uus teema   vasta Raud »  Protsessorid »  AXP2400+ overclock märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3  järgmine
seven`
seven`
sõnum 29.08.2003 11:48:09 vasta tsitaadiga
Nu kirjutas:
2,15V on ikka liig mis liig t-bredile.
( MHz. V Step. Mobo )
2945 2.40 AUIHB A7N8X Delux Mase 3-1 18877
2578 2.27 AIUCB 0239SPEW ABIT KD7-R Prometeia 17677
2553 2.15 AIUGB 0244 EP-8rda+ with VDD mod SLK-600/ low TMD 17156
1470 2.15 AUIGB0245TP6W Epox 8K5A2+/512mb pc3200c2/205fsb Swiffy H2O/226w. Pelt 17287
2577 2.15 AIUHB 0249 EPoX EP-8RDA+ cV here - MCX462+ & cold winter air, 26Ct load 18583
2624 2.10 AIUCB 0241RPKW Amd Kr7a Raid Prometeia 15956
2425 2.10 AIUCB 0241 Epox 8K3A+ H2O Den Maze 3 16104
2750 2.10 AIUCB Abit KD7 (KT400) Prometeia. Surface Temp +15C, Core +3C under load 16185
2424 2.10 AIUCB 0242 Abit AT7 Thermalright SLK800, Delta 0812EHE 16226
2654 2.10 AIUCB 0244 8RDA+ Prometeia 16321
2500 2.10 AXDA AIUHB 0248 UPDW Epox 8k3A+ Own Casemod /w Koolance watercooling 16721
2523 2.10 AUIGB 0244 9 8RDA+ SLK-600 / Low TMD 16815
2330 2.10 aiucb0242tpaw EOPX 8RDA+ swiftech waterblock +coolercore +eheim 1250 16978
2405 2.10 AIUCB EpoX Ep-8RDA+ Water 19135
2604 2.10 AIUCB 0241XPDW ABIT NF7-S v2.0 Thermalright SLK-800 w/ Vantec 80mm Tornado 19580
2400 2.07 AIUCB "9" 0243 Abit AT7-MAX2 Watercooled 15991
2375 2.05 AIUCB 0242 Epox 8K3A+ Watercooled, Maze 2, Eheim 1250, Heatercore 15826
2455 2.05 AXDA Asus 16306
2460 2.05 AUIGB0245TP6W Epox 8K5A2+/512mb pc3200c2/205fsb H2O/226w. Pelt 17277
2478 2.05 AIUGB 0245 8k5a2+ watercooling mase3 17420
2400 2.05 AIUHB0302SP7W Epox 8RDA+ (12x200) Glacialtech silent breeze 18950
2850 2.03 AIUHB 0248 EP 8RDA+ (190x15) SLK800+Delta 80cfm 16269
2560 2.00 AIUCB 0243 Epox 8rda+ Prometeia 16280
2333 2.00 AIUCB Chaintech 7NJS nForce2 SLK800 + SmartFan II 16469
2460 2.00 AIUGB0245TPW Epox 8K5A2+(205fsb-c2 * 12) Pelt/Swiffy 462-U 23C.Load 16619
2300 2.00 AXDA 8K3A+ AX-7 7Volt delta 16640
2505 2.00 AGYO Epox 8k5a2 InnovaCool 5 17799
2450 2.00 AIUGB Abit KD7-Raid WW #056 18034
2565 2.00 AIUHB0103 Abit KD7-R Water 18198
2590 2.00 AIUHB ABIT KD7 Swiftech MCX-462+ & TT SmartCase Fan 2 19084
2500 2.00 AIUHB Abit NF7-S 2.0 SLK-800 / Delta 80 CFM (200x12.5) 19700
PS! 0.5 V lisatud vaid täieliku stabiilsuse saavutamiseks!
Kommentaarid: 136 loe/lisa Kasutajad arvavad:  :: 1 :: 2 :: 120
Nu
Nu
sõnum 29.08.2003 11:57:17 vasta tsitaadiga
mis siin uurida?
kas arvad, et need tulemused seal 24/7 jooksvatelt masinatelt võetud we?
Seal pigem maksimumid millega prose on mõneks ajaks tööle saadaud.
Minugi -20C juures klokitud (maksimum voltidega) palomino tulemus seal kirjas.
DO you want it.. And if you had it would you flaunt it...
ss
Kommentaarid: 177 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 157
seven`
seven`
sõnum 29.08.2003 12:12:41 vasta tsitaadiga
Nu kirjutas:
mis siin uurida?
Nagu ütlesin, see 0.5 V lisatud vaid täieliku stabiilsuse saavutamiseks! Võin ajada ka 0.25 V juures 2505 MHz. peale klokituna tööle, aga kas ta on siis stabiilne? Ei ole! Proovi sellega mõnda testi teha? Mina jahutan seda 2.15V Volcano 7+'iga, nagu eelpool öeldud! Temperatuur on sel hetkel 40 C. @ 12 V. Lärmi teeb, aga jahutab tõesti väga hästi, parim!
Nu
Nu
sõnum 29.08.2003 12:51:36 vasta tsitaadiga
stabiilsuse saavutamiseks või mitte aga +0,5V pikemas perspektiivis
on prosele eluohtlik, olgugi et temp normis.
ss
Nu
Nu
sõnum 17.09.2003 18:35:56 vasta tsitaadiga
ilhtsalt infoks:
sai täna kiil147'le ostetud AXP2400+ AIXHB mis kõiki kuulduste kohapealt
pidavat 2,5GHz saavutama aga paraku 2,24 peal asi pilti ette ei võtnud. icon_sad.gif
võrdluseks, et minu AIUHB käib def voltidega 2,3GHz.
Jahutuseks on sellel muide VÄGA JUUST coolermasteri väiksemat sorti alu radikas
ja 90mm vent. idle temp on seejuures ~30 ja mõningase full loadi järel 38 icon_eek.gif
mul start-up temp juba 40
ss
Nu
Nu
sõnum 22.09.2003 08:23:16 vasta tsitaadiga
XP2400 omanike vist eriti ei ole siin ma vaatan aga väiksed katsetuse tulemused
jälle. seekord downclock
1GHz peal 1,4V´ga saab seda proset edukalt pasiivjahutusega kasutada.
Temp tõusis peale mõningast kasutamist küll 50C juurde aga see pole ju
paha arvestades täieliku vaikust CPU cooleri osas.
Seejuures 3DM2K1 tulemus langes aint 3K võtteldes 2GHz'ga.
ss
Dumb(_;_)
sõnum 22.09.2003 12:03:50 vasta tsitaadiga
Kui toiteplokiks on kõhu all oleva 12cm ventiga variant, mis kogu tõusva sooja otse välja puhub, võiks selle 1,4V peal ka lausa nimisagedust proovida. Need 1,5V Athlonid taluvad 1,4V ikka paganama hästi
(OK, võibolla 2G on siiski liiast)
Nu
Nu
sõnum 22.09.2003 14:02:27 vasta tsitaadiga
mul on default 1,65V siiski kuid 2GHz peal käib ka 1,5´ga.
1,4V pilti ette ei võtnud ja 1,45 pole proovinud.
ss
Le Inc
Le Inc
sõnum 02.10.2003 07:21:13 vasta tsitaadiga
Värske AXDA moditud traaditrikiga kordajale 16 ning "õrna" oc'i tulemused.
2128 Mhz +0,00 V
2200 Mhz +0,075 V -> jätsin nii
2260 Mhz +0,1 V
2328 Mhz +0,2 V
Rohkem ei saa sest emme ei luba. Kusjuures kõikides olukordades jooksutasin Prime95 ca 1 tunnike ja ei mingeid vigasid.
viimati muutis Le Inc 02.10.2003 12:13:27, muudetud 1 kord
Nu
Nu
sõnum 02.10.2003 07:29:37 vasta tsitaadiga
AXDA küll aga mis steping?
ss
Le Inc
Le Inc
sõnum 02.10.2003 07:35:37 vasta tsitaadiga
Peast küll tervet rodu numbreid mis prosele kirjutatud ei tea, peab uurima.
Arvo Cobrietti
Arvo Cobrietti
sõnum 02.10.2003 08:52:48 vasta tsitaadiga
kordajat saaks ju tõsta veel sama nipiga?
Le Inc
Le Inc
sõnum 02.10.2003 12:12:21 vasta tsitaadiga
Emme ei luba volte rohkem tõsta 1,85 on max. (Epox 8KHA+)
shaolin
shaolin
sõnum 09.10.2003 02:35:14 vasta tsitaadiga
mul endal oli ka vahepeal 2400+ xp... niisama sai katsetatud ühe vana emaplaadi tarvis, aga too oli nii juust et otsustasin lahti saada ja sõbrale müüa... nüüd aga sai kõrini sellest vanakraamist ja ostsin abit kv7 kt600 chipsetiga emme ja selle peale 2200+ 1200 eegu eest.. antud isend töötab hetkel 1.75 voldi peal nagu peaaegu 3200+ (223x10) ... ainult raisal on kõik agp ja pci kiirused üle normaalse: agp on 80MHz ja PCI on miski 40... nforce emmedel seda probleemi küll pole - aga samas on mul mälu kiirus üle 3GB/s ainult ühe odava PC3200 mäluga(sisoft sandra) 2003; imelik et video ja ata veavad probleemideta kõik välja - kordagi pole miski kokku jooksnud. Videokaart on Gf 4 MX440 64 miskite heade DDR mäludega ja see andis 3dmark2001 peal kuhugi 7800 punkti kanti... samas ti4200 8x agp oleks andnud kõvasti üle 10k ehk isegi 12k juba... vähemalt pakun.
Le Inc
Le Inc
sõnum 09.10.2003 07:10:24 vasta tsitaadiga
Vaevalt et XP 2200+ (T-bred) reiting on 2230 MHz juures 3200+, see rohkem bartoni rida. Pigem XP 2700 - XP 2900 icon_smile.gif
Arvo Cobrietti
Arvo Cobrietti
sõnum 09.10.2003 17:40:53 vasta tsitaadiga
no bartonitel FSB kõigest 166/200. mehel ju 223 peal, see cache ei anna peaaegu midagi juurde. ja 223 jures agp/PCI sul kõigest 75/37,5.
Le Inc
Le Inc
sõnum 10.10.2003 09:01:59 vasta tsitaadiga
Nu kirjutas:
Vaatasin järgi, stepping on AIXHB. 2400 Mhz saab +0,2 V kätte küll, kuid Prime95 ei kannata. Ilmselt
läheb rohkemgi veel, pole proovinud.
Arvo Cobrietti
Arvo Cobrietti
sõnum 10.10.2003 11:06:52 vasta tsitaadiga
siis pead volte veel tõstma või sagedust langetama.
Fredu
Fredu
sõnum 10.10.2003 14:31:14 vasta tsitaadiga
Nii, tegin väikese kloki ja nüüd töötab 2.2 GHz peal ehk xp2700+, idle temp on mingi 37-40 ja full loadis 45
Kommentaarid: 27 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 23
Nu
Nu
sõnum 10.10.2003 16:43:41 vasta tsitaadiga
Fredu ja Le Inc teil on default pinge kuipalju?
ss
Fredu
Fredu
sõnum 11.10.2003 10:21:34 vasta tsitaadiga
Core saab 1.66 V
tobler
tobler
sõnum 11.10.2003 10:29:58 vasta tsitaadiga
eelmisel talvel sai oma JIUGB proze natuke tesitud külmailmadega.. 180x ( kordajat ei mäleta )... viimane stabiilne kiirus, mis jooxutas 3dmarke ja värke oli 2360mhz @ 2,3V ( icon_lol.gif 8) ).
Le Inc
Le Inc
sõnum 13.10.2003 07:21:19 vasta tsitaadiga
Def pinge on 1,65 V. Huvitaval kombel õnnestus 2200 Mhz (16x137) kätte saada ka 0,05 V, varem 0,075. Ehk vajab prose ka nö. sissesõitmist icon_biggrin.gif
Prime95 kannatas ilusasti välja.
teadmamees
sõnum 18.10.2003 19:12:41 vasta tsitaadiga
no nii. sattusin kah täna seda teemat lugema ja mõtlesin siis et teeks ka väikse overclocki oma pilliga. emaplaat siis vastavalt kd7 prose xp2400 ja mälu pc2700 . läksin siis biossi ja hakkasin nummereid näperdama. a siis selgus, et mingi asi juksib, kuna kui panin kiiruseks üle 2200mhzi, siis arvuti keeldus pilti ette võtmast ja aitas ain bios clear. pingeid ei näppinud ja ratiot ei muutnud(see oli defaultilt 4:2:1). kõige kaugemale jõudsin niimoodi et panin 133X16 selle konfiga jõudsin winni ja win jõudis 5 minni umbes töötada ja siis plaksti restart. mälude kiirusi ega midagi muud ei muutnud. kes oskab öelda, mida tegin valesti või mida muutsin liiga vähe/palju, sellele olen ülimalt tänulik icon_wink.gif praegu töötab prose defaulti peal.
Kommentaarid: 53 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 46
teadmamees
sõnum 19.10.2003 00:27:05 vasta tsitaadiga
arenesin oma asjaga siis natuke. nüüd töötab prose 136X16 peal mis teeb siis ümaralt 2,18 ghzi. core voltage panin 1,85v ja mälu on 2,75v. mälude cli panin kah 2 peale(oli see vajalik või mitte??????) nüüd on asi kaks tundi ilma restarti tegemata töötanud ja päris stabiilselt. ega volti liigselt saanud? lisaks veel see, et prose surface temperatuur on 45 kraadi ringis.
uus teema   vasta Raud »  Protsessorid »  AXP2400+ overclock mine lehele eelmine  1, 2, 3  järgmine
