AJ
19.03.2010 11:42:57
Intel releases more affordable X25-V solid-state drive
http://www.techspot.com/news/38233-intel-releases-more-affordable-x25v-solidstate-drive.html
Even though it has been available for a while at certain online retailers, Intel today officially announced the 40GB X25-V solid-state drive, a cut-down version of its X25-M model that will sell for a mere $125. The new drive is being marketed as an "entry-level" option for use in netbooks or dual-drive desktop PCs, where it would serve as a boot drive to offer users faster boot times and faster access to key applications.
The X25-V features 40GB of 34nm MLC NAND flash memory and support for Windows 7's TRIM function via the Intel SSD Optimizer. Windows XP and Vista users can also retain the out-of-box performance of this drive with the included SSD Toolbox. Unfortunately unlike its bigger siblings, which boasts sequential read speeds of 250MB/s and write rates of up to 100MB/s, the X25-V is limited to 170MB/s for reads and just 35MB/s for writes.
The 80GB X25-M drive can be had for around $230, so while the price of the X25-V is indeed easier to swallow, the cost per gigabyte is actually higher and you forfeit a great deal of performance.
Perhaps not so coincidentally Intel's announcement comes hot on the heels of rival vendor OCZ's Onyx SSD launch. That drive will give you 32GB of storage capacity along with read and write speeds of 125MB/s and 70MB/s, respectively -- all for a still unspecified sub-$100 price. |
Intel-i pressiteade http://www.intel.com/pressroom/archive/releases/2010/20100315comp.htm
E.
Intel's X25-V & Kingston's 30GB SSDNow V Series: Battle of the $125 SSDs
http://www.anandtech.com/storage/showdoc.aspx?i=3773
| Kommentaarid: 37 loe/lisa |
36 |
friik1
19.03.2010 20:15:47
| Lihtsalt suurepärane. Mu OCZ Vertex 256GB failis täna.
| Kommentaarid: 190 loe/lisa |
168 |
Andrus Luht
itimees.ee
318 |
friik1
19.03.2010 20:28:24
| Jätsin õhtul läpsi tööle. Hommikuks oli restartinud ja ketast enam ei leidnud. Restardi järel leidis üles, aga juba töö juures polnud kuskile backupi teha. Mingi corruption oli kah, kuna mõned DLLid olid puudu ja shortcutid katki, mille chkdsk väidetavalt ära parandas ning kõik töötas edasi. Koju tagasi jõudes ei leia enam üldse üles.
168 |
toivos
19.03.2010 20:45:45
| friik1 kirjutas: |
| Lihtsalt suurepärane. Mu OCZ Vertex 256GB failis täna. |
Annad kätsejäneseks?
_________________ Taastan datat katkistelt ketastelt ja katkistelt Flash(USB) mäludelt. Nüüd ka katkistelt SSD ketastelt. |
| Kommentaarid: 69 loe/lisa |
65 |
friik1
19.03.2010 20:47:09
| Kui peale paaritunnist seismist pilti ette ei võta (OCZ foorumi soovitus) ning OCZ ise ringi ei vaheta (eBayst pärit) ja vähemalt üritad datat kätte saada, siis küll.
168 |
Jaanus
19.03.2010 20:47:35
Mul sama kala juhtunud, Kristoferr-l juhtus paar päeva tagasi...
Tean kuidas korda saab
| friik1 kirjutas: |
| Jätsin õhtul läpsi tööle. Hommikuks oli restartinud ja ketast enam ei leidnud. Restardi järel leidis üles, aga juba töö juures polnud kuskile backupi teha. Mingi corruption oli kah, kuna mõned DLLid olid puudu ja shortcutid katki, mille chkdsk väidetavalt ära parandas ning kõik töötas edasi. Koju tagasi jõudes ei leia enam üldse üles. |
| Kommentaarid: 712 loe/lisa |
567 |
friik1
19.03.2010 20:54:04
| Jaanus kirjutas: |
Tean kuidas korda saab  |
Ehk siis...?
168 |
Kristoferr
19.03.2010 21:41:00
Suht lihtne korda saada, aga aega võtab ja selle käigus kaotad kettal olevad andmed. Kahjuks on see paratamatus, et ketaste firmware vahel töö lõpetab.
Installida tuleb uus firmware.
1. Installi 1.1 firmware, mille saad http://www.upload.ee/files/449626/Vertex_1.10.zip.html
- Kõigepealt ühenda ketas järelt ära ja pane kettale jumper.
- Tee arvutile clear bios. Arvuti ei tohi olla üle klokitud
- Ühenda ketas järgi, buudi windowsi ja lase 1.1 firmware peale. (Ilmselgelt on selleks vaja teist ketast, millel windows)
2. Ühenda jumper lahti, clear bios uuesti buudi windowsi ning kontrolli administrative tools alt, kas ketas on olemas. Kui ketas on operatsioonisüsteemi ketas, siis ära kettale partitsiooni tekita. Windowsi installi käigus tehakse automaatne format ja tekitatakse uus partitsioon.
- Mina tegin selles etapis kettale veel sanitary erase, aga ma ei tea kas see oli vajalik. Lihtsalt igaks juhuks lasin üle.
3. Järgmiseks tuleb sul tekitada usb boot drive või cd/dvd boot drive. Õpetuse leiad siit http://www.ocztechnologyforum.com/forum/showthread.php?67815-This-thread-has-the-1.5-FW-update-for-Agility-and-Vertex-drives
Kui see tehtud, siis õnnelikku uue OP süsteemi installimist sulle!
Mul nüüd ketas 1.5ga uuesti töös teist päeva. Ühtegi anomaaliat ega probleemi enam esinenud ei ole (sülitab kolm korda üle õla)
Igaks juhuks teen nüüd regulaarselt süsteemikettale kogunevatest andmetest koopia HDDle.
_________________ Liitu Binance'ga
Liitu Honey'ga |
| Kommentaarid: 264 loe/lisa |
215 |
friik1
19.03.2010 21:44:25
| Kristoferr, 1.1 ei tohi installida ketastele, millel see või vanem pole tehasest peal olnud, kui ma olen õigesti aru saanud.
168 |
Andrus Luht
itimees.ee
318 |
friik1
19.03.2010 22:13:36
| Paistab, et 1.3'le võib ikkagi 1.1 selga lasta. Lasen pigem üle öö ikka seista, enne kui andmed maha kannan ja katsetama hakkan.
168 |
Kristoferr
19.03.2010 22:49:17
| friik1 kirjutas: |
| Kristoferr, 1.1 ei tohi installida ketastele, millel see või vanem pole tehasest peal olnud, kui ma olen õigesti aru saanud. |
Mina ei leidnud sellist informatsiooni ja mul kõik toimis. Ehk vedas siis sellega.
Mul võisid probleemid tekkida ka seoses sellega, et arvuti oli vahepeal kõvasti üle kellatud ja kohati ebastabiilne. Nüüd HDD OPsüsteemil stabiilsus kontrollitud ja SSD võib rahus töötada.
Liitu Honey'ga |
215 |
tqz
19.03.2010 23:51:20
| BReaK da iCE kirjutas: |
Ptüi-ptüi-ptüi üle vasema, minul pole Intel X25-M ketastega mingit jama olnud. Juba pool aastat 3tk neid RAID0's ja muret pole. Kiirust aga nii et tapab
Inteliga paistab üldse probleeme vähem olevat. Mul praegu päris hea meel, et Vertexit ei ostnud.
| Kommentaarid: 74 loe/lisa |
71 |
friik1
19.03.2010 23:55:32
| Intel oli omal ajal plaanis, aga 160GB poleks vast välja tulnud.
168 |
Andrus Luht
itimees.ee
318 |
friik1
20.03.2010 11:05:38
| Seda küll, aga läpparisse RAIDi ei topi ning mul on pidevalt 100GB+ kola kaasas töö jaoks...
168 |
Kristoferr
20.03.2010 11:34:08
Vertexid on küll oluliselt kiiremad, kui Inteli SSDd, kuid kahjuks jah nendega on ka rohkem muresid.
Siiski tavakasutajal, kes arvutit üle ei kella ja firmware tihti uuendada ei viitsi, ei tohiks tohiks erilisi muresid tekkida.
Liitu Honey'ga |
215 |
tqz
20.03.2010 12:17:37
| Kristoferr kirjutas: |
| Vertexid on küll oluliselt kiiremad, kui Inteli SSDd |
Kuidas nii?
Ühesõnaga suurt vahet neil jõudluses pole. Sarnane seis on peaaegu igal pool.
71 |
Kristoferr
20.03.2010 12:47:30
See test kalab sajaga muide. Aga ma ei viitsigi siinkohal vaielda. Otsi mõnda uuema firmwarega vertexi testi. Või siis testi, mis pole inteli poolt rahastatud.
Liitu Honey'ga |
215 |
Andrus Luht
itimees.ee
318 |
friik1
20.03.2010 13:10:52
| Barefooti sequential read ja write on paremad, Intelil on random parem.
168 |
tqz
20.03.2010 13:14:07
Ma sain ta jutust nii aru, et Anandtechi testid on Inteli poolt rahastatud. Küsitava väärtusega jutt nii või teisiti. Tooks siis enda väidete juurde tõestustki
Kristoferr, tegelikult tahaks ma täitsa teada, kui suur see jõudluse vahe erinevate firmware'dega on OCZ-l, aga ei õnnestunud selliseid teste leida. Kui tead mõnda siis lingi siia
friik1, sequential write on vist jah Inteli nõrk koht, aga nagu testidest näha, siis reaalses kasutuses pole need näitajad enamasti kuigi olulised.
71 |
Kristoferr
21.03.2010 00:43:30
Otsisin seda testi, mis lugenud olin, aga ei leia enam. Leitud testides on tõesti ineli teiste põlvkonna SSD kettad väga kiired ja on samal pulgal või kiiremad, kui Vertexid. Ainuke asi jah, milles inteli SSDle kott pähe tõmmati, oli sequental write.
Tegin natuke liiga inteli SSDle.
Liitu Honey'ga |
215 |
AJ
22.03.2010 14:54:47
New Intel driver brings TRIM support for RAID setups
http://www.tcmagazine.com/comments.php?shownews=33366&catid=3
The TRIM function in Windows 7, Server 2008 R2 and Linux 2.6.33+ is something that all SSD owners should enjoy, unfortunately that's not the case for those with drives that do not support TRIM or for RAID users. Actually, scrap the last category cause not all RAID users are TRIM-less thanks to a new driver for Intel chipsets that enables TRIM on almost all setups (RAID 5 is apparently the exception).
Available here, the driver will add TRIM support only if all the drives in the RAID configuration are TRIM-enabled. If this requirement is fulfilled then rejoice, you can have TRIM working for you in the background to maintain the super speeds of your RAIDed SSDs. Happy days indeed, now hopefully AMD users will get something similar.
36 |
