kiire
02.03.2010 05:01:56
jah, saab kinnitust. ka minu ps3 on elus.
aga milles asi oli?: http://playstationlifestyle.net/2010/03/01/playstation-3-error-8001050f-demystified/
What’s causing the problem?
The system clock thinks that today is a leap year dated February 29th, 2010. Meanwhile, the OS Clock doesn’t have that date available in its table since it doesn’t exist. What we have are two very conflicting dates which have caused the PlayStation 3 to change behavior. It’s hard to tell exactly why the date on many PS3s has been rolled back to 1999, but it could be a protocol set in place by Sony for situations like this.
Why does the system clock think it’s leap year?
Apparently, the older PlayStation 3s have been programmed to think that every even year is a leap year. You might be asking, “Well, why didn’t PS3 consoles face this issue in 2008 then?”. The answer is, because 2008 WAS a leap year. This is an unfortunate set of circumstances, because in reality leap year is every four years, but the console thinks that it is every two.
| Kommentaarid: 11 loe/lisa |
pealuu
02.03.2010 10:02:20
| helga kirjutas: |
* tegeliku lahendust ei otsitagi, pigem koostatakse juba homseks pressikat "kõik on P's" ja lihtsalt loodetakse, et kaob ise viga ära.
selles teoorias oli oma 50% tõtt. vaid pressiteatega ei ole maha saadud samas mahasaadud pressiteate sõnakasutus on imetlustvääriv - "we are aware that SOME users have been unable to connect to PlayStation Network".
huvitav millal kasutataks "many" kui praeguse sisu on umbes siuke et "jah... mõnedel üksikutel on probleeme".
| Kommentaarid: 211 loe/lisa |
170 |
jules
02.03.2010 10:13:01
no nüüd on korras asi juba.
huvitav kas viga võib korduda kui tuleb märts->aprill üleminek, süsteemis ju nüüd 1/3 kuupäev...
| Kommentaarid: 86 loe/lisa |
73 |
pealuu
02.03.2010 10:29:14
| kahtlustan et mitte. peale aja sünkroniseerimist üle võrgu peaks vast kõik õigeks keeratama. eks näis kas 4 aasta pärast tuleb ApokalyPS3 2 (ilmselt siiski lapitakse softiga asi ära enne seda).
170 |
asdasd
02.03.2010 11:01:49
| Oh p.s guys expect this all to happen on '29th February' 2014, 2018, 2022, and if you managed to make it last that long 2026. |
pealuu,
| Kommentaarid: 14 loe/lisa |
visalik
02.03.2010 14:39:14
| mul on slim ja crashis kah päris mitu korda
| Kommentaarid: 17 loe/lisa |
17 |
Labukana
02.03.2010 16:56:00
| seljuhul oli mingi muu viga :)
| Kommentaarid: 32 loe/lisa |
30 |
Raunts33
02.03.2010 17:40:16
See error oli sony märk sellest, et tuleb osta ps3 slim . Täna vist juba asjad korras kõigil? Mul õnneks selle ajavahemiku sees ei juhtunud midagi.
| Kommentaarid: 39 loe/lisa |
smola
02.03.2010 20:19:41
Eile foorumi lugedes ei julgenud oma ps3 käima panna, täna panin käima , ning midagi ei juhtunud , kõik töötab nagu peab Mudel CECHG04
| Kommentaarid: 67 loe/lisa |
59 |
angel
02.03.2010 20:25:35
juhtus vaid see et kuupäev läks seenele ja ei saanud asi võrku minna... ps3 ise töötas täitsa kenasti v.a võrgu lahendused.
157 |
Tom-D
02.03.2010 20:31:24
| Ei töötanud, mängida ta ei lubanud, trophisi installides andis errori ja edasi ei lasknud.
| Kommentaarid: 174 loe/lisa |
155 |
angel
02.03.2010 20:33:49
hm nu jah mängu minna ei proovinud (single player) aga videosid passisin jms asju nagu lubas teha. Oleks teadnud, et ma offline värk ei tööta oleks järgi proovinud. Ehk siis nüüd teatud kuupäeval või üldse tuleb PS3 võrkust maha võtta, et asi normaalsena toimiks
157 |
SaImu85
hondaa
02.03.2010 23:19:52
| angel kirjutas: |
Ehk siis nüüd teatud kuupäeval või üldse tuleb PS3 võrkust maha võtta, et asi normaalsena toimiks  |
Kiire poolt antud linki lugedes sain mina aru, et tegu pole absoluutselt võrgu veaga vms. 1 kell PS3 sees lihtsalt valetab iga 4 aasta tagant, ei ole just eriti suur kaotus ja seda ei saa ise kuidagi ära hoida, kui sony otsustab FW update-iga selle parandada, siis saad õnnelikult aastal 2014 1. märtsil mängida
| Kommentaarid: 24 loe/lisa |
24 |
angel
02.03.2010 23:35:55
eks häda ei ole aga veider apsakas... alguses mõtlesin et udu aetakse aga siis kui 2000 01 01 vastu passis ja võrku ei lubatud sain aru et asi on naljast kaugel. ... huvitav oleks see kui PS3 võrgust välja võtaks ja kuupäevaga mängiks siis peaks ju asi töötama offline mode'is ja sp mängudes. Kus kuramuse kohast PS3 teab mis kuupäev on kui tal võrku ei ole. Võib ju "reseti" kah asjale teha vajadusel.
157 |
jules
02.03.2010 23:54:31
| inimesed ikka ei ole päris aru saanud sellest bugist. tegu oli liigaasta bug'iga - aga juhtus see tavalisel aasta. oleks olnud liigaasta, nagu süsteem arvas, poleks midagi juhtunud.
73 |
Timberg
ööKARU
02.03.2010 23:55:18
Millised on suure replay väärtusega ps3 mängud?
Millised on parimad ps3 mängud, mida saab koos ühe konsooli taga korraga mängida (2 pulti, 1 telekas)?
http://www.co-optimus.com/ pole vaja,
Thx
272 |
ArvQ
02.03.2010 23:56:18
| angel kirjutas: |
| eks häda ei ole aga veider apsakas... alguses mõtlesin et udu aetakse aga siis kui 2000 01 01 vastu passis ja võrku ei lubatud sain aru et asi on naljast kaugel. ... huvitav oleks see kui PS3 võrgust välja võtaks ja kuupäevaga mängiks siis peaks ju asi töötama offline mode'is ja sp mängudes. Kus kuramuse kohast PS3 teab mis kuupäev on kui tal võrku ei ole. Võib ju "reseti" kah asjale teha vajadusel. |
Ajast täiesti valesti aru saanud. probleem oli nn bios'i kellas millega sa ei saa niisama mängida.
Ning võrgul ei olnud kah veaga miskit pistmist
| Kommentaarid: 176 loe/lisa |
149 |
angel
02.03.2010 23:59:59
mis mõttes? Kuidas ps3 teab mis kuupäev on kui ma lasen tal reseti ära teha, uue ketta sisse etc? Või on jutt sellest et see kuramuse "piix" hoiab omal cmos'is kella kogu aeg ärkvel ja seda ei ole võimalik maha tappa ilma bataka ära võtmisega? a'la cmos resett'i asjal ju ei ole. Nu siis tuleb oodata milllal bios batakas tühjaks saab kui just akuga tegemist ei ole (minuteada vanasti kasutasid teatud firmad akusid batakate asemel).
157 |
Timberg
ööKARU
03.03.2010 00:04:48
| Lisaks sooviks spetsidelt teada, mida peaks üks nub ps3 omanik teadma? Olen kuulnud, et ps3 peaks olema "sellili"; siis kestavad plaadid kauem. Vastab tõele?
272 |
Labukana
03.03.2010 00:13:34
| Timberg kirjutas: |
| Lisaks sooviks spetsidelt teada, mida peaks üks nub ps3 omanik teadma? Olen kuulnud, et ps3 peaks olema "sellili"; siis kestavad plaadid kauem. Vastab tõele? |
see kehtib pigem xboxi puhul, ps3 plaatide kestvusega minuteada probleeme pole, ka ei ole kuulnud kriibitud blu-raydest (mingi ekstrakaitsev kiht neil vms). ps3 slimi ei saa aga ilma jalata püsti panna vist väga, jäme seisis ilusti aga see peenem variant võib üsna lihtsalt küllili minna. pead kas mingite asjade vahele panema või ametliku jala ostma. kui aga ruumi on siis pane küllili.
kui ingliskeelt jagad siis võid uue ps3 omanikuna seda postitust seal lugeda, mängudesoovitusi ei tasu aga eriti tõsiselt võtta, see osa on uuendamata ja ei sisalda uuemaid mänge ega multiplatform mänge.
http://www.neogaf.com/forum/showthread.php?t=371859
30 |
gruuv
03.03.2010 00:14:27
| Minu CECHA00 aeg ka vale. Kõige hullem on et, Play TV-l saadete salvestus ajad viskasid kõik erroreid. Hea et kuskil reisil ei olnud, muidu ei oleks ühtegi saadet peale saanud.
| Kommentaarid: 4 loe/lisa |
jules
03.03.2010 00:15:41
"kell" koguaeg elab oma elu jah. peaks olema mingi aku moodi asi, töös olles pidi laadima ennast.
Timberg, seal teemas sulle juba räägiti ju
Little Big Planet - platvormikas
Uncharted 2 - coop on mission based. local-coopis kindel pole, keegi teine võiks täpsustada.
MW2 - saad splitscreeniga teha spec-op'e ja niisama ka DM'ida
Resistance 2 - saad splitscreeniga MP ja mission based coop'i teha (mõlemad onlines koos veel teistega)
Resident Evil 5 - story coop
Army of Two seeria - story coop
Red Alert 3 - saab coopis mängida
Mercenaries 2 - story coop võimalik
jnejnejne. hetkel on trendikas lisada coop sisse, nii et väga paljudel mängudel mingitpidi see on teostatud.
ja lisaks automängud splitscreens, spordimängud, kaklusmängud, guitar/band/dj/jamisiganes herod.
defineeri enda jaoks replay value. ja kas tahad lihtsalt coop mänge või muid asju ka. samuti kui palju sa pc'ga oled viimase aja multiplatvorme mänginud.
kui hakkad trophiesid koguma, saad platinumi jaoks mängu enamasti vähemalt 2 korda läbi teha (erinevate raskusastmetega). kui tahad tõelist powerit, võta ninja gaiden sigma 2 - et kõike ära teha, minimaalselt 7 läbimängimist.
gruuv... mine settings->date and time->date and time-> pane kell õigeks (manuaalselt või läbi interneti).
viimati muutis jules 03.03.2010 00:18:02, muudetud 1 kord |
73 |
angel
03.03.2010 00:16:33
Ma kuulnud jutte, et kui võtad auto plaadi lugemise maha siis kestab midagi kauem vms. Endal kah mugavam kui ei hakka kohe mäng tööle kui plaadi sisse viskad (mõnes mõttes, ise vahest viskan plaadi sisse, teen teisi asju ja alles siis viskan mängu käima). Endal on PS3 olnud enamus ajast juba püsti kuna vastasel juhul ei mahu ära.
Teadma peaks vast ka seda, et seadetest valida limited hdmi range. Vastasel juhul kui telekas (enamus ei toeta seda v.a lcd montior dvi to hdmi?) seda ei toeta on pilt suht piixsus (tumedamad mängud = üks must lärakas).
Enda "top" listis on mängud -> uncharted 1 ja 2 kus on väga kõva gameplay seoses kõmmutamise ja leveli ehitusega ehk siis ei ole üks kasti porno kus iga map on ühesugune ja ühe tasandiline v.a kast on nüüd 2cm teises kohas (2 osa isegi meeldib kenasti rohkem + coop, mp läbi võrgu), inFamous, God of War I, II, III? (kui meeldivad sedasorti mängud muidugist), Little Big Planet, Heavenly Sword, Saints Row 2 (kui jätta välja asjaolu et asi on olemas ka teistel kastidel, PC versiooniga võrrelda ei tasu kuna see oli ikka üks liikumatu käkk), ... gta 4
157 |
Tom-D
03.03.2010 09:05:56
Mulle jälle automaatne plaadimängimine istub kuna kasutan PS3 ka CD-mängijana. Jääb ära teleka sisse lülitamine. Kodukino tööle, valin kanaliks optilise, siis pleissa tööle, ootan paar sekundit, vajutan "X"-i ja pistan plaadi sisse, hakkab automaatselt mängima. Muusikakeskuse olin olude survel sunnitud lapse tuppa viima
155 |
Labukana
03.03.2010 10:56:02
| Tom-D kirjutas: |
Mulle jälle automaatne plaadimängimine istub kuna kasutan PS3 ka CD-mängijana. Jääb ära teleka sisse lülitamine. Kodukino tööle, valin kanaliks optilise, siis pleissa tööle, ootan paar sekundit, vajutan "X"-i ja pistan plaadi sisse, hakkab automaatselt mängima. Muusikakeskuse olin olude survel sunnitud lapse tuppa viima  |
või siis kui on uuem ps3 slim ja braviasync toega (hdmi-cec) toega kino ja telekas lülitavad viimased kaks end ise tööle kui ps3'e plaadi sisse paned.
30 |
visalik
03.03.2010 14:13:51
minu arust ei pea bravia telekas olema et ps3 teleka käivitaks, ,, et telekas ps3 e käivitaks selle jaoks vist on vaja, mul on samsungi oma ja läheb kohe tööle kui ps3 käima panen.
peab lihtsalt mingi hdmi control enabled olema
17 |
Labukana
03.03.2010 15:00:38
| visalik kirjutas: |
peab lihtsalt mingi hdmi control enabled olema |
jep seda ma selle hdmi-cec all mõtlesingi, igal tootjal oma nimetus asjale.
30 |
aivo80
| Kommentaarid: 31 loe/lisa |
29 |
03.03.2010 16:07:00
rezistääns kolm pakun
313 |
aivo80
03.03.2010 16:12:58
| SKG kirjutas: |
rezistääns kolm pakun |
Poleks paha, R2 lõpp jäigi "rippu"
29 |
Labukana
03.03.2010 17:05:55
või killzone3 või infamous2, mõlemad väidetavalt töös juba mõnda aega.
kui resistance 3 siis võiks see rohkem esimese resistance sarnane olla, teine osa oli minuarust märksa lahjem.
30 |
jules
03.03.2010 17:23:49
ammu aeg syphon filtri jaoks ps3'le. poleks viimast splintercelli vajagi
73 |
PeZ
03.03.2010 20:15:10
Sly Cooper 4
| Kommentaarid: 12 loe/lisa |
Raunts33
03.03.2010 20:37:48
inFAMOUS 2 ja KZ3 oleks loodud kui minu jaoks.
Mulle meeldiks ka üks jak and daxter ps3'le
Labukana
03.03.2010 20:41:13
| motorstormi ja warhawki järjed unustasin täitsa ära ja need ka täitsa reaalsed :)
30 |
gerhard
03.03.2010 22:39:45
| mul selline küsimus , et kuidas ma saan vanalt psn kasutajalt tõsta trohpy-ed tõsta uuele
10 |
ArvQ
03.03.2010 22:52:28
| Ei saagi ju?
149 |
malukas
| Kommentaarid: 124 loe/lisa |
95 |
313 |
angel
03.03.2010 23:35:33
tea ma vist üks väheseid keda resistance täitsa külmaks jätnud. Üritasin tükk aega 2 osa mängida aga nu ei suuda. 1'ese demo peletas juba ära seega selleni eriti ei jõudnudki. 2 osas on suht -> igav gameplay, jura graafika.... täitsa külmaks jättis. Näis mida 3 osa siis toob.
157 |
me@homeq
04.03.2010 00:26:16
| Endal CECHH04 see vanem 40GB mudel ja oli sama probleem sisselogimisega ja kell/kuupäev oli vale.Tahtsin tol päeval Bioshock2 onlines mängida aga kui sisse ei saanud siis tol päeval PS3 rohkem ei kasutanud.
| Kommentaarid: 23 loe/lisa |
21 |
313 |
Timberg
ööKARU
04.03.2010 21:53:51
kus ma ps3'le update teha saan? settings all ei leidnud.
sain täna ps3 kätte ja tahaks psnist mingeid demosid vms tõmmata, sest praegu on ainult saints row 2 ja mängiks hea meelega midagi normaalset
küsiks veel, kas ps3 saints row 2 on sama hull, kui pc'l olev versioon?
272 |
angel
04.03.2010 21:59:38
Settings -> System update?
Ta peaks sul seda ise pakkuma kui võrku lähed...
Ja nagu juba enne mainisin siis Saints Row 2 ei ole PS3 peal selline jooksmatu käkk nagu PC peal. Asi kohati viskab "pop up'i ehk siis autod ilmutavad või kaovad kauguses" ja tunda on "madalat" fps'i aga mitte midagi jubedat. PC omaga võrreldes jookseb PS3 oma suht nagu siid.
157 |
Timberg
ööKARU
04.03.2010 22:19:39
Kas te soovitate neid kange kuidagi konffida ka süsteemi alt? Proovisin natuke saints row 2'te, see kaamera liigutamine tundus nii sürr
272 |
Labukana
04.03.2010 22:39:34
| Timberg kirjutas: |
Kas te soovitate neid kange kuidagi konffida ka süsteemi alt? Proovisin natuke saints row 2'te, see kaamera liigutamine tundus nii sürr  |
pudliga peab harjuma lihtsalt, default on enamus mängudes juba hästi.
30 |
Timberg
ööKARU
04.03.2010 23:18:58
kuhu ma ennast psni elama peaksin regama?
272 |
Stig
04.03.2010 23:21:38
| UK või Soome
| Kommentaarid: 26 loe/lisa |
25 |
beastbeats
04.03.2010 23:56:24
Timberg, tee mitu kontot või vähemalt US ja mingi EU oma
_________________ Päevad lõpevad siis, kui lased neil minna... |
284 |
