janek87
22.10.2009 18:19:03
| Jah
CoiL
22.10.2009 20:05:40
tomorrow, viska shortcutid taskbarile ja ei ole mingeid noolekesi
25.10.2009 16:47:24
| CorsairX kirjutas: |
Mul ei mahuks kõik ära .Praegugi juba piiri peal.Ettevaatust 2MB pilt!:
EDIT2:
Mitteametlikud Win 7 Updated(25.10.2009):
x64:
http://www.megaupload.com/?d=L1FXUNF5
x86:
http://www.megaupload.com/?d=LY6QERV4
Contains all known updates minus RSAT(Not many need this) and IE Addons(Few use N versions and those who do wont install this anyway)
Does not contain 974333 as it cant be properly installed anyway
Contains some updates that can be considered unneended(3 or 4)
Updates are installed by size:Biggest first,Smallest last
Requires only 2 keystrokes.All else is automatic
Skips already installed updates so no need to worry about that
x86 contains 78 updates and x64 contains 80 updates
x64 tested but x86 not.If you have problems with x86 let me know |
25.10.2009 17:10:32
tomorrow, miks sa need updated siia niimodi mingi suvalingina paned, kas WU kaudu neid siis ei saa?
25.10.2009 17:17:33
Tegid ise juurde vöäi?
25.10.2009 17:22:36
pane upload.ee, see megaupload on nii segane, kliki sadat nuppu ja kirjuta numbreid lahtritesse ning oota sekundeid enne kui midagi kätte saab
01.11.2009 02:43:00
Mitteametlikud Win 7 Updated(31.10.2009):
x64:
http://www.megaupload.com/?d=Z1IUSN19
x86:
http://www.megaupload.com/?d=OIYHLCIV
Added - KB890830(Malicious Software Removal);KB947821(Servicing Store winsxs inconsistency fix);KB954430(Security Update for MSXML 4.0 Service Pack 2)
Updated - KB974431(Reliability Update).WU was offering this although i had 974431 installed so i grabbed possibly a newer 974431 from WU database
Removed - Nothing
x86 contains 81 updates and x64 contains 83 updates
x64 and 86 both tested and working |
CoiL
01.11.2009 03:03:14
tomorrow, eelmist mitteametlikku update pakki ei ole vaja alla lasta sellele?
Natuke OT aga oskad öelda kust ma saaks need ATK0110 ACPI drivud kätte mida W7 ise updates pakub? Asuse supportist ei ole W7 omasid pakkuda ja Vista x64 omad ei lähe peale
01.11.2009 03:11:06
| eelmist mitteametlikku update pakki ei ole vaja alla lasta sellele? |
Ei ole vaja.Uusim sisaldab ka kõiki eelmisi fixe.Kui installima hakkad siis juba installitud fixid jäetakse vahele .Tasub tähele panna, et #1 mida installib on uus ja selle install võtab tükk aega
oskad öelda kust ma saaks need ATK0110 ACPI drivud kätte mida W7 ise updates pakub? Asuse supportist ei ole W7 omasid pakkuda ja Vista x64 omad ei lähe peale  |
Huvitav.Minul küll toimivad ASUS A8N32 SLI-Deluxe puhul just Vista x64 omad ASUS-e lehelt.Kasutaks uuemaid aga uuemaid enam ei tehta minu platele
Kasuta Internet Explorerit ja otsi siit: http://test.catalog.update.microsoft.com/
Seal palju asju mida naljalt mujalt ei saa.Pean silmas just drivereid
CoiL
01.11.2009 03:19:01
tomorrow, sellelt lingilt ei leia neid uusimaid. Pakub ainult ATK0100 mitte ATK0110
Huvitaks kust just neid drivusid kätte saada mida W7 pakub... netist kah ei leidnud.
01.11.2009 03:31:10
Huvitaks kust just neid drivusid kätte saada mida W7 pakub... netist kah ei leidnud. |
Kui WU-st panid peale siis peaks sul masinas tegelikult olemas olema.Kui pole WU-st installinud siis installi
Peaks olema need
asacpi.cat
AsAcpi.inf
asacpi.PNF
Asacpi.sys
Ja peaksid asuma @ C:\Windows\System32\DriverStore\FileRepository\asacpi.inf_amd64_neutral_9fe33cbdd27308a4
Lihtsalt otsi asac seal kaustast
Võimalik, et ei lase normaalselt kopeerida ja peab Safe Mode-s tegema aga eks näis
Kui kätte saad siis paki kokku ja riputa kuhugi üles.ATK peaks olema kõikidele emaplaatidele ühine ja ei ütleks ära Win7 ATK versioonist oma emaplaadile kah
CoiL
01.11.2009 03:44:32
tomorrow, istallimises ei ole probleem. Kõik töötab ja ok aga tahaks neid drivusid plaadile teiste drivude juurde kirjutada
Aga vaatasin järgi... need mis W7 update ise peale pani on pärit aastast 2004 :
CoiL
CoiL
01.11.2009 04:23:34
tomorrow, niipalju kui mina tean reguleerivad need ka sleep/hibernate funktsioone Osadel siin olid jamad, et arvuti ei naase sleep režiimist. Äkki aitab.
Peaks need viimased postid laskma vist w7 teemasse ümber tõsta
e: proovisin järgi ja mul W7x64-ga sleep ja hibernate ilusti toimivad selle drivuga
05.11.2009 13:23:25
Mitteametlikud Win 7 Updated(05.11.2009):
x64:
http://www.megaupload.com/?d=UM96H7KV
x86:
http://www.megaupload.com/?d=2XO470NA
Added - 12 Updates for x86 and 13 updates for x64
Updated - Nothing
Removed - Nothing
x86 contains 93 updates and x64 contains 96 updates
x64 and x86 both tested and working |
CoiL
15.11.2009 13:33:59
tomorrow, äkki sina oskad öelda kuidas Folderit eraldi taskbar`le pinnida. Hetkel proovinud shortcut/otse pinnimist kuid ta tõstab selle taskbar`le pinnitud My Computer alla Tahaks nt. et oleks eraldi Games kataloog pinnitud taskbarile.
E: Leidsin ise lahenduse:
Kuidas üksikuid foldereid/objekte TaskBar`le Pinnida?
1) Tee soovitud kaustast/objektist shortcut.
2) Paremklikk shortcutil > Properties > Shortcut Tab > Target reale kirjuta olemasolevale ette explorer (Näide - explorer(tühik)E:\Games). Apply > Ok.
3) Kui soov ikooni muuta, siis paremklikk shortcutil > properties > shortcut tab > change icon.
4) Paremklikk tehtud shortcutil > Pin to Taskbar.
5) Tehtud shortcut`i võib kustutada (minul toimib taskbarile pinnitud folder ka peale shortcut`i kustutamist).
27.11.2009 07:53:35
Võimalus vahetada desktopi taustapilti Windows 7 Starteril:
http://rapidshare.com/files/307848721/Win_7_Starter_Background_Changer.rar
EDIT:
Kes ei kasuta Hibernation valikut see saab järgneva käsuga 1,5GB ruumi kohe juurde süsteemipartitsioonil .
*Ava Command Prompt(start menüü otsingusse cmd või WinKEY+R ja cmd.exe )
*Sisesta järgnev käsk:
*Süsteemipartitsioonilt kustutatakse koheselt hiberfil.sys (varjatud fail ~1,5GB)
*Tee restart
Sleep jms toimib nagu ennegi.Kui on vaja uuesti sisse lülitada Hibernation siis saab tagasi selle käsuga:
Kasulik kui vaja tsipa ruumi juurde saada või lihtsalt ebavajalikust vabaneda
EDIT2:415 lehekülge põhjalikku infot
The TweakGuides Tweaking Companion for Windows 7
After a great deal of time and effort, I'm pleased to announce that the TweakGuides Tweaking Companion for Windows 7 is now available. Designed for novice and advanced users alike, it is written in plain English to help you genuinely understand all key aspects of Windows 7 and your PC. Every major topic is covered in detail: from the correct installation of critical drivers and software, through to simple explanations and recommendations for every significant Windows setting and feature, all performance and convenience tweaks and customizations, as well as thorough troubleshooting advice. Also provided are links and instructions for a large number of reliable free applications which can enhance your system and give you viable alternatives to purchasing commercial software. I hope you find the book worth the wait.
http://www.tweakguides.com/TGTC.html
>>>OTSELINK<<<
miq1988
27.11.2009 23:15:00
| Unfortunately, the link you have clicked is not available. |
antikas
09.12.2009 14:39:01
| Olen siit teemast väga palju kasulikke ja vajalikke asju saanud, tänan, aga nüüd kui servised maha keerasin siis avastasin et ei saa homegroupi-ga enda teise arvutisse sisse enam, ühtegi publik folderit ega teist arvutit workgroupis ei näe. Oskab äkki keegi öelda mis tegema peaks või mis service tööle panema ? (:
09.12.2009 14:45:24
| antikas kirjutas: |
| Olen siit teemast väga palju kasulikke ja vajalikke asju saanud, tänan, aga nüüd kui servised maha keerasin siis avastasin et ei saa homegroupi-ga enda teise arvutisse sisse enam, ühtegi publik folderit ega teist arvutit workgroupis ei näe. Oskab äkki keegi öelda mis tegema peaks või mis service tööle panema ? (: |
Alusta HomeGroup Listener ja HomeGroup Providerist
Edasi vastavalt mõlema peal Propertis ja Dependancies(eks siis millistest teenused sellest veel sõltuvad) ja siis need kah käima ja proovi uuesti
antikas
09.12.2009 15:08:20
| HomeGroup Listener ei hakka üldse tööle. Error 1068: The dependency service or group failed to start.
antikas
09.12.2009 15:53:42
Propertiesest on kõik nagu peale keeratud, aga seda Listeneri ei saa ikka kuidagi tööle.
CoiL
10.12.2009 15:17:14
Äkki tõstaks keegi adminn need viimased postid W7 teemasse ümber? See siin rohkem twiikimise teema ju mitte w7 probleemid jms.
13.12.2009 21:05:44
Mitteametlikud Win 7 Updated(13.12.2009):
x64:
http://www.megaupload.com/?d=0MSX3V0F
x86:
http://www.megaupload.com/?d=UIW1VTGS
Added - Many
Updated - Some
Removed - Some superseded
x86 contains 136 updates and x64 contains 138 updates
ertr2
14.12.2009 23:47:22
| mingit sellist quide ka on kus mul on selline 100lk teksti ees ja siis ma step by step käin selle kõik läbi ja saan kiireks windowsi?
olafsand
16.12.2009 00:52:03
| tomorrow kirjutas: |
x64:
x86:
Added - Many
Updated - Some
16.12.2009 21:55:37
Kas need midagi annavad ka juurde?
16.12.2009 22:07:16
| carlking kirjutas: |
| Kas need midagi annavad ka juurde? |
Pead silmas featuure?
Ei seda need ei tee.Kõik käib nö "kapoti all".Ehk siis mõningad komponendid uuendatakse uuemate versioonide peale.Nt Explorer,Kernel jne.
Ühtlasi viimaste seas on paar WMP uuendust.Igatahes ma pidin WMP käima pannes uuesti paar klikki tegema nagu pärast installi.Vist WMP Core ja Enchanged Video Rendeder said uuenduse kui ma õieti mäletan.
Süsteemi töökiirus pole halvenenud ega ka märgatavalt paranenud.Mingeid uuendustega seotud probleeme või anomaaliaid pole märganud.Kõik pisiprobleemid mis olid enne on ka praegu(Event log corruptib vahel jne).
Kuna uuenduste hulk on juba päris suureks kasvamas siis SP1 Beta pole ilmselt enam kaugel.Väljalaset prognoositakse järgmise aasta suveks
olafsand
17.12.2009 00:15:17
tomorrow, tänud uute linkide eest ja et sa viitsid sellega üldse jamada
vb on asi minus, aga stabiilsemaks ja paremaks peale nende uuenduste peale panekut on asi alati läinud
G80
17.12.2009 00:41:32
tomorrow, Kas win7 saab ka modida vlitega vms programmiga? Oleks vaja bench win 7 teha, kus 24/7 jura pole.
CoiL
17.12.2009 01:48:40
| vlite toetab ka win7-t (mitteametlikult).
17.12.2009 13:13:26
| G80 kirjutas: |
| tomorrow, Kas win7 saab ka modida vlitega vms programmiga? Oleks vaja bench win 7 teha, kus 24/7 jura pole. |
Pole kahjuks otsest programmi millega modida
Hetkel suht segapudru aga toon välja kuidas mina modin:
Mount/Unmount - GimageX
Driverite/Uuenduste/Keelepakettide integreerimine - DISM (Ainult konsooli kaudu...keeruline)
AutoUnattend.xml - Vista UA ( http://www.astranet.org/forums/showthread.php?p=469840 - jällegi suht keeruline )
Tweaks/UAC Off/Services - vLite
ISO - oscdimg -h -u2 -m -bD:\7Work\DVD\boot\etfsboot.com -lWindows7 D:\7Work\DVD D:\7Work\Windows7.iso
Seega suht killustunud värk .Pole ühtset programmi ja vLite toimib ainult osaliselt.Asjade eemaldamisega peab olema VÄGA ettevaatlik: http://www.msfn.org/board/windows-7-x64-vlite-extreme-removal-t136837.html
Pmst mul on pikemas perspektiivis plaan teha extreme 7.Installitaustad ja värgid 3DMark põhised ja optimeeritud ainult 3DMark jaoks.Kahjuks aja ja testimisega on nagu on  |
Siin sa kahjuks nüüd küll eksid...
http://www.msfn.org/board/stefanrtrs-win-integrator-t139748.html
17.12.2009 19:45:31
| Etz kirjutas: |
| G80 kirjutas: |
http://www.msfn.org/board/stefanrtrs-win-integrator-t139748.html  |
Kasutasin üht varasemat tema oma aga see ei lasknud suurt teha.Nagu näha on ta nüüd featuure lisanud  |
vahepeal on ka arendajaid lisandunud
Look Right
Anna vin
25.12.2009 19:56:46
Lasin ka enda x86 masinale tomorrow lingitud update peale. Tulemuseks see, et enam ei buudi, loobib bsodi ning peale system restore sain masina tagasi töökorda. OS oli 7 Home Premium. Kuid samas teisele arvutile lasin x64 peale ja need uuendused toimisid kenasti. Võta nüüd näpust, miks ta siis ei toiminud.
_________________ Ehitusprojektid ja konstruktiivsed lahendused HV kasutajatele soodsamalt
M: Zafira A/Astra G põhjakaitse - 30€ |
26.12.2009 00:32:52
| taikonaut kirjutas: |
| Lasin ka enda x86 masinale tomorrow lingitud update peale. Tulemuseks see, et enam ei buudi, loobib bsodi ning peale system restore sain masina tagasi töökorda. OS oli 7 Home Premium. Kuid samas teisele arvutile lasin x64 peale ja need uuendused toimisid kenasti. Võta nüüd näpust, miks ta siis ei toiminud. |
Tegemist oli ikka RTM-ga?
Enne nende installimist polnud Windows Updates mingeid pooleliolevaid updatete installe?
Muidu on x64 2 update isegi rohkem ja ülejäänud samad KB artikliga
Look Right
Anna vin
26.12.2009 00:59:50
Jah, RTM. Noh, karbitoode pmst see sama ongi. Ning ei, polnud ühtegi pooleliolevat installi.
