rixk
28.02.2010 23:55:29
Wings of Prey |
http://www.airwargame.com/eng/start/
Selline huvitav lennusimu on väljas juba mõni kuu. Sobib nii algajale lendajale, samas pakub pinget ka tõsisele simulatsiooni huvilisele.
Ei hakka jalgratast leiutama, teen lihtsalt copy-paste mängu kirjeldusest.
Wings of Prey is based around the large-scale aerial combat and ground military operations of World War II. Players can participate in some of the war’s most famous battles piloting fighters, battle planes and bombers across a range of thrilling missions. There are six theatres of war to engage in – The Battle of Britain, Stalingrad, Ardennes, Berlin, Sicily and Korsun' representing the main airborne battles of World War II in Europe.
Wings of Prey also boasts an all new damage effects engine as well as advanced environmental visuals enriching the game play. Wings of Prey features hundreds of airplanes taking part in air battles. The unique environmental engine also produces highly detailed, realistic landscapes that allow players to see breathtaking ground support actions.
* Authentic World War atmosphere: Cutting edge technologies with highly detailed visuals bring the epic battles to life;
* Engage in more than 50 missions from famous historical battles over Eastern and Western Europe;
* Historically accurate aircrafts: Experience over 40 planes including fighters, battle planes and bombers. Learn to master Spitfire, Mustang, Messerschmitt and many more;
* Flexible difficulty level system: from arcade to realistic simulation;
* Support of 6-DOF TrackIR, TripleHead2Go, Saitek and Thrustmaster joysticks, mouse and voice headsets;
* Thrilling multiplayer: 4 game modes to choose; VoIP, lobby game system, leaderboards, friends lists, join-in-progress and host migration features provide great experience;
* Realistic sound effects and original music from Jeremy Soule.
Kommentaarid: 35 loe/lisa |
angel
01.03.2010 00:10:33
Kena demo oli asjal, graafiliselt etc aga veel kenam "lisa soft" on asjaga kaasas -> http://forums.steampowered.com/forums/forumdisplay.php?f=824
mõned väidaks nagu kah et mingi aeg lubatakse uuesti "aktiveerida" aga kui korrad otsa saavad siis võid seenele minna...
... ja see ei ole veel kõik. Väidetavalt mingi Yuplay junni saab kah külge.
Tundub asjalik aga loodaks, et ehk tuleb midagi asjalikumat kunagi välja ilma igasugu huvitavate lisanditeta nagu vanasti oli
Kommentaarid: 175 loe/lisa |
157 |
rixk
01.03.2010 00:25:07
See DRM ja Yuplay klient jah tekitavad paksu verd foorumites. Samas ütlen ausalt, et asi pole nii hirmus, kui seda ette kujutatakse. Kuigi jah, vähe tüütu on küll.
Steamis on üks kasutaja viitsinud detailselt kirja panna, et mis siis "juhtub" kui selle mängu ära ostad.
http://forums.steampowered.com/forums/showthread.php?t=1163443
angel
01.03.2010 00:48:04
mnjah aga minuarust ei oleks vaja sellist ajuvabadust korraldada... + ma isiklikult vihkan igasugu lisa softi mida peale lastakse... stiilis a'la GTA 4
Ise arvatavasti ostan mängu siis lõpuks ära (algselt plaanisin konsoolile osta aga tundub et hea et ostmata jätsin) kui asja hind kõvasti odavamaks läheb (vahepeal oli juba 50% laks seega loodan et ka 75% tulemata jää) ning kui mingit perversed DLC'd tulevad siis need kah seal odavalt sees oleks.
157 |
Evil14
28.05.2010 23:09:25
Keegi proovinud ka antud mängu?
Kommentaarid: 222 loe/lisa |
194 |
rixk
29.05.2010 12:56:57
Jep, mul on olemas see mäng. Samas on juba tükk aega sellest möödas, kui käima sai viimati pandud
destiny12
29.05.2010 12:58:37
Mõtlen samuti kas see endale soetada või mitte.
rixk, Miks ei mängi?
_________________ "Ära mine sinna, kuhu rada viib. Mine selle asemel sinna, kus rada ei ole, ja saa teerajajaks." |
Kommentaarid: 83 loe/lisa |
77 |
rixk
29.05.2010 13:10:14
destiny12 kirjutas: |
rixk, Miks ei mängi? |
Single player osa oli super, see sai läbi. Võrguosas oli jama see, et dedi servereid ei olnud..
Arendajatel oli dedicated serverid küll TODO listi sisse kirjutatud, aga ei oska öelda, kas need on valmis või mitte.
Nii et kui single player ainult huvitab, siis osta kindlasti. Kui võrguosale rõhku tahad panna, uuri kas on ikka P2P või mitte.
angel
29.05.2010 13:36:57
... jutud levivad et (mingi "pisseed off" komuun vms värk) mängu loojad lasid komuuni üle ja see mida lubasid ei tehtud ning nüüd vist teevad üldse uue mängu et otsast peale rahvalt raha saada... ning senikaua aga lüpsavad rahvalt raha välja DLC'dega.
Demo proovinud... üllatavalt hea näeb välja ning üllatavalt hästi optimiseeritud imo Kui sedasorti arcade ja simu võimalustega mängud meeldivad siis täitsa hää. Aga sellist "mööda raudteed" lendamist nagu ühes viimases "fighter" mängus nähtud ei ole seal mängus ehk siis Arcade on kah osade tootjate järgi vaadates "simu".
157 |
