uus teema   vasta Raud »  Mängukonsoolid ja konsoolimängud »  [PS3] SONY PlayStation 3 arutelu märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 285, 286, 287 ... 434, 435, 436  järgmine
Mihkel^^
Mihkel^^
sõnum 25.04.2010 16:31:28 vasta tsitaadiga
mul on korea versioon bad company 2, DLC ka korea oma aga miks ütleb, et kood vale?
Kommentaarid: 39 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 35
firemark
firemark
sõnum 25.04.2010 22:33:00 vasta tsitaadiga
xxlmaster kirjutas:
iDemon kirjutas:
xxlmaster - jah, on. 3D toega ekraani on tarvis.
Ja kas 3D "tugi" eeldas 120Hz monitori?
see oli minuteada jah miinimum nõue, soovitav oli 200hz, sis mõlemale silmale saab kuvada kiired kaadrid.
Kommentaarid: 102 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 93
sõnum 26.04.2010 00:16:22 vasta tsitaadiga
xxlmaster kirjutas:
iDemon kirjutas:
120Hz monitori, mis oskab ka vastavat signaali sisse süüa. Enamus praegu turul olevatest 200Hz telekatest ei oska üle 30p signaali süüa.
sõnum 26.04.2010 12:40:13 vasta tsitaadiga
Sony release new PlayStation 3 hardware
Sony has released a new version of the PlayStation 3 hardware. The new iteration features an improved version of the RSX graphics chip that uses 15 per cent less power and is less prone to the 'yellow light of death'.
The console is more power efficient and cooler to run than previous versions. Significantly for Sony it is also cheaper to produce. However, it is still unclear if the console is being sold at a profit - although the original version of the PlayStation Slim was believed to be close to break even.
As first discovered by website PlayStation University the hardware update features a 45nm version of the RSX chip, rather than the less efficient 65nm version originally released. The Cell chip has been 45nm in both iterations.
The console also now uses two 128MB XDR RAM chips instead of four 64MB chips and features a new cooling assembly and a lighter power supply.
Specified as the CECH-2100A, like most minor hardware iterations the new version of the console has not been publically announced or promoted by Sony.
pics: http://pocketnews.cocolog-nifty.com/pkns/2010/04/post-eed3.html
DF testis:
aise
aise
sõnum 26.04.2010 13:26:23 vasta tsitaadiga
oleks võinud ju mälu juurde panna ja RSX ka vähe kõrgema sageduse peale kruttida icon_biggrin.gif
Kommentaarid: 189 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 172
sõnum 26.04.2010 13:42:03 vasta tsitaadiga
sel poleks pointi
Cander
sõnum 26.04.2010 17:43:23 vasta tsitaadiga
Mälu lisamisel oleks mõtet küll - Live Stream jalgpalli näiteks ei suuda PS3 kanda telekaekraani peal kvaliteetselt üle..kogu aeg hakib..ja asi ei ole ülekandes, sest pildikvaliteet ja stream on vägagi normaalsed arvuti peal.
Kommentaarid: 39 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 34
sõnum 26.04.2010 18:28:37 vasta tsitaadiga
Cander, mäluga sel küll mingit pistmist pole.
Cander
sõnum 26.04.2010 21:08:21 vasta tsitaadiga
millega siis ?
scaryx
sõnum 26.04.2010 21:28:50 vasta tsitaadiga
Cander kirjutas:
millega siis ?
streamid arvutist? mis kiirusel, minul 1gb ruuter vahel, üle wifi hakkis mulgi icon_smile.gif
Cander
sõnum 26.04.2010 22:08:54 vasta tsitaadiga
ei, netijuhe läheb otse PS3-e. Nagu ennem mainisin, siis arvutist vaadates on kõik pravilno.
47th ronin
47th ronin
sõnum 26.04.2010 23:07:13 vasta tsitaadiga
ps3 mtu size on mis?
rgrds,
ronin, neljakümne seitsmes
Kommentaarid: 52 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 50
1dumbpcuser
sõnum 27.04.2010 11:25:46 vasta tsitaadiga
SKG kirjutas:
DF testis:
M: MSI B660M MORTAR
O: AM5 ITX emaplaat
beastbeats
beastbeats
sõnum 27.04.2010 13:24:12 vasta tsitaadiga
http://kotaku.com/5524889/ps3-remote-play-also-coming-to-pcs-vaio-pcs-at-least
MummikAl
MummikAl
sõnum 28.04.2010 22:54:43 vasta tsitaadiga
mis selle remote play mõte üldse on?
kas saab läpaka tagant mängida ka või niisama tühja menüüdes ringi vaadata?
Kommentaarid: 42 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 39
Mihkel^^
Mihkel^^
sõnum 28.04.2010 23:15:02 vasta tsitaadiga
FPS oleks suht ebaaus nii, arvuti peal palju parem sihtida ja värki
beastbeats
beastbeats
sõnum 28.04.2010 23:15:36 vasta tsitaadiga
http://en.wikipedia.org/wiki/Remote_Play
j2mm
j2mm
sõnum 29.04.2010 21:37:05 vasta tsitaadiga
Kas PSOne Classic'uid saab kopeerida ka PSP-lt PS3-le? Ning kas antud või siis PS3 -> PSP tegevuse jaoks peab olema mõlemas konsoolis sama kasutaja alt sisse logitud?
Kommentaarid: 88 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 72
beastbeats
beastbeats
sõnum 30.04.2010 00:51:02 vasta tsitaadiga
Ei pea; küll pead olema sisse loginud selle PS3 kontoga, millega mäng ostetud...
sõnum 30.04.2010 10:01:28 vasta tsitaadiga
Sony viidi kohtusse kollektiivse hagiga seoses OtherOS võimaluse eemaldamisega.
KrisVr
sõnum 30.04.2010 14:07:29 vasta tsitaadiga
Teenager Kills Brother Over PlayStation Argument
The BBC reports that a 16-year-old boy has been charged with killing his 18-year-old brother after he stabbed him in the chest for using his PlayStation.
While the two were home alone, the younger teenager is said to have flown into a rage after his older brother powered on his PlayStation without first asking his permission. The younger boy allegedly picked up a kitchen knife and plunged it into his brother's chest. The boys' adoptive mother was in Belgium. The two are said to have been abandoned by their biological mother and were in care for 10 years before being taken in.
The 16-year-old admitted to police that "things got out of hand," but he still faces five years in prison under the charges filed.
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 27
weasel
weasel
sõnum 30.04.2010 14:09:59 vasta tsitaadiga
ps3.planet.ee foorumiga keegi liitunud on? Liitumiseks peab saatma sms-i numbril xxxxx, kuid see on tasuline teenusnumber ja maksab 50 krooni. Hinnast pole nende lehel juttugi. Päris huvitav...
PSN: weaselEST
JoonasJJ
JoonasJJ
sõnum 30.04.2010 14:55:57 vasta tsitaadiga
weasel kirjutas:
Väga nõme raisk, ma ei saa aru, mis neil seal sisse läks. Ma regasin kohe alguses suht ja siis ei olnud küll mingit tobedat süsteemi seal.
Vajate abi auto müümisel?
KES TA ON? / YT: Junkman
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 55
zipzic
zipzic
sõnum 30.04.2010 15:39:35 vasta tsitaadiga
PS3 Planet foorumi reeglites summa ilusti kirjas - http://ps3.planet.ee/viewtopic.php?f=2&t=8 Paneme siis ka registreerimise selle sinna!
Tänu sellele sümboolsele summale on foorum elus, just saanud uue logo jms. Kellel käib summa üle jõu siis PS ja leiame lahenduse icon_wink.gif
veloo 🚲 söidame stiilselt!
Kommentaarid: 270 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 217
PeZ
sõnum 30.04.2010 15:49:57 vasta tsitaadiga
T4
sõnum 30.04.2010 16:27:21 vasta tsitaadiga
zipzic kirjutas:
Selle summa võiks kusagile registreerumise lehele lisada, kuna seal ka mingi tekst millega ma nõustuma pidin. Pmst asi näeb hetkel nii välja et liitun ära ja siis loen reegleid mida ma foorumis teha tohin/ei tohi ja seal siis naeratab kiri Tasuline.
See kõigest soovitus mitte mingi etteheide, tänan tähelepanu eest ! beer_yum.gif
Carl963
Carl963
sõnum 30.04.2010 17:44:32 vasta tsitaadiga
Kas Keegi Minuga Onlines Ei viitsi midagi mängida ? mul pole eriti inimesi kellel selliseid mänge on ... kui teil on mõni allpool mainitutest mängudest võiksite ühendust võtta icon_wink.gif . Operation flashpoint : Dragon Rising , Bioshock 2 , Far Cry 2 , Socom , Call Of Juarez BiB , TC's EndWar , SvR 2010 . beer_yum.gif
PSN : zlatake123-
V/M [PS3]: Tiger Woods PGA TOUR 10, NBA LIVE10, F.E.A.R2!!!
Inimene123
sõnum 30.04.2010 22:53:40 vasta tsitaadiga
Keegi Metal Geari ka veel online'is mängib? pole ammu ise näppe külge saanud aga hakkab isu tekkima küll.
Mängude arvustused
Raunts33
sõnum 01.05.2010 01:43:26 vasta tsitaadiga
Keegi eestlastest veel bondi ka onlines mängib? kui mängib lisage PSN'i: Rauntss, mängime koos icon_wink.gif
Jandre
sõnum 01.05.2010 04:22:03 vasta tsitaadiga
weasel kirjutas:
Liitu siis www.Konsool.eu -ga - täiesti tasuta ja alati!
Vaevalt sealt kohtust Sony kahjuks välja tullakse.
Kommentaarid: 64 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 62
(_)
sõnum 01.05.2010 10:09:20 vasta tsitaadiga
Tere
Kas ps3-el mälupulgalt läbi usb filme(ka bluraysid) saab vaadata?
ivokas
ivokas
sõnum 01.05.2010 10:24:47 vasta tsitaadiga
Saab. Mul endal 500GB väline ketas javäga gut kooslus.
Reisijate ja fekaali vedu kahekorruselise bussiga.
Praepelmeenid ja Vana Tallinn suudavad nii mõndagi muuta!
Carl963
Carl963
sõnum 01.05.2010 10:29:16 vasta tsitaadiga
zipzic kirjutas:
absurd ju . selle lehe ülal pidamine maksab 9 eeku kuus .
PSN : zlatake123-
ivokas
ivokas
sõnum 01.05.2010 10:35:58 vasta tsitaadiga
Pole suurem asi õnnetus kah, kui ühte konsoolifoorumisse kasutaja tegemata jääb.
1dumbpcuser
sõnum 01.05.2010 11:19:16 vasta tsitaadiga
Rendering 3D Slows Down PS3 Game Performance
TomsGuide
Eurogamer is taking a look at Wipeout HD, which runs in its original form on the PlayStation 3 at 1080p at 60 fps, but in 3D it gets moved to 720p at 30 fps. While the sacrifice in resolution and frame rate may be worth the 3D-ness for Wipeout HD, most games for the PS3 run at 720p. This would lead one to wonder if a current PS3 game running at 720p at 30 fps would become unplayable if it had to take on the task of making things 3D.
M: MSI B660M MORTAR
O: AM5 ITX emaplaat
InQbus
InQbus
sõnum 01.05.2010 13:27:14 vasta tsitaadiga
Oskab keegi öelda, kas PSN kaarte on võimalik kuskilt osta ka sedasi, et kood saadetakse näiteks emailile! Tean, et kui need alles müüki tulid, siis hmv.com pakkus sellist lahendust, kuid hetkel enam mitte.
Oleks vaja just naelu, kuna enamus mängud inglismaalt tellitud ja seega DLC peaks kah UK Storest ilmselt ostetud olema! Põmst saab game.co.uk-st tellida neid kaarte, aga lihtsalt leian, et mingi koodi shippimine ja postkiulude maksmine on veits mõttetu ja kui on alternatiive, siis parema meelega kasutaks neid.
PSN: InQbus
Labukana
Labukana
sõnum 01.05.2010 13:30:00 vasta tsitaadiga
shopto.net vist
Kommentaarid: 32 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 30
weasel
weasel
sõnum 01.05.2010 14:16:31 vasta tsitaadiga
InQbus, sealt ps3.planet.ee lehelt saab osta: http://ps3.planet.ee/viewtopic.php?f=25&t=263
Ise pole veel proovinud.
PSN: weaselEST
euforia
euforia
sõnum 01.05.2010 15:23:43 vasta tsitaadiga
http://www.punktid.ee/?psn on kah icon_wink.gif
xxlmaster
xxlmaster
sõnum 01.05.2010 16:03:27 vasta tsitaadiga
euforia kirjutas:
Misasja, US PSN 50 Dollar maksab 740 krooksu, kallis ei ole vähe v? icon_rolleyes.gif
T4
sõnum 01.05.2010 16:06:16 vasta tsitaadiga
arvatavasti euroopas seda kaarti ei müüda, hinna sees ka väike transport jne. kuidagi peab raha tegema icon_evil.gif
xxlmaster
xxlmaster
sõnum 01.05.2010 16:07:41 vasta tsitaadiga
T4 kirjutas:
nojah, eks ta vast neile ole kellel krediitkaarti ei ole. Ise vist ei ostaks elusees sellise hinnaga.
euforia
euforia
sõnum 01.05.2010 19:03:18 vasta tsitaadiga
Ise ei ole ma sealt ostnud, viimase kaardi ostsin koos mänguga Amazon'ist.
See link oli lihtsalt siit mingist varasemast vestlusest läbi käinud...
Schumi
Schumi
sõnum 02.05.2010 15:39:17 vasta tsitaadiga
Mai on jälle üks kuradi hea kuu mängude poolest, pean silmas just eksklusiive.
Ennekõike muidugi ModNation Racers - peaks tulema suurepärane kardimäng. Nagu Mario Kart, ainult et HD's ja märksa vaheldusrikkam tänu mängijate enda loominguvabadusele.
Teine mäng, mida ma isiklikult väga ootan, on 3D Dot Game Heroes. Mulle meeldib, kuidas nad püüavad klassikalise Zelda stiili taas ellu tuua. Graafika, gameplay ja muusika - kõik retro stiilis loob väga omapärase elamuse.
Anisse
sõnum 02.05.2010 21:39:51 vasta tsitaadiga
maist ootan ainult Red Dead Redemtpion (PS3, Xbox360)
ModNation Racers - arvatavasti soetamist väärib aga eks ta selline MarioKart HD on. Demot paar ringi sai mängitud - sõbra lapsele käis küll. Võib-olla tõesti on lisaväärtuseks isetehtavad tasemed a'la LBP
3D Dot Game Heroes - peab ikka tõeline mängufänn olema et selliseid kuubikuid HDs tänapäeval vaadata
aise
aise
sõnum 04.05.2010 10:59:43 vasta tsitaadiga
imelik värk on STV DNS nimeserveritega, kui kasutan neid siis loobib PSN´st välja suvalisel hetkel (näiteks võrgumängust), kui kasutan mõnda open DNS taolist siis kõik korras...
paanz
paanz
sõnum 05.05.2010 00:15:27 vasta tsitaadiga
InQbus kirjutas:
Saab ka kasutada UK sõbra/tuttava abi, kes sealset pangakaarti omab.
PSN: Paanz
Kommentaarid: 9 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 8
Mihkel^^
Mihkel^^
sõnum 05.05.2010 19:38:33 vasta tsitaadiga
millal skate3 tuleb eesti poodidesse müügile?
wunki
sõnum 06.05.2010 09:37:19 vasta tsitaadiga
http://electronicfirst.com/buy-psn-cards/playstation-network-cards-uk/
ise tellisin sealt - koos paypal kontotegemise ja rahakandmisega oli kood u 10 minutiga postkastis.
Ise kasutan ka just UK kontot ja £ kaarte
Kommentaarid: 77 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 73
scaryx
sõnum 06.05.2010 10:10:23 vasta tsitaadiga
paanz kirjutas:
InQbus kirjutas:
vaata siia, mina tellin siit, tasuda saab paypaliga ja mailile saadetakse kood ühe tunniga http://xboxliveuk76.com/
uus teema   vasta Raud »  Mängukonsoolid ja konsoolimängud »  [PS3] SONY PlayStation 3 arutelu mine lehele eelmine  1, 2, 3 ... 285, 286, 287 ... 434, 435, 436  järgmine
