uus teema   vasta Tarkvara »  Arvutimängude foorum »  The Bureau: XCOM Declassified märgi kõik teemad loetuks
mine lehele 1, 2  järgmine
The Man
The Man
sõnum 14.04.2010 20:20:57 The Bureau: XCOM Declassified vasta tsitaadiga
Vahepeal aastake varjusurmas olnud XCOM on tagasi uue nimega The Bureau: XCOM Declassified. Lubatakse taktikalist tulistamismängu. Välja tuleb 20. august 2013.
Set in 1962 at the height of the Cold War, The Bureau tells the origin story of the clandestine XCOM organization’s first encounter with a mysterious and devastating enemy. Originally established as America’s covert defense against the Soviet Union, The Bureau must adapt and overcome a threat unlike anything the world has faced before. As special agent William Carter, players will call the shots and pull the trigger, leading their squad of agents in the high-stakes secret war for humanity’s survival. Paramount to repelling the outside threat is The Bureau’s ability to cover-up the enemy’s existence in order to prevent worldwide panic.
In the spirit of the XCOM franchise, The Bureau’s calculated combat design requires players to think and act tactically. The game’s third-person perspective gives the player a sense of spatial awareness and grants them the freedom to transition in and out Carter’s unique Battle Focus ability seamlessly — heightening the tactical shooter action. The Bureau also fully embraces the concept of permanent consequence. As our last line of defense, every command can mean the difference between life and death for Carter, his squad and mankind.
Värske live action trailer:
Vana info:
Press A to disagree.
<Too late!>
viimati muutis The Man 26.04.2013 17:26:40, muudetud 3 korda
muff
muff
sõnum 15.04.2010 10:24:06 vasta tsitaadiga
Ma ütleks siia juurde, et UFO:Extraterrestrials toodab hetkel teist osa ning sellest peaks midagi head tulema. X-Com fpsina kisab feili järgi. Nagu see X-Com : Enforcer - luls icon_biggrin.gif
Fukiku
Fukiku
sõnum 15.04.2010 19:06:12 vasta tsitaadiga
Ühe vihase mehe arvamus sellest jamast
Foxic is just a simple fox
Enne kui sa küsid oma küsimuse - küsi seda vannipardilt! Rangelt soovitatav enne programmeerimise alafoorumisse uue teema tegemist.
DigeBeni
DigeBeni
sõnum 16.04.2010 10:13:26 vasta tsitaadiga
... natuke liiga palju verist vahtu aga eks mõnes mõttes võib ka aru saada, inimesed on juba tüdinud neist kommertslaipadest, mida üha uuesti elustada üritatakse aga tulemused on siiski väga keskpärased või pahatihti isegi kõvasti alla selle ...
DeTHiCa.
DeTHiCa.
sõnum 26.04.2011 13:35:07 vasta tsitaadiga
koperdasin selle otsa täna:
http://www.wired.com/gamelife/2010/06/xcom-impressions/
2010 treiler:
dev interview:
Kommentaarid: 145 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 137
DigeBeni
DigeBeni
sõnum 26.04.2011 14:47:23 vasta tsitaadiga
... originaalset XCOM'i ei meenuta küll eriti millegi poolest, kuid teatud omapära tundub asjal siiski olevat, eks näis ...
DeTHiCa.
DeTHiCa.
sõnum 26.04.2011 15:31:50 vasta tsitaadiga
eks ta bioshock stiilis tule. juba visuaalselt tundub selline art style olevat, mitte just realismi poole sihitud (vaadates millised tegelaste näod videos olid).
tegijad ju samad.
Kruvi
sõnum 27.04.2011 10:51:23 vasta tsitaadiga
Art style väga ei meeldi, mäng ise tundub huvitav aga pole tükk aega mingit infot näinud.
Ehk E3
DeTHiCa.
DeTHiCa.
sõnum 08.06.2011 23:24:25 vasta tsitaadiga
ei näidatud midagi huvitavat E3'l, peale selle:
The Man
The Man
sõnum 26.08.2011 21:04:24 vasta tsitaadiga
Päris pikk ja korralik gameplay walkthrough E3'lt, värkelt avaldatud kõigile:
Tundub lihtne tulistamismäng, aga see ei ole tingimata halb asi. 60-ndate stiil on lahe.
<Too late!>
DigeBeni
DigeBeni
sõnum 02.09.2011 14:22:02 vasta tsitaadiga
... tjah, kuigi atmosfäär ja ajastu on intrigeerivad, oleks lootnud natuke mitmekesisemat mängulahendust icon_rolleyes.gif aja aeglustamise efekti ekspluateerimine hakkab juba tõsiselt ära tüütama ja tundub rohkem lihtsama vastupanu teed minekuna arendajate poolt, kui hea lahendusena, mida kõlbab pea igas teises mängus kasutada. Ma oleks oodanud RPG/strateegia elementide lahendust just läbi klassikalise strateegia vaate, oleks märksa mugavam hallata ja kombineeritult FPS vaatega annaks võrreldamatult mitmekesisema mänguelamuse. Tõenäoliselt on praeguse lahenduse kasuks otsustatud just konsoolimängurite pärast, kelle armastatud juhtkonsoolid ei võimalda strateegiat PC mänguritega samaväärselt nautida, kahju ...
The Man
The Man
sõnum 26.04.2013 17:28:51 vasta tsitaadiga
Esialgne lihtsalt XCOM nimetati ümber ja reliisi aeg pandi lõpuks paika, lisaks tuli välja värske trailer. Tundub igati hea asi tulevat.
<Too late!>
Goon
Goon
sõnum 26.04.2013 22:33:34 vasta tsitaadiga
See mäng võib väga hea tulla aga võib ka väga kergesti metsa minna kui baasis toimetamist liiga vähe on ja tulistamist liiga palju
PILTE:
Ertai
Ertai
sõnum 26.04.2013 23:37:34 vasta tsitaadiga
No tihti sõltub siiski AIst, kui sama sitt kui Colonial Marines'il siis on pekkis icon_smile.gif
Kommentaarid: 51 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 47
libe
kvaliteetne mees
libe
sõnum 19.08.2013 17:43:33 vasta tsitaadiga
Scart
Scart
sõnum 19.08.2013 20:01:01 vasta tsitaadiga
Destructoidi revüü lekkis.
4.5/10
Goon
Goon
sõnum 19.08.2013 21:14:38 vasta tsitaadiga
Scart kirjutas:
4.5/10
Karta on ... Nii palju kui ma lugenud/näinud ja teiste xcomi fännidega rääkinud, siis asi on ikka väga mööda. Xcom ei tohiks olla selline mäng kus võtad maast tulnukate relva ja hakkad kohe nottima sellega ...
libe
kvaliteetne mees
libe
sõnum 23.08.2013 23:36:31 vasta tsitaadiga
pelanud nüüd natukene ja minu jaoks on väga palju sarnasust enemy unknowniga ja palju tuttavat
lugu on sellel pelal sujuvam ja paeluvam
AI rapsib palju, isegi kui korraldused anda, siis mingihetk avastan, et mehed on uitama läinud
25€ eest pela küll ja oleks rohkemgi, kui varasemalt poleks enemy unknowni ostnud
surfasin pisut ini failides ja seal on märkeid multyplayeri kohta, kuid pelas seda ei ole
tõenäoliselt läks tootmine lappama ja tõmmati tuimalt rubilnikut thumbs_down.gif
486
sõnum 24.08.2013 14:44:23 vasta tsitaadiga
Kas alien revli tuleb uurida enne kui täit võimsust teevad.? Ja abilityd tuleb ka kuskil enne arendada või saab need lihtsalt kätte?
Ja kui asine on see turnbased värk?
zero
libe
kvaliteetne mees
libe
sõnum 24.08.2013 14:49:14 vasta tsitaadiga
486 kirjutas:
see ei ole turn based pela
alien relvi saab kasutada peale leidmist ja ability'd saab lisada lahingväljal, kui piisavalt expi on
Killhoven
OC`er
Killhoven
sõnum 25.08.2013 11:14:38 vasta tsitaadiga
Hirmus monotoonsus: paar sammu astud - fight, paar sammu astud - järgmine fight samasuguste vastatstega. Mängu progresseerudes vastuakaaluks sinu meeskonna arengule lihtsalt topitakse rohkem samu vastaseid. Ma olen päris kaugele juba jõudnud, aga igavus on eemale peletanud. Lisaks häirib AI idiootsus - peab fighti ajal liialt neid kantseldama (osaliselt ma spammin F2 / F1). Graafika optimeering on kohutav. 4,5/10st on normilt antud.
Kommentaarid: 409 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 351
libe
kvaliteetne mees
libe
sõnum 25.08.2013 13:25:52 vasta tsitaadiga
graafika seadetest on vaja vaid mingi reflections disableda, et oleks pidev 60fps, isegi physixi kannatab seejärel peale laduda
samad vastased? kokku on pelas 17 eritüüpi vastaseid seitsmes klassis
http://xcom.wikia.com/wiki/Aliens_%28The_Bureau:_XCOM_Declassified%29
enemy unknownis oli 18 kümnes klassis
hea, et see mingi tesise maailmasõja pela polnud, oleksid vist igavusse surnud, kuna ainult inimesed vastas icon_rolleyes.gif
Ai idiootsused tulenevad su enda tegemistest. mängus on kindel tsoon, kus saad oma kaaslastele korraldusi jagada, kui sellest välja lähed, siis teevad isetegevusi.
muidugi vahetavad nad kaitsepositsioone automaatselt turvalisemate vastu, kui see nö sinine kilp punaseks muutub
kogu pela võib läbida ainult kaaslasi kasutades ja ise mitte ühtegi lasku tegemata.
küll olen näinud buge, kus kaaslased jäävad mingi ukse taha või kuhugi mujale kinni ja enda juurde kutsuda ei õnnestu, kuid natukene edasi liikudes "hüppavad" nad tagasi gruppi
samuti jäin ühes tasemes kinni, kuna justkui mingi vastane oleks veel kuskil olnud, aga reaalselt mitte - selletõttu aga uksed ei avanenud
pisemaid buge olen veel kohanud, aga need ei ole mainimist väärt
Killhoven
OC`er
Killhoven
sõnum 25.08.2013 15:10:56 vasta tsitaadiga
libe kirjutas:
Suurt sõltumata seadetest on fps ikka päris jama, hea kui 30. Juu sul siis ime masin kui 60 kätte saad. Kogu internet täis häda selle mängu FPS-iga. 17 tüüpi ja mis siis? Iga jumala madin on sul needsamad fking 4-5 tüüpi ainult vastas ja ülejäänud on uniigid korraks ehk ksukil mängus või videos näha. Jälle tee oma tavapärane etteaste..
Hakka mängima veterani peal ja lõpeta see Rookie chillimine. Veterani peal see AI kohatine debiilsus rikub tihti kogu lahingu ära (kui ei kantselda pidevalt) kuna teamikaaslaste surma saamist seal tasemel suurt lubada ei saa. Klassikaline näide on see, kui oled juba tükk aega madistanud, peaaegu on tehtud ja siis otsustab üks teamikaaslane lambist valelt poolt katet liikuma hakata - kastis - tee uuesti jälle.
lopes39
lopes39
sõnum 25.08.2013 15:13:50 vasta tsitaadiga
Vaatasin eile siis oma tunnike seda walkthrough-i et saada aimu millega mängus tegu on. Need väiksed sinised tulnukad kasutavad inimeste püstoleid ? ja kui neid punadeid kuule laskvaid tegelasi maha võtab, siis miks nende tulnukate relvi maast korjata ja kasutada ei lase.
Mulle sellised mängud ei meeldi kus pead mingi tiimiga tegelema, et pidev tegevus läheb selle peale, et paigutad oma mehi kuskile, et need kõik asja ära teeksid ja ise tulistada pmst ei saagi ja tundub et see mäng selline ongi terves pikkuses.
Ma pigem vaatan selle läbitegemis õppetusega vidoed terves mängu ulatuses ära kui ise mängima hakkaks.
Mul lihtsalt nii igav ja pole nagu hetkel ühtegi mängu mida mängida.
DigeBeni
DigeBeni
sõnum 25.08.2013 15:18:54 vasta tsitaadiga
... märksa hullem, kui oleks arvanud icon_confused.gif "advanced duck hunt - alien etition" oleks sellele mängule paras nimi icon_confused.gif thumbs_down.gif
uus teema   vasta Tarkvara »  Arvutimängude foorum »  The Bureau: XCOM Declassified mine lehele 1, 2  järgmine
