can choose whether to have side and top panels open or not, makes the case appealing for users seeking optimal silence, as well as the performance hungry ones. The sleek black interior is matched with pre-fitted, dense noise absorbing material on the side panels, efficiently absorbing noise and vibrations. You can fit an astonishing total of eight hard drives into this case, using the user friendly HDD-trays. All painted in a nice white color and using black silicone mounts. PSU is mounted in the bottom of the case, with a convenient pull-out filter beneath it.
    Are you one of those users always ending up with a case full of tangled cables? No more. The Define R3 offers a convenient and good looking way of hiding them away. The motherboard has rubber covered holes in which you can easily route the cables behind the motherboard.
Improvements from R2:
Key features:
Specifications :
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 27
Heineken
sõnum 12.08.2010 01:59:51 vasta tsitaadiga
Kena disain ja üsna pädev jahutus. Jahutus võiks muidugi parem olla aga see puhtalt minu arvamus(ma Antec 1200 poolt ära hellitatud icon_redface.gif ).
KrisVr
sõnum 19.08.2010 15:28:09 vasta tsitaadiga
Lian Li Launches PC-C50 HTPC Chassis
TechPowerUP
Lian Li Industrial Co. Ltd. launches its PC-C50 multimedia HTPC chassis - a combination of modern functionality and hair-line brushed anodized aluminum finishing outlook perfectly for the home theatre décor and friendly for the end-users. The PC-C50 stands at 445x167x325mm (W. H.D) and weighs only in 3.20kgs. Available in black and silver colors, the PC-C50 case supports Micro ATX/Mini DTX/Mini ITX motherboards. The chassis is designed with unique modular CD-ROM cage and HDD cages that can be arranged by users' needs. Making it most convenient, the PC-C50 offers three USB3.0, HD audio and e-SATA I/O ports, as well as a MS/SD card reader slot, right at the front of the chassis for easy access.
The ideal cooling the Lian Li's PC-C50 has incorporated two 120mm exh aust fans on the side, PCI brackets with vent holes for extra cooling, as well as the power supply unit at the bottom to draw in cold air directly. Two 120mm and 80mm-size fan holes on the top and at the rear, respectively, are also available for additional fans. The Lian Li PC-C50 HTPC chassis has one 5.25" external drive bay, the modular drive cages support three 3.5" HDDs and three 2.5" HDDs. There are four expansion slots available.
Like all Lian Li products, the PC-C50 HTPC chassis has the finely honed finish to prevent sharp edges. The internals are modular, so components can be pre-fitted and then installed in stages, allowing an organized and structural design for your DIY HTPC home theatre system. Tool-less thumb screws keep the case top panel attached, while a structural support bar adds strength to the case design. Everything is designed to comply with Intel Standards for maximum compatibility. The essence of Lian Li products is the craftsmanship of the engineering. Intrinsic to the workmanship and quality is the customization which includes a whole host of optional extras that can be purchased to add more features to an already feature rich product.
    AeroCool Intros Strike-X Gaming Mid-Tower Case
    TechPowerUP
    AeroCool introduced the Strike-X gaming PC chassis. This ATX mid-tower sports a space-age design with distinct x-shaped grills panels and structures. It is built for rough and touch use for the LAN party-animals, and comes in total-black, or with a dash of red. Drive bays included are 9 5.25" (with internal 3.5" cages detachable). The ventilation system includes 120 mm fans on the side and rear, and one 140 mm fan on top. The chassis is mostly tool-free, as far as installing drives and addon cards goes. The rear panel holds two handles that make opening the side panels easy, and holes for water-cooling tubing. The front-panel includes audio and USB ports. AeroCool's new case is expected to be priced at 60 EUR.
Lian Li Launches PC-Q11 Chassis Under the Mini-Q Series
TechPowerUP
Lian Li Industrial Co. Ltd. today announces the PC-Q11 under its Mini-Q Series. Compact and light, the PC-Q11 is designed for users who require space and convenience for mini systems. The new Mini-Q series is now available in four different colors, including black, silver, red and the eye-catching piano white - definitely one of the Lian Li models that power users shall not miss.
Dimensioned at 200x326x260mm(W.H.D.) and weights only in 2.42kg, the new Mini-Q PC-Q11 series supports Mini-ITX/Mini-DTX motherboards. For an ultimate convenience sake, users can easily remove the HDD cage, undo the thumb screw, as well as upgrading all the standard parts including one 5.25" optical drive, two 3.5"/2.5" hard drives and ATX P S/2 power supply units. Lian Li once again leads the industry by offering the maximum quality and user-friendly design on its mini tower series - PC-Q11.
The PC-Q11 is made of 1.5mm aluminum alloy panel - thick and solid enough offering no vibration problem. The side panel secured with screws also reduces vibration and lowers the noise level. Last but not least, the PC-Q11 case stands are padded with rubbers to absorb vibration.
For an ideal thermal solution, the Mini-Q PC-Q11 incorporates one 140mm intake fan at the front to output high air flow volume with lower RPM to push the cold air through the HDD rack. There are vent holes at the top and on the side panels, allowing air to enter and cool the system down. Additional vent holes for CPU cooling are located next the slot for the rear motherboard panel connectors. Users can place can easily install a standard ATX PS/2 power supply with 120mm cooling fan facing the motherboard for more passive coolin g. What is more, there are vents holes on the PCI brackets, providing even extra cooling to the VGA cards.
1dumbpcuser
sõnum 24.08.2010 09:41:14 vasta tsitaadiga
Part 1: Four Gaming Enclosures Under $50
TomsHW
Vasakult paremale:
* Antec Three Hundred
* Enermax Staray ECA3171 / ECA3170
* Cooler Master Elite 430
* AeroCool VS-9
Antec Wins?
Antec’s Three Hundred leads our cooling, noise, and efficiency charts, but it’s an unfortunate fact that today it cannot be found at our intended $50 price point (it's now $10 higher than that on Newegg). Yes, it was cheaper a few weeks ago when Antec shipped it. But users who want superior quality should be willing to pay the extra $10 to get a unit that’s 33% thicker, more durable, better at cooling, and quieter than its competition.
Next up is the Enermax ECA3171-BR-AP, with three cooling fans sporting red LEDs and an unbelievably low $50 price tag. An obvious pick for the best case at or below this predetermined price point, our only concern is that its price will go up before anyone can click the “buy” button. For now, the chassis remains priced at $49.
Cooler Master’s Elite 430 takes third place overall, and we’re happy to see that it looks at least as good as it performs. Cheaper at the beginning of the month, it jumped up to $55, and is now back to $49 online--right where we were hoping it'd land. It only has one fan, but does well considering that fact.
The only real loser of the cases we're looking at today is AeroCool's VS-9. The thing started falling apart as we were assembling the system, it did little to nothing to muffle the noise of internal components, and it twisted so easily that we had to weigh it down with a power supply just to keep it sitting flat. We’ve not seen a case this weak since the Hades earned our ire a few months ago. But at least the VS-9 has a comparatively low-cost. We’ve even read user reviews that tell others how to beef the VS-9 up to the standards of other $50 cases but—armed with this foreknowledge—we’d just as likely chose a better starting point.
Of course, it's too early to declare one overall winner of our case comparison. We have four more models to add to our data here in Part 2. Look for that follow-up soon!
M: MSI B660M MORTAR
M: Dell RTX 2060
O: AM5 ITX emaplaat
mirko27
mirko27
sõnum 24.08.2010 21:10:11 vasta tsitaadiga
Mis hetkel 1k ümber või alla siis head saada on? Müra ja jahutus peamisteks muredeks.
destiny12
destiny12
sõnum 24.08.2010 21:11:26 vasta tsitaadiga
Mis seal muud.
"Ära mine sinna, kuhu rada viib. Mine selle asemel sinna, kus rada ei ole, ja saa teerajajaks."
Kommentaarid: 83 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 77
mirko27
mirko27
sõnum 24.08.2010 21:15:38 vasta tsitaadiga
See on jube kast, pole sahtleidki kõvaketastele.
KrisVr
sõnum 24.08.2010 21:25:29 vasta tsitaadiga
mirko27
mirko27
sõnum 24.08.2010 21:30:06 vasta tsitaadiga
No vaata ülevaadet, tühi auk kõikide seadmete jaoks ja siis külgedele kruvidega kinnitad.
K3ndu
K3ndu
sõnum 25.08.2010 09:48:35 vasta tsitaadiga
Võta Coolermaster Gladiator 600
Kommentaarid: 131 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 121
wezz
wezz
sõnum 25.08.2010 17:07:46 vasta tsitaadiga
Gladiator 600 ei ole näe väga kena välja imo.
Soovitage korralikku case't AK'st, max hind 1500.-
Praegu olen vaadanud http://ak.ee/index.php?pid=23&id=189&menyy_id=23&action=look&lookid=93658
Võiks olla rohkem kui 2 USB porti.
Kommentaarid: 16 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 14
omgwtf
omgwtf
sõnum 25.08.2010 17:12:55 vasta tsitaadiga
http://ak.ee/index.php?pid=0&id=23&menyy_id=23&action=look&lookid=87398
Juan Pablo
sõnum 25.08.2010 18:22:56 vasta tsitaadiga
kakkusin ka oma kasti laiali ning laotasin laiali.... ning installin eri ketastele winne icon_biggrin.gif
viimati muutis Juan Pablo 25.08.2010 18:24:22, muudetud 1 kord
Kommentaarid: 33 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 29
Smoking
Smoking
sõnum 25.08.2010 18:23:46 vasta tsitaadiga
Btw, pilt väike, ei avane suurena.
Kommentaarid: 360 loe/lisa Kasutajad arvavad:  :: 2 :: 1 :: 298
Juan Pablo
sõnum 25.08.2010 18:25:39 vasta tsitaadiga
Smoking kirjutas:
nüüd peaks...
Murdock
sõnum 25.08.2010 18:33:16 vasta tsitaadiga
Endal modikompist see. Maksis küll koledalt, aga väga rahul. Mõnusalt suur, pääseb sees korralikult majandama.
AJ
AJ
sõnum 26.08.2010 00:40:03 vasta tsitaadiga
wezz kirjutas:
Mina võtaks selle
Cooler Master 690
Kristoferr
Kristoferr
sõnum 26.08.2010 10:52:13 vasta tsitaadiga
Murdock kirjutas:
Andeks, aga see armor on üks kõige mõttetum kast üleüldse. Eriti veel sellise raha eest. Olematu jahutus, vaatamata paljudele ventidele ja ainuke koht kus see kast hea välja näeb on prügimäel. icon_neutral.gif
Liitu Opencode Go soodsa coding plaaniga ja saa 5€ soodust!
Liitu Wise'ga!
Kommentaarid: 268 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 219
Player1
Player1
sõnum 26.08.2010 16:46:57 vasta tsitaadiga
AJ kirjutas:
wezz kirjutas:
Mina võtaks selle
Cooler Master 690
Pigem võibolla Cooler Master II Advanced, erilist hinnavahet ei tohiks olla.
Kommentaarid: 40 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 38
Murdock
sõnum 26.08.2010 17:50:32 vasta tsitaadiga
Nujahh Kristoferr, eks ilu ole vaataja silmades, aga faktid on need mida mõõta saab. Milles seisneb olematu jahutus? Oleks tore, kui mõni test ette näidata. Mitte just odav, jah. Aga ma tahtsin kõige suuremat kasti, normaalse jahutusega ja selle ka sain. Vahelduseks annan paar linki, eriti põhjalik on teine link. http://www.xtremesystems.org/forums/showthread.php?t=197267 http://www.hitechlegion.com/reviews/cases/697-thermaltake-armor-plus-full-tower-case-review Ja mis puutub veel välimusse, siis näiteks minu meelest on enamik kinniseid musta värvi a'la Coolermaster kaste täiesti mõttetu välimusega, mis ei näe isegi prügimäel head välja. http://ak.ee/index.php?pid=23&id=189&menyy_id=23&action=look&lookid=88708
sõnum 26.08.2010 18:39:56 vasta tsitaadiga
Murdock kirjutas:
Samast hinnaklassist mis sinu kast: http://www.modikomp.ee/korpused/RC-1000-KSN1-GP/#RC-1000-KSN1-GP
Flavius
sõnum 26.08.2010 18:46:00 vasta tsitaadiga
Raven 2 mu meelest kõige huvitavam nendest suurtest korpustest. Hind pole ka ülikõrge.
http://www.modikomp.ee/korpused/SST-RV02B-W/
Kommentaarid: 126 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 118
omgwtf
omgwtf
sõnum 26.08.2010 18:48:29 vasta tsitaadiga
Ja jahutab ka vast paremini enamustest. See cosmos just ei hiilga jahutus omadustega icon_rolleyes.gif
sõnum 26.08.2010 18:50:03 vasta tsitaadiga
Flavius kirjutas:
Jep lihtsalt see reversed setup vajab harjumist.Tavaliselt ikka vasakult küljelt teed lahti.
Kuigi ma saan ka oma Stackeril teha reversed setupi.Kunagi mul oli see aga ma ei näinud temperatuurieelist.
metallika
metallika
sõnum 26.08.2010 18:55:30 vasta tsitaadiga
Flavius,
Raven II on tõesti hea kast - piisavalt ruumikas ning õhk liigub hästi! icon_cool.gif
Kommentaarid: 388 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 313
mirko27
mirko27
sõnum 26.08.2010 19:38:27 vasta tsitaadiga
Kumb võiks parem kast olla, kas CM 690 II või TT tsunami dream.
KrisVr
sõnum 26.08.2010 19:39:32 vasta tsitaadiga
mirko27
mirko27
sõnum 26.08.2010 19:40:41 vasta tsitaadiga
Noh ilu on maitse küsimus, küsimus rohkem kasutusmugavuses ning jahutusomadustes.
sõnum 26.08.2010 20:13:39 vasta tsitaadiga
mirko27 kirjutas:
Tsunami Dream olen omanud.Selle probleem on nõrk plekk.Kipub värisema ja kõrisema kui miski ideaalselt pole paigas - aken eriti.Suht väike kah teine.Jahutusele tohutult midagi ette ei heidaks kuigi nt üleval pole ventikat ja selle asemel on seal äärmiselt veidras kohas USB jms pordid icon_rolleyes.gif
Eemaldatav HDD tray on pluss.PCI kinnitusklõpsud pole just parimad.
Välimus on kah suur näpujäljekoguja.
FD
FD
sõnum 26.08.2010 22:45:11 vasta tsitaadiga
metallika kirjutas:
Flavius,
minu poolt ka +1, kena välimus ja just õhu poolest parem (eriti graafikakaartide näöl, kuum õhk liigub kohe vahelt välja ülesse)
metallika
metallika
sõnum 26.08.2010 22:48:28 vasta tsitaadiga
otty
sõnum 27.08.2010 01:43:12 vasta tsitaadiga
AJ
AJ
sõnum 31.08.2010 10:14:41 vasta tsitaadiga
Murdock kirjutas:
Maitse asi. Minu meelest on enamus kirjuid ja säravaid kaste lihtsalt rõvedad. icon_lol.gif
Auron
Auron
sõnum 31.08.2010 12:19:58 vasta tsitaadiga
AJ kirjutas:
Murdock kirjutas:
Sekundeerin. Soliidsus ja efektiivsusu on see mis on oluline. See aeg kus pidi olema sada akent ja ustmiljonm ledventi on läbi - täpselt nigu on läbi atuode teibituuningu aeg kus ledid pidi olema käigukangil, istmeall ja sumpsis.
omgwtf
omgwtf
sõnum 31.08.2010 12:37:22 vasta tsitaadiga
No kuskil kolkas veel sõidavad igast sierrad tuunitult ringi,ehk sinna liiguvad ka need üksikud pedemajakast kastid icon_lol.gif
sõnum 31.08.2010 15:56:23 vasta tsitaadiga
ma arvan, et seda ei saa nii üheselt võtta. ka mulle ei meeldi värvilised, tuledes säravad ja muidu popid ja noortepärased kastid aga ilmselgelt on selliste huvilisi ja olenevalt sihtotstarbest ja kasutuskeskkonna interjöörist võivad need olla täiesti lahedad.
soliidsus on osalt ka maitse asi ja efektiivsuse sõltuvus välimusest praktiliselt puudub.
- londiste
Juan Pablo
sõnum 31.08.2010 21:57:44 vasta tsitaadiga
FD kirjutas:
metallika kirjutas:
Flavius,
mulle meeldib raven2 kuna ise oman seda ja olen rahule jäänud
mullemeeldib et kasti põhjas on 3x16cm ventikat mis tirivad yles arvutisysteemi jahedat õhku ning yleval yks mis veab välja
Heineken
sõnum 01.09.2010 00:52:52 vasta tsitaadiga
KrisVr
sõnum 02.09.2010 15:15:45 vasta tsitaadiga
Sharkoon Announces Bandit ATX Case with Integrated Hard Drive Docking Station
TechPowerUP
Sharkoon expands on their PC-housings portfolio: The ATX Case Sharkoon Bandit brings together comfortable installation options, an elaborate airflow concept, integrated card reader and as a special feature, a practical docking station for 2.5 and 3.5 inch SATA hard drives.
Thus, Sharkoon has integrated for the first time their highly-demanded external QuickPort docking station into a housing. SATA hard drives of both sizes can be easily plugged into the PC without any complicated assembly. Another distinctive feature on the top of the housing is the blue illuminating 180mm LED fan, which blows warm air out of the housing. Also, easily accessible on the housing surface are Power and Reset switches, audio connections, a power and hard drive LED, an eSATA and two USB ports. A card reader is installed in the highest front panel which supports SD, SDHC, MS, as well as CF I formats and contains an additional USB port.
The Sharkoon Bandit is constructed out of sturdy SECC-steel with a black finish on both the inside and outside. Behind the plastic front faceplates, which are constructed in a mesh design for optimum air intake, the housing offers space for five optical drives and three hard drives. The latter sits nicely cooled due to the preinstalled 120mm LED front fan situated in a removable hard drive cage. The optical drives can be installed tool-free by their practical quick-locking mechanisms, the CPU with the handy fitting aperture allows construction without the cumbersome task of dismounting the motherboard and the hidden cable management system routed between the motherboard bracket and the side panels ensures an uninhibited air circulation throughout the housing.
For those whom the two preinstalled fans on the top and front are not enough will find additional installation options for two 140mm or 120mm fans on the side panel and a 120mm or 80mm fan on the backside. The housing measures 200mm x 485mm x 485mm (W x H x L), the empty weight averages 6.6 kg. Sharkoon provides in shipping extensive installation accessories including three mounting frames for internal 3.5 inch drives.
End customers will find the Sharkoon Bandit available immediately for the recommended retail price of 69.90 euros in authorized retailers.
radok
sõnum 03.09.2010 17:06:21 vasta tsitaadiga
Täitsa kena kast, aga see suur vent seal üleval on minu silmis kole.
Maitse asi.
K3ndu
K3ndu
sõnum 03.09.2010 19:55:40 vasta tsitaadiga
radok kirjutas:
Maitse asi.
Kole koledaks ,aga samas see langetab kenasti temperatuure seal üleval.
Juan Pablo
sõnum 03.09.2010 20:04:30 vasta tsitaadiga
Heineken kirjutas:
välja vedamiseks pole vaja kui yhte 120mpist kuna põhiline on sisse tõmme ja välja on niigi korralik ava............
Heineken
sõnum 04.09.2010 16:45:57 vasta tsitaadiga
Kuhugi peab soe õhk minema ka ju ja mida kiiremini see välja saab seda parem. icon_rolleyes.gif
AJ
AJ
sõnum 05.09.2010 00:05:48 vasta tsitaadiga
Fractal Design Define XL grows to fulltower
http://www.nordichardware.com/news/67-cases/41011-fractal-design-define-xl-grows-to-fulltower.html
Valmistaja leht
KrisVr
sõnum 06.09.2010 14:29:40 vasta tsitaadiga
Cooler Master Intros HAF-912 ATX Mid-Tower Case
TechPowerUP
Cooler Master introduced its latest case in the high-airflow (HAF) series, the value-segment HAF-912. This case lives up to its series name of being extremely airy, with a completely perforated front, a large fan on the top, apart from fans-slots on the side and rear, apart from a number of builder-friendly features. This ATX mid-tower 230 x 480 x 496 mm, weighs 8 kg, and is made up of SECC and plastic. Front drive bays include four 5.25" of which one is 3.5" convertible. The front-panel is located entirely on the front, and not the top.
There are six internal drive bays, which are split between two sets of 4 bays and 2 bays, each. The bays can be detached for cleaning, or to accommodate extremely long graphics cards. The bottom set can accommodate 2.5" drives. There are 7+1 expansion slots (8th one being vertical, for expansion brackets, etc.). Ventilation includes two front 120 mm fans, one rear 120 mm fans, while there's room for either two 120 mm fans (or a 2x 120 mm radiator), or one 200 mm fan on the top, one 120 mm fan on the side panel. The motherboard tray has a hole around the CPU slot area which makes it easy to deal with CPU coolers with backplates, there are three water-cooling holes, the third smaller hole could be for wiring to fans or pumps located outside. Cooler Master is asking US $60 for this case.
AJ
AJ
sõnum 06.09.2010 22:05:00 vasta tsitaadiga
Ülevaade ka
Cooler Master HAF 912 Plus Review
http://www.vortez.co.uk/contentteller/articles_pages/cooler_master_haf_912_plus_review,1.html
kalluka
sõnum 08.09.2010 21:39:19 vasta tsitaadiga
AJ kirjutas:
Valmistaja leht
Kust saada?Eestis ei müüda ja pixmanias kah mitte.Välismaalt tellides shipping kirves.
Kommentaarid: 16 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 12
uus teema   vasta Raud »  Kast / Toide / Casemod »  Korpuste teema mine lehele eelmine  1, 2, 3 ... 19, 20, 21 ... 100, 101, 102  järgmine
