praegune kellaaeg 06.10.2026 18:59:40
kk
28.06.2010 10:53:30
Digilevi - Kas TechniSat DigiPal2 seade peaks töötama? |
Mul vanast ajast olemas TechniSat DigiPal2 digibox ja proovisin maal metsas tööle panna. Signaali näitab ainult 15% ja quality 0. Kanalid leidis üles aga veider on see, et heli tuleb küll aga ilma pildita. Digilevi infotelefon ei tea seadmetest midagi muud kui , et digilevi märk peab olema (obv seda ei saa ju olla kui on vanem seade). Kas keegi teab siin öelda kas see seade muidu norm antenni ja õige seadistusega peaks töötama või mitte? Kui peaks siis pean oma antennimajanduse ja muude settingutega edasi mängima. Kui mitte siis jään maal ilma telekata sest uut sinna suvilasse küll ostma ei hakka.
VHF channels: 5-12 (174...230 MHz)
UHF channels: 21-69 (470...860 MHz)
Autoinstall
(Autoinstall is a software product developed by TechniSat providing automatic and simple unit installation)
Automatic programme scan feature
4.000 programme memory slots available in Total list
Convenient on-screen operating menu in 14 languages
"SiehFern INFO": Convenient programme information service provided free of charge
SuperTechniText generating, as well as additional own TechniText with 800-page memory, sub-titles
Timer (maximum 124 events, one year in advance)
Software update via antenna
2 Scart sockets
Elektrical digital audio output
Dolby Digital (AC3)
RS 232 interface for connecting a PC
Large LED display
TWIN receiver function
Using an additional remote control (Art.-No. 0000/3734) you can operated two DigiPal 2 units separately and in parallel, as the DigiPal 2 features two remote control options.
5 V current supplied via the antenna cable, allowing you to operate an active indoor antenna without a need for a separate mains adapter
Power supply: 220 V
Power consumption Standby: 3 W (without clock)
Power consumption Standby: 3,4 W (with clock)
Power consumption in operation: 7 W
7 :: |
94 |
green
28.06.2010 11:08:41
karta on et ei tööta siin eestis see karp, nimelt siin vaja mpeg-4 toega aparaate, aga antud aparaat vististi mpeg-2 toega(seda vist ka see number mudeli lõpus tähendab "2")
_________________ Ema ja Isa tassivad jõmpsikat 1. septembril kooli, kes punnib vastu ja karjub täiest kõrist: Kaksteist aastat! Mille eest!? |
| Kommentaarid: 176 loe/lisa |
146 |
kk
28.06.2010 11:12:03
| OK, siis selge. Seepärast vist siis ongi nii, et heli on aga pilti mitte. Tänud!
7 :: |
94 |
Maldur
28.06.2010 11:24:57
| Praegust Soome digilevi see pill tunneb, vaata põhjarannikul või müü soomlasele maha.
| Kommentaarid: 4 loe/lisa |
