Absona
| Kommentaarid: 11 loe/lisa |
| Kommentaarid: 745 loe/lisa |
561 |
Fukiku
27.01.2010 17:15:56
Google Docs peaks nüüd lubama ka suvalisi faile üles laadida minu teada, ise katsetanud pole.
_________________ Foxic is just a simple fox
Enne kui sa küsid oma küsimuse - küsi seda vannipardilt! Rangelt soovitatav enne programmeerimise alafoorumisse uue teema tegemist. |
Adebisi
| Kommentaarid: 58 loe/lisa |
55 |
Andium
29.01.2010 22:37:49
Kuidas on privaatsusega ning ega nad läbi ei scanni mis inimesed sinna üles laadinud.?
_________________ Olen alati ühel arvamusel inimestega, kes minuga nõustuvad. |
| Kommentaarid: 4 loe/lisa |
Mario.
29.01.2010 23:13:50
| Seda ei saa sa kunagi teada.
6 :: |
217 |
Andium
30.01.2010 19:56:56
| MarioA. kirjutas: |
| Seda ei saa sa kunagi teada. |
Arvata võib, et nad teevad seda. Muidu kuidas nad neid asju kontrollivad. Pakun, et mingi scan programmi vist kasutavad.
Your Responsibilities
You represent and warrant that you own or have the necessary licenses, rights, consents and permissions to grant the licenses that both your public and shared folders require, as described above. Please note that moving all or portions of Your Files from your public folders does not revoke the license granted to those individuals who previously accessed those files.
You should be aware that Files may be protected by intellectual property rights which are owned by the Dropbox user whose folder (public or shared) that File resides in. You may not modify, rent, lease, loan, sell, distribute or create derivative works based on the content(s) (either in whole or in part) of another user's shared folder unless you have been specifically told that you may do so by the rightful owner of that File, in a separate agreement.
You acknowledge and agree that you should not rely on the Site, Content, Files and Services for any reason. You further acknowledge and agree that you are solely responsible for maintaining and protecting all data and information that is stored, retrieved or otherwise processed by the Site, Content, Files or Services. Without limiting the foregoing, you will be responsible for all costs and expenses that you or others may incur with respect to backing up, and restoring and/or recreating any data and information that is lost or corrupted as a result of your use of the Site, Content, Files and/or Services. |
https://www.dropbox.com/terms#security
21.02.2010 18:23:48
Ei soovita seda kasutada.Viimati blokeeris Google mu konto lihtsalt ära 24 tunniks selle tõttu
| Kommentaarid: 92 loe/lisa |
HacaX
21.02.2010 22:28:43
Liigse POP3 aktiivsuse korral nad seda teevadki. Ning mitte lambist vaid kooskõlas teenuse kasutuslepinguga. GMaili pinda failid hoidmiseks kasutada saab, aga mitte sääraste virtuaalsete kettaseadmete kaudu (küll aga meilimisprogede vahendusel, P2M ilmselt parimaks märksõnaks).
| Kommentaarid: 24 loe/lisa |
22 |
22.02.2010 07:12:19
Niikuinii kasutan juba mitmeid kuid SkyDrive(25GB tasuta) ja Live Mesh(5GB tasuta)
lehm2
22.02.2010 09:23:22
Ise kasutan ning täitsa töötav teenus, kui vaja turvalisemaks võid ju enda poolt veel krüpteerida ära
_________________ Piilu siia, progreja!
Vajad abi Node.JS-ga ?
Võta ühendust ! |
| Kommentaarid: 15 loe/lisa |
Longero
07.08.2022 21:47:57
Kergitab vana teemat.
Soov lihtne, aga kui vaatama hakata siis polegi pilveteenust kerge leida, erinevatel pakkujatel omad hädad kollitamas.
Oleks lihtsalt vaja tavalisi file exploreri võimalusi + album/galerii + androidist ja arvutist "one way sync" ja backup. Kohta kus saab nii toimetada, et mingi pilvepoolne "oma äranägemist järgi intellekt" ei modiks su faile vaid jäävad nii nagu kasutaja on üles laadinud. Isegi kui eri kaustades on samad failid eri nimedega jms asjad.
1. Saan fotodega kausta teha oma äranägemist järgi sinna kuhu tahan ja selle hiljem vajadusel jagatud albumiks/galeriiks teha (mitte ainult kaust fotodega mida välja saab jagada).
2. Saan faile kopeerida mõnda teise kausta ja seejärel oma soovi järgi ümber nimetada vms, nii, et lähttekohas nimed, ega muu ei muutuks.
3. Saan oma telefonist äpiga ja arvutist kolmanda osapoole progega "one way sync", peaasi et ühepoolne sync pilve oleks.
4. Mahtu võiks saada vajadusel juurde osta, aga selline 2-3TB võimalus peaks olema igaljuhul.
5. Suurte failide tugi võiks olla.
6. WebDAV jms vajalik võiks olla.
Hetkel kasutan androidil "Autosync - Universal cloud file sync and backup", hea app, toimib hästi, erinevad seadistusvõimalused kuid olemuselt siiski lihtne https://metactrl.com/blog/2021/04/14/autosync-universal/
OneDrive:
Hakkan Onedrive võimalusi uurima mul tasuta konto olemas ja kas maksab tasulisele üle minna.
Kas 1TB ongi Onedrive ainsus võimalus, et mina ainsa kasutajana ei saa ruumi juurde osta juhul kui Onedrive sobib siis 2TB v 3TB suurendada?
* Microsoft 365 Personal 1TB
* Microsoft 365 Family 6TB total (1TB kasutaja kohta).
Edit: Pole veel õieti netis otsimist alustanudki ja juba üks suurem Onedrive häda, tasub ka kommentaare vaadata https://jimhphoto.com/index.php/2020/11/13/onedrive-for-photo-backup-iptc-in-the-cloud/ kuna artikli kuup polnud siis lingi järgi eeldaks, et 2020a ja kommentaarid 2022a.
No ei kutsu kasutama kui sellised asjad juhtuvad.
DropBox:
Siiani kasutanud DropBox Pro For individuals kus 3TB saadaval. Kuigi ma niipalju ruumi otseselt vbla ei vajagi siis sai see võetud suuresti nende võimaluste pärast:
* File recovery and version history 180 day (vs 30 päeva dropbox madalamad paketid).
* Shared link controls.
DropBox sai võetud peale pikemat uurimist just sellepärast, et oma olemuselt selline lihtne asi ja ei pea iga väikese asja pärast netist infot otsima.
Nüüd oleks vaja mõned albumid/galeriid teha, aga DropBox pole ok asi selle jaoks. Androidi app nagu näitas, et saab albumeid teha, nüüd ei saa enam ja arvutis samuti ei saa brauseri kaudu. Ma ei pea albumi all silmas seda kui pildid lihtsalt kuhugi kausta kopeeritud ja siis välja jagatud lingiga... see selline hädapärane lähenemine.
GoogleDrive:
Pole suurem asi. Albumit saab teha ja näeb välja ok, aga muud hädad kimbutavad.
Selline totter häda juhtus (ja veel allapoole paar posti) https://foorum.hinnavaatlus.ee/viewtopic.php?p=10492905#10492905
Esmapilgul võib GoogleDrive lihtne ja hea tunduda, aga paljud on sealt just sellepärast lahkunud, et suht haige asi kui midagi vaja... pmst kasutaja upub supporti abifailidesse ära.
Igasugu suurtesse ülevaadetesse netis suhtun pigem umbusuga, kipub nii olema, kes maksab tellib muusika.
Pigem usuks kasutajate kommentaare ja kogemusi, kuigi ka sinna juhtub promojaid.
On keegi omale mõne hea pilve leidnud kus faile ei modita ja mis oleks turul tõenäoliselt ka aastate möödudes???
viimati muutis Longero 07.08.2022 21:57:43, muudetud 1 kord |
| Kommentaarid: 55 loe/lisa |
52 |
07.08.2022 21:52:06
Onedrive vaevalt su exif faili ise muudab.
Tahad täielikult kindel olla, siis pane sync folder ka androidis teine ehk kopeerid faile mida hiljem editiga näppimas ei käi.
200 |
LKits
| Kommentaarid: 13 loe/lisa |
08.08.2022 09:15:50
NAS on üsna kulukas ja ikka kodune ehk turva pool niru.
Pigem soovitaks ikka vaadata miks mida see MS lahendus teeb. Päris lampi ikka seal asju ei susita.
Viimati testides jäi Telia ühendus lahjaks mitte link MS serverisse.
See 1TB väga tore ka
Seda family versiooni pole näppinud, ainult äri või edu.
200 |
Longero
08.08.2022 11:11:29
NAS'iga on kahjuks nii, et ma alles õpin seda teemat tundma, sai üks vana QNAP õppimiseks võetud... sorgin, vaatan, uurin .
NAS on samuti nö arvuti ja vajab teadmisi, olgu ta Syno, QNP v midagi muud. Enne kui asi selge pole pole mõtet sinna midagi väärtuslikku toppima hakata.
Mul poleks NAS'i vastu muidu midagi, aga olen selline kes ei taha asju väga tööle jätta (va hädavajalik) kui kodust ära, pealegi äike jms. Seega jääks NAS minupuhul ikkagi nö hoiustamise tasandile.
Oleks vaja siiski mingit pilve lahendust kus võimalik faile välja jagada ja teistel lingi omanikel juurdepääs.
DropBox peaaegu rahuldab mu soovid, aga veits jama jah, et niisuur tegija albumi võimalust enam ei paku. Netist lugedes oli neil kunagi see võimalus, aga koristasid ära... ju siis läks liiklus tihedaks, mida muud arvata.
52 |
perenoel
08.08.2022 11:13:39
Kui on mure, et pilves failide turvalisus kuidagi breachitud saab, siis pole mitte mingit muud lahendust, kui osta korralik krüpteerimistarkvara ning kõik folderite kaupa krüpteerida. Näiteks mindagi siit.
_________________ The biggest delusion is that there are causes other than your own state of consciousness. - Neville Goddard |
LKits
08.08.2022 12:07:20
Aaa ma saingi aru, et on vaja backup lahendust, et juba "serveris" olevaid faile enam ei muudeta, vaid tekivad juurde.
Küll aga kui ikkagi tagavarakoopia ja mahud juba terabaitides, siis miks mitte Synology NAS + mõned kettad ning äkki saab 500€-ga hakkama.
Pilvelahendusega oleks see umbes 1 kalendriaasta.
Ja kui tahad majast välist koopiat, siis Glacier Backup, ei tohiks olla väga kulukas.
EDIT: Microsoft 365 Family kasutusel juba mõnda aega, töötab hästi, 6 kasutajat, igal ühel 1TB, saab juurde osta +1TB vist 10€/kuus kasutaja kohta.
08.08.2022 12:15:07
| LKits kirjutas: |
| EDIT: Microsoft 365 Family kasutusel juba mõnda aega, töötab hästi, 6 kasutajat, igal ühel 1TB, saab juurde osta +1TB vist 10€/kuus kasutaja kohta. |
Ta võiks võtta 365 basicu 7,2€/kuu vist ja sealt onedrive e-mail extended share.
Saad läbi selle välistada ka lihtsalt lingi edasijagamise.
See mis doogle drive dokumentidega toimub on ikka halekoomika
Mida ei jagata siis NAS ja see Amazon "külmserver" (tundub tõesti selliselt ok)
200 |
Longero
09.08.2022 09:30:42
| Magic kirjutas: |
| Onedrive vaevalt su exif faili ise muudab. |
See ei juhtu kõigi fotodega, lihtsalt jumal teab mis loogikal.
OneDrive changing the dates on my photos?!?!? https://answers.microsoft.com/en-us/windowslive/forum/all/onedrive-changing-the-dates-on-my-photos/07266aca-fc74-4e8c-8e73-c48bd4e3cb3d?page=9
2018a teema, kommentaarid kuni 2020a. Kommentaare sirvisin pisteliselt, piisab kui esimese ja viimase lehe omi vaadata. Kommenteerimine pannakse tuimalt lukku, et mitte asjaga tegeleda .
Kuigi mul tasuta Onedrive olemas, sis pole vist isegi mõtet katsetama/riskima hakata.
Ma pole küll fotograaf ja suurt fotokogu ei oma, aga tavainimesele põhjustab samuti selline asi meelehärmi. Kujutlege nüüd mõne inimese ahastust ette kes aastatega piinlikult korrastanud fotod pilve laeb.
viimati muutis Longero 09.08.2022 09:39:23, muudetud 1 kord |
52 |
09.08.2022 09:36:40
Saan aru, et probleem on ikka selles, et teatud exif väljad on puudu ja viga tekib piltide üleslaadimise käigus mitte hiljem. Ehk kui picture taken on puudu ehk tegemist modifitseeritud pildiga.
Tavakasutaja kes oma nutiga pilte teeb ilmselt selle otsa ei komista.
Otsin pärast enda onedrive üles, sai sinna samsungist pilte lastud. Minu meelest töötas 5+
200 |
Longero
09.08.2022 09:55:13
Magic, Vaata jah kasvõi huvipärastki pisteliselt järele just metadata osa. Eks nad "töötavadki kõik" pealevaadates.
Mulle igatahes on nendest pilvhoidlatest üsna sünge mulje jäänud.
Nagu kuskil ühest kommentaarist loetud sai siis teenusepakkujad võistlevad omavahel, et pinnal püsida ja juhtuvadki igasugu automaatsed fotode tag'imised jts asjad.
Enamus kasutajatest lihtsalt vajab "kõvaketast netis" + albumi tegemise võimalust mis oleks koguaeg kättesaadav ja lingiga jagamist.
52 |
09.08.2022 11:24:09
Õnneks oli see era onedrive alles. Uploadi on teinud konkreetse kuupäeva järgi ja seega ka kaust selle kuupäevaga.
Fotode all samas kõik konkreetse exif taken kuupäeva järgi.
Testisin ka seda, et kas see download muudab midagi (orginal fail on õige)
Ehk ma ütleks, et kõik toimib.
Ideaalis siis peaks testima erinevate failidega, et näha kuidas see erand tekib, aga pigem arvan et jama tuleb siis kui see exif ise ebakorrektne.
200 |
Longero
09.08.2022 13:56:31
exif ebakorrektne...kas see juhtub sissescannitud piltidega (digitaliseerimine) jts asjad? Pole kursis eriti selliste asjadega, lihtsalt mulle ei meeldi kui faili ennast taustal kuidagi minu teadmata muudetakse.
Seal OneDrives on 1TB vist max piir?
Vaatasin DropBoks seadeid eile, ja soovikorral saaksin oma 3TB veel 1TB lisada, mida mul pole vaja muidugi, aga hea teada, et selline ostuvõimalus olemas.
52 |
LKits
