RCC
30.01.2010 17:52:30
| urri kirjutas: |
täna kell 6 hommikul oli kiirus seal 1200 kbit/s
lõunaajal 150 kbit/s
arvata on et asi ikka korralikult ülemüüdud |
jah sest just eelmine (nüüd üleelmine ) post normeeris taaskord kiiruse 6kbps peale
9 :: |
147 |
hendrik32
31.01.2010 00:02:42
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Assass1nat0R>ping www.ee
Pinging www.ee [194.204.33.19] with 32 bytes of data:
Reply from 194.204.33.19: bytes=32 time=888ms TTL=58
Reply from 194.204.33.19: bytes=32 time=1300ms TTL=58
Reply from 194.204.33.19: bytes=32 time=1007ms TTL=58
Reply from 194.204.33.19: bytes=32 time=484ms TTL=58
Ping statistics for 194.204.33.19:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 484ms, Maximum = 1300ms, Average = 919ms
Tase, anna minna KÕU!
| Kommentaarid: 16 loe/lisa |
12 |
urri
31.01.2010 09:34:52
kell 05:00 - keskmine DL 1,1 Mega
kell 08:30 - keskmine DL 0,6 Mega
kell 13:10 - keskmine DL 0,2 Mega
kell 16:10 - keskmine DL 0,1 Mega
midagi liigutamata, midagi ümber tegemata, ilm laias laastus sama olnud kogu aeg
viimati muutis urri 31.01.2010 17:16:18, muudetud 3 korda |
| Kommentaarid: 4 loe/lisa |
gnoom
31.01.2010 10:20:02
| hendrik32 kirjutas: |
Tase, anna minna KÕU!  |
ping www.ee
PING www.ee (194.204.33.19) 56(84) bytes of data.
64 bytes from www.infoweb.ee (194.204.33.19): icmp_seq=1 ttl=59 time=158 ms
64 bytes from www.infoweb.ee (194.204.33.19): icmp_seq=2 ttl=59 time=142 ms
64 bytes from www.infoweb.ee (194.204.33.19): icmp_seq=3 ttl=59 time=181 ms
64 bytes from www.infoweb.ee (194.204.33.19): icmp_seq=4 ttl=59 time=140 ms
64 bytes from www.infoweb.ee (194.204.33.19): icmp_seq=5 ttl=59 time=158 ms
--- www.ee ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4001ms
rtt min/avg/max/mdev = 140.861/156.487/181.723/14.670 ms
Mobiilne seade ilma lisaantennita. Mastiks Pärnu-tervis. Kaugus mastist ~5km
| Kommentaarid: 67 loe/lisa |
hendrik32
31.01.2010 14:29:06
| gnoom kirjutas: |
ping www.ee
Mobiilne seade ilma lisaantennita. Mastiks Pärnu-tervis. Kaugus mastist ~5km |
Nüüdseks on mul nett jälle OK, sai just Austraalia lahtiste finaal ära vaadatud ilma suurtemate tõrgeteta
12 |
anim
| Kommentaarid: 23 loe/lisa |
22 |
gnoom
31.01.2010 14:51:21
No sellisel juhul ei tasuks seda remontida.
hendrik32
31.01.2010 20:47:12
2 päeva järjest on asi väga dial upi moodi ja ping on 1000ms
12 |
02.02.2010 03:15:42
Täiesti müstika ikka, käisin mööda maja ja tegin igas punktis 5 speedtest netti ja kõige parema tulemuse sain teleka peal, stabiilselt 1.5 mbit alla ja 0.5 ülesse, teistest kohtadest sai 0.4-1.1mbit... ja siis poole tunni pärast ei olnud tal teleka peal üldse ühendust
02:15 öösel, ei tea kas Jägala või Kuusalu masti küljes
| Kommentaarid: 94 loe/lisa |
81 |
eng1net
03.02.2010 18:51:43
Sooviks osta omale mobiilse kõu seadme,et kas keegi oskab soovitada mingit paremat seadet....
vaatan,et mõni on antenniga ja mõni ei ole,et milline neist kõige parem on?
urri
03.02.2010 19:45:30
| www.kou.ee - seal enamasti kõik pulkadeks lahti seletatud
gnoom
03.02.2010 21:09:56
| eng1net kirjutas: |
vaatan,et mõni on antenniga ja mõni ei ole,et milline neist kõige parem on? |
Kõige parem on see mis töötab.
Näiteks oma ise ühte esimestest USB-i klotsidest ja siiani käib asi nagu mees muiste.
Xcater
04.02.2010 00:35:15
Tallinn, Kristiine. Seadmeks C-Motech CNR 680W. Seade on paigaldatud aknalauale ning igast lisa jubinad puuduvad. Päeval saab netis ilusti surfada ja meili lugeda, Youtubes peab enamus videosid ette laadima, multiplayer mängud jooksevad enam-vähem "läägi" vabalt, torrent tuleb kuskil 100Kb ringis.
Tulemus
| Kommentaarid: 29 loe/lisa |
26 |
urri
1n5an3
04.02.2010 16:44:53
Asi liigub paremuse poole m6ni hommik sarvik seina peal suudab isegi 200KB/s v2lja ajada
Läbiviimise aeg: 04.02.2010 15:36:08
Kliendi IP-aadress: 95.153.1.59 <---- k6ul uus ip?
Kliendi AS-number (päringu tekitajat ja teenusepakkujat identifitseeriv info): IP-aadress ei kuulu ühegi autonoomse süsteemi (AS) alla
Testi tüüp: JavaScript
Üleslaadimise kiirus: 124.74 kbit/sek
Allalaadimise kiirus: 992.07 kbit/sek
Kommentaarid:
Keskmine kõikumine: 8.03%
Suurim kõikumine: 12.34%
hendrik32
09.02.2010 00:27:13
Reply from 194.204.33.19: bytes=32 time=1568ms TTL=58
Reply from 194.204.33.19: bytes=32 time=1637ms TTL=58
Reply from 194.204.33.19: bytes=32 time=1560ms TTL=58
Reply from 194.204.33.19: bytes=32 time=1435ms TTL=58
Minimum = 1435ms, Maximum = 1637ms, Average = 1550ms.
Mõnus!
EDIT: Peale sellise ootamatu pingitõusule on DL kiirus ka suure taandarengu teinud 200kb/s pealt 60kb/s max peale.
12 |
urri
09.02.2010 06:02:32
tea kui pika aja peale EE oma Kõu plaanid tegi, kuid selliste kiiruste ja kvaliteedi languse juures
jooksevad kliendid suht siva laiali, otsima alternatiive
seega saavad ka teised firmad üsna pea tunda nõudluse kasvu
Duckhead
09.02.2010 06:26:09
kui on, alternatiive.
Tol hetkel, kui liituti, siis muud ei olnud valida. Ega naljapärast pasaga ei oleks ju liitunud
_________________ ÄRA KOORMA PENSIONIKASSAT, SURE ÕIGEAEGSELT!!! |
| Kommentaarid: 74 loe/lisa |
68 |
RvD
09.02.2010 11:44:43
Neid kahte vanti siit teemast ära ei anna blokkida või? Täiesti teemavälist OT juttu pidevalt tuleb ja moded ei tee midagi
Ja kuhu jääb wifi.ee lõuapooliku staatus?
Ostsin ka välisantenni. Tulemuseks sama 120ms ping ja upload tõusis 0,03Mbps võrra. Ütleks, et suht kehv investeering
| Kommentaarid: 51 loe/lisa |
47 |
One
09.02.2010 12:33:29
suunasid ikka korralikult? ping on küll suht kehva..
aga jah, dl ja ul kiirused ongi 24/7 koomas kuna trollis on juba 200+ inimest ja televõrgu vennad lihtsalt eiravad probleemi.
728 |
NightStriker
09.02.2010 12:35:49
Olen seda juba varem küsinud, kuid pole vastust saanud. Miks ei kasuta wifi.ee Täiesti asustatud punktis Laeva oma suurepärast, kiiret ja stabiilset Wimax ühendust. Kas tõesti on võimalik, antud piirkonnas ülivõimas Wimax puudub ja hoolimata Kõu puudujääkidest on see siiski olemas?
_________________ Allverelaev sukeldub määramata ajaks... |
| Kommentaarid: 65 loe/lisa |
63 |
gnoom
09.02.2010 13:10:28
| radist87 kirjutas: |
| Miks ei kasuta wifi.ee Täiesti asustatud punktis Laeva oma suurepärast, kiiret ja stabiilset Wimax ühendust. |
Tal ei ole aega seda kasutada, sest kogu aur kulub Kõu mahategemisele.
09.02.2010 14:01:01
RvD: No mina pole 3 aastat muuga tegelenud, kui Lp. KÕU-Oponentidele seda vahendanud, mis Televõrgu kodulehel kirjas on ning mida Lp. KÕU-Oponendid hirmsasti kardavad lugeda ja teada saada.
Ja siis mossitavad, kui ma nad pilve pealt "heljumisest" reaalse maa peale tagasi toon.
RvD: Nii, et mitu korda oled kirjutanud Televõrgu juhtidele kaebekirju, et miks küll KÕU ei tööta nii, nagu see sulle meeldib.
211 |
RvD
09.02.2010 19:55:03
| tahanteada, tegele siis vahepeal millegi muuga eksole. Ammu teada, et kõu on sitt, aga suvel siiski nett jookseb normaalselt ja seega paranemisruumi on.
47 |
urri
09.02.2010 22:01:07
| Duckhead kirjutas: |
Tol hetkel, kui liituti, siis muud ei olnud valida. Ega naljapärast pasaga ei oleks ju liitunud  |
aga kas nüüd on alternatiive... v anna teada täpsem koht parditiigis, ehk leiab sinna mingi signaali
mega
09.02.2010 22:08:07
kui peerusikutajaid ei oleks, siis funkaks kindlasti paremini...
_________________ - censored - |
| Kommentaarid: 270 loe/lisa |
237 |
Duckhead
09.02.2010 22:19:26
urri, mul pole enam vaja, mulle saabus alternatiiv emt näol
68 |
1n5an3
09.02.2010 22:28:06
V2hemalt ei pea teletorni ehitama voi ~5 km kaablit vedama et netis olla! Kiiruse yle eriti viriseda kah ei saa........
wifi.ee
09.02.2010 22:48:47
mobiilivõrk või püsiühendus |
RvD:
| Ammu teada, et kõu on sitt |
Kõu on liikumisel väga hea, aga kodu ei liigu .)
koju ehitab eesti mees omale püsiühenduse!
_________________ WiFi/WiMax.ee traadita Interneti levialad
WiFi oskusteave: http://wiki.wifi.ee/index.php/Esileht
Roosikrantsi 9. Tallinn EMail: veljo(at)wifi.ee |
hendrik32
09.02.2010 23:37:14
Re: mobiilivõrk või püsiühendus |
| wifi.ee kirjutas: |
RvD:
koju ehitab eesti mees omale püsiühenduse! |
Ma jäängi oma püsiühendust Tallinnas ootama, Elion ise ei ehita ja kui ehitab, siis küsib sellist hinda, et anna otsad.
12 |
RvD
09.02.2010 23:44:08
| No ei tule kaabel majja ja 100k pole mul ka selle alla panna. Mingist kuramuse wimaxist ei taha ma enam midagi kuulda, läägis samamoodi kuni teenusepakkuja pankrotti läks. Veljo, kas HV-le ka midagi maksad, et sul siin reklaami lubatakse teha?
47 |
NightStriker
09.02.2010 23:50:34
Kui karp tahab 220 ja autos ei ole 220, siis ei ole karp loodud autosse paigaldamiseks. Kui kodus seinast tuleb 220, siis sinna ma selle ka taha ühendan. Kui karp ühendada ka korraliku välisantenniga on tulemus täitsa püsiühenduse moodi. Jutt, et autosse on võimalik tekitada 220 ja seinale mõeldud karpi kasutada, läheb kategooriasse- tegelikult on see riistapuu laste tegemiseks, aga ma leidsin sealt tagant veel ühe augu
Kas wifi.ee oleks äkki nõus täpsustama, kuidas käib püsiühenduse ehitamine tingimustes kus lähim mobiilimast wifi pakkujaga on 13km ilma igasuguse otsenähtavuse haisuta. Kõige tipuks tuleb sellest mastist Kõust veel hullemat ja kallimat netti juba masti all elajatele. Püsiühendust ei ehita ainult õhust ja armastusest, mingi ühendus peab siiski võtta olema. Kas väljaspool wifi või wimax leviala kodu omajad pole sellepärast eesti mehed, et nad kasutavad Kõud ja ei vingu nagu sead, sest Holliwoodi parklas tarburgis istudes pagassi jäetud kõu levi ei leia.
63 |
Silwer
10.02.2010 00:36:50
| *Tegelikult need karbid ei taha 220v vaid oluliselt vähem. Vähemalt mõnda neist saab ka otse auto 12v elektrivõrku ühendada ilma igasuguse toitemuundurita, teistele on vaja muundurit mis teeb 12 voldist 5 volti.
| Kommentaarid: 13 loe/lisa |
wifi.ee
10.02.2010 01:03:15
| kas oleks äkki nõus täpsustama, kuidas käib püsiühenduse ehitamine tingimustes kus lähim mobiilimast wifi pakkujaga on 13km ilma igasuguse otsenähtavuse haisuta. |
Mehed lahendavad probleemid oma kätega, mitte wifid, viimaksid või kõud. täpsemalt ei tohi rääki, sest see on reklaam nagu Rvd ütles
Kõu karbi autosse paigaldamine pole probleem, seal on tema koht.
sõna Mobile tähendab liikumist->Mobility is the state of being in motion.
elukaz
10.02.2010 01:16:29
Re: kiirus kontra mobiilsus |
Ja kuidas su viimaks mobiilne on? Liikurvahendite kõrguspiirang ei lase 7m mastiga ringi sõita
| wifi.ee kirjutas: |
Mobiilne Internet on kasutamiseks liikumisel: autos, bussis, rongis on kõu koht.
Kodu seisab aga paigal ja sinna sobib püsiühendus.
Elu läheb edasi: kõu karbid kolivad autodesse ja kodukatusele tekib raadiolink.
Illustratsioon muudab teema arusaadavaks.
158 |
gnoom
10.02.2010 01:34:22
| wifi.ee kirjutas: |
| Mehed lahendavad probleemid oma kätega, mitte wifid, viimaksid |
Karmimad mehed lahendavad oma side probleemi üle sateliidi. Näiteks http://www.europeonline.com kaudu
NightStriker
10.02.2010 01:46:33
Ei ole seda häbi tunnistada, kuid sai sateliidiversiooni isegi kaalutud, kuid siis tuli kõu ja see probleem sai lahendatud.
TO wifi.ee. Kõvemad mehed teevad palkmaja ainult kirvega valmis, see ei tähenda, et lolli peab punnima. Minupoolest reklaami mida soovid, see ei muuda fakti, et midagi paremat kui Kõu mul püüda ei ole.
63 |
urri
10.02.2010 08:01:25
TO wifi.ee. Kõvemad mehed teevad palkmaja ainult kirvega valmis, see ei tähenda, et lolli peab punnima. Minupoolest reklaami mida soovid, see ei muuda fakti, et midagi paremat kui Kõu mul püüda ei ole. |
suht sama siin, paremat kui Kõu püüda pole, kuniks nö tänaseni
käib läbirääkimine ühe wiimaks teenusepakkujaga ja kuna leidsime küla pealt juba 8 talu
kes on huvitatud korralikust ühendusest, siis on isp nõus oma rahaga masti kesk küla püsti ajama
wiimax megane ühendus on küll kallim kui Kõu (375.-) kuid kui mega on ka suurem osa ajast olemas siis miks ka mitte
ka saab kliendiseadmed u 30 prossa sooduga
wifi.ee
10.02.2010 09:41:57
wifi.ee: OT: Tegelikult on neid lahendusi päris hulgim, mida nutikad maa-inimesed juba oma 5-10 aastat tagasi kasutasid.
On suudetud isegi tollane Eesti Telefon viia sinnamaani, et maasse tõmmati täiesti uued sidekaablid, on suudetud Elion viia selleni, et Elion tõi külla WiFi-lingi kaasabil ADSL-i.
On ehitatud kilomeetreid katvaid WiFi-linke juba tollal, kui midagi WiMaxist ei teatud jne, jne.
Ehk nagu ma ka varem öelnud olen - on olemas 2 kogukonda - need, kes tahavad "kohe ja praegu" endale asja ehitada ja see tööle panna ning on need, kes aastaid karjuvad, et miks küll mulle keegi midagi ehitama ei tule.
Mossitada pole mõtet, nii see elu kahjuks maal on. Sama, nagu vanasti, et kes ehitas, vaatas Soome TV-d, kes ei ehitanud, ei vaadanud, vaid hädaldas.
211 |
| Kommentaarid: 1156 loe/lisa |
724 |
One
728 |
HA
10.02.2010 19:38:09
Koduseade wifiga ZTE AR550
ja
Koduseade wifiga Axesstel MV410
kas neil miskit erilist vahet ka on 2korda hinnavahe eest?...esimesel vist ei saa akut kasutada?
121 |
enterprice
10.02.2010 20:02:56
| HA kirjutas: |
ja
kas neil miskit erilist vahet ka on 2korda hinnavahe eest?...esimesel vist ei saa akut kasutada? |
Tundlikkuse vahe ka. 410 parem levi.
98 |
S11muweb
10.02.2010 21:51:26
Hei, mehed, kas keegi oskab parem pakkuda KÕUle mingit korralikku alternatiivi paides? Elikas veaks kas või 100mb mulle koju, aga rutsi pole selle jaoks
wifi.ee
10.02.2010 23:21:30
Kõu Paides |
Mis on Kõul Paides häda?
Kas soovid end ise aidata või ootad et keegi võõras on abiks.
NightStriker
63 |
wifi.ee
11.02.2010 13:21:45
Internet linnaservas |
Linnas ja linnaservas on võimalik püsiühendust jagada raadiolinkide abil, kiirusel kuni 100 Mbits.
2,4 GHz on rämpsu täis, aga 5 GHz abil võrk toimib. Asi eeldab pealehakkamist.
enterprice
98 |
hendrik32
12.02.2010 16:28:14
Reply from 194.204.33.19: bytes=32 time=2664ms TTL=58
Reply from 194.204.33.19: bytes=32 time=415ms TTL=58
Reply from 194.204.33.19: bytes=32 time=114ms TTL=58
Reply from 194.204.33.19: bytes=32 time=64ms TTL=58
Minimum = 64ms, Maximum = 2664ms, Average = 814ms
selline asi juhtub hetkel iga 5 sek tagant
12 |
