devilman
11.02.2010 17:15:23
Oli jah normaalne, AINULT 1500 eeku maksid mängud 1995a.
| Kommentaarid: 19 loe/lisa |
19 |
1dumbpcuser
15.02.2010 14:43:51
Assassin's Creed 2 PC is DX9 only
PCGamesHardware
PCGH: Can you explain why you removed support for DX10.1 in Assassin's Creed with the patch 1.02 although DX10.1 improved the quality of FSAA as well as the performance on Radeon cards? Is it really true that DX10.1 caused errors when calculating post processing? Will the renderer of Assassin's Creed 2 support DX10.1 or once again just DX10?
David Champagne: I personally didn't work on the first Assassin's Creed PC so it would be hard for me to answer this question. For Assassin's Creed II, we decided to stick to DX9. This allowed us to focus on a single version of the renderer and helped us to achieve the best possible performances. |
_________________ M: |
97 |
KrisVr
15.02.2010 15:08:30
| 1dumbpcuser kirjutas: |
PCGamesHardware
Pekki küll. Kõik on arvatavasti nende konsoolide süü.
| Kommentaarid: 30 loe/lisa |
1dumbpcuser
15.02.2010 15:10:43
Kui artiklit loed, siis nii ongi.
PCGH: Why do you decide against supporting DX11? Would the integration of the API into the renderer have consumed too much developing time? Are there any plans to patch in DX11 support later?
David Champagne: We are using the same rendering engine as the Xbox 360 version which is based on DX9. Integrating DX11 in our renderer would have definitely been too much time-consuming given our release date. |
97 |
Timberg
ööKARU
15.02.2010 15:19:25
Permanent internet connection
required to play
• No need for cd/dvd to play!
• Unlimited installs
• Saved games are synchronized online
Info päris ametlikult AC2 ümbriselt
272 |
Timberg
ööKARU
15.02.2010 15:22:51
| omgwtf kirjutas: |
10-15 a tagasi oli hind ka ehk normaalne Hetkel lähevad mängude hinnad kuni 1k kanti.. |
Ei vasta tõele.
Ca 10 aastat tagasi maksis originaal mäng umbes 600-1400 krooni.
Sai sellel ajal ostetud igasuguseid starwars mänge, red alert, sam and max jms.
Ära ei tohiks ka unustada seda, et krooni väärtus oli siis KÕVASTI suurem.
See, et tänapäeval lähevad mängude hinnad kuni 1k kanti on bs. Konsoolimängud maksavad Eestis alguses nii palju (ja mitte kõik). PC mängud on alguses 500-800. Lisaks ei olnud vanasti mängude suhtes Eesti turul rohi rohelisem, sest mängude müüginumbrid olid kordades väiksemad - hinnad langesid kõvasti aeglasemalt ja valik oli kõvasti nirum võrreldes tänapäevaga.
272 |
Ahf
15.02.2010 18:28:55
| Dude . kirjutas: |
| Enivei, kõik kes maksavad tänapäeval tavalise mängu eest on lollid (ei räägi special edition'itest jms). |
| Kommentaarid: 57 loe/lisa |
54 |
15.02.2010 18:50:26
Ei no mul pole sõnu.DX9 only kuna ei viitsitud lihtsalt DX10.1/11 külge pookida ja siis see draconian DRM veel takkaotsa .Mina haistan FAIL-i tulemas
_________________ Win11 25H2 upgrade skriptid neile kelle masin ise ei taha 23H2 või 24H2 pealt ennast uuendada:
https://foorum.hinnavaatlus.ee/viewtopic.php?p=11720738#11720738 |
| Kommentaarid: 92 loe/lisa |
xxlmaster
15.02.2010 18:55:47
ära haista, mäng on väga püss
Palju on mänge mis uute osadega aina halvemaks on läinud aga selle puhul jäin mõtlema miks nad üldse esimese osa tegid
Endale meeldis väga ja oli minu lemmikute seas teisel kohal
| Kommentaarid: 83 loe/lisa |
77 |
Dude .
15.02.2010 19:12:13
xxlmaster, mängu enda kvaliteet ei määra midagi! Kui DX11 toetust ei ole ja ma seda väikest graafikalist vahet ei näe, siis on täiesti mõttetu.
_________________ TALUSILDID |
| Kommentaarid: 15 loe/lisa |
15 |
xxlmaster
15.02.2010 19:33:12
Dude ., Ee mx siis seda mulle räägid. Mul jumala savi mis asjaga see tuleb. Olgu või DX8 Ise paugutan selliseid mänge naguni pleisi peal
77 |
denis28
15.02.2010 20:26:43
| mina ka mingeid suuri vahesi ei näe dx9 vs dx10 ni et savi sellest
| Kommentaarid: 67 loe/lisa |
omgwtf
15.02.2010 20:40:25
Sul ikka vista või W7 on peal? Ma ka XP peal vahet ei tee.
137 |
heretic666
15.02.2010 20:40:52
| omgwtf, see vahe on ikka tühine. Varjuefektid vms midagi on näha jah, ent üldjuhul on kõik samasugune.
| Kommentaarid: 73 loe/lisa |
heretic666
15.02.2010 21:05:12
| No mis tollest, toda ei tuleks ju mitte mingil juhul anyway. nVidia *~> 0wn ya
denis28
15.02.2010 21:21:29
| omgwtf, ? tiba on , aga mingi et omfg now thats dx10 allright effekti ei ole...
Gap
16.02.2010 00:00:12
esimene Assasins Creed oli DX10 või oli ka ainult DX9 ? sry ei mäleta enam hakkasin mõtlema et on sellel siis mingit vahet DX9 all peaks siis paremini mäng jooksma ka ? Dirt 2 oli ka ju DX9 ainult juhul kui sul seda DX11 kaarti polnud.....
| Kommentaarid: 21 loe/lisa |
17 |
heretic666
16.02.2010 00:02:40
| Esimene oli dx 10.1
Gap
16.02.2010 00:19:13
jama ma nii ootasin seda mängu ja nüüd keeratakse kõik ptsi nojah ega nende konsoolide graafikast polegi midagi paremat oodata
17 |
Ramones
16.02.2010 00:26:09
Gap, misasja... See, et mäng on DX9 ei tähenda, et ta eelmisest sajandist on. 99% ajast teegi vahet kas mäng jookseb dx9 või dx10 peal. Isegi konsoolil nägi see mäng suurepärane välja ja ma arvan, et PC peal tuleb sellest suurepärane eyecandy . Ja mängu ikka mängitakse, mitte ei vahita luubiga ekraanil piksleid. Kui esimene osa meeldis, siis meeldib teine osa veel rohkem!
| Kommentaarid: 76 loe/lisa |
75 |
NeroEST
16.02.2010 09:57:27
Ega suurt vahet tõesti ei ole, niipalju kui näinud olen, näeb ac 2 xbox360e peal täiesti kobe välja. Kui ma hästi mäletan, siis meeldis mulle AC1e ka pigem xboxi kui arvuti peal mängida, sest arvuti peal nägi ta kuidagi vähem polished välja.
Halva maitse jätab aga see, et nad seekord siis ei varjagi oma marketingutrikki, tavaliselt tuleb arvuti peale mäng hiljem välja sellepärast, et "tehakse graafika paremaks", mitte ei jäeta samaks vms. Kõik teavad nagunii, et trikk on xboxi pealt raha kokku koorida, kuid tunne on ikka selline, et vähemalt saame arvuti peal parema graafika, kuid seekord tuleb välja, et developerid kusevad arvutiomanikele näkku: "saate sama graafika ja lihtsalt 4 kuud hiljem"
_________________ Winter is coming... |
| Kommentaarid: 38 loe/lisa |
37 |
Ramones
16.02.2010 12:26:39
| NeroEST, kus on väidetud, et PC peale sama graafika tuleb? Konsooligraafika on madala resolutsooniga ja PC peal võrreldes heal juhul medium (tavaliselt med-low) graafikaseadetega. PC peale tuleb ikkagi kõrge resolutsioon, kõrge kvaliteediga tekstuurid, kõrgem view distance, AA/AF ja ilmselt veel lisaks käputäis muid parendatud detaile millest konsooli peal ainult unistada võib. Ega dx9 vs dx10 (11) pole mingi pühalik ime, et graafika 100x paremaks teeb kohe. Hea, et üldse mingit vahet nende vahel märgata on.
75 |
Sakurai
16.02.2010 20:03:56
| Täiega suva et ei tule dx 10. Nkn ei paneks seda peale, vahe minimaalne. Booo
18.02.2010 20:41:28
noh, enne kui see vahva drm ära häkitakse, seda ostma ei tõmba küll mitte kuidagi.
_________________ - londiste
216 |
