15.01.2007 10:02:13
USB buutiv linux i distro |
tere! sõbral tekkis küsimus sellise linuxi kohta mis oleks suuteline USB ist buutima ja kuidas sellist asja teha. Kuna otsing mulle olulist tulemust ei andnud guugeldasin suti ja leidsin teksti, mille sellisel kujul siia pistan, et otsingu kasutajad oma probleemi kiremini lahendada ning huvilised mõtteainet saaks. kogu lugu alljärgnevalt lingilt:
http://rz-obrian.rz.uni-karlsruhe.de/knoppix-usb/ Loodan, et keegi mulle väga valusasti lõuga ei anna ning mõni hädas kodanik selle teema leiab.
tänud.
Boot KNOPPIX from an USB Memory Stick
What you'll need:
* Knoppix or an already stripped down version
* USB Memory Stick
* Computer capable of booting from USB
* kernel with cloop-support
* syslinux
Preparing everything:
I used Damn Small Linux for this (it's only 51MB and has fluxbox , but every other stripped down Knoppix version should do (if you have enough space on your memory stick).
You can also strip down your own version of knoppix (see the Knoppix Customising FAQ).
Modifying miniroot.gz:
First you need to modify the boot-image (KNOPPIX/boot.img). Mount it (mount -o loop boot.img /mnt) and copy everything in a directory (e.g. ~/knoppix-usb/bootdisk). You need to modify linuxrc in miniroot.gz and put the relevant usb modules in modules/usb/.
Now use gunzip to uncompress miniroot.gz and then mount it (mount -o loop miniroot /mnt). Open linuxrc with your editor. You need to load the relevant usb-modules and make sure to sleep some time, because the modules need some time to recognize your USB Memory stick. I put the relevant parts before the scsi modules are loaded to make sure, that my USB Memory Stick will be /dev/sda:
# load usb-modules first (so that memory-stick becomes /dev/sda1)
# uncomment for USB 2.0 support (experimental)
#insmod -f /modules/usb/ehci-hcd.o
insmod -f /modules/usb/usbcore.o
insmod -f /modules/usb/usb-uhci.o
insmod -f /modules/usb/uhci.o
insmod -f /modules/usb/usb-ohci.o
insmod -f /modules/usb/usb-storage.o
# need to sleep because it takes some time to register things
ash -c "sleep 4"
Now you need to make sure, that your root-fs is mounted to /cdrom: I commented out the section in linuxrc where a CDROM is searched and put the following lines in:
# mount /dev/sda1 (memorystick to cdrom)
FOUND_KNOPPIX="/dev/sda1"
mount -t vfat /dev/sda1 /cdrom
You can get my modified linuxrc here http://rz-obrian.rz.uni-karlsruhe.de/knoppix-usb/linuxrc
Now we still need the usb modules (that aren't on the miniroot). Mount the compressed KNOPPIX file (insmod cloop file=PATH/KNOPPIX && mount -t iso9660 /dev/cloop /cdrom) and copy the following files under /cdrom/lib/modules/$KERNELVERSION/kernel/drivers/usb/ to /mnt/modules/usb/:
ehci-hcd.o uhci.o usb-ohci.o usb-storage.o usb-uhci.o usbcore.o
Now you're finished modifying miniroot. Umount it and gzip the file again.
Preparing the Memory Stick
Create a fat-partition on your stick and format it with mkfs.vfat
Mount the memory stick
Copy the files from ~/knoppix-usb/bootdisk/ on the memory stick (that should include your modified miniroot.gz)
Copy the other files from your modified knoppix to the memory stick (the most important is KNOPPIX/KNOPPIX)
The layout on your Memory Stick should look like this:
sh-2.05b# ls -lR
total 1576
-rw-r--r-- 1 root root 54 Apr 27 12:48 autorun.bat
-rw-r--r-- 1 root root 47 Apr 27 12:48 autorun.inf
-rw-r--r-- 1 root root 180 Apr 27 12:48 boot.msg
-rw-r--r-- 1 root root 1759 Apr 27 12:48 f2
-rw-r--r-- 1 root root 256 Apr 27 12:48 german.kbd
dr-xr--r-- 2 root root 4096 Apr 27 12:48 knoppix
-rw-r--r-- 1 root root 3262 Apr 27 12:48 knoppix.ico
-r--r--r-- 1 root root 7836 Apr 27 12:51 ldlinux.sys
-rw-r--r-- 1 root root 34395 Apr 27 12:48 logo.16
-rw-r--r-- 1 root root 607866 Apr 27 14:03 miniroot.gz
-rw-r--r-- 1 root root 2402 Apr 27 12:48 syslinux.cfg
-rw-r--r-- 1 root root 921602 Apr 27 12:48 vmlinuz
./knoppix:
total 50820
-rw-r--r-- 1 root root 2048 Apr 27 12:48 boot.cat
-rw-r--r-- 1 root root 1474560 Apr 27 12:48 boot.img
-rw-r--r-- 1 root root 50553629 Apr 27 04:48 knoppix
-rw-r--r-- 1 root root 27 Apr 27 12:48 mkfloppy.bat
Now you need to get the Memory Stick bootable: umount it and run 'syslinux /dev/sda1' (or /dev/sd?1 depending on your system).
The ugly part: booting
If you're lucky your computer will boot out of the box when you select USB ZIP as a bootdevice. Otherwise read on...
* You can try the other USB Boot Options (Floppy, CD-ROM, Harddisk), if still nothing happens you might have to enable USB Keyboard Support in your BIOS (needed on some motherboards with AMI BIOS and a Via chipset, including Epia-m and Shuttle mv42n).
* On some broken boards (like my Epia-M...) you need to plug the memory stick in without any power (remove your power plug), otherwise the BIOS might not recognize the memory stick.
* If your BIOS boots from the Memory Stick, but you can see only sequences of ones and zeroes, you can try an alternative bootsector from spblinux. http://www.8ung.at/spblinux/ As the site is sometimes down you can download the bootsector here http://rz-obrian.rz.uni-karlsruhe.de/knoppix-usb/spb2_mbr.sec (Version 1.01). Just put this one on /dev/sda and try it out (dd if=spb2_mbr.sec of=/dev/sda). Many thanks to Christian Ostheimer for his great work (I didn't believe anymore in booting from USB, but his spblinux made it possible
You can get my modified Damn Small Linux here (52 MB) http://rz-obrian.rz.uni-karlsruhe.de/knoppix-usb/damnsmall-0.3.6-usb.tar
Comments to: Matthias Müller
| Kommentaarid: 1159 loe/lisa |
725 |
marqs
15.01.2007 18:31:33
sul jäi viimane rida pasteerimata
| Last update: Sun Jun 1 20:45:48 CEST 2003 |
knoppix kandis siis versiooninumbrit... umm.. ma ei teagi. igatahes praegusest 5.1.1'est midagi hulka väiksemat.
alates 5.0.1'est võiks see tekst - http://www.knoppix.net/wiki/Bootable_USB_Key - täitsa kehtida. asjal ainult miinus küljes, enne vaja knoppix plaadi sisse kirjutada. (vmware ju ei saa usbi seadmetele hirm-otse ligi? või saab?)
laisematele pakub http://pendrivelinux.com/ usb-pulga versioone Knoppixist, DSList, Slaxist ja PCLinuxOSist. aga jälle miinus küljes: sealne bootladeri paigaldaja toimib ainult winis ja vajab .Net'i. ma tegeilikult isegi ei viitsinud uurida, mida too .neti jupp teeb, kui ta on lihtsalt graafiline liides syslinuxile ( http://syslinux.zytor.com/ ) saab ka ilma selleta hakkama.
silmad-kõrvad lahti hoida, siis leiab mõnel live-distrol/knoppixi kloonil veel usb-pulga tõmmiseid ja sisu. näiteks http://featherlinux.berlios.de/usb-instructions.htm
_________________ 0xDEAD
0xBEEF |
| Kommentaarid: 28 loe/lisa |
kurask
06.04.2010 08:39:57
Ma kirjutaks siia teemasse otsa:
Mul on knoppixi miniroot.gz mis boodib risist/wdsist, vaja oleks sellesse lisada custom võrgu drivereid. Sest muidu ta ei oska ju minna võrku nfs serveri peale knoppixi iso sisu küsima.
Ehk siis küsimus, kuidas lisada knoppixi miniroot.gz sisse võrgukaardi drivereid?
edit: ise olen wini pede noh...><
| Kommentaarid: 69 loe/lisa |
65 |
Strix
13.04.2010 10:42:40
Ise kasutanud enamus linuxite puhul Unetnootingut.
Näiteks backtrack 4 final-i pani ilusti usb-i pealt bootima ning peaks hakkama saama ka enamus OS-idega.
http://unetbootin.sourceforge.net/
| Kommentaarid: 26 loe/lisa |
26 |
Tint
13.04.2010 11:46:56
Siin räägitakse linuxist mis oleks suuteline usb pealt buutima ja kuidas seda teha. Olen ise kasutanud järgmist varianti ja pole mingeid probleeme.
lae iso alla, windowsi all, winega või virtual machines avad programmi ja see toimetab ise kenasti sul kõik valmis:
Universal USB Installer – Easy as 1 2 3
| Kommentaarid: 34 loe/lisa |
31 |
Strix
13.04.2010 22:27:51
| Minu pakutud variant on täpselt sama.
26 |
