uus teema   vasta Raud »  Protsessorid »  AMD K10 arutelu märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 68, 69, 70 ... 93, 94, 95  järgmine
C1rca
C1rca
sõnum 17.03.2010 17:41:12 vasta tsitaadiga
aga http://www.arvutikeskus.ee/index.php?pid=33&id=152&menyy_id=33&action=look&lookid=93676 või http://www.arvutikeskus.ee/index.php?pid=33&id=152&menyy_id=33&action=look&lookid=89755 ?
Kommentaarid: 104 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 97
K3ndu
K3ndu
sõnum 17.03.2010 20:14:10 vasta tsitaadiga
AMD Phenom II X6 Series Clock Speeds Revealed
AMD's much talked about six-core processors, the Phenom II X6 series, consists of three models for what we know in good detail: model numbers 1075T, 1055T, and 1035T at the bottom. But what remained a mystery were their clock speeds. A leak by one of the motherboard manufacturers who recently released supportive BIOS updates reveals the clock speed for the entry-level Phenom II X6 1035T to be 2.60 GHz, that of the 1055T to be 2.80 GHz, and of the high-end 1075T to be 3.00 GHz. As revealed earlier, the 1035T has a TDP of 95W, while the 1055T has both 125W and 95W variants in the making, and the 1075T has a TDP of 125W.
With so many motherboard vendors specifically designing their upcoming products to be ready for "140W TDP", it isn't hard to guess that there could be a higher-end part in the making, which is probably clocked even higher, and comes with the Black Edition branding. All Phenom II X6 processors are based on the "Thuban" core, a port of the Istanbul six-core architecture to the AM3 package. There are six cores with dedicated 512 KB of L2 caches and a shared 6 MB L3 cache (total cache being 9 MB). The new chip will be announced in the weeks to come.
Link
Kommentaarid: 130 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 120
1dumbpcuser
sõnum 17.03.2010 20:22:00 vasta tsitaadiga
C1rca kirjutas:
400 eest Arctic Cooling Freezer 7 PRO rev.2
M: MSI B660M MORTAR
M: Dell RTX 2060
O: AM5 ITX emaplaat
AJ
AJ
sõnum 17.03.2010 21:49:55 vasta tsitaadiga
1dumbpcuser kirjutas:
C1rca kirjutas:
Need kõik siis 92 MM vendiga, omgwtf pakutud jahutus on suurem ja 120 mm vendiga.
C1rca
C1rca
sõnum 17.03.2010 22:00:26 vasta tsitaadiga
seda küll aga rahaga ei ole hetkel priisata, seega pean odavamate variantide vahel valima. Aga kui ütlete et 92mm vendiga jahutust ei ole mõtet osta siis ehk vaatan foorumist parem midagi kasutatult. Ehk 3-400 eest saab midagi asjaliku kasutatult.
AJ
AJ
sõnum 17.03.2010 22:07:56 vasta tsitaadiga
C1rca, siin mingi jahutuste võrdluse tabel http://www.frostytech.com/articleview.cfm?articleid=2401&page=4
sõnum 17.03.2010 22:24:12 vasta tsitaadiga
C1rca kirjutas:
Hetkel küll midagi asjalikku ei näinud...
AJ
AJ
sõnum 17.03.2010 22:26:03 vasta tsitaadiga
AMD Phenom II X6 clocks leaked
http://www.tcmagazine.com/comments.php?shownews=33295&catid=2
C1rca
C1rca
sõnum 17.03.2010 22:29:39 vasta tsitaadiga
tomorrow kirjutas:
C1rca kirjutas:
Uurisin ka, üldse ei liigu jahutusi hetkel. AM2/3-le mitte vähemalt. Eks siis tuleb oodata. See stocki lärm sööd närvid seest ära. Enam Smart Fan vms värk ka ei tööta, pärast kordaja tõstmist.
omgwtf
omgwtf
sõnum 17.03.2010 22:36:14 vasta tsitaadiga
C1rca kirjutas:
tomorrow kirjutas:
C1rca kirjutas:
chesm6mmi
chesm6mmi
sõnum 17.03.2010 22:36:15 vasta tsitaadiga
see Arctic Cooling Freezer 7 PRO rev.2 on endal peal phenom 965-l ja kui 4ghz peale lükata siis idles on kuskil 42 kraadi, ja prime 95 tegema panna siis läheb kuskil 68...
Kommentaarid: 107 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 102
AJ
AJ
sõnum 17.03.2010 22:50:48 vasta tsitaadiga
chesm6mmi kirjutas:
Mina eelistaksin 10C jahedamat tempi.
chesm6mmi
chesm6mmi
sõnum 17.03.2010 23:05:01 vasta tsitaadiga
noh default peal hoiab 29 kraadi... kui 4ghz lükkan siis panen ka 1.52v, tundub et vähem volti ei saa anda siis ei kannata prime välja...
K3ndu
K3ndu
sõnum 17.03.2010 23:06:52 vasta tsitaadiga
AJ kirjutas:
1dumbpcuser
sõnum 17.03.2010 23:11:01 vasta tsitaadiga
K3ndu kirjutas:
AJ kirjutas:
M: MSI B660M MORTAR
M: Dell RTX 2060
O: AM5 ITX emaplaat
Denkeš
Denkeš
sõnum 17.03.2010 23:43:07 vasta tsitaadiga
Kas too X6 peaks oskama tuumasi eraldi välja lülitada?
a.k.a Ummikummi
Kommentaarid: 5 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 4
Kristoferr
Kristoferr
sõnum 18.03.2010 05:49:28 vasta tsitaadiga
http://phenommsrtweake.sourceforge.net/
Keegi seda nummit progejuppi kasutab igapäevaselt?
Kommentaare?
Liitu Opencode Go soodsa coding plaaniga ja saa 5€ soodust!
Liitu Wise'ga!
Kommentaarid: 266 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 217
G80
G80
sõnum 19.03.2010 00:12:13 vasta tsitaadiga
3.0 Deff savi, kuna õhuga pidi klokkuma nagu 965BE C3 ehk 4GHz kanti. thumbs_up.gif
6 tuuma 4 peal on mõnus.
New thuban in Q3, 3,2GHz?
http://www.xtremesystems.org/forums/showthread.php?t=247612
Kommentaarid: 256 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 210
K3ndu
K3ndu
sõnum 20.03.2010 13:45:50 vasta tsitaadiga
Paistab ,et mu neljas core täiesti defektne, kui oli neljas tuum enabletud ja 3 tuum disable ei läinud stabiilseks ja kui vastupidi oli kohe stabiilne.
Osiris
Osiris
sõnum 20.03.2010 21:30:52 vasta tsitaadiga
Mida arvatakse sellisest jahutusest nagu SpinQ VT.
Plaanin asja panna Phenom II X4 955 BE peale.
Kommentaarid: 115 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 103
omgwtf
omgwtf
sõnum 20.03.2010 21:33:11 vasta tsitaadiga
Selle hinna sees vast perfi suht vähe,enamus raha läheb välimusse ilmselt..
Kutsu
Kutsu
sõnum 20.03.2010 21:36:29 vasta tsitaadiga
Plaanin ise ka varsti teha PC upgrade.Praegu olen inteli peal aga seekord lähen Phenom X6-le.Motherboard tuleb vist Asus Crossfire IV ning jahutuse Arctic või Coolermaster.
Soovitage kumba võtta.
CoiL
CoiL
sõnum 20.03.2010 21:41:38 vasta tsitaadiga
Kutsu, ostuabi asub teises kohas > https://foorum.hinnavaatlus.ee/viewforum.php?f=8
Või kui tahad CPU jahutuste kohta küsida, siis ka selleks vastav teema olemas > https://foorum.hinnavaatlus.ee/viewtopic.php?t=273610
Kommentaarid: 95 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 83
G80
G80
sõnum 22.03.2010 01:17:59 vasta tsitaadiga
AMD Phenom II X6 1090T = 230€/308$
AMD Phenom II X6 1055T = 160€/216$
sõnum 22.03.2010 01:33:56 vasta tsitaadiga
Oot kas mitte X6 1075T polnud hetke kiireim @3.0?
Nägin küll jutte X6 109xT @ 3.2
Heineken
sõnum 22.03.2010 01:43:38 vasta tsitaadiga
G80 kirjutas:
Oi , päris kenad hinnad icon_smile.gif thumbs_up.gif . Millegipärast ootasin midagi 2 korda kallimat icon_lol.gif .
CoiL
CoiL
sõnum 22.03.2010 02:07:17 vasta tsitaadiga
G80 kirjutas:
Krt, ise kuulen esimest korda sellest PII X6 1090T-st. See siis kõige suurema klokiga? Ainult 230€ ? WOW! icon_razz.gif thumbs_up.gif
K3ndu
K3ndu
sõnum 22.03.2010 09:13:14 vasta tsitaadiga
Optimist
Optimist
sõnum 22.03.2010 10:36:29 vasta tsitaadiga
Kristoferr kirjutas:
Kommentaare?
Mis muud kui ülikõva vidin. Volte ja kellasi saab otse OSist näppida. Kiiremini tuleb madalast taktist välja seega ei teki CnQ'ga omast kiiruse kaotust. Prosedel mis suudavad tuumade takte eraldi majandada, ei teki CnQ bugi kui vanem OS (näiteks XP, Vista) otsustab max kellal töötava tuuma töö ümber tõsta madalama taktiga puhkavale tuumale.
Kommentaarid: 10 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 8
G80
G80
sõnum 22.03.2010 11:06:59 vasta tsitaadiga
tomorrow kirjutas:
1090 kiirem ikka ja see on black edition, teised tavalised.
http://www.xtremesystems.org/forums/showthread.php?t=247790
We just received the official prices from AMD:
Phenom II X6 Six Core
1090T Black Edition: 125(W), AM3 Socket, 9MB Cache, 3.2 GHz Freq @ 295 USD
1055T: 125(W), AM3 Socket, 9MB Cache, 2.8 GHz Freq @ 199 USD
Jann1
Jann1
sõnum 22.03.2010 12:24:06 vasta tsitaadiga
Kas hetkel intelil on siia vastu midagi peale I7 Panna?
Kommentaarid: 144 loe/lisa Kasutajad arvavad:  :: 5 :: 1 :: 128
tiirP
tiirP
sõnum 22.03.2010 12:26:48 vasta tsitaadiga
PCman kirjutas:
Oman CL-P0466D jahutit. Kiiruse reguleerimiseks on juhtmel ka potekas. Väga vaikne, kuid hind on kohutav.
Kommentaarid: 115 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 107
martin366
martin366
sõnum 22.03.2010 14:00:26 vasta tsitaadiga
Kas see mobo http://www.asrock.com/mb/overview.asp?Model=M3A790GXH/128M toetab Phenom II X2 550/555 ? Seal pole phenom ii x2 kirjas, aga netis uurin siis ühel vennal on selline kooslus.. keda nüüd uskuda? icon_neutral.gif
Kommentaarid: 185 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 172
KrisVr
sõnum 22.03.2010 14:05:18 vasta tsitaadiga
martin366 kirjutas:
Täitsa kirjas on, et toetab.
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 27
AJ
AJ
sõnum 22.03.2010 14:42:58 vasta tsitaadiga
DefXtreme kirjutas:
martin366 kirjutas:
On jah kirjas http://www.asrock.com/mb/cpu.asp?Model=M3A790GXH/128M
Ollaz
Ollaz
sõnum 22.03.2010 23:06:56 vasta tsitaadiga
Jann1 kirjutas:
ot:
Mis seal ikka vastu panna.. Inteli PP on ju alati suurem olnud icon_rolleyes.gif
Hinna suhtes muidugi ei ole.
Kommentaarid: 83 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 57
Sponge
Sponge
sõnum 23.03.2010 00:53:59 vasta tsitaadiga
Kommentaarid: 398 loe/lisa Kasutajad arvavad:  :: 4 :: 4 :: 323
Kristoferr
Kristoferr
sõnum 23.03.2010 01:13:36 vasta tsitaadiga
eih tea, kas tasub. Ehk tuleks klokkamise mõttes jälle esimene laar neid vahele jätta. icon_rolleyes.gif Muidu ma 100% huvitatud. Kui ainult saaks normaalse pingega 4000+ mhz toimiva isendi.
Liitu Wise'ga!
G80
G80
sõnum 23.03.2010 14:09:48 vasta tsitaadiga
Miks vahele jätta?
AMD X6 1055T 2.8GHz testid:
http://diybbs.zol.com.cn/10/11_94441.html
Kristoferr
Kristoferr
sõnum 23.03.2010 14:46:43 vasta tsitaadiga
Näita mulle ühte C2 mis teeks 7Ghz. C3 on neid nagu putru... Oma C2 ei saanud ma ka nii vähese pingega tööle @ 3600mhz, kui nüüd C3. See siis 24/7
Liitu Wise'ga!
G80
G80
sõnum 23.03.2010 14:52:43 vasta tsitaadiga
Ah krt mõtlesin ikka esimesi C3-mesi, oleks pidand täpsustama.
C2 sai suvel lastud 4100MHz marke õhuga ja 4ghz oli 24/7 stable aga volt oli jõhker. 1.55V.
One
sõnum 23.03.2010 17:14:09 vasta tsitaadiga
link :: AMD Phenom II X4 T Series Detailed
The Phenom II X4 960T operates at 3.30 GHz, while the 940T runs at 3.00 GHz. What makes these chips different from existing chips based on the Deneb die is that it is in fact based on the Thuban die with two cores disabled. The resulting quad-core chip is codenamed Zosma. The other characteristic feature about not only Zosma, but also Thuban in general, is the introduction of a feature called "Turbo Core". The feature senses performance needs and steps up clock speeds of some cores, while powering down others. The stepping up of clock speed happens on the fly, and using a jump in BClk multiplier by a few units. The new chips also come with the unofficial incentive of being able to unlock the two disabled cores to turn it into a six-core chip. Unlocking may not work in all cases.
ehk siis X4 Turbod tulekul ning kõige parem on asja juures see, et nad on kahe suletud tuumaga X6-d thumbs_up.gif
1dumbpcuser
sõnum 23.03.2010 17:59:58 vasta tsitaadiga
M: MSI B660M MORTAR
M: Dell RTX 2060
O: AM5 ITX emaplaat
Kristoferr
Kristoferr
sõnum 23.03.2010 18:06:48 vasta tsitaadiga
Launch Date pole täpselt teada?
Liitu Wise'ga!
Taavi©
Taavi©
sõnum 23.03.2010 20:35:48 vasta tsitaadiga
Jann1 kirjutas:
Eks need prosed on ~i7 920 võimsusega (8 threads= ~6core)
Seega kui arvestada need eurid ümber selleks mis nad reaalselt siin maksma hakkavad siis on 920 sama hinaga+ intel klokkub paremini normaal tingimustes.
Inflatsioon on maksustamine ilma seadusandluseta
viimati muutis Taavi© 23.03.2010 20:55:41, muudetud 1 kord
Kommentaarid: 377 loe/lisa Kasutajad arvavad:  :: 6 :: 1 :: 328
Kristoferr
Kristoferr
sõnum 23.03.2010 20:43:15 vasta tsitaadiga
http://www.xtremesystems.org/forums/showthread.php?t=247950
Paistab et +2tuuma = +40-50% perfi, multithread programmides.
Hea uudis selle juures on see, et P II pole eriti cashi nõudlik. 6MB L3 ajab asja eeskujulikult nii 4corega kui ka 6 corega. icon_smile.gif
Liitu Wise'ga!
AJ
AJ
sõnum 23.03.2010 21:24:48 vasta tsitaadiga
AMD 880G Chipset Detailed
link
G80
G80
sõnum 23.03.2010 21:53:43 vasta tsitaadiga
Selge on see, et kuna uued AMD-id pole i7 kiiremad (ammu teada) siis tulevad hinnad head.
Perfi ja hinna suhtes tuleb aga masu ajal väga kift. 1055T saab olema väga magus enda hinnaga.
Ja kellajatele 1090T püss.
Sest 6GHz + 1090T on kiirem kui 5-5.3GHz i7.
maxman321
maxman321
sõnum 24.03.2010 01:30:48 vasta tsitaadiga
G80 kirjutas:
Kommentaarid: 96 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 88
Sponge
Sponge
sõnum 24.03.2010 01:47:04 vasta tsitaadiga
maxman321 kirjutas:
G80 kirjutas:
uus teema   vasta Raud »  Protsessorid »  AMD K10 arutelu mine lehele eelmine  1, 2, 3 ... 68, 69, 70 ... 93, 94, 95  järgmine
