7 :: |
364 |
sant
10.05.2010 20:18:23
Lahe, mulle meeldivad kvantarvutid, kahjuks siin tegemist siiski ühe molekuli peal töö jooksutamisega, seal mainiti ära kah et praegu aint ühe molekuli peal saabki jooksutada, ja niipea neid kokku liita ei saa Lisaks sellele info sisestamiseks ja lugemiseks vajalik tehnika on paras ulme, praegu.
Arvasin et ma oskan inglis keelt
The physics underlying the algorithm is simple and elegant. The vibrational mode of a diatomic molecule, when excited close to equilibrium, approximates an isolated harmonic oscillator. If the molecule is well isolated from its environment, and at a low temperature, the oscillator experiences very little decoherence either from collisions, or by the coupling of the vibrational and rotational motion, so that the unitary evolution necessary for the effect is dominant.
Allikas: http://physics.aps.org/articles/v3/38
_________________ So, at the end of the day, after I have butchered all the nvidiots all around me, standing alone in a pool of blood surrounded by the corpses of my victims, a horrible truth reveals itself to me: I am an amd\ati fänboy...and I must do my dark masters bidding, for I am damned for all eternity... |
| Kommentaarid: 68 loe/lisa |
61 |
rixvilll
12.05.2010 10:40:30
Kunagi oli teler kah ulme, rääkimata arvutitest, mille andmekandjateks perfokaardid , see mis täna on meie jaoks ulme, on meie lastele igapäevane nähtus.
_________________ regret all the things i have done wrong... |
| Kommentaarid: 32 loe/lisa |
24 |
Auron
13.05.2010 06:53:40
| Varsti Quad-Molekul proZed
133 |
kalluka
13.05.2010 20:54:24
AMD Molecule II
Six core Molcecule Processor BangforBuck
Intel i7 990m
12 core Molecule Processor from Intel
Sellist asja ei eksisteeri.Nali!
See on arvata ,et Amd teeb seda kindlasti odavamalt aga arvata ka seda ,et uute molekul protsessoritega tuleb palju jagelemist õiguste ja patendidega.Ilmselt tekib mõni uus proze tootja ka .Tore oleks kui Eestis .Pilud krt neil veab.
| Kommentaarid: 16 loe/lisa |
12 |
maxsimiljo
16.05.2010 09:19:23
| Kuidas molekul arvutab?
| Kommentaarid: 28 loe/lisa |
28 |
Etsike
16.05.2010 09:51:03
| maxsimiljo kirjutas: |
| Kuidas molekul arvutab? |
Oskad vist isegi arvata, et seda meist täpselt ei tea keegi. Ja need kes teavad ei suudaks seda isegi 1000 lehekülje abil lihtsurelikule selgeks teha. Seda ikka tead kuidas tavalised protsessorid "arutavad"?
| Kommentaarid: 77 loe/lisa |
69 |
Chaza!
18.05.2010 10:58:36
Lähen ostan apteegist joodi.
_________________ Linux - Future
1984 was not supposed to be instruction manual |
| Kommentaarid: 59 loe/lisa |
53 |
bratwurst
02.06.2010 20:14:35
Suht ulme ju. Kuhu me omadega välja jõudnud oleme? Varsti võtavad robotid ka toas tolmu ja pesevad pesu...
_________________ Mis toimub? |
XYZ
03.06.2010 08:06:40
| bratwurst kirjutas: |
| Suht ulme ju. Kuhu me omadega välja jõudnud oleme? Varsti võtavad robotid ka toas tolmu ja pesevad pesu... |
Kui sa oled miljardär, siis jookse kohe ostma. Pole vaja oodata ühti...
| Kommentaarid: 81 loe/lisa |
12 :: |
56 |
Renka
03.06.2010 11:03:56
Mõnetuhandekroonise väljamineku jaoks on vaja olla miljardär?
61 |
XYZ
03.06.2010 11:15:14
| Renka kirjutas: |
Mõnetuhandekroonise väljamineku jaoks on vaja olla miljardär?  |
Pesu pesev robot juba nii odavaks muutunud? Ma olen tõesti tähelepanematuks muutunud
12 :: |
56 |
Renka
03.06.2010 11:39:39
XYZ, palju siis pesumasin maksab sinuarust?
61 |
XYZ
03.06.2010 11:49:36
| Renka kirjutas: |
XYZ, palju siis pesumasin maksab sinuarust?  |
Sa sead võrdusmärgi lihtsa pesumasina ja roboti vahele
pesumasinasse peab ju omanik ise pestava sisse panema jne.
12 :: |
56 |
Renka
03.06.2010 11:51:35
| XYZ kirjutas: |
| Renka kirjutas: |
pesumasinasse peab ju omanik ise pestava sisse panema jne. |
Mis veel hullem - omanik peab kõigepealt ise pesu ka seljast võtma
Tahad väita, et pesumasin ei olegi robot mis peseb pesu? Kust see piir siis läheb?
61 |
XYZ
03.06.2010 12:00:59
| Renka kirjutas: |
| XYZ kirjutas: |
| Renka kirjutas: |
Tahad väita, et pesumasin ei olegi robot mis peseb pesu? Kust see piir siis läheb? |
No ma ikka kujutasin ette, et omanik võtab riidetüki seljast ja lihtsalt annab selle robotile-majateenijale. See vaatab ise millal paras kogus, et pesemine ette võtta ja pärast paneb puhta ja triigitud rõivaeseme teiste puhaste asjade hulka (taas)kasutust ootama.... Jaapanis on selline asi juba reaalsus, ainult roppkallis on meiesuguste jaoks taoline majateenija.
12 :: |
56 |
sosssepp
03.06.2010 12:05:47
Ilmselt loodetakse midagi sellist, mis käib mööda elamist ringi ja korjab kokku vedelema jäetud riided, analüüsib kas vajavad töötlust (kui jah, siis toimub vajaliku pesuprogrammi ja -vahendite tuvastamine, pesu, pesu õnnestumise kontroll, kuivatus, triikimine) või võib otse kappi õigele aadressile paigaldada eelnevalt riideeseme nõuetele vastavalt kokku lappides. Ning kui mõni pesu- või loputusaine otsa peaks saama, tellib netist uue täitepakendi ning läheb võtab selle saabumisel ise kullerilt vastu ka
| Kommentaarid: 87 loe/lisa |
75 |
XYZ
03.06.2010 12:09:18
| sosssepp kirjutas: |
Ilmselt loodetakse midagi sellist, mis käib mööda elamist ringi ja korjab kokku vedelema jäetud riided, analüüsib kas vajavad töötlust (kui jah, siis toimub vajaliku pesuprogrammi ja -vahendite tuvastamine, pesu, pesu õnnestumise kontroll, kuivatus, triikimine) või võib otse kappi õigele aadressile paigaldada eelnevalt riideeseme nõuetele vastavalt kokku lappides. Ning kui mõni pesu- või loputusaine otsa peaks saama, tellib netist uue täitepakendi ning läheb võtab selle saabumisel ise kullerilt vastu ka  |
Ja kordan veelkord, see ei ole enam mingi ulme, vaid reaalsus.
12 :: |
56 |
Lukksepp
03.06.2010 12:19:10
XYZ, tood ehk mõne näite?
See molekuli asi võiks nüüd hullult areneda ja jõuda ka tava inimeste taskutesse ja kodudesse.
96 |
XYZ
03.06.2010 12:57:31
| Lukksepp kirjutas: |
See molekuli asi võiks nüüd hullult areneda ja jõuda ka tava inimeste taskutesse ja kodudesse. |
Näiteid võid lugeda Forte artiklite hulgast.
Viimane robotite suutlikust puudutav artikkel oli küll tsipa tulevikku aga siiski - robotkoloonia kuul, kus nad saavad ülesande endale baas ehitada, saavad loa teatud autonoomseks tegvuseks jne.
Ka juba olemasolevate lahenduste kohta on olnud artikleid, nende ülesotsimine on vaevarikkam, kuna osa avaldati juba aasta, paar tagasi : juttu oli vanurite hooldamisest, laste abistamistest jne.
12 :: |
56 |
aixi
