Prayer
27.10.2009 00:32:30
djelton kirjutas: |
Mis jama on, nimelt asi HP LaserJet 1020 installis, algul panin lihtsalt USB taha, et peaks oleam plug&play... |
See mudel on veidi problemaatiline, näiteks teatud pdf failide trükkimisel läheb printer spooler sassi, sai hiljuti Vista all sellega vaeva nähtud.
Soovitan proovida järgi "HP LaserJet Full Feature Software and Drivers" (367.86M) kogumis leiduvad tüürelid: HP leht (on küll XP kategoorias aga Vista all sai printeri toimima sellega).
miq1988
27.10.2009 00:32:35
Kahtlen, et msn süüdi, see oli pigem niisama öeldud, et arvuti suht idles.
Siiski keegi oskab mu esialgsele küsimusele vastata ?
27.10.2009 00:36:02
Minuni jõudis järgmine info:
tsitaat: |
Microsoft released a 'new' N version, N-1, that includes IE8..
The original N version was without both IE8 and WMP, but it got cancelled together with the E version.
Just to add to the confusion they are all the same build though, 6.1.7600.16385.090713-1255.
The N-1 is only visible in the name of the iso: 7600.16385.090713-1255_x64fre_clientn-1_en-us_Retail_UltimateN-GRMCNULXFRER_EN_DVD.iso |
Teadmiseks
lokuta
27.10.2009 01:10:29
Nii isemine jama win7 ei taha boot-ida ega upgrade-ida eelnevalt samal masinal win7 peal olnud.
Kirj järgmine:
The following issues are preventing Windows from upgrading. Cancel the upgrade, complete each task, and then restart the upgrade to continue.
This computer is not compliant with the Advanced Configuration and Power Interface (ACPI) standard. Windows must be installed onto a computer that supports ACPI. Contact your computer manufacturer for a BIOS update or install Windows on an ACPI-compliant computer.
27.10.2009 01:12:58
lokuta kirjutas: |
Kirj järgmine:
This computer is not compliant with the Advanced Configuration and Power Interface (ACPI) standard. Windows must be installed onto a computer that supports ACPI. Contact your computer manufacturer for a BIOS update or install Windows on an ACPI-compliant computer. |
Mis build enne oli peal ja mis buildi nüüd üritad installida?
lokuta
27.10.2009 01:15:44
nüüd on ametlik win7 pro mille litsentsi sai ostetud. ennem sai peale vuratud 7600 ja probleemi polnud
27.10.2009 01:18:30
lokuta kirjutas: |
nüüd on ametlik win7 pro mille litsentsi sai ostetud. ennem sai peale vuratud 7600 ja probleemi polnud |
Hmm veider error siis .
lokuta
27.10.2009 01:20:38
oma jagu jah, selle plaadiga olen varem installinud läpakale, siis oli kõik ok aga nüüd ruineerib ajusi
Timberg
ööKARU
27.10.2009 02:38:07
"Setup was unable to create a new system partition or locate an exisiting system partition."
Ei lase paigaldada ja kuvab sellise veateate.
Masinas kaks füüsilist ketast.
Esimesel kettal XP sp3.
Emaplaat: P5E3-WS-Pro
Üritasin teisele kettale (kus pole OSi) lasta Win7 peale, aga ei õnnestunud.
Tegin siis teisest kettast 50GB parti (ntfs), aga veateade ikka sama.
Sai ka googeldatud veateadet, aga kuradi ulmelisi asju hakati soovitama. Endal pole vist tehnilist taipu või julgust, et neid kõiki soovitusi katsetada. Ootaks HV tarkadelt abi
27.10.2009 03:44:23
Timberg kirjutas: |
Sai ka googeldatud veateadet, aga kuradi ulmelisi asju hakati soovitama. Endal pole vist tehnilist taipu või julgust, et neid kõiki soovitusi katsetada. Ootaks HV tarkadelt abi  |
Ehk tahab kettakontrolleri driverit?.Partitsiooni valides vali Load Driver
Vaata siit: http://support.asus.com/download/download.aspx?SLanguage=en-us
Ühtlasi millega pardid tegid?.Tee Windows 7 enda setupiga
Kasuks võib tulla ka kõik välised ja üleliigsed kettad lahti ühendada installi ajaks
eci
27.10.2009 08:36:54
Pole aega pikalt kirjutada aga täna hommikul arvutit käima pannes on tekkinud teine kasutaja konto nimega PQPBSADMIN.
Oskab keegi seletada, miks peaks arvuti ise kasutajakonto looma? Tundus, et asjal on samuti admini õigused peal.
maremark
27.10.2009 08:41:27
originaalversioon sul ikka? äkki mõni uss sees
AJ
27.10.2009 09:54:31
Windows 7 had 8 million beta testers
http://www.nordichardware.com/news,10111.html
tsitaat: |
Now that Microsoft has finally released Windows 7 it has started to reveal details on the development of the most popular OS in many years. Among others we have found that the beta versions of Windows 7 has had more testers than any other software by Microsoft and a grand total of 8 million users have participated in the beta program, a pretty staggering number.
The reasons have been plenty but the common nominator has been that the beta version and Release Candidate of Windows 7 have been so stable and functional that many have decided to use the operating system, for more than just testing.
Microsoft is no advocate of open source code, but it is pretty clear that even the creators of Windows has been given a lot of help from outsiders with its products. |
Andrus Luht
itimees.ee
27.10.2009 10:46:43
tomorrow kirjutas: |
overgrow kirjutas: |
St. kui mu lauaarvuti on 32 bitine kas x64 jookseb ka siis? |
Esimene reegel on ikka:
>3GB RAM - x64
<3GB RAM - x86
Teine asi on, et kas arvuti riistvarale on x64 drivereid?.Prose osas ei tohiks probleemi olla.95% modernsetest prosedest toetab x64  |
SilQ kirjutas: |
Päris paljud protsud on veel ainult 32bitise toega. Näiteks 478 soc'ti omad. |
Jutt käis modernsetest protsessoritest, mitte 5a vanadest üllitistest. Viimane Socket 478 protsessorituum oli Prescott, mis tuli turule 2004. Viimane 32bitine Inteli protsessor lasti välja 2006 aasta jaanuaris (Intel Core T2000/L2000/U2000 seeriad) ja seda oli vaid sülearvutitele saada. 64bit Intel Core 2 tuli turule 2006 Juulis, 64bit toega P4'd aga juba Jaanuar 2005.
RaidoR
27.10.2009 13:34:53
Mul selline probleem, et tahtsin sõbrale W7 peale panna. Buutisin siis plaadi ära ja nii kui peaks setupi aken ette tulema (see, kus saab valida installeri keele jne.), siis tuleb BSOD ette, viga näitab failis ACPI.sys. Sama ka Vistat üritades installida. Ainuke, mida laseb installida on XP.
27.10.2009 13:38:36
Loomulikult ei ütle me mingit infot aparaadi kohta, kuhu üritati paigaldada seda.
RaidoR
27.10.2009 13:56:39
Sorry, läks meelest jah
AMD Athlon II X2 250 (3.0Ghz/2MB/65W)
GIGABYTE GA-MA770-UD3
A-DATA 2x2GB DDR2 800MHz G-Series
SAPPHIRE HD4730, 512MB, 128bit, GDDR5
320GB, WD3200AAKS
Fortron 400W ATX12V v2.0
kaspar00
27.10.2009 14:03:31
võiksid IDE kettaga proovida võimalusel
RaidoR
27.10.2009 14:15:45
Kui võtsin selle ketta
RaidoR kirjutas: |
320GB, WD3200AAKS
ja panin selle masinasse, mis mul profiilis, siis töötas
Gap
27.10.2009 14:51:25
Mul oleks üks rumal küsimus veel et sellest on siin kindlasti räägitud aga teema päris pikk juba...et ostsin ka selle Windows 7 lõpuks ära (täisversioon) ja nüüd tahaks hakata varsti installima, aga tekkis selline küsimus et kui ma tahan nagu puhta installi teha selles mõttes et Vista täitsa maha arvutist ja puhtalt Win 7 peale panna, siis kas ma saan/pean selle formati Vista plaadiga tegema või on mul võimalik see n.ö format ka teha ka selle Windows 7 plaadiga ? loodan et saite mu küsimusest aru ja ei pahanda kuna kuidagi ei leidnud kuskilt netist selle kohts mitte midagi et nagu Vistale tegin formati vista plaadiga ja kuidas nagu 7-me puhul see asi nagu käib ?
27.10.2009 14:53:09
Gap kirjutas: |
Mul oleks üks rumal küsimus veel et sellest on siin kindlasti räägitud aga teema päris pikk juba...et ostsin ka selle Windows 7 lõpuks ära (täisversioon) ja nüüd tahaks hakata varsti installima, aga tekkis selline küsimus et kui ma tahan nagu puhta installi teha selles mõttes et Vista täitsa maha arvutist ja puhtalt Win 7 peale panna, siis kas ma saan/pean selle formati Vista plaadiga tegema või on mul võimalik see n.ö format ka teha ka selle Windows 7 plaadiga ? loodan et saite mu küsimusest aru ja ei pahanda kuna kuidagi ei leidnud kuskilt netist selle kohts mitte midagi et nagu Vistale tegin formati vista plaadiga ja kuidas nagu 7-me puhul see asi nagu käib ? |
Windows 7 installiprodseduur on väga sarnane Vista omale ja saad kenasti Win7 plaadiga formati ja clean installi teha
Gap
27.10.2009 15:00:43
Suured tänud [/b][/user]tomorrow[user][b] Sa oled alati õigel ajal õiges kohas abistava infoga tänud
sellel HV on midagi viga
kaspar00
27.10.2009 15:01:44
RaidoR kirjutas: |
RaidoR kirjutas: |
320GB, WD3200AAKS
ja panin selle masinasse, mis mul profiilis, siis töötas  |
Ei arvanudki, et ketas vigane kui ta XP all toimis, pigem ehk konflikt emaplaadi SATA driverites vista/7 puhul.. lihtsalt üks paljudest võimalustest, mida katsetada tasuks.
RaidoR
27.10.2009 15:53:15
Annab seda kuidagi parandada? Viimane BIOS update on peal.
