Juan Pablo
18.12.2009 23:17:06
| teretalv kirjutas: |
inimese nägemise resolutsioon ol oluliselt väiksem kui mõne su seebikarbi oma |
agapiksel on hullult kvaliteetne-nii arvan ma
29 |
| Kommentaarid: 92 loe/lisa |
heretic666
19.12.2009 02:21:58
Inimene näeb pmst vektorite, mitte pikslitena.. resolutsioon on pixels x pixels.
| Kommentaarid: 73 loe/lisa |
teretalv
19.12.2009 13:08:14
see silma resolutsioon on suhteline, kui sul on ideaalne nägemine ja prille pole on hoopis teine teema, nagu telekaski reklaamib "ma näen nagu loom"
_________________ Ära usu kes kutsuvad kuskile raha investeerima. Suurt tootlust ei tule keegi kandikul kätte tooma! Head ja kindlat tootlust saab ainult siis, kui ise enda kontrolli all on kogu protsess või enamus sellest.
Teen Hobikorras Audio, Video, Foto ja Trükiettevalmistust/Kujundust ja Python Scripte |
| Kommentaarid: 51 loe/lisa |
44 |
Ho Ho
19.12.2009 13:30:14
| heretic666 kirjutas: |
Inimene näeb pmst vektorite, mitte pikslitena.. resolutsioon on pixels x pixels. |
Konkreetselt simladest ajusse lähevad ikka midagi pikslilaadset, aju paneb kokku mitte vektorid vaid terved objektid.
87 |
19.12.2009 18:30:30
| For a human eye with excellent acuity, the maximum theoretical resolution is 50 CPD[26] (1.2 arcminute per line pair, or a 0.35 mm line pair, at 1 m). |
Allikas: http://en.wikipedia.org/wiki/Eye
Based on the above data for the resolution of the human eye, let's try a "small" example first. Consider a view in front of you that is 90 degrees by 90 degrees, like looking through an open window at a scene. The number of pixels would be 90 degrees * 60 arc-minutes/degree * 1/0.3 * 90 * 60 * 1/0.3 = 324,000,000 pixels (324 megapixels).
At any one moment, you actually do not perceive that many pixels, but your eye moves around the scene to see all the detail you want. But the human eye really sees a larger field of view, close to 180 degrees. Let's be conservative and use 120 degrees for the field of view.
Then we would see 120 * 120 * 60 * 60 / (0.3 * 0.3) = 576 megapixels.
The full angle of human vision would require even more megapixels. This kind of image detail requires A large format camera to record. |
Allikas: http://gadgetopia.com/post/5381
HV-s ID-kaardiga autentimine
7 :: |
362 |
