ei tea, mis tõlget keegi kasutab. minu oma räägib igatahes piparkoogimehikesest. aga laias netis jälgi ajades leidsin juba üles (samuti piparkoogi nime abil),
et selle leiab esimesel kaardil "pineoak'i" anomaalia kohal võrsuva moodustise pealt.
As some of you may know, polish release date for CoP is 27th of November - which is over a month before the official english release, since the date is still unspecified. And "Q1" might be anything from 1st January to 29th of April.
However, today's news(http://www.gry-online.pl/S013.asp?ID=49213&NC=1) is that polish version of CoP will come in three languages. All in-game text is in polish; but during the installation you will be able to choose the language the voices will be in:
a) Original russian;
b) Russian with polish lector;
c) English.
Yes, you read that right. Polish release of CoP will have optional English VO. Why? I have no friggin' idea. It doesn't make any sense no matter how you look at it. But it's there.
So where I'm going with this?
The unofficial CoP translation has been available for quite some time, and its quality is excellent. But it lacked one thing - english voices. Now, you get these voices in the polish version. Add the two and two together and... If you get the polish version and apply the unofficial translation patch, you will be able to play 100% english Call of Pripyat a long time before the game is officially released in english.
tõesti veider et english sisse pannakse. aga polegi vaja seda inglise keelt eriti, ainult cutscenede jaoks kus subtiitreid pole ja storyline mõistmiseks.
No paljud poolakad vene keelt ei räägi ja niipalju kui mina tean siis enamikke inimesi tõsiselt häirib ülelugemine ükskõik mis keeles originaal ka ei oleks ( mind igaljuhul häirib ) .
Niiet head uudised !
nagu näha, tessellatsioon teeb terve mudeli ümaramaks, vähem nurki ja teravusi... samas ta moonutab mudelit veidi, teeb siit sealt paksemaks jne...
"does tessellation make me look fat?"
Korraliku veresauna järel sain Monolithy seppade käest plasmarelva aga mis sellega edasi teha, ükski teadlane ega remondimees ei oska sellega midagi peale hakata?
On ideid kellelgi?
- In the advanced graphics settings added option "tessellation" (for DX11);
- Vital reduced load times and improved overall performance when using DX11;
- Improved texture on the 32-bit systems;
- Added ability to simultaneously run the game under different user accounts;
- The possibility to run the game under a user account with restricted privileges;
- Improved system falling knife;
- Fixed a visual disappearance of objects and characters in front of the buildings;
- Fixed black rectangles around lights;
- Fixed display vollmarkov under static illumination;
- Fixed graphical artifacts in the rain;
- Fixed sticky cursor in the upper left corner of the screen;
- Fixed detection support DX11 graphics cards;
- Fixed switching between input languages;
- Fixed the lack of damage anomaly "burning down";
- Added the correct configuration file to create a new game, if the old was removed;
Single player
- Fixed a crash with the message "gamedata \ scripts \ xr_effects.script: 1288: attempt to index global 'npc' (a nil value)";
- Fixed a crash with the message "Arguments: bad node in heap";
- Fixed a crash with the message "any vertex in patrol path [...] is inaccessible for object [...]";
- Fixed a crash with the message "bonePHGetSyncItemsNumber ()";
- Fixed a crash with the message "xrGame.dll, CxIOFile:: Scanf ()";
- Fixed crash when opening "message history" in the CPC;
- Fixed crash when you try to talk to the shingle after hunting Creek;
- Fixed crash when you try to talk to the shingle after it was found Magpie;
- Fixed crash when you try to talk to Kowalski after setting the "One Shot";
- Fixed crash when trying to talk to Bear after the job "Hostage";
- Fixed crash when you try to talk to Sychom after setting the "Transaction";
- Fixed crash when talking with Herman about research during the job "Investigation of anomalies;
- Fixed crash when trying to give Azot more material than was originally in the game;
- Fixed hang on the loading level;
- Fixed inability to continue the game after the issuance of the job "One Shot";
- Added saving rate approximation in dynamic elevations;
- Fixed the loss of character in the first katstsene in Pripyat from the release;
- Fixed inability to open the container at the convoy;
- Fixed inability to speak with Garik in certain situations;
- Fixed inability to speak with roach in a specific situation;
- Fixed the issue of achieving "supporter of equilibrium;
- Fixed the lack of awards from the St. John's wort for hunting Creek in certain situations;
- Fixed appearance of two units Gonty;
- Fixed re-emergence of previously killed Uncle Yar;
- Fixed bug with auto-saving meeting with the Zulus;
- Added correct lifting tasks "tell Kowalski on weapons;
- Added correct lifting tasks "One shot";
- Minor bugs fixed targets;
- Fixed inability to get a grenade in a certain situation;
- Fixed bug due to which the characters are not eating, not drinking and not playing the harmonica;
- Fixed incorrect animations, acting out the characters after the transition from a conductor on the location;
- Fixed too long treated the characters wounded allies;
- Minor fixes weapon system improvements;
- Fixed incorrect tooltip when you hover at the door of the tower Zulu during an alert to "Jani";
- Fixes some dialogues;
- Slightly corrected texts;
- Slightly changed the assortment and prices from merchants and technicians;
- For sale added detectors;
- Changed set of medicines issued by military medical personnel;
- Increase the distance at which may disappear corpses;
Multiplayer
- Optimized network part of the game, which substantially reduced the number used by traffic;
- Improved system to combat cheaters;
- Fixed crash when connecting to the server, by changing the team and when the map changes;
- Fixed crash when attempting to connect to GameSpy no connection to the Internet;
- Fixed a crash when the collection of statistics;
- Fixed crash when recording a demo;
- Fixed game hang if the server was forbidden mode observer;
- Fixed the loss of character during the spawn;
- Fixed the lack of ammunition for the pistol in the "team against the team";
- Change the speed of the character height of his jump and control during the flight;
- Increased damage of the character and some of the costumes in the fall;
- The possibility of running with SVDm-2 "and" SVUmk-2 ";
- Changed the characteristics of certain types of weapons;
Sain nüüd tänu pätsile Pripijatti, sealt sain ka juba gaussi ja ka calibration kiti, nüüd tekkisidki küsimused:
1- kuidas Jupiteri tagasi saada (kui ma sinna tunnelisse tagasi läksin, siis oli see õhku lastud)
2-
Mida ma selle Gaussiga siis teen, kui ma olen need monolithi tegelased raamatukaupluses mättasse löönud, kuskil PDAl mingit märki ei ole ja ka sõduritelt ka abi ei saa...
(põhimõtteliselt sama asi, nagu Bastardil)
kas ükskõik, millisele stalkerile nisukesi modisid on, kus on hulgaliselt uusi missioone? või millal järgmine osa tuleb? või miskit...ma ei tea, käed juba värisevad. cold turkey...
Eks ukrainlastel liiguvad juba uue osa mõtted peas (või paberil)
EDIT:
No mul ikka ei vea... Sain natuke edasi mängida, kuni olen saanud joodikult võtme laborisse. Sinna joostes aga loobib mu arvuti BSODe
CSis oli ka sama jama, aga seal tõi leevendust 1.6? päts...
Vähemalt saab ingliskeelne maailm omale bugivaba versiooni.
Ma eelistan igal juhul versiooni, kus tegelased räägivad ikka "emakeeles", mitte ei pea kahtlast aktsenti kuulama...
Sama asi häirib paljude filmide juures
just nimelt, CS-ga pingutati natuke üle, dialoogid peaksid ikka olema vene keeles kuigi on ju võimalik asendada rahvusvahelise CS/tulevase COP-i keelefail - (db) - "xrussian.db" lahtipakkitult vastavalt soovile _________________ "Mõtle kriitiliselt"
Kas mõni ostab ka neid АКМ-74/2 ? Vaatan , et rahaks saab teha vaid erilisi relvi.
Mäng ise jookseb suht hästi, paremini kui Clear SKY ehk on story ka hea. Huvitav asi see, et vana laeva sees olev medic müüb küll asju, aga samas tema juures riiuls olev First-aid kit ja Anti-rad võib võtta täitsa tasuta.
Mõni koht võiks veidi teistmoodi olla, sest see aeg peaks läbi olema, kus kogu mäng käib mööda väikest ja kindlat koridori.
Näiteks tooks , et väikesest künkast mängutegelane ei lähe üles, eriti siis, kui alla kukkunud lennumasin käega katsuda on ja samas kui on mõni kõrgem küngas siis vana ronib küll : ) _________________
Crow, traderid ostavad ainult peaaegu täesti korras oleva relvi (vist max. -1 pulk) . Teised stalkerid ostavad ka veidi halvemas olukorras relvi (vist -2 pulka).
Relvi parandada ei ole mõtet enne müüki (isegi kui -1 pulga juures) - kui sa just kahjumisse ei jää on kasum ikkagi marginaalne. _________________ ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn
kas keegi oskab öelda, kust saaks vabalt tirida pripjati modi DragonForse? seda siin-seal pakutakse aga kõik daunlõudimisvariandid on tasulistes urgastes.
äkki teab keegi veel mõnda põhjalikumat pripjati modi?
Sain lõpuks läbi, hea mäng oli, parem kui Clear Sky. Lõpp oli imelik. Achievements jäi tegemata " his fellow , Friend Freedom, Keeper of Secrets "
Tasub teist korda veel läbi teha, kui aega leian. _________________
Crow, ajad isu peale , mul COP-ga sama seis mis CS-ga pool aastat seisab, aegajalt natukese haaval saab salvestatud progessi, hiljem võtan kätte et läbi teha _________________ "Mõtle kriitiliselt"
Kas kuskilt saab Call of Pripyati mapi ka juba, mingi vene keelse leidsin, aga sealt ei saa midagi aru eriti.
Ja kas Call of Pripyatis tuumajaama juurde ei pääsegi, et enamus tegevus Pripyatis..?
K3ndu, jep seesama nõks ongi
EDIT: Ettevaatust - DragonForse_Mod.exe:\1\обновления.exe";"Adware Generic4.NYR", DragonForse_Mod.exe";"Adware Generic4.NYR"
kas keegi seda peale panna on proovinud? ma üritasin. asi hakkas midagi otsima, taustaks mingi krõnksudes väljendatud, arusaamatu tekst (ilmselt keeleprobleem). tundus, nagu otsinuks ta midagi c-kettalt. seejärel asi lõppes ja tolku ei essugi. võibolla ta otsis mängu c-kettalt, mul aga mäng ise d-kettal.
Satakas, tüüpiline spyware - midagi on külge poogitud mis arvatavasti ei lase installikal kävituda kuigi fail kaalub parajalt et olla mod'i installikas/manuaalselt paigaltatav _________________ "Mõtle kriitiliselt"
Mitte siis, kui ostsid nö. full versiooni, on olemas ka versioon, mis kasutab CSi faile.
seda mõtlesingi, versioon mis kasutab SOC/CS faile või lihtsalt tsekkab olemasolu antud raalis, full-ga (retail) on lihtsam _________________ "Mõtle kriitiliselt"
