Kas kavatsed peale järelvaatamise lõppemist tellida salvestusteenust 5€ kuus? |
Jah |
9% |
[ 51 ] |
Ei |
42% |
[ 223 ] |
Mul juba olemas |
38% |
[ 201 ] |
Kolin mujale |
9% |
[ 48 ] |
hääli kokku : 523 |
10.03.2010 01:00:13
MummikAl kirjutas: |
ärihai kirjutas: |
ja ja räkige aga nii kõvasti sellest siin varsti kraanid kinni.  |
mõtlesin seda sama |
Tanel kustuta viimased 3 posti ära, me oleme nõus sellega
Et kindel olla siis viimased 10
Kommentaarid: 71 loe/lisa |
MummikAl
10.03.2010 01:18:26
nüüd on juba hilja. elioni öövaht jägib seda teemat 24/7
Kommentaarid: 42 loe/lisa |
39 |
10.03.2010 20:03:59
Nii, ruuter juba mingi 2 tundi resanud vapralt end.
ruuteri logi
[code]Mar 10 19:48:25 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 83.242.9.72 Dst ip: 90.191.233.143 Type: Destination Unreachable Code: Host Unreacheable
Mar 10 19:48:18 SNTP Synchronised to server: 194.126.115.242
Mar 10 19:48:18 SNTP Systemtime update: time setting 00:01:30 > new time setting: 19:48:18
00:01:30 (since last boot) GRP Default destination is routed via gateway 90.191.232.1
00:01:29 (since last boot) DHCC lease ip-address 90.191.233.143 bound to intf ip_internet
00:01:29 (since last boot) DHCC IP address 90.191.233.143 (255.255.254.0) set on intf ip_internet: ok.
00:01:28 (since last boot) xDSL linestate up (downstream: 11998 kbit/s, upstream: 767 kbit/s; output Power Down: 14.0 dBm, Up: 12.0 dBm; line Attenuation Down: 9.0 dB, Up: 4.0 dB; snr Margin Down: 14.0 dB, Up: 20.5 dB)
00:01:09 (since last boot) xDSL linestate down
00:01:07 (since last boot) LOGIN User Administrator logged in on [HTTP] (from 192.168.1.64)
00:00:41 (since last boot) DHCS server up
00:00:40 (since last boot) FIREWALL level changed to Disabled.
00:00:11 (since last boot) FIREWALL exact tcp state check (1 of 1): Protocol: TCP Src ip: 192.168.1.64 Src port: 61309 Dst ip: 92.8.157.250 Dst port: 56000
00:00:10 (since last boot) FIREWALL event (1 of 1): enabled rules
00:00:02 (since last boot) WIRELESS interface turned on.
00:00:01 (since last boot) KERNEL Cold restart
00:00:01 (since last boot) FIREWALL event (1 of 1): modified rules
00:00:01 (since last boot) FIREWALL event (1 of 1): created rules[/code
Liini andmed
[code]Uptime: 0 days, 0:01:22
Modulation: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 767 / 11.998
Data Transferred (Sent/Received) [KB/MB]: 778,00 / 54,81
Output Power (Up/Down) [dBm]: 12,0 / 14,0
Line Attenuation (Up/Down) [dB]: 4,0 / 9,0
SN Margin (Up/Down) [dB]: 22,0 / 13,5
Vendor ID (Local/Remote): TMMB / BDCM
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 0 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 2 / 0
HEC Errors (Up/Down): 565 / 0[/code]
Restart näeb ruuteril nii välja:
Plaks lööb Ethernet ja Wifi tulukesed kustu, sellises olekus on mingi 30-40 sek, seejärel lööb ka DSL ja Internet tulukese kustu jne.
EDIT: ei kustu, jäävad kinni hoopis.
Palju see kuradi vahetamine maksab et CAT5 tuppa ja DSList lahti
EDIT: lehtesi peab kh muidu suht tihti nüüd mitu korda refreshima et ette tuleks. Lihtsalt annab Could not locate remote server
Kommentaarid: 39 loe/lisa |
darkside
12.03.2010 13:18:13
salatoimik kirjutas: |
ruuteri logi
Liini andmed
EDIT: lehtesi peab kh muidu suht tihti nüüd mitu korda refreshima et ette tuleks. Lihtsalt annab Could not locate remote server |
Hyperkiirega liitumine võimalik ja tellid selle, siis 0 kr. Muidu lohistad võrgukaabli ise vajalikku kohta ja tehnik kohale 280 kr.
taavi
12.03.2010 15:39:10
hyperkiiret ei saa enne, kui valguskaabel majja tuleb.
ma võtaks veaks omale tänapäev kaableid, kui ainuke kulu oleks tehnik+280 kr. nii see kahjuks pole. isegi seda ei suuda elion öelda, kui palju ma maksma pean, et asi niikaugele saaks. valeinfo -> paska ajad.
Kommentaarid: 64 loe/lisa |
58 |
darkside
12.03.2010 16:43:28
taavi kirjutas: |
ma võtaks veaks omale tänapäev kaableid, kui ainuke kulu oleks tehnik+280 kr. nii see kahjuks pole. isegi seda ei suuda elion öelda, kui palju ma maksma pean, et asi niikaugele saaks. valeinfo -> paska ajad. |
ma vabandan siis, et ma nii napisõnaliselt ennast väljendasin. parandan ennast:
KUI ON ELIONILT TEHNILISELT VÕIMALIK hyperkiiret inetrnetiühendust pakkuda. SEE TÄHENDAB Elion helistab 3 tööpäeva peale sinu tellimuse sisseandmist ja teavitades, et saab hyperkiiret ja soovib tehniku aega kokku leppida, siis saad 0 krooniga. Tehnik tuleb kaabeldab ja ruuteri vahetab ka vajadusel välja. KUI EI SAA hyperkiiret ja tahad ikka kaableid vahetada, siis maksad 280 kr kohaletulek + 280 kr 30 min + iga järgnev 15 min 140 kr
... ja kui sina elad sellises kohas, kus Elion ei pea otstarbekaks ise oma kuludega optikat vedada, siis loomulikult sinu soovil paigaldatakse see. Sellilsel juhul peab sul rahapuu aed lausa olema Hinda ei osata öelda, kuna see on keeruline väljaarvutamine ja kui sa ei ole tõsiseltvõetav tellija. Siis, miks peaks keegi aega võtma ja selle välja arvutama sinule teadmiseks. Sinu vastus on teada!
minu väike arvamus seega ma ei aja paska, ainult sõltub asjaoludest
psydeblo
12.03.2010 21:24:22
Kas keegi hea inimene viskaks üles THOMSON ST546 v7 user.ini faili, kus on muditud, et ruuteri kolmas ja neljas port näitaksid digipilti?
Kommentaarid: 148 loe/lisa |
135 |
olafsand
Kommentaarid: 61 loe/lisa |
58 |
psydeblo
12.03.2010 21:59:15
Selle lingini jõudsin ma ise kah, kuid mina ei saanud sealt targemaks kahjuks.
135 |
olafsand
12.03.2010 22:50:07
psydeblo, kui saad teada, et kumb jaam sul on, siis järgmised read:
win vista või 7... start...trükid...telnet 192.168.1.254 (kui pole muutnud)...sisestad kasutajanime...parooli...ja hakkad antud lingilt kirjas olevaid ridu sisestama
58 |
12.03.2010 23:04:49
olafsand kirjutas: |
win vista või 7... start...trükid...telnet 192.168.1.254 (kui pole muutnud)...sisestad kasutajanime...parooli...ja hakkad antud lingilt kirjas olevaid ridu sisestama  |
Ruuterist saab kh teada mis jaamaga tegu.
Vendor ID (Local/Remote): TMMB / BDCM = Alcatel
Nokia = GSPN
olafsand
12.03.2010 23:22:27
salatoimik,
samas vaatasin enda ruuterist järgi ja oli selline kiri seal: Vendor ID (Local/Remote): TMMB / GSPN
kumb siis ?
58 |
12.03.2010 23:31:00
Nokia
olafsand
58 |
psydeblo
13.03.2010 01:14:54
Minu ruuteris kahjuks sellist kohta nagu Vendor ID olemas pole, ega ei leia ma muud infot, mis võiks sarnandega sellele. On võimalik veel kuskilt seda järele uurida?
135 |
13.03.2010 01:18:15
psydeblo kirjutas: |
Minu ruuteris kahjuks sellist kohta nagu Vendor ID olemas pole, ega ei leia ma muud infot, mis võiks sarnandega sellele. On võimalik veel kuskilt seda järele uurida? |
Mis ruutewr sul üldse on? Kasutad mingit 100 mega neti lahendust?
psydeblo
13.03.2010 01:22:04
Ruuteriks on THOMSON ST546 v7.4.3.2
Ei kasuta mingit 100 mega neti lahendust, tavaline kodulahendus on.
135 |
13.03.2010 01:24:34
Ei kasuta mingit 100 mega neti lahendust, tavaline kodulahendus on. |
http://192.168.1.254/cgi/b/dsl/dt/?be=0&l0=1&l1=0
Ma ei tea muidugi kas tollel on 780-ga sama url...
psydeblo
13.03.2010 01:32:42
Kurat, täitsa olemas, "Vendor ID (Local/Remote): TMMB / BDCM", silm vist vähe krillis
edit: Neh, sai telnetiga read sisse toksitud ja asi töötab, uhke värk neh, tuhat tänu teile!
135 |
format666
13.03.2010 15:10:18
2 digiboxiga m6ni kanal hangub m6nda ei n4ita yldse.
Leidub mingi lahendus?
Kommentaarid: 70 loe/lisa |
42 |
fgth
13.03.2010 15:17:06
16mbit port? kui jah siis vast liin kehvake
Kommentaarid: 65 loe/lisa |
63 |
harakas
13.03.2010 23:00:06
Logisin täna üle pika aja ruuterisse sisse ja üllatus üllatus, näen, et mingil ajal on ruuterile TG585 v7 peale pandud uus tarkvara 8.2.6.5. Mis kõige üllatavam, ruuterist on näha, et see on järjepanu juba 20 päeva käigus, kuigi varem olid igapäevased katkestused tavalised. Kas tõesti võib stabiilsus olla seotud uue tarkvaraga?
Kommentaarid: 1 loe/lisa |
tarx1000
14.03.2010 11:25:35
harakas kirjutas: |
Kas tõesti võib stabiilsus olla seotud uue tarkvaraga? |
Aga loomulikult!
Isegi läpakatega oli ju nii, et ostes oli peal vista ja hirmus piin ja vaev oli sellega. Aga nagu XP peale panid, kohe hakkas läpakas korralikult tööle.
Kommentaarid: 2 loe/lisa |
15.03.2010 18:23:09
Iseteeninduses teemapaketist loobumine ei tööta? Eila mingi 8 ajal sai seal Viasati paketist loobutud (kuupäevaks siis 15 valitud = ehk siis kuupäeva vahetusega oleks kinni pidanud minema...) Aga midagi, täna ikka pilt kenasti jookseb edasi ja raha tiksub.
Ja nii digibox kui ruuter on restarti saanud...
darkside
15.03.2010 20:46:32
Ja nii digibox kui ruuter on restarti saanud... |
kas mitte pole siis 15 kuupäev kaasaarvatud, ehk siis täna ööse kella 12ni
