| Millises serveris ja miks hakkad mängima? |
| PVP, sest ... (täpsustan teemas) |
42% |
[ 29 ] |
| PVE, sest ... |
25% |
[ 17 ] |
| RP, sest ... |
2% |
[ 2 ] |
| RP-PVP, sest ... |
10% |
[ 7 ] |
| Vahet pole, sest ... |
19% |
[ 13 ] |
| hääli kokku : 68 |
ready
26.03.2010 22:37:44
| Rääkides kullast on üks noob küsimus. Need asjad mis ma questides saan aga mulle ei ole vajalikud aga on soulbond või midagi sellist,näitab nagu nende AH hinda, kuid oksjonile panna ei lase. Kas neid siis saab ainult prahi pähe vendorile müüa?
veso
26.03.2010 22:56:37
| Jah või disenchantid nad katki ja saad selle eest mingeid kivikesi ja pulbrit millega saad teisi esemeid enchantida.
Ho Ho
27.03.2010 10:33:51
Sommid said siis esimesena maailmas LK25 heroicu maha
”This is definitely the most challenging boss in WoW history, and I’ve been there among the first to kill Horsemen in Naxx-40 and whatnot. Everything else up to this point pales in comparison. The encounter is extremely ruthless in the sense that anyone making a mistake will almost instantly lead to a raid-wide wipe. The fight itself requires almost 20-minutes of full-on concentration coupled with very high personal skill-level.
Quite simply the perfect end-boss to finish the expansion with, couldn’t have hoped for more. My hat is off to Blizzard on this one. I can’t wait to see if this encounter can be outdone in Cataclysm.” |
86 |
veso
27.03.2010 16:20:40
Tublid soomlased
Button
28.03.2010 15:08:49
heh, selle g tegemisega on ka nii kuis on, kui viitsimist on siis teed, siis jälle nädal v rohkem ei viitsi vaeva nähe
praegu istub kahe charri peal kokku miski 100k ,noh samas pole ostnud epic kalleid mounte ega midagi
battered hilti müüsin 16k g
icc weekly quest droppis ring of rotting sinew vms,,,, another 16k,,
flaske on andnud fellow alchemy viimased pool aastad
sama gemmidega.
ja muu pahn tuleb gildi pangast, enchantid food etc
| Kommentaarid: 28 loe/lisa |
Kristoferr
| Kommentaarid: 266 loe/lisa |
217 |
Timberg
ööKARU
28.03.2010 18:44:52
| Cataclysme date kohta pole veel midagi öeldud?
272 |
Confector
28.03.2010 21:00:21
| Kristoferr kirjutas: |
Button, hästi elame  |
Nojah, vähemalt pole wowis masu.
| Kommentaarid: 10 loe/lisa |
10 |
Kristoferr
217 |
Zanzhu
28.03.2010 23:00:21
Pole aega?
Sebi RAF 0-60 in 60 seconds.
Siis heirloomid selga ja 6-9 päevaga on 80.
10 |
Ho Ho
28.03.2010 23:14:55
Mis mõttega sa L80'ks ennast boostida üritad kui mängida aega pole? Või siis juba 80 olles see aeg tekib kusagilt?
86 |
Kristoferr
28.03.2010 23:27:09
Äkki küsid kas mul oma naist panna on ikka aega? Võibolla pakud abigi?
Mis see su jaoks muudab, kui palju ja mille jaoks mul aega on.
Zanzhu, Eks ma nii vaikselt lasengi. RAF küll ei kasuta. Hunter lvl 48 hetkel.
PS. WoW (login) server vist maas? Ei suuda sisse logida. Jääb success-->connected tiitlile.
_________________ Liitu Opencode Go soodsa coding plaaniga ja saa 5€ soodust!
Liitu Wise'ga! |
217 |
eShelobik
29.03.2010 00:29:27
ma arvatavasti pooks ennast hiire kaabli külge üles kui ma peaksin veel mõne chari 1-80 leveldama. ehk siis 80 peal mängimiseks võiks nagu aega olla aga, et ma leveldamiseks aega leiaks.... no way.
Vanilla WoWis:
1-60 Priest
1-60 Mage
TBC:
60-70 Priest
60-70 Mage
1-70 Warrior
1-70 Shaman
1-70 Druid
1-70 Hunter
LK:
70-80 Warrior
70-80 Druid
55-76 ja 55-78 DK'd
1-80 Warlock
| Kommentaarid: 295 loe/lisa |
262 |
FR3AK
29.03.2010 01:54:12
PS. WoW (login) server vist maas? Ei suuda sisse logida. Jääb success-->connected tiitlile. |
Praegu on vist korras, kindel ei ole. Poole ICC pealt läks server maha. Pmst mis loot'ist saab, kui just raidleader lootis bossi ära ja enne kui jõudis asju kellelegi anda, server läks maha.
Ja teine küsimus, kumb bow parem on, kas 251 või 264 ICC oma. Loogika ütleb, et 264 oma, aga samas tolle boonused pole võrreldes 251 omaga midagi erilist.
| Kommentaarid: 42 loe/lisa |
40 |
ozzott
Ho Ho
29.03.2010 09:30:41
Kui iga õhtu paar tundi mängida saab 1->80 tehtud umbes kuu ajaga, kiiremini kui kasutada mõnd paljudest leveldamise giididest. Bote ma väga ei kasutaks, blizz sulgeb vahele jäänud inimeste kontosid üsna karmikäeliselt.
86 |
noonius
29.03.2010 11:33:13
kurask, eile lendasid login serverid jälle uppi. Ma ei saa enam üldse aru, mis toimub. Neljapäeval oli sama jama (Shadowsong). Mingi 20 min enne raidi algust oli kööga. Ja eile sama moodi. Proovime täna õhtul uuesti. Loodetavasti on koolilapsed juba siis magama läinud Tundub, et wow on populaarne (sic!)
Ja kui praegu peaks asi hull olema, siis ei oska ette kujutadagi, kuidas serverid koormusele vastu peavad, kui cata välja vupsab.
Mingi paks pihv paugub siin
| Kommentaarid: 8 loe/lisa |
Ho Ho
29.03.2010 11:42:13
Eile põlesid vist neil kõik servud maha nii siin kui sealpool merd. Ka foorumid ja armory oli maas mingi aeg.
Õnneks juhtus see paar minutit peale runemaster last+can't do while stunned ning 1-light'i tegemist
86 |
freestyler
29.03.2010 11:50:53
eile olid jah mingi hetk kõik servud maas, välja arvatud terokkar kus minu charrid istuvad
Ho Ho
29.03.2010 11:58:02
Tegelikult mängu serverid ise vist ei läinudki maha, või siis läksid ainult hetkeks. Näiteks tean, et kui rahvas oli Ulduaris siis enamust sealt välja ei vistatud. Paar inimest said DC ning tagasi logida ei saanud kuna login serverid olid maas. Vahepeal keegi üritas Ulduarist välja saada ning samuti sai DC kuna world server oli maas. Mõni minut ootamist ning rahvas läks Ulduarist välja ilma DC'd saamata. Nood, kes juba olid mängust väljas aga tagasi ei saanud kuna login serverid olid endiselt maas.
86 |
Traf
29.03.2010 12:19:32
| Ho Ho kirjutas: |
| Tegelikult mängu serverid ise vist ei läinudki maha, või siis läksid ainult hetkeks. Näiteks tean, et kui rahvas oli Ulduaris siis enamust sealt välja ei vistatud. Paar inimest said DC ning tagasi logida ei saanud kuna login serverid olid maas. Vahepeal keegi üritas Ulduarist välja saada ning samuti sai DC kuna world server oli maas. Mõni minut ootamist ning rahvas läks Ulduarist välja ilma DC'd saamata. Nood, kes juba olid mängust väljas aga tagasi ei saanud kuna login serverid olid endiselt maas. |
Eile olime LKd proovimas, sama lugu. Instance sees oli kõik korras, aga need kes releasisid said DC kohe, world server oli maas. World server tuli lõpuks tagasi üles aga login server jäigi maha ja nendel, kes juba DC said, tagasi sisse logida ei õnnestunud. LK jäigi ellu.
| Kommentaarid: 49 loe/lisa |
48 |
Ho Ho
29.03.2010 12:59:17
Igavus + ports rakette = win
86 |
Button
29.03.2010 13:03:37
| freestyler kirjutas: |
eile olid jah mingi hetk kõik servud maas, välja arvatud terokkar kus minu charrid istuvad  |
kle jah, terokkar oli üleval, mingi hetk login servud olid maas
aga üldiselt läks õhtune raid rahulikutl, lagivabalt isegi
saime LK25 harjutada pisut, so far 52%, half fail sunday setupiga,
Kristoferr
217 |
Elitegamer
bloodraven
29.03.2010 14:43:38
| Alonsus servus oli SW Ah blokitud .. tundub et eile oli rahval üle maailma igav ..
486
29.03.2010 16:11:45
| Ho Ho kirjutas: |
| Kui iga õhtu paar tundi mängida saab 1->80 tehtud umbes kuu ajaga, kiiremini kui kasutada mõnd paljudest leveldamise giididest. Bote ma väga ei kasutaks, blizz sulgeb vahele jäänud inimeste kontosid üsna karmikäeliselt. |
Miks boti keelatakse? Kui mängija ei viitsi kõiki queste teha, et leveleid saada siis las olla. Level üksinda ei anna ju midagi, questidega alles saab head varustust.
_________________ zero |
| Kommentaarid: 46 loe/lisa |
39 |
Ho Ho
29.03.2010 16:18:49
Selle pärast, et botid segavad inimesi kes üritavad tavalistel meetoditel üritavad leveldada. Küll nähtud, kus bottijad on pandud populaarsemaid questmobe grindima. Rääkimata kõiksugu farm-bottidest mis mööda taevast või maa all ringi lendavad ja kõik lilled-maagid kokku korjavad või kalu püüavad. Üldiselt botid sisaldavad nii grindimis kui farmimistuge ning et farmimist takistada bannitakse järjest kõik, kes bottimisega vahele jäänud.
86 |
Timberg
ööKARU
29.03.2010 16:52:06
| 486 kirjutas: |
| Miks boti keelatakse? Kui mängija ei viitsi kõiki queste teha, et leveleid saada siis las olla. Level üksinda ei anna ju midagi, questidega alles saab head varustust. |
Bottimist keelatakse selle präast, et blizzard saaks kulda rahus müüa ning blizzardi konkurentidest vabaneda:P
272 |
Kristoferr
217 |
FR3AK
30.03.2010 01:51:07
Kas selline makro põhimõtteliselt töötab?
/target Shambling Horror
/cast Tranquilizing shot
/target lich king
40 |
Kristoferr
30.03.2010 02:22:14
Sa saad ilma Lich king targetit kaotamata ka pmst Tranqi kasutada selle addi peal
Mousover:
/cast [target=mouseover] Tranquilizing Shot
või:
#showtooltip Tranquilizing Shot
/cast [target=Shambling Horror] Tranquilizing Shot
Mõlemad peaks töötama ehk.
Viimast saad nii katsetada, et vahetad mobi nime ära mingi muu vastu.
Liitu Wise'ga! |
217 |
Ho Ho
30.03.2010 03:01:28
Ma ei tea kuidas teil on kuid me raidis on suht tihti kaks suurt addi korraga elus. Niiviisi target=blah makroga seda asja ära ei lahenda sel juhul
86 |
Kristoferr
217 |
FR3AK
30.03.2010 08:26:57
| Ho Ho kirjutas: |
| Ma ei tea kuidas teil on kuid me raidis on suht tihti kaks suurt addi korraga elus. Niiviisi target=blah makroga seda asja ära ei lahenda sel juhul |
Meil on raidis (10man) 2 add'i korraga üleval väga lühikest aega ja tavaliselt saame 2 addi enne maha kui transition pihta hakkab.
40 |
Ho Ho
30.03.2010 09:40:02
Eks see sõltub, kui kiirelt ja hästi toda stackivat disease'i kasvatatakse. Kui viletsalt, siis korra olen 25-manis ka kolm suurt addi korraga ära näinud
Eile sai icc10 heroicut tehtud taas ning blood princes maha võetud esmakordselt. Nüüd siis veel 3 bossi heroicus maha saada ja paar achievementi teha ning uus drake ongi käes
86 |
FR3AK
30.03.2010 09:46:14
Tekkis selline küsimus, et kas hunter pet'i statsid sõltuvad tema levelist, kui ta tame'iti? Ehk siis kas on mingi vahe näiteks lvl 30 ja lvl 70 pet'il kui nad mõlemad on lvl 80? Enda loogika ütleb, et neil ei tohiks vahet olla, aga ehk keegi oskab kinnitada seda?
40 |
Ho Ho
30.03.2010 09:53:29
Vahet ei ole. Sama perekonna petid käituvad täpselt samamoodi. Ainus vahe tuleb sisse nende spetsiifilistest võimetest a'la dot'id või hundi AP buff.
86 |
eShelobik
30.03.2010 10:04:18
| kas mõni kes siin aktiivselt endgame'i raidib teab mõnda veidi kõvemat kui casual guild, et 2-3 õhtut nädalas hea seltskonnaga raidida. Chariks siis Ulduar 25man geared + paar uuemat juppi resto druid.
262 |
Ho Ho
30.03.2010 10:28:19
Oleksid paar nädalat tagasi pakkunud oleksid saanud ehk mu gildi tulla. Hetkel paraku vajame ainult resto shamanit, disc priesti, dps warriori ning huntereid. Muidugi applicationi võivad teha kõik kuid teiste rollide peale saamiseks peab ikka üsna kõva mulje jätma. Raiditakse k, n, p ~20-24.
Keda huvitab siis gildi leht on http://www.furious-resurrection.com/ ning applicationi tegemine käib siin: http://www.furious-resurrection.com/index.php?topic=145.0
86 |
FR3AK
30.03.2010 11:18:31
Mis kuradi jama on, et mul on dps nii madal? Sama geariga hunter teeb 1-2k kõrgemat dps'i kui mina, mõlemad oleme survival'is ja tõenäoliselt specc on suht sama. Shot prio on meil mõlemal sama, aga ikka jään dps'i poolest alla.
40 |
Ho Ho
30.03.2010 11:20:03
Ilma mõnd logi nägemata on suht võimatu midagi tarka öelda. Lambist pakun, et sa ei klõpsi nuppe päris nii kiirelt, kui tema ning tõenäoliselt raiskad liikumise peale rohkem aega. Kindlasti on võimalik ka see, et dualspeciga ei ole uuendanud asjade rank'e.
86 |
FR3AK
30.03.2010 11:26:58
Nuppe klõpsin piisavalt kiirelt, gcd on enamiku ajast peal. asjade rank'id on uuendatud. Protsentuaalselt dps'i vaadates on näitajad ka suht samad, vahe 1-2%. Liikumises võib ka viga olla, aga noh, eks ICC's see dps võib ikka väga hullult kõikuda, kui ikka Festergut'i ajal saad 7-8 korda järjest pungent blighti peale, siis on raske dps'ida.
40 |
Ho Ho
30.03.2010 11:32:20
Et siis ühtki logi sul näidata pole ning peame kohvipaksu pealt ennustama probleeme?
86 |
Driftmoon
30.03.2010 12:15:49
| Oskab keegi öelda kas on mõtet üldse warrior tanki teha, või on paladin parem? Endale meeldiks warrior rohkem, kuna paladine on kõik kohad täis...
| Kommentaarid: 40 loe/lisa |
39 |
Traf
30.03.2010 12:19:02
| Olen mõlemat proovinud. Olgugi, et paladine kõik kohad täis, kui ma warrioriga gruppides tankisin, siis oli tunda kuidas inimesed tegelikult soovisid, et ma paladin oleks.
48 |
Ho Ho
30.03.2010 12:39:09
Kui tahad OP klassi raid-tankimiseks siis on kõvasti äsavate bosside tankimisel nimekiri druid > blood dk > pala > warrior. Kui tahad huvitavat tankimist siis warrior > dk > pala > druid.
86 |
Kristoferr
217 |
Zanzhu
30.03.2010 19:11:42
| Traf kirjutas: |
| kuidas inimesed tegelikult soovisid, et ma paladin oleks. |
Ainult mingid lolboid tahavad palasid. Warrior sõltuvalt nerfikiige swingist on eri kohtadel raidbossude tankimisel aga ei ole ühtegi teist klassi millega oleks võimalik tankida speedrunne nii kiiresti kui warrioriga.
10 |
dzombe
30.03.2010 19:27:59
| Konks kirjutas: |
| Oskab keegi öelda kas on mõtet üldse warrior tanki teha, või on paladin parem? Endale meeldiks warrior rohkem, kuna paladine on kõik kohad täis... |
Kuna gnoom paladin olla ei saa siis loomulikult, warrior!
_________________ -- |
