Celos
19.07.2010 14:12:26
| wazaabi kirjutas: |
| Gothic 4 kohta niipalju, et välja tuleb 12. oktoobril nii euroopas kui USAs. Ja nendele, kes arvavad, et mäng jänkide ja konsoolide tarvis liiga lihtsaks tehakse, siis niipalju, et kõike seda jama (minimap, questmarkers jms) saab optionsist maha võtta. Ise loodan parimat. |
Probleem on enamasti pigem selles, et igasugu questmarkerite jms kasutamine teeb devid laisaks. Selle asemel, et korralikke juhiseid anda, käsitakse vaid questmarkerit järgida. Seega nende kinni keeramine teeb mängu idiootselt raskeks. Loodan samuti, et G4-jas tehakse asju teisiti.
| Kommentaarid: 16 loe/lisa |
15 |
kriist
19.07.2010 18:48:10
| wazaabi kirjutas: |
Võibolla kedagi huvitab. Endal pole sellist rauda, et proovida.
The German website PCGames Hardware (PCGH) now offers a configured ini-file with which the graphics of Gothic 3 CP v1.74 can be brought to an extreme graphical quality never seen before.
This however comes at a price: At maximum detail and tweaked ini, Gothic 3 uses up to 5 Gigabyte of memory. Also at that level Gothic 3 needs a very strong CPU: PCGH recommends using an overclocked quad core…
On the PCGH website you will find more than 30 screenshots made at 2560 x 1600 resolution using the latest Geforce GPU in a high-end PC also featuring an SSD. When playing G3 this results in just about 30 frames per second. Even Crysis would yield a higher frame rate on such a system... We all knew that Gothic 3 is hardware-hungry but this is... insane.
Also the website pubished a HD video in 720p resolution. It shows what Gothic 3 can offer with CP v1.74: FP16-HDR-Rendering including Tone Mapping, Spherical Harmonics, Soft Particles, Bloom, Rim- und Per-Pixel-Lighting, Depth of Field, Soft Shadows, Parallax- and Bump-Mapping and Ambient Occlusion.
link
Proovisin antud .ini järgi. Minu masinal jooksis asi päris talutavalt (resol 1440x900). Fps seal 35-50 vahel, kohati suurema "drop"-iga. Mälu õgis mäng igatahes pea kõik ära, miski 300mb jäi vast järgi. Aga silmailu tuli ikka mõnuga juurde.
Mõned pildid kah:
93 |
Scart
19.07.2010 19:04:26
Minu masin igatahes suri. Laadis sisse oma head 2-3 minutit ja tüüpiline Gothicu tõkkamine asendus totaalse seisakuga. Nii 15 minutit hiljem suutis mäng end ise kokku pakkida
101 |
486
19.07.2010 19:07:42
Graafika on niigi suht OK G3-l aga kuradi aeglaselt jookseb ja hakib kogu aeg.
_________________ zero |
| Kommentaarid: 46 loe/lisa |
39 |
heretic666
19.07.2010 19:51:13
Sellel kuupäeval algab ametlikult paljudel gothicu sõpradel nolife periood.
| Kommentaarid: 73 loe/lisa |
angel
19.07.2010 20:25:52
iseasi kas tuleb ikka "gothic" kuna vist teine team asja taga ning seniste videode põhjal võib olla kahtlust et tulemas "one button game play" mäng ehk siis lastele kellel tähelepanu võime on 0 ja igasugunegi "raskus" käib üle jõu. A'la the next generation. Aga loodan et ma eksin rämedalt
157 |
kriist
19.07.2010 20:27:06
angel, ma loodan ka, et eksid.
93 |
heretic666
19.07.2010 20:45:41
Rahu, angel lihtsalt pessimistlike eelarvamustega, lootus sureb viimasena .
angel
19.07.2010 20:57:11
lootus on lolli lohutus... lihtsalt teine team? ja näis kas hakkavad seda nime ära kasutama või teevad väärilise järje. Ja kui juba by default on "suur punane nool pea kohal mis näitab kõik ära" siis see tekitab juba kahtlusi. Välja tuleb siis näis... Loodetavasti ei taha nad mängu teha "laiemale kasutajaskonnale" mis ütleks kohe et tegemist on asjaga mis võib vabalt olemata olla... laiem kasutajaskond on oma flash mängudega enam kui rahul
157 |
wazaabi
20.07.2010 10:30:22
Nojah, devid pole sellest mingit saladust teinud, et toodavad mängu laiemale kasutajaskonnale. Samas, aga lubavad, et ka tõsisemad Gothicu fännid mängu häbenema ei pea. Valmis tehti mäng 6 milj. euroga, mis annab lootust näha viimistletud lõpptoodet. Enne ametliku reliisi on ka demo oodata, nii et ei pea mängu pimesi ostma minema.
Tõsisemad Gothicu fännid võivad lugeda The Cleaved Maiden lühijutte, mis annavad kerge ülevaate mängu tegelastest ja õhustikust.
| Kommentaarid: 9 loe/lisa |
rene92
20.07.2010 19:56:47
krt mull endal on selline huvitav pull , et arvuti peab ilust vastu , pole midagi häda , veerand mängu juba läbi , aga järsku ühes linnas hakkab laagima.Ja konkreetselt ühte linna ei saagi minna , sest ta ei liigu seal , jookseb kinni ja kõik...
Jube närvi ajab , igalpool saab käia ja teha aga ühes linas ei saa ja mängu ka ei saa selel pärast lõppetada .
angel
20.07.2010 20:24:50
tiri graafika alla ? endal, kui mängisin vanasti oli teatud linnadega kah kamm.. mootor süüdi vist vms jama kuna nii kui linna sisse lähed on fps kolinal läinud. Risen omas kah sellist bug'i vist just nvidia kaartidega. Ehk siis lampi tõmbas fps'i 10-20 peale ja vsio... ei aita midagi isegi graafika alla laskmine
sellest lausest võib juba lugeda hoiatus sõnu et tulemas on tavaline dumbed down hingetu, elutu, üks nupp ftw süsteemiga mäng mida parim mängida konsooli puldiga a'la xkasti omaga. Aga eks paistab. Ise pooldan siiski veel ajutegevust ja väljakutset pakuvaid mänge mille mängimine ja läbimine annab nagu sellise "omfg i made it" tunde mitte.. meh... grind fest.
157 |
marcor1
20.07.2010 20:54:50
RPG eeldaks seda, et mängija otsused mõjutavad mängu käiku ... aga siis tuleb hädakisa, et osad questid ei "tööta" ja kõike oskav tegelane ei saa millegagi hakkama. Pluss laiale massile piisab "äkšonist" - mitte et nad lugu ei oskaks hinnata kuid selle puudumine pole probleemiks...näiteks mis oli Avatari sisu - kaevurid läksid kaevama, kohalikud hakkasid vastu, kaevurid läksid koju.
_________________ War. War never changes.
Malkavian: [to a stop sign] No, you stop! |
| Kommentaarid: 69 loe/lisa |
63 |
One
01.08.2010 19:39:11
proovisin ka selle grafamodi ära.
profiilis olev arvuti vedas asja fullhd resol ja täisgrafaga 50+
fpsiga välja ja mingit hakkimisit küll ei olnud.
grafa muidugi oli ikka tunduvalt parem kui g3 niigi kena grafa
728 |
manraynor
12.08.2010 09:25:16
| angel kirjutas: |
sellest lausest võib juba lugeda hoiatus sõnu et tulemas on tavaline dumbed down hingetu, elutu, üks nupp ftw süsteemiga mäng mida parim mängida konsooli puldiga a'la xkasti omaga. Aga eks paistab. Ise pooldan siiski veel ajutegevust ja väljakutset pakuvaid mänge mille mängimine ja läbimine annab nagu sellise "omfg i made it" tunde mitte.. meh... grind fest. |
Eks mina ka tahan et Gothic 4 tuleks ikka nagu Gothic alati on olnud ... Kasutad natuke aju ja loodad et jääd ellu. Selle tegigi Gothicu seeria minujaoks parimaks üldse teistest RPGdest.
| Kommentaarid: 15 loe/lisa |
angel
12.08.2010 14:36:44
kui tegijad ei ole samad ja enamasti on tänapäeval põhi eesmärk raha teenida ja lasta end juhtida idiootidel kes asja üldse ei jaga ja ainult raha tasku pistavad siis ei ole see midagi et "kottik on ikka kottik".
Gothic 'ut tahta siis võta Risen ette. Täitsa nende käekiri igatpidi isegi bugid
157 |
One
12.08.2010 19:09:42
ulme, proovisin G3-e huvi pärast koos selle grafa ilusaks tegemise tweaki ja HD4770-ga.
krt kuidas asi jookseb, fps pidevalt üle 50, graafika maxed out ja reso 1920x1080.
ehk siis müstika kuidas osadel asi ei jookse
ainuke probla on, et viimane patch tegi asja saksakeelseks..
ei tea kas tirisin ise vale patchi või nii ongi?
728 |
Syncmahv
16.08.2010 17:20:54
Täiesti segane värk, ei saa Gothicut enam üldse tööle, lööb pildi mustaks, monitor ei jaga enam üldse matsu ära, kuid muusika taustal käib.
Kõik mängud töötasid peale G3, vahetasin DVI pesa monitori ja TV vahel, ja hakkas tööle G3.
viimati muutis Syncmahv 16.08.2010 19:38:03, muudetud 1 kord |
102 |
Scart
16.08.2010 18:55:31
| Winterwind kirjutas: |
ehk siis müstika kuidas osadel asi ei jookse  |
Vaata korraks oma proset ka, näiteks? G3 on single-threaded ja i5 on oi kui magus paugutaja.
101 |
Syncmahv
17.08.2010 15:07:19
Erilist muutust graafiliselt ei täheldanud selle ini failiga, kuid mäng muutus tõesti saksakeelseks. Proovisin ini failist eng muuta, kuid ikka sakslane.
Muidu täitsa hästi jooksis.
102 |
kriist
22.08.2010 18:31:41
Tohohh, paar nädalat tagasi kõik toimis, nüüd aga käivitamisel selline error:
Erinevaid lahendusi mida guuglist leidsin ka proovisin. Isegi reinstalli tegin ja kõik komuuni patch´id ka peal nagu varem. Ja ühtegi draiveri muudatust pole ka vahepeal teinud.
Ideid?
93 |
mutabor
23.08.2010 12:32:04
run as admin ei aita?
_________________ /allkiri |
| Kommentaarid: 24 loe/lisa |
22 |
kriist
23.08.2010 17:41:15
Ei aitanud.
Asi oli hoopis selles .ini failis. Seal oli ekraani reso suurem kui minu monitor seda võimaldab ja sellest ka see error.
Syncmahv, muuda kõik neli kirjet .ini faili lõpust "english" ja siis peaks korras olema.
93 |
Syncmahv
23.08.2010 19:42:31
| kriist kirjutas: |
Ei aitanud.
Syncmahv, muuda kõik neli kirjet .ini faili lõpust "english" ja siis peaks korras olema. |
Seda ma tegingi, nagu ma ütlesin, aga ei midagi.
102 |
Scart
15.10.2010 00:03:01
| Selline mure, et tuli teha masina vahetusega seoses Wini reinstall ning juba paraja varuga sai G3 salvestatud mängud ära kopeeritud. Steam uuesti peal ja ka G3 jälle olemas, kuid mäng ei taha kohe mitte tunnistada neid salvestatud mänge, mis tõstsin My Documents\Gothic 3 kaustast varukettale. Kas G3 siis ei võimaldagi salvestatud mängude "importi"?
101 |
