rainisk
19.01.2010 17:42:52
Driverite installimine |
Tegin eile arvutile formati, panin windoosa peale ära, aga see ei lase heli drivereid peale installida viskab mingi errori nagu ei tunnista omaks või midagi. Muidu tegemist int. heliga.
viimati muutis rainisk 20.01.2010 17:51:07, muudetud 2 korda |
| Kommentaarid: 23 loe/lisa |
18 |
563 |
rainisk
20.01.2010 15:33:15
Op süsteem windows xp nagu ennegi ja helikaarti pole küll aga on see AsRock K7vt4a Pro emaplaadi küljes.
e: lisan pildi ka.
Ei oska keegi öelda mis viga on?
18 |
arvi16
20.01.2010 15:40:09
veateate järgi võib eeldada ,et valet driverit ajad peale
heli peaks olema:
Audio - CMedia CMI9761A 5.1 channel AC'97 audio codec
viimati muutis arvi16 20.01.2010 15:42:50, muudetud 1 kord |
| Kommentaarid: 97 loe/lisa |
89 |
rainisk
20.01.2010 15:41:03
Ei ole kuna tõmbasin selle emaplaadi kodukalt, ja cd peal on ka ja sealt viskab sama teate.
_________________ ( -_・) ︻デ═一 ▸ |
18 |
563 |
arvi16
20.01.2010 15:45:02
File name: c-media-cmi9761a-driver.1.4.3.zip
File size: 339 KB
sellise leidsin googlist,
89 |
rainisk
20.01.2010 16:11:22
Ei ole heli pole.
Windows® XP 21.23MB C-Media audio driver ver:UDA046_build02 Selline on see mille mobo kodukalt tõmbasin ja selline on ka plaadi peal.
18 |
arvi16
20.01.2010 16:23:47
| kiibistiku driveri installisid ikka ennem ?
89 |
rainisk
20.01.2010 16:51:45
Mis nime see kiibistiku driver kannab?
18 |
arvi16
20.01.2010 17:16:18
| If you're installing a new operating system from scratch then Windows will use default chipset drivers to get your system running. Those default drivers have limited functionality. Generally, the first thing to do once Windows is up and running is to install the chipset drivers. It's best to install chipset drivers before anything else because some of your motherboard devices won't appear until after the chipset drivers are installed. In most cases things will still work if you install chipset drivers later, but generally speaking, it's best if they're installed first.
89 |
rainisk
20.01.2010 17:18:38
Aga mul väike probleem kui installin selle VIA 4 in 1 drivers plaadi pealt ja käsib restardi teha siis arvuti taaskäivitamisel ta pilti ette ei võta, pean toiteka juhtme tagant ära võtma ja kõvakettalt korra juhte ära võtma ja siis kui tagasi panen läheb käima.
18 |
