Marvel vs. Capcom 3 is a fighting game where up to two players compete in battle using characters with their own unique fighting styles and special attacks. The game features the same tag-based team feature as previous installments of the series, where each player chooses three characters that can be swapped at any point during a match, and utilizes an order selection called "Evolved Vs. Fighting System", a modified version of earlier systems seen in other Marvel/Capcom and Capcom vs. SNK crossover games. It is the first game in the franchise to feature three-dimensional character models as opposed to two-dimensional sprites, though gameplay remains restricted to two-dimensions, allowing characters to move only backward, forward, or straight up into the air. Unlike Marvel vs. Capcom 2, which featured four attack buttons separated as two pairs of low and high-strength punches and kicks, Marvel vs. Capcom 3 uses a simplified, three-button control scheme of undefined low, medium, and high attacks modeled after Tatsunoko vs. Capcom: Ultimate All-Stars, which Capcom believes will "knock down the wall of complicated controls and open up the field of strategic fighting to all comers", as well as a new "Exchange" button used to launch opponents into the air, switch characters while performing a combo, and slam the opponent into the ground when used by certain characters. Players can use each button to string together combination attacks, as well as perform special moves using a combination of button presses and joystick movement. As characters attack, their Special Gauge fills with energy which can be expended by the player to execute powerful Hyper Combos and Team Combos that involve multiple characters.
The game features a single-player story mode that is more robust than its predecessors, with unique endings for each character. Marvel has stated that Marvel vs. Capcom 3 is "all about fan service", and plan to work with Capcom to include dialogue quips and mid-match events between the company's characters that reference past Marvel Comics storylines. Marvel vs. Capcom 3 will include an online play mode using Microsoft's Xbox Live and Sony's PlayStation Network services.
Väga ootan seda, MVC2 on fun ja see tuleb arvatavasti sama hea. (Ja treilerit vaadates kukkus suu ammuli) _________________ M: Heavenly Sword, Eternal Sonata (PS3), Legaia 2: Dual saga, Blazblue Continuum Shift (Limited Edition, PS3), Golden Sun: The Lost Age, Final Fantasy X-2
Suht julm, kui palju häid tegelasi lisatakse. Chris, Amaterasu, Thor ja Dante kasvõi.
Ainus asi, mis praeguses vormis ei meeldi on see, et need teamup combod on liiga kirevad. 2D mängus oli kõik arusaadav, kus rünnakud lähevad - sprited noh... siin aga suur virrvarr käib.
See, Tekken X SF, SF X Tekken, NarutoUNS2, SF3 Online, Blazblue continuum shift.. Fighteritest vist puudust ei jää _________________ M: Heavenly Sword, Eternal Sonata (PS3), Legaia 2: Dual saga, Blazblue Continuum Shift (Limited Edition, PS3), Golden Sun: The Lost Age, Final Fantasy X-2
Zero ka announciti just hiljuti, väga epic! Nii palju lahedaid tegelasi lihtsalt _________________ M: Heavenly Sword, Eternal Sonata (PS3), Legaia 2: Dual saga, Blazblue Continuum Shift (Limited Edition, PS3), Golden Sun: The Lost Age, Final Fantasy X-2
Capcom on oma veebruaris ilmuvas superkangelaste võitlusmängus "Marvel vs Capcom 3" võtnud luubi alla ragequitterid. Tegemist on vana tulemuste jälgimise süsteemi edasiarendusega. Nagu paljude teiste mitmikmängude puhul, salvestab ka "Marvel vs Capcom 3" süsteem mängija võidud ja kaotused. Ühtlasi jälgitakse ka seda, kui tihti ning millal lõpetad mängu.
Näiteks kui oled vastasmängijalt liiga mitu korda jalga näkku saanud ning otsustad, et viitsi mängu lõppu oodata ja katkestad ühenduse, salvestatakse see automaatselt kaotusena ning talletatakse ka see, et lõpetasid võistluse enneaegselt.
Kui lahkuda mängust enneaegselt paar korda ei juhtu midagi. Kui aga ragequittimine muutub mõne kasutaja puhul harjumuseks, tuvastab süsteem selle üsna varsti ning tulevikus määratakse mitmikmängus mängijale vastaseks samasuguste mänguharjumustega isikud (ehk teised ragequitterid).
Teoorias peaks Capcomi lahendus tegema kõigile tavalistele mänguritele ainult rõõmu ning suunama ragequitterid teiste omasuguste hulka. Kas ja kui hästi see süsteem tegelikult toimib, saame teada alles veebruari teisel poolel, kui "Marvel vs Capcom 3" jõuab ametlikult poelettidele.
