06.01.2010 09:38:26
Western Digital Developing Next Generation VelociRaptor
http://www.dailytech.com/article.aspx?newsid=17194
WDC has decided that it is time for a refresh in order to push its capacity advantage further, and is currently developing its fifth generation Raptor. It will also be a 10k RPM drive, but will utilize advances in areal density to achieve a 600GB capacity with two platters. The new drive will also have "a significantly larger cache", but our source won't specify whether it was 32MB or 64MB. The best part will be the pricing, as it will launch at close to the original launch price of the 300GB VelociRaptor. A new single platter 300GB version will follow later on.
Seagate recently released its latest Barracuda XT drive featuring 64MB of cache and a 6Gbps SATA interface. There is no information available on whether the new VelociRaptor will also use a 6Gbps interface, although it does seem likely. |
Peaks ikkagi üsna konkurentsivõimeline olema selle hinna ja mahu juures
EDIT:
Crucial C300 6Gbps SATA SSD Available in February, Looks to Claim Fastest Drive Title
http://www.dailytech.com/article.aspx?newsid=17300
| The drive is able to reach a sustained sequential read speed of 355 MB/s, and a sustained sequential write speed of 215 MB/s. |
| Kommentaarid: 92 loe/lisa |
AJ
| Kommentaarid: 37 loe/lisa |
36 |
1dumbpcuser
97 |
AJ
36 |
DVDRW
11.01.2010 17:18:23
| xheix1712 kirjutas: |
Huvitav kas 32gb-sest ssd-st piisaks windowsi jaoks või jääb siiski veits väikseks  |
Saan siin enamvähem 4GB (EEEPC XP) kettaga hakkama
Närvi ajab juba see SSD ketaste kirjutamiskiiruse tuletikuga taga otsimine
Ilma seda teadmata ei saa ju ketast osta, kõige tähtsam kriteerium. Kuskil võiks olla mingi tabel vms.
| Kommentaarid: 28 loe/lisa |
Denke
AJ
11.01.2010 23:04:51
Plextor shows Marvell-based SSDs at CES
http://techreport.com/discussions.x/18274
A longtime a manufacturer of optical drives, Plextor will dip its toes into the solid-state market in 2010 with a pair of SSDs based on a 3Gbps Marvell SSD controller. The drives use flash memory from Samsung and will be available in 64 and 128GB capacities in February. Final versions weren't on display at Plextor's suite, but the only changes to the drives pictured below will be cosmetic etching on the casing.
These first two models have already been qualified for use by Dell. Plextor has additional models planned for the summer, as well. Expect those drives to use a newer Marvell controller, presumably with 6Gbps SATA support. Plextor also told us that its second batch of SSDs will use flash memory from Toshiba. |
36 |
1dumbpcuser
15.01.2010 18:26:28
Kingston Coming With 30 GB 'Boot' SSD for $80
TomsHW
| Kingston will ship next month the SSDNow V Series 30GB Boot Drive which will be promotionally priced at $79.99 after rebates (U.S. only). Performance is rated up to 180MB/sec. read, 50MB/sec. write. The SSD will offer Windows 7 TRIM support, which helps the SSD maintain high performance through the life of the drive. |
97 |
AJ
36 |
rene p
01.02.2010 20:26:52
Intel & Micron Announce 25nm NAND Flash Production, SSDs to get Bigger/Cheaper in Q4
http://www.anandtech.com/storage/showdoc.aspx?i=3731
Obviously supply and demand economics play their roles here. We may not see the sort of aggressive pricing we want to on 25nm X25-M drives if demand remains as high as it has been for the 34nm G2s.
Samas jälle viimane lause tõotab paremat.
If IMFT can ramp up production of 25nm NAND flash, 2012 may be the year of the first truly affordable mainstream SSDs.
68 |
AJ
02.02.2010 23:35:31
Corsair goes on SSD offensive, launches Reactor and Nova series drives
http://www.hexus.net/content/item.php?item=22197
Around this time last year, Corsair jumped into the SSD market with a splash - and though its Performance and Extreme series drives continue to offer hard-drive-shaming speeds - we've yet to see the California-based memory specialist really stretch its legs.
Well, that's all about to change today with the introduction of four new drives as part of the companies Reactor and Nova series SSDs, all of which have made an appearance at UK retailer cclonline.com.
Corsair's Reactor series, pictured above, arrives in 60GB and 120GB capacities, with early pricing set at around £147 and £285, respectively.
We've yet to see any mention of which controller is used but we do know there's 128MB of onboard cache, and read and write speeds are quoted at 250MB/s and 110MB/s, respectively, for the 60GB drive, whilst the larger 120GB offering will hit 250MB/s and 170MB/s.
Corsair reckons the Reactor series offers "the perfect balance of performance and value", but considering the speeds and pricing, these look to be direct replacements for the existing Performance line.
Need more choice? There's also the all-new Nova series, available in 64GB and 128GB capacities, with pricing currently at around £155 and £295, respectively.
With the Nova you'll be treated to the popular Indilinx Barefoot controller, and read speeds of up to 215MB/s. The 60GB drive will net you write speeds of 130MB/s, whilst the range-topping 128GB model will peak at an impressive 195MB/s. A like for like replacement for the existing Extreme series range, perhaps?
All four drives ship with TRIM support right out of the box, and we expect Corsair's latest to show up at various retailers by the end of the week.
*Update* Corsair's latest drives have surfaced on the virtual shelves of SCAN.co.uk*, with pricing at £146.70 and £284.63 for the Reactor drives and £154.82 and £292.75 for the respective Nova models. Looks as though those initial pricing figures were spot on. |
E.
IMFT's 25nm NAND Flash Will Cut Production Costs in Half, Spur New SSDs
http://www.dailytech.com/IMFTs+25nm+NAND+Flash+Will+Cut+Production+Costs+in+Half+Spur+New+SSDs/article17549.htm
36 |
Mario.
03.02.2010 13:13:53
| TomsHardware kajastas hiljuti üht ülevaatlikku SSD-de võrdlust. Tuleb välja, et säästumälu pole väga mõtet omandada kui ei raatsi paar tuhat selle peale panna. Muidugi Intel G2 tegi puhta töö. Võrdluseks oli ka Raptor toodud.
6 :: |
217 |
Kristoferr
| Kommentaarid: 269 loe/lisa |
220 |
AJ
03.02.2010 15:08:27
Kristoferr, mul kastis sama ketas. Kuidagi ei tahtnud W7-t HDD peale installida. Ketta peal kül kirjas, et Kingstan aga arvuti tunneb selle ära kui Inte X25-M'i.
36 |
Kristoferr
220 |
AJ
03.02.2010 15:32:03
Seda tean, et tegemist on sisuliselt sama tootega. Sai enne ostmist hulga ülevaateid läbi loetud. Ma lihtsalt arvasin, et nad on viitsinud nii palju vaeva näha, et seda SSD-d tuntakse ära kui Kingston-i. Hind on jah sõbralikum aga võiks olla veel parem.
36 |
Kristoferr
03.02.2010 15:35:28
| AJ kirjutas: |
Seda tean, et tegemist on sisuliselt sama tootega. Sai enne ostmist hulga ülevaateid läbi loetud. Ma lihtsalt arvasin, et nad on viitsinud nii palju vaeva näha, et seda SSD-d tuntakse ära kui Kingston-i. Hind on jah sõbralikum aga võiks olla veel parem.  |
Ole hea viska paar testi selle kettaga.
HD tach read ja write jms
Ma tean, et igasugu revjuusid on olemas, aga tahaks just sinu oma näha
Mul läheks too tutika XPS 16 sisse.
_________________ Liitu Z.ai coding plaaniga ja saa 10% soodust!
Liitu Wise'ga! |
220 |
XYZ
03.02.2010 15:35:56
| AJ kirjutas: |
Mida see sulle annab, kui Kingstonina ära tuntaks ja samas üks-ühele tegelikult Inteli mudel on ja tööks vajab, et teda Inteli vastava mudelina käsitletaks? Ma pigem kahtlustaks, et kvaliteet viletsam ja seetõttu siis Intel ei taha oma nime all müüa....
| Kommentaarid: 81 loe/lisa |
12 :: |
56 |
AJ
03.02.2010 20:05:02
Mõned testid sai lastud. Koju jõuan, siis panen ülesse.
E.
36 |
Andium
03.02.2010 21:15:11
| AJ kirjutas: |
| Kristoferr, mul kastis sama ketas. Kuidagi ei tahtnud W7-t HDD peale installida. Ketta peal kül kirjas, et Kingstan aga arvuti tunneb selle ära kui Inte X25-M'i. |
Eks seal olegi jälle üks firma kes toodab ning erinevad firmad kleebivad oma nimesid peale. See on näiteks Video kaartidega ja päris palju IT tehnikaga viimasel ajal nii.
_________________ Olen alati ühel arvamusel inimestega, kes minuga nõustuvad.
viimati muutis Andium 04.02.2010 19:59:02, muudetud 1 kord |
| Kommentaarid: 4 loe/lisa |
AJ
36 |
1dumbpcuser
05.02.2010 00:17:34
SilverStone Device Gives 70% HDD Boost
TomsHW
97 |
AJ
36 |
Kristoferr
08.02.2010 15:19:56
V seeria on suht pointless jah. V+ seeriast alates võib juba võtta.
Eestis kahjuks pole eriti valikut ja hinnad on neil Eestis ka väga
Vahel leiab siin foorumites normaalseid pakkumisi. Vähe kasutatud SSD pole halb, kui saad ta 1000-2000eek odavamalt.
Liitu Wise'ga! |
220 |
1dumbpcuser
08.02.2010 15:27:57
Q&A: Tom's Hardware And Kingston On SSD Technology
TomsHW
97 |
tqz
08.02.2010 15:52:52
40.
| Kommentaarid: 75 loe/lisa |
72 |
AJ
36 |
aise
10.02.2010 16:05:51
krt ma ei saa aru miks need kettad nii kallid on. see tehnika, mis on pöörleva ketta sees peaks olema oluliselt kallim ja vajab karmimaid tingimusi kokku panekuks... SSD on tavaline trükiplaat mälude ja kontrolleritega ehk kividega
| Kommentaarid: 189 loe/lisa |
172 |
AJ
10.02.2010 16:19:40
| aise kirjutas: |
krt ma ei saa aru miks need kettad nii kallid on. see tehnika, mis on pöörleva ketta sees peaks olema oluliselt kallim ja vajab karmimaid tingimusi kokku panekuks... SSD on tavaline trükiplaat mälude ja kontrolleritega ehk kividega  |
Uus asi hea ostjaid lüpsta ja rohkem pappi teenida.
36 |
Kristoferr
10.02.2010 16:24:30
Sama võid küsida, miks ddr3 nii kallis on. 4gb kit u1500eek. Ilmselt peitub vastus tootmise tehnoloogia kalliduses. Ma ei usu hetkekski, et keegi siin otseselt hiigelkasumeid nende ketaste pealt teenib.
SSD on turul olnud ikka üsna mitu aastat ja konkurents oleks hinnad ammu õiglaseks surunud.
Ma sain oma 120gb OCZ Vertexi 3500eestimaisega ja rahul. Perfi kasv tavalise läpaka kettaga võrreldes on ikka ulmeline.
Kui kiiret programmide loadimist ja data transferi tahad, siis tuleb kahjuks see papp välja käia.
Liitu Wise'ga! |
220 |
sepaonu
11.02.2010 12:16:44
Üks rumal küsimus ka: millised oleks Acronisega image ülekandmise puudused/konksud puhta installi ees? Mis katki saab minna?
Ja teine rumal küsimus: mille poolest Kingstoni M seeria parem on (tootja hindab teda justkui kõrgemalt) kui V+? Viimane peaks ju kiirem olema?
viimati muutis sepaonu 11.02.2010 12:20:55, muudetud 1 kord |
| Kommentaarid: 6 loe/lisa |
AJ
11.02.2010 12:16:49
Kingston Boosts Speed, Adds TRIM Support to Entry-Level SSD Line
http://www.techpowerup.com/114994/Kingston_Boosts_Speed_Adds_TRIM_Support_to_Entry-Level_SSD_Line.html
Kingston Digital, Inc., the Flash memory affiliate of Kingston Technology Company, Inc., the independent world leader in memory products, today announced it will ship its second generation SSDNow V Series solid-state drive (SSD) on February 15. Targeted for mainstream consumers and small and medium businesses, the new Kingston SSDNow V Series offers higher performance than its predecessor and supports Windows 7 TRIM functionality while maintaining pricing. Capacities are 30GB, 64GB and 128GB and the drive comes as a standalone unit or with a bundled solution for desktop or notebook systems.
"Kingston has really increased the performance on the new second generation SSDNow V Series drive without raising the price. A first-generation SSDNow V Series 64GB bundle upgrade kit can be found for about $150 (U.S.) at retailers and e-tailers so maintaining pricing will be huge for our customers," said Ariel Perez, SSD business manager, Kingston. "By bundling together all of the software, hardware and step-by-step instructions with the drive, we make it easy for everyday users to upgrade with an SSD. The addition of TRIM support is a key benefit because it enables the SSD to maintain optimal performance throughout its lifespan."
Kingston's SSDNow V Series upgrade bundles are the simplest, most efficient upgrade path to inject new life and performance into an existing desktop or notebook PC. There is no need to reload the operating system or do anything that would alter critical data files. The included cloning software makes it simple to move the contents of the existing hard-disk drive (HDD) to the SSD.
The SSDNow V Series upgrade bundle kits include:
* Kingston SSDNow V Series solid-state drive
* Acronis True Image cloning software and CD installation guide
* 3.5" mounting brackets and hardware (desktop bundle only)
* SATA data and power cable extenders (desktop bundle only)
* 2.5" USB SATA external enclosure (notebook bundle only)
The Kingston SSDNow V Series and bundle are backed by a three-year warranty, 24/7 tech support and legendary Kingston reliability.
Kingston SSDNow V Series Features and Specifications:
* Sequential Speed*:
o 128GB: up to 200MB/sec. read; 160MB/sec. write
o 64GB: up to 200MB/sec. read; 110MB/sec. write
o 30GB: up to 180MB/sec. read; 50MB/sec. write
* PCMark HDD 2005**:
o 128GB: 20,177
o 64GB: 21,317
o 30GB: 18,900
* Performance: enhances productivity; makes users more efficient
* Innovative: 2.5" form factor; uses NAND Flash memory components
* Silent: runs silent and cool with no moving mechanical parts
* Reliable: less likely to fail than a standard hard drive
* Shock Resistant: no moving parts so the SSD handles rougher conditions than a hard drive
* Supports TRIM: TRIM notifies the SSD which data blocks are available to be written to
* Supports S.M.A.R.T.: Self-Monitoring, Analysis and Reporting Technology
* Guaranteed: backed by a three-year Kingston warranty, 24/7 tech support
* Capacity: 30GB, 64GB, 128GB
* Storage temperatures: -40° C to 85° C
* Operating temperatures: 0° C to 70° C
* Vibration operating: 2.17G (7-800Hz)
* Vibration non-operating: 20G (20-2000Hz)
* Power specs: 128GB, 64GB Active: 5.2W (TYP); Sleep: 0.7W (TYP)
30GB Active: 1.7W (TYP); Sleep: 0.05W (TYP)
* Life expectancy: 128GB , 64GB: 1 million hours MTBF
30GB: 500,000 hours MTBF
* Based on internal testing. Performance may vary based on system settings.
** Test System: Intel DG45ID Desktop Motherboard; Intel Core 2 Quad Q9550 CPU at 2.83GHz; 4GB system memory; Windows XP SP3 |
36 |
rene p
11.02.2010 13:08:41
| sepaonu kirjutas: |
Ja teine rumal küsimus: mille poolest Kingstoni M seeria parem on (tootja hindab teda justkui kõrgemalt) kui V+? Viimane peaks ju kiirem olema? |
M seeria peaks olema Inteli kontrolleriga, V+ on samsungi kontrolleriga. Eks sealt see vahe sisse tuleb.
68 |
AJ
36 |
Player1
12.02.2010 02:45:21
| sportlikust huvist küsin, et kas näiteks need SuperTalenti ja OCZ PCI-E kettad on ka buuditavad ja kui palju neil üldse perspektiivi on?
| Kommentaarid: 40 loe/lisa |
38 |
12.02.2010 07:17:16
| Player1 kirjutas: |
| sportlikust huvist küsin, et kas näiteks need SuperTalenti ja OCZ PCI-E kettad on ka buuditavad ja kui palju neil üldse perspektiivi on? |
Ma usun, et on buuditavad küll jah.Igatahes sarnased FusionIO omad on.
Kahjuks need on ilmselt veel pikka aega liiga kallid.
Vb tekib kunagi sama olukord SSD turul nagu HDD turul kunagi oli, et enamus kettaid on tavalised 7200rpm ja siis entusiastid kasutavad 10000rpm Raptoreid.
Et siis enamus kasutab tavalisi MLC SSD-sid ja entusiastid siis kas kallemaid SLC või PCI-E SSD-sid
AJ
36 |
Kristoferr
12.02.2010 11:29:25
tomorrow, suure tõenäosusega PCI-E SSD muutub hoopiski järjest vähem populaarseks. PCI-E-2 x16 pakub küll (kümneid kordi)rohkem, kui piisavalt läbilaskevõimet (8GB/s), kuid uus -juba välja tulnud Sata 3 pakub ka juba 6 Gbit/s, mida siiamaani ükski SSD ei suudaks ära kasutada. Tõsi on, et Sata 2 võib teatud olukorras SSD ketastele vist jalgu jääda.
Liitu Wise'ga! |
220 |
AJ
36 |
12.02.2010 13:18:47
| Kristoferr kirjutas: |
| tomorrow, suure tõenäosusega PCI-E SSD muutub hoopiski järjest vähem populaarseks. PCI-E-2 x16 pakub küll (kümneid kordi)rohkem, kui piisavalt läbilaskevõimet (8GB/s), kuid uus -juba välja tulnud Sata 3 pakub ka juba 6 Gbit/s, mida siiamaani ükski SSD ei suudaks ära kasutada. Tõsi on, et Sata 2 võib teatud olukorras SSD ketastele vist jalgu jääda. |
Mingil põhjusel suudetakse praegugi PCI-E peal hulga suuremaid kiiruseid kätte saada kui SATA peal kunagi nähtud on.Selles suhtes SATA 6Gb/s veidi aitab jah aga usun, et PCI-E omad jäävad ikka kiireimateks(ja kalleimateks )
Kristoferr
12.02.2010 13:40:20
NU raid0 SSD puhul võibki sata2 < pci-e. Üldiselt aga ei tohiks kiiruse vahe eriti märgatav olla. Sata 3 - pci-e puhul veel vähem. PCI-e porti võiks ikka muudel otstarvetel kasutada. PCI-e SSD ketastel minu arvates siiski pikka pidu enam pole.
Liitu Wise'ga! |
220 |
Jaan
14.02.2010 16:53:45
Sa ajad midagi segi- SATA 3 on "kõigest" 600MB/s (Transfer speed), PCI-Ex16 (v2.0) on aga 8000MB/s, ehk 133X suurem, mitte kümneid kordi.
Hetkel parimad SSD kettad suudavad täita üle pole SATA3 läbilasest, kaks sellist "rauas" RAID0-s ja ongi piirajaks liides. Jälle.
123 |
Kristoferr
220 |
14.02.2010 17:30:22
6gbit/s = 750mb/s, 715mb/s kanti peaks olema max reaalselt saavutatav (minimaalse overheadiga). nagu nimetuski räägib, 600mb/s on projekteeritud garanteeritud kiirus.
Jaan, paranda kui eksin, aga mäletamist mööda ka single ssd-d on jõudnud kuskile 250mb/s kanti.
_________________ - londiste
217 |
Jaan
123 |
1dumbpcuser
16.02.2010 09:46:29
Adaptec MaxIQ: Flash SSDs Boost RAID Performance
TomsHW
| Conclusion kirjutas: |
With MaxIQ, Adaptec doesn’t offer a revolutionary product to the business storage market, but it manages to combine proven caching technology with a high-performance flash SSD in an effort to accelerate existing systems at an affordable cost. Although the effective I/O performance level may vary and often cannot reach individual SSD performance, the MaxIQ approach is strikingly conclusive and very easy to implement. It introduces a few of the benefits offered by SSDs without touching your storage strategy.
Adaptec's marketing claims that the MaxIQ package is able to deliver up to 5x performance boosts. We do see instances where this holds true, but only if the RAID volume capacity is limited to less than the flash SSD’s capacity. However, arrays larger than the cache capacity may still contribute to overall performance, as Adaptec can actually read cached “hot” data from the SSD and simultaneously deliver uncached “cold” data from the array.
Effective I/O performance gains for applications that are primarily dependent on read operations will be anywhere from 15% to 45% if the RAID volume is several times larger than the cache. This alone is worth the $1,295 investment because such an increase in I/O performance would otherwise require many additional disk drives you might not want or need. Needless to say, these would also increase power requirements, the chance of a drive failure, and probably even require the transformation of an existing RAID array across all available drives. Going for a single SSD is, of course, not an option, since you would lose redundancy. Only the minimum of three X25-E SSDs at 32GB for a RAID 5 would provide redundancy. The sacrifice there would be much smaller capacities than you might already be using and lots of additional cost.
We’ve also seen performance benefits of 2x and greater in a few cases, which is more than you can reach through tacking on additional mechanical hard drives. Adaptec’s solution does a great job at lifting RAID storage performance to levels at which existing storage solutions can, in fact, be refreshed for another few years of operation.
_________________ M: MSI B660M MORTAR
O: AM5 ITX emaplaat |
97 |
Juan Pablo
16.02.2010 18:43:59
Crucial "laksab" ikka igal pool mälu kiirustes teistele ära
küll ddr3-mes küll ssd-s
29 |
AJ
36 |
omgwtf
137 |
