libe
kvaliteetne mees
24.06.2010 15:45:49
väga totter tõlgendus direktiivist
ja sinu veel totram tõlgendus totrast tõlgendusest
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
Mario.
28.06.2010 17:20:09
6 :: |
217 |
vipu
28.06.2010 17:37:44
jeesus on sinuga
libe
kvaliteetne mees
28.06.2010 18:30:53
tunnistan, et MarioA. on minuga
Mario.
6 :: |
217 |
MatchMaker
09.07.2010 14:01:18
Pole aimugi kas see on kusagilt läbi käinud, aga lihtsalt tekitas suurt nalja, siin zeitgeisti ka mainitud. Mõtlesin, et kas faktidega annab ikka nii kõvasti eksida. Aga suurepärane näide inimesest kes materdab kõike maha, ise ilmselt mitte kordagi asja uurimata.
http://crusoe.pri.ee/blog/prison-planet-vandenouteooreetikute-volusona
Mario.
09.07.2010 14:05:54
Prison planet jm. analoogid on tõesti paranoilise ja veidi haiglase mentaliteediga.
Üllatav, et on väheseid saite, mis suudavad olla konkreetsed, viisakad ning tunduda ka mõistlikud.
6 :: |
217 |
MatchMaker
09.07.2010 20:41:48
Jäi kõrva veel huvitavat, aga ühtegi teise teemasse ei oska ka seda panna.
Albert Pike and Three World Wars
http://www.threeworldwars.com/albert-pike2.htm
August 15, 1871 On need punktid seal siis kirja pandud
"The First World War must be brought about in order to permit the Illuminati to overthrow the power of the Czars in Russia and of making that country a fortress of atheistic Communism. The divergences caused by the "agentur" (agents) of the Illuminati between the British and Germanic Empires will be used to foment this war. At the end of the war, Communism will be built and used in order to destroy the other governments and in order to weaken the religions.
"The Second World War must be fomented by taking advantage of the differences between the Fascists and the political Zionists. This war must be brought about so that Nazism is destroyed and that the political Zionism be strong enough to institute a sovereign state of Israel in Palestine. During the Second World War, International Communism must become strong enough in order to balance Christendom, which would be then restrained and held in check until the time when we would need it for the final social cataclysm.
"The Third World War must be fomented by taking advantage of the differences caused by the "agentur" of the "Illuminati" between the political Zionists and the leaders of Islamic World. The war must be conducted in such a way that Islam (the Moslem Arabic World) and political Zionism (the State of Israel) mutually destroy each other. Meanwhile the other nations, once more divided on this issue will be constrained to fight to the point of complete physical, moral, spiritual and economical exhaustion…We shall unleash the Nihilists and the atheists, and we shall provoke a formidable social cataclysm which in all its horror will show clearly to the nations the effect of absolute atheism, origin of savagery and of the most bloody turmoil. Then everywhere, the citizens, obliged to defend themselves against the world minority of revolutionaries, will exterminate those destroyers of civilization, and the multitude, disillusioned with Christianity, whose deistic spirits will from that moment be without compass or direction, anxious for an ideal, but without knowing where to render its adoration, will receive the true light through the universal manifestation of the pure doctrine of Lucifer, brought finally out in the public view. This manifestation will result from the general reactionary movement which will follow the destruction of Christianity and atheism, both conquered and exterminated at the same time.
Albert Pike näol oli tegemist siis USA kõrge vabamüürlasega, kes elas aastatel 1809 - 1891.
http://et.wikipedia.org/wiki/Albert_Pike
15.07.2010 07:53:04
| Tagantjärele tarkus on täppisteadus. Siia kõrvale võid panna teised 999999 ennustajat - üks tabab ikka "täppi".
147 |
Starfield
15.07.2010 10:41:22
| tsitaat sealtsamast lehest kirjutas: |
It is a commonly believed fallacy that for a short time, the Pike letter to Mazzini was on display in the British Museum Library in London, and it was copied by William Guy Carr, former Intelligence Officer in the Royal Canadian Navy. The British Library has confirmed in writing to me that such a document has never been in their possession.
To date, no conclusive proof exists to show that this letter was ever written. Nevertheless, the letter is widely quoted and the topic of much discussion. |
Faktid.
| Kommentaarid: 22 loe/lisa |
22 |
Scart
15.07.2010 10:47:39
| Starfield kirjutas: |
Faktid. |
Millal on faktid enne korralikku paranoiat seganud?
101 |
MatchMaker
raxz
20.07.2010 00:50:11
Kui tuleb välja, et MatchMaker on mingit ummamuudut kirjutanud, siis viskab uue lingi ja kõik. Tõestagu parem ära, et see kiri on päriselt kirjutatud.
Samamoodi paljudes teemades teiste linkide ja väidetega...
| Kommentaarid: 46 loe/lisa |
45 |
MatchMaker
20.07.2010 02:34:27
Linkides on sellist infot mis on mõeldud selles, et aidata Sul (just nimelt sinul) selgeks teha "mõtlemise" tähendust ja aidata sul seda tegema õppida. Ega ilma asjata seda mis hetkel maailmas toimub infosõjaks kutsuta. Ühel poolt massimeedia, mis teeb kõik selleks et sulgeda su meeled kasti ja koolitada sind välja ainult kasti sees mõtlema. Teiselt poolt need kes üritavad meeli vabastada ja näidata maailma väljaspool kasti. Selge on see, et ka see jääb osaliselt kasti sest me ei tea veel täit tõde ja ei näe täit pilti, aga see on algus.
Maailmas kus on tohutul, lausa lugematul hulgal salastatud dokumente, riigijuhtide avaldusi, kirju jms on keeruline tõestada et kas tegemist on faktiga, ning sama raske on ka tõestada, et tegemist pole faktiga, sellele vaatamata imbub ikka ja jälle välja infot mis algselt sildistatakse kui vandenõuteooria, ning hiljem kui näiteks ka ametlikult tunnistatakse, et vandenõulastel oli õigus siis muudab see vähe sest inimeste ajudesse on juba kood sisestatud. Info eesmärk pole seda pähe õppida või pimesi uskuda, vaid purustada kood mida üldsus üritab inimese mõistusesse sisestada igas tema elu etapis-. sünnist kuni surmani.
Nüüd aga minnes tagasi washingtonposti väga põhjaliku uuringu juurde, siis on seal ka väga huvitav skeem mis näitab kui sügavale on salastatus imbunud Ameerikas, kus üks käsi ei tea mis teine teeb, või siis õigemini ei pruugi enam teadagi teise käe olemasolust.
http://projects.washingtonpost.com/top-secret-america/network/#/overall/most-activity/
NaguVari
22.07.2010 19:14:22
Aga miks sa arvad, et see tõde on???
_________________ ohoh.. |
| Kommentaarid: 17 loe/lisa |
16 |
fic
22.07.2010 22:08:58
MatchMaker ajab mulle ikka naeru peale. Inimesele võidakse igat asja tõepähe serveerida, pea ja mõistus peaks olema selleks, et tõde välja sõeluda sealt. Raudselt kodus Derby tolmuimejad jms, mida müügimehed 22. sajandi imeleiutiseks nimetavad. Ja Su kirjalaad on ka selline, et rääid nagu raudpolt kindlast tõest, pole näinud Su postitustes selliseid lauseid nagu; see on minu arvamus, ma arvan nii, sest; See pole kindel, kuid ma arvan, et...
Naljakas lugeda lihtsalt.
_________________ PhotograFICal |
MatchMaker
23.07.2010 01:20:21
Tõe väljasõelumisega tegelemegi. Vandenõuteoreetikute suurim eksitaja kipub muidugi olema kas religioon, või siis see et süüdistatakse liialt ainult ühte osapoolt ja jäetakse kõik muud kõrvale. Aga üldised tõed on lihtsalt niivõrd ilmsed et ei jäta palju ruumi kahtluseks. Globaalne eliit lihtsalt on alati rääkinud kõigest sellest mis nad teinud on ja mida teha kavatsevad üsna avalikult ja muidugi see mida nad räägivad ja keda nad ka väidavad ennast teenivat on nö tavainimese jaoks üsna hirmutav nii et tavaliselt üritatakse neid punkte eirata. Samamoodi vandenõuteoorlased on avastanud ka selle, et meie planeedi globaalne eliit peab üleval tohutut pedofiilia ja laste varguste võrgustiku mis on iga järgneva aastaga läinud järjest hullemaks. Probleemiks on lihtsalt see, et on palju nõrgamõistusega inimesi kes on valmis oma elu hinnaga seda süsteemi kaitsma. Seda siis põhjusel, et nad kardavad vaadata kastist väljapoole või on neile antud kübeke võimu, nii et nad tunnevad nagu oleks nad koos eliidiga.
Ma postitan ühe klipi mida olen kuskil teemas varem maininud. Mis vähemalt näitab, et kui rahvas hakkab ärkama on võimalus see eliidi nö lõppmäng ära hoida või siis enne selle toimumist miskit ette võtta.
Trilateral Commission co-founder Brzezinski Decries “Global Political Awakening” During CFR Speech
vipu
23.07.2010 09:21:25
| Rahvas ärgake - kas mitte vahitornil polnud selline pealkiri. MatchMaker, kui su globaalne eliit murtud saab, mis asemele tuleb?
MatchMaker
23.07.2010 09:45:24
Ma arvan, et keegi ei kujuta täpselt seda ette mis juhtub siis kui emb kumb pool selle nö sõja võidaks. . Eliidi plaan oleks põhimõtteliselt ainult iseennast alles jätta ja oma geenide pealt tuleviku ühiskond luua (koos siis teatud arvu nö biorobotitega kes neile küsimusteta alluvad).
Ma ei kahtlegi selles, et kui teatud grupp vandenõuteoreetikud selle sõja võidaksid siis nad kuulutaks iseennast uueks eliidiks ja üritaks ära koristada seda rahva osa kes nö pole valmis ärkama. Kokkuvõttes on nad ikka üksteise poolused ju.
Mina isiklikult eelistaks oopis mingit kolmandat teed, ma pole kindel et seda hetkel veel tekkinudki on, vb siis kui nood kaks omavahel arved ära klaarivad ja vana maailm nö varemetes on, siis puudub vajadus mõlema järele ja on võimalus alata puhtalt lehelt. Inimesi peaks ka siis tunduvalt vähem olema kui hetkel ja loodetavasti oleks religioonidel ka kriips peal.
vipu
23.07.2010 10:14:34
| MatchMaker: mis sul inimestega on, miks inimesi peaks vähem olema.
Ho Ho
23.07.2010 10:16:31
| vipu kirjutas: |
| MatchMaker: mis sul inimestega on, miks inimesi peaks vähem olema. |
Resursse ei jätku nende elus hoidmiseks ja normaalseks arenguks
86 |
vipu
23.07.2010 10:46:32
| Ho Ho kirjutas: |
| vipu kirjutas: |
Resursse ei jätku nende elus hoidmiseks ja normaalseks arenguks |
jätkub ikka, pealegi kõigil inimestel on õigus elule ja kõigil on õigus saada lapsi. Ega mitte kunagi ei saa võimalikuks terve planeedi katmine heaoluühiskonnaga. Aafrikas, indias on sündivus suur, samas ka surevus on väga kõrge. Kui tehnoloogiad paranevad siis paraneb seeläbi ka inimeste elukvaliteet. Kui keegi soovib inimeste vähendamist, alustagu iseendast
Ho Ho
23.07.2010 10:56:40
| vipu kirjutas: |
| jätkub ikka |
metallid-fossiilkütused on suht otsakorral.
| vipu kirjutas: |
| Ega mitte kunagi ei saa võimalikuks terve planeedi katmine heaoluühiskonnaga |
Ehk siis nagu ütlesin, resursse puudu arenguks.
86 |
Cocapunn
23.07.2010 11:05:09
Vaidlen vastu. Mida kitsamad on olud, seda leidlikumaks inimesed muutuvad ja seega toimub ka areng. Kunagi elasid inimesed koopas, õppisid tuld kasutama, hakati paremaid elutingimusi looma jne. Kui on antud ellujäämisinstinkt siis see su liigutama panebki hädaolukorras. Selge see, et 5-10 aastaga ei juhtu midagi aga kui võrrelda elu kasvõi 100 aastat tagasi on areng muljetavaldav.
_________________ Olgu sul sama hea, kui mul.
Vaimukus on haritud ülbus.
Maailma kõige lühem anekdoot: ``Mees`` |
Ho Ho
23.07.2010 11:24:52
| Cocapunn kirjutas: |
| Mida kitsamad on olud, seda leidlikumaks inimesed muutuvad ja seega toimub ka areng |
a'la rahva populaarsuse hoidmise nimel tõmmatakse NASA eelarve kokku ja tambitakse pappi iganenud ja äärmiselt viletsasse tervishoidu või jagame penskaritele kommiraha selle asemel, et teede auke lappida.
86 |
