krist2an
21.06.2010 12:35:18
Ülevaade: Sanyo Xacti HD2000 |
Sai märtsis uus videokaamera ostetud. Kuna ka digikas oli juba kergelt ajale jalgu jäämas, siis tahtsin sellist aparaati, millega kannataks nii filmida kui ka pilte teha. Lihtsalt reisidel on alati tüütu, kui peab mitut seadet kaasas kandma. Pika otsimise tulemusena sai välja valitud Sanyo HD2000. Välimuselt "veidi" teistsugune, kuid heade parameetritega kaamera tuligi Prantsusmaalt Pixmania laost umbes 6000.- eest minu postkasti (okei, kuller tõi kätte).
Specs:
Effective pixel count/Camera element Stills: Approx. 8.0-Megapixels
Videos: Approx. 5.31-Megapixels (in Full HD/HD mode), Approx. 2.00-Megapixels (in SD mode)
Camera element 1/2.5 inch CMOS sensor, Approx. 8.1-Megapixels (total)
Recording media SD Memory Card, SDHC Memory Card (up to 32GB)
Recording file formats Photos: JPEG (DCF*1, DPOF*2, Exif Ver2.2*3)
Videos: ISO standard MPEG-4 AVC/H.264 (.MP4)
Audio: 48kHZ sampling, 16bit, 2ch, AAC
Resolution (pixels) Photos*4 12M: 4000 x 3000*4, 8M-H: 3264 x 2448 (low compression) 8M-S: 3264 x 2448 (standard compression) 6M[16:9]: 3264x1840 2M[16:9]: 1920x1080 2M: 1600 x 1200 0.9M[16:9]: 1280x720 0.3M: 640x480
Continuous shots 8M: 3264 x 2448 , 6fps/Max 9 photos, 4M: 2288 x 1712 , 12fps/Max 15 photos
Videos*5 Full-HR: 1920 x 1080 (60 fps/ 24Mbps) Full HD: 1920 x 1080 (60fields/sec 16Mbps)
Full-SHQ: 1920 x 1080 (30 fps/ 12Mbps) HD-SHQ: 1280 x 720 (30 fps/9Mbps)
TV-SHQ: 640 x 480 (30 fps/3Mbps)
Web-SHR: 448 x 336 (240 fps/8Mbps) Web-UHR: 192 x 108 (600fps/8Mbps)
Lens 10x optical zoom lens; Aperture: F=1.8(W) – 2.5(T)
Focus distance: f=6.3 to 63mm;
Galvanometer method structure, Auto focus: 8 groups, 11 elements (3 aspheric elements, 5 aspheric surfaces), Built-in neutral density filter
Photos: f=38-380mm(=35mm) Optical 10x zoom
Videos: f=44.4-710mm(=35mm) 16x Adv. zoom
Photo range Standard: 50cm to infinity (wide), 1.0m to infinity (tele) / Super macro: 1cm – 1m (wide)
Digital zoom Shooting: 10x max., Playback 62.5x max. (12M mode, depending on the resolution)
Low light sensitivity (video) Approx. 6 lux (Auto mode, 1/30 sec.)
Approx. 2 lux (High-sensitivity/ Lamp mode, 1/15 sec.)
Stills sensitivity Auto (ISO 50 – 200), Manual (ISO 50/100/200/400/800/1600/3200, Switching system)
Digital Image Stabilizer Photos: Digital Image Stabilizer (Multi-Calculation method),Videos: Digital Image Stabilizer (electronic)
Audio Microphone: Built-in stereo, Speaker: Built-in monaural (L+Rch mixed output)
LCD monitor 2.7 inch, Low-temperature polysilicon TFT color widescreen LCD display, Approx. 230,000 pixels (7-level brightness, 285 degrees rotation)
Languages English/ French/ German/ Spanish/ Italian/ Dutch/ Russian/ Portuguese/ Turkish/ Thai/ Korean/ Simplified Chinese/ Traditional Chinese
Interface AV output* (Video: HDMI/D/ S-Video/ Composite video (NTSC/PAL) Audio: Stereo sound)
Microphone input (plug-in power type: φ2.5mm,φ3.5mm adaptor bundled)
Headphone output (φ3.5mm stereo mini-plug, 16Ω-32Ω)
USB 2.0* (high-speed mode compatible)
*When used with Docking Station
Power source Lithium-ion battery x 1 (DB-L50 included: 1900mAh) AC-adaptor
Power consumption When using battery: 4.3W (when filming videos)
Approx. battery-use time*6 Photos: Approx. 355 shots (CIPA standard), Continuous video filming: Approx. 135min./Continuous playback: Approx. 350 min.
Dimensions/Volume 90.0 (W) x 112.6 x 54.5 (D)mm (maximum dimension, excluding protruding parts)
Volume: Approx. 272cc
Weight Approx. 268g (main unit only), Approx. 311g (including battery, Approx. 41 g, and SD card, Approx. 2 g)
Karpi avades oli üllatus suur, sest alguses tundus, et kaamerat polegi! Tegelikul on kaamera lihtsalt nii väike, et mahub vabalt mul jakitaskussegi, väga mugav seega kaasas kanda. Karbis olid veel kaasas ühendustedokk, USB-kaabel, USB-pikendus, RCA-kaabel, laadimiskaabel, komponentkaabel, pisike pult, pehme kott, 2.5-3.5mm adapter ning käepael. Kahjuks (nagu sellise hinnaklassiga kaamerate puhul tavaks) puudus HDMI kaabel ning mälukaart. Kuna sisseehitatud mälu sel kaameral pole, ostsin ise juurde 16gb mälukaardi.
Nagu juba mainitud, siis kaamera näeb ise äärmiselt pisike välja. Välimuse kohta pole midagi halba öelda, kena must värv ning mõned tagasihoidlikud metallist detailid. Kuju on aga äärmiselt mugav: võib vabalt ühe käega igasuguste nurkade alt filmida. Samuti ei ole selline kuju käele nii kurnav, kui klassikaline kaamerakuju. Nuppude paigutus on lausa geniaalne. Kõik vajalikud nupud on ühes kohas ning loogiliselt paigutatud. Ka siin on selge vihje sellele, et see kaamera on kaks ühes: nii foto- kui ka videonupud on võrdse suurusega ning kõrvuti. Igatahes ergonoomika kohta pole mitte midagi halba öelda. Täielikult ühe käega opereeritav kaamera. PS! ka vasakukäelised saavad seda väga lihtsasti just vasakus käes kasutada.
Kui rääkida nüüd videokvaliteedist, siis see on peaaegu ideaalne sellise kaamera kohta. 1920x1080/60p (esimene consumer-kaamera, mis seda suudab) on lihtsalt hämmastav! Värvid on täpsed, pilt terav. 60p annab ka ülima sujuvuse, eriti kasulik näiteks spordivõistlustel. Käisingi filmimas üht korvpallimatši ning peale seda tunduvad teleülekanded justkui üleeilsest päevast. Kuigi tavaliselt on sellistel üritustel müra väga suur, siis kaamera sai päris hästi heliga hakkama. Ei ole kuulda ainult pasunate karjumine, vaid ka muud helid. Sama tõestas ka ühe kontserdi video, kus heli inimkõrvale juba talumatuks muutus, kuid Sanyo salvestust vaadates pole asi üldse hull. Olemas on ka mikrofonipesa, see küll 2.5mm, kuid nagu juba mainitud, siis 3.5mm adapter tuli kaasa.
Pildikvaliteedi juurde tagasi tulles: näiteks camcorderinfo.com ütles oma ülevaates, et HD2000 võib pildikvaliteedis vabalt konkureerida kaks korda kallimate kaameratega. Samuti kiidetakse seda just pimedas tehtud videote pärast. Ainus miinus on korraliku pildistabilisaatori puudumine. Olemas on ainult elektrooniline, mis saab oma tööga enam-vähem hakkama, kuid kõndides filmitud kaadrid ei tule ilusad. Statiiv on selle kaamera puhul kindlalt kohustuslik! Samas on teatud nipid, mis aitavad stabiilsusele kaasa, seega paar kuud harjutamist ning ka selle kaameraga saab päris stabiilseid võtteid teha. Teine pisike mure on fokusseerimise kiirus. Vahetevahel võiks fookus kiirem olla. Fookuskaugust saab ise muuta, kuid mitte filmimise ajal. Olemas on ka makrovõte, mis lubab kuni 1cm kauguselt filmida/pildistada. Makrot teeb see pill igatahes hästi. Aga kui võtta seda kui sellist tavalist point-and-shoot kaamerat, siis kurta ei saa küll otseselt millegi üle. Võtad taskust välja, teed ekraani lahti ning hakka aga filmima! AUTO-seaded on piisavalt head ning saavad päris hästi hakkama, kuigi ise on võimalik samuti seadistada: White balance, Exposure (Aperture, Shutter), ISO, Focus pluss veel mõned teised seaded.
Fotode tegemise koha pealt võib öelda, et tavalistele digikatele ei jää küll see kaamera alla. 8Mpix on täiesti piisav ning pildikvaliteet on igati korralik. Sanyo väide, et see on "dual camera" vastab igati tõele. Loomulikult ei saa seda võrrelda peegelkaameratega, kuid tavakasutaja jaoks on see täiesti piisavalt. Hea funktsioon on ka veel see, et filmimise ajal on võimalik fotot teha. Nagu ka video puhul, on võimalik fotosid väga erinevates formaatides teha, näiteks nii laiekraanis kui ka 4:3 ja väga erinevate resolutsioonidega. Fotod salvestab ta .jpeg formaadis. Pimedas pildistamiseks on olemas ka välk.
Aku kestab piisavalt, 1920x1080/60p formaadis saab umbes 1h 20min filmida, madalamate resolutsioonidega loomulikult kauem. Seega ei pea muretsema, et aku pidevalt tühjaks saab. Laadimine võtab umbes 4 tundi. Laadida saab nii otse kui ka läbi doki. Dokk ongi üks tähtsamaid osasid selle kaamera juures, sest ilma selleta ei ole võimalik kaamerat nt. teleriga ühendada. Mõnikord väheke tüütu seda kaasas kanda, kuid see-eest on kaamera ise väiksem. Kaasasolnud pult on äärmiselt kasulik, sest sellega saab nii kaamera seadeid muuta, pildistada/filmida kui ka hiljem oma salvestusi näidata.
Kokkuvõtteks võib öelda, et kui keegi on sama laisk, kui mina, ning ei viitsi igale poole kaht kaamerat kaasa vedada, siis Sanyo HD2000 on väga hea kaamera, mille videod kannatavad võrdlust ka hoopis kallimate konkurentidega ning mille pildid ei jää alla tavalistele digikaameratele. Hinna-omaduste suhe on igatahes ülihea (seda tõestab ka camcorderinfo.com'i auhind "Best Value Camera 2009" ning kokkuvõttes 4. koht üldtabelis).
Plussid:
Ülihea videokvaliteet
Korralik fotokvaliteet
Mugav kuju
Loogilised menüüd
Piisavalt palju seadeid
Väike
Väga hea pimedas (madala valgusega kohtades)
AUTO-seaded
Miinused
Ainult elektrooniline stabilisaator
Mõnikord aeglane autofookus
Paar endatehtud videot kah:
http://www.youtube.com/watch?v=Z1LebTWBMII
http://www.youtube.com/watch?v=W79crKwfxsk
Pilte kah:
Edit: tegin siiski pildid väheke väiksemaks.
viimati muutis krist2an 21.06.2010 12:58:22, muudetud 3 korda |
| Kommentaarid: 42 loe/lisa |
41 |
K3ndu
21.06.2010 12:35:25
| Kena kvaliteet videl ,aga kaks esimest pilti väga hägused või sellised.
120 |
krist2an
21.06.2010 12:53:14
| K3ndu kirjutas: |
| Kena kvaliteet videl ,aga kaks esimest pilti väga hägused või sellised. |
Tundub, et Painti viga, sest originaalid on küll korralikud. Ruttu tegin väiksemaks, noh huvitav jah, et tervaust nagu pole enam ja värvid kah kergelt paigast ära (võrreldes just originaaliga).
41 |
TheDJ
21.06.2010 13:12:16
Tänud ülevaate eest
_________________ Võta aega veidi ringi vaadata |
21.06.2010 13:16:21
| krist2an, Irfanview või mõni muu asisem näppija abiks.
| Kommentaarid: 85 loe/lisa |
krist2an
21.06.2010 17:49:07
| mikk36 kirjutas: |
| krist2an, Irfanview või mõni muu asisem näppija abiks. |
Mul on isegi olemas väheke korralikumad tööriistad selle jaoks, aga noh, ega siis hommikul ju mõistus ei tööta Viimased kaks pilti on see-eest väheke paremad.
41 |
-Koppel-
21.06.2010 20:25:58
| Kas sa tahaks äkki upload.ee-sse näiteks otse kaamerast pärit videofaili laadida?
| Kommentaarid: 10 loe/lisa |
10 |
krist2an
21.06.2010 23:57:09
| -Koppel- kirjutas: |
| Kas sa tahaks äkki upload.ee-sse näiteks otse kaamerast pärit videofaili laadida? |
Kuna mul m-internet, siis see alles laeb.
Aga paar pilti ka pimedas (väga suure resoga):
41 |
MelesMeles
21.06.2010 23:58:16
Filmimiseks mõeldud vidina kohta väga head fotod
_________________ Allkiri |
194 |
krist2an
41 |
wex
| Kommentaarid: 124 loe/lisa |
117 |
22.06.2010 19:37:37
Tundub huvitav kaameraolevat. Olles toda eesoovitanu panat ise käes hoidnud, siis loodan Sanyo paremat kasutatavust minusuguse eesti mehe kämbla jaoks .
Need FHD kaamerad on lihtsalt niivõrd ebamugavalt väiksed, et ei saa kuidagi teist käes hoida ja samal ajal veel sama käe sõrmedega miskit opereerida.
Tubli ülevaade
130 |
krist2an
22.06.2010 19:40:48
Tol hetkel polnud sellist kaamerat seal valikus, arvatavasti mingi uuem mudel. Muidugi kaalusin ma ka teisi kaameraid, kuid lõppkokkuvõttes pakkus see Sanyo parimat kooslust ning mina olen igati rahul. Ma ei saa aru, mida sa selle viimase lausega tahad öelda. Okei, see Sanyo on tõesti eelmise aasta mudel, kuid NII vana ta ju ka pole
Aga selle panasonicu miinus on minu arust puutetundlik ekraan. See tähendab, et ühe käega kaamera kasutamine pole kahjuks võimalik. Samuti jääb see Panasonic Sanyole piltide tegemisel kõvasti alla (vähemalt minu arvates on 2Mpix natuke vähe, eriti kui võrrelda seda Sanyo kaheksaga, aga eks pildikvaliteet sõltub ka muudest asjadest)
Edit: Avastasin, et see sinu pakutud Panasonic on lihtsalt uuendatud mudel, endine SD20, millega ma seda Sanyot ikka võrdlesin. Selle ülevaate kohaselt jääb Panasonic Sanyole ikka päris korralikult alla, sellel uuendatud mudelil on samas uus lääts, seega hetkeseisu ei oska kommenteerida.
41 |
TheDJ
23.06.2010 14:53:25
Pimedas tehtud fotod on ikka väga ilusad selle asja kohta. Väga kena. Paneb mõtlema!
enterprice
24.06.2010 16:40:30
Suht sarnaste mõõtmete puhul olen ise alternatiivina näinud hoopis fotokat mis filmib. Valikut on palju, tõsi enamus piirdub 1280*720 videotega, minu vajadusteks aga täiesti piiav. Fotoka plussiks, et nii videol ja pildil laiem nurk, pikem zoomi ulatus, parem pildikvaliteet, optiline stabilisaator ja muidugi soodsam hind
Aga eks niipalju kui inimesi on erinevaid armamusi ja igaühe maitsele leidub midagi sobivat.
98 |
Probleem.
24.06.2010 20:16:24
| enterprice kirjutas: |
Aga eks niipalju kui inimesi on erinevaid armamusi ja igaühe maitsele leidub midagi sobivat. |
Sellise hinna eest vist sellist fotokat veel ei saa.
_________________ -.- |
enterprice
24.06.2010 22:13:50
| 5K eest saab juba näiteks Canon sx 210is Enda sx200 12x zoomiga läeb müüki 3,2
98 |
seebakas
10.07.2010 20:45:48
| Mul nikon Coolpix p100 teeb ka suht kena HD video ( http://www.youtube.com/watch?v=qEoWVuwLYao ) ja teeb ilusad pildid ka. Kusjuures ma otsisin sama kooslust, et aparaat oskaks teha nii pilte kui ka videoid ning videokaamera asemel saigi siis Nikoni kaamera ostetud.
enterprice
10.07.2010 21:30:11
| seebakas kirjutas: |
| Mul nikon Coolpix p100 teeb ka suht kena HD video ( http://www.youtube.com/watch?v=qEoWVuwLYao ) ja teeb ilusad pildid ka. Kusjuures ma otsisin sama kooslust, et aparaat oskaks teha nii pilte kui ka videoid ning videokaamera asemel saigi siis Nikoni kaamera ostetud. |
Coolpix suht suur kaamera, kui väiksemat tahta siis Canon Ixus 300HS teeb ka super head videot. Ava on ka 2,0 ja väga väikese müraga sensor. Hea alati taskust võtta. Ka väike kuid ixusest siiski vähe suurem oleks Canonil SX210 ja Panasonicul on ka paara aparaati mis väiksemad.
98 |
DVDRW
01.08.2010 15:40:19
Võtsin ka selle kaamera. Mul nii, et katik (lens cap) jääb väga õrnalt ja kukub kergesti ära.
Muidu sellise hinna kohta väga hea kaamera.
Makrofotod on hämmastavad, ei saagi aru kas on tehtud peegelkaameraga või mitte.
Tegin sellise kaabli, et saab USBi kaudu laadida ka kaamera akut + faile sirvida.
Ei mõista miks ei võiks kohe nii olla
Stabilisaatori asemel saab kasutada monopodi või isetehtud steadycami näiteks.
Tellisin ka lisaaku yeintist 233kr.
| Kommentaarid: 28 loe/lisa |
skulmars
20.09.2010 18:35:25
| DVDRW kirjutas: |
Tellisin ka lisaaku yeintist 233kr. |
kas pixmaniast ja palju kokku läks? Mul kalkuleerus sealt hinnaks koos transaga 6 199 EEK
| Kommentaarid: 213 loe/lisa |
177 |
DVDRW
21.09.2010 09:23:56
Oli kiiresti vaja, tellisin UPSiga ~6400kr 2 päevaga kohal.
Maatranspordiga läheb ~kuu
skulmars
23.09.2010 13:30:00
| DVDRW kirjutas: |
see tundub tüüpviga olevat, mul ei püsi üldse ees. oled sinna mingi normaalse asenduse leidnud?
177 |
krist2an
23.09.2010 22:04:47
| skulmars kirjutas: |
| DVDRW kirjutas: |
see tundub tüüpviga olevat, mul ei püsi üldse ees. oled sinna mingi normaalse asenduse leidnud? |
Mul küll seisab väga hästi ees, pole kordagi ära kukkunud. Ju on mulle siis hea eksemplar juhtunud
41 |
hacman
07.01.2011 11:54:01
kas keegi teab mis erinevused on HD2000 ja HD2000A versioonidel!?
ning mis vahed/erinevused on VPC- või siis DMX- mudelitel?
google nagu ei abistand.
| Kommentaarid: 9 loe/lisa |
9 |
