uus teema   vasta Tarkvara »  Arvutimängude foorum »  World of Warcraft märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 250, 251, 252 ... 383, 384, 385  järgmine
Millises serveris ja miks hakkad mängima?
PVP, sest ... (täpsustan teemas)
42%
 42%  [ 29 ]
PVE, sest ...
25%
 25%  [ 17 ]
RP, sest ...
2%
 2%  [ 2 ]
RP-PVP, sest ...
10%
 10%  [ 7 ]
Vahet pole, sest ...
19%
 19%  [ 13 ]
hääli kokku : 68
dzombe
sõnum 08.10.2009 01:10:13 vasta tsitaadiga
Enamus mängijaid ei tee mingit vahet, kas RP või Normal server. Ainus vahe mu ühe horde chari serveris toimivaga näiteks on pisiasi, et kui seal peetakse lausa ninjade nimekirja (loodi jagamise probleemid) siis mu RP serveri charid ausalt ei mäletagi sellist teadliku jama, arvestades, et enamuse ajast on saanud PUG raidida/HC teha... Aga on ka rangeid RP gilde. Mis seal toimub, pole aimugi.
Ho Ho
Ho Ho
sõnum 08.10.2009 10:23:58 vasta tsitaadiga
We are trying to make haste a slightly more attractive stat for classes that utilize a lot of damage or healing over time spells, specifically Shadow priests, warlocks (though especially Affliction) and Resto druids. We realize other classes use hots and dots too, but I think we can all agree that it's a bigger problem for the ones I mentioned.
We have new tech that will allow specific hots and dots to tick faster -- the time between ticks would decrease. This means more damage or healing per time but also having to refresh those spells more often
For 3.3 we are talking about introducing three new glyphs for Shadow Word: Pain, Corruption and Rejuvenation that would allow these spells to tick faster with the more haste you have
We might eventually apply it to more dots and hots if we (and you) think it's a good change. We feel like we may need a patch or two to make this conclusion though.
We might apply it to more dots and hots originally, especially DP and VT.
Don't think of this as a "Shadow priest dps is too low" issue. Think of it as a "Shadow priests don't scale with haste" issue
Kui nad jätavad selle ainult SWP peale siis erilist tolku see ei anna, max ~5% buff kui vaja oleks ~15-20%.
Lisaks veel buffiti prieste/locke/maage:
Glancing Blows: The mage, warlock, and priest classes no longer have an increased chance for their melee attacks to be glancing blows; and the damage penalty due to their glancing blows is the same as for other classes.
\o/
s4nder
sõnum 08.10.2009 12:31:01 vasta tsitaadiga
Jaa, melee kulub marjaks ära ka casteritel. Kunagi lõin oma warlockiga sobival hetkel tulnud staffi critiga ühe druiidi maha. See oli küll level 30 kandis.
dzombe
sõnum 08.10.2009 12:50:46 vasta tsitaadiga
Mingid mõttetud muudatused ju. Saaks aru, kui rupture hakkaks stäkkima... aga ei, seda nad ei tee icon_sad.gif
Ho Ho
Ho Ho
sõnum 08.10.2009 12:58:00 vasta tsitaadiga
Elric
sõnum 08.10.2009 22:42:49 vasta tsitaadiga
Ho Ho kirjutas:
\o/
Ei peagi ehk rerollima thumbs_up.gif . Multidottimine samas aga muutuks õudusunenäoks ^_^
Ho Ho
Ho Ho
sõnum 09.10.2009 09:43:57 vasta tsitaadiga
Elric kirjutas:
Nuh, hetkel on 2-3 targetit multidottida suht-koht lihtne, 4'ga läheb juba keerukaks. Bloodlusti ajal saab vist isegi ainult 2 dottimine paras peavalu olema.
Samas bloodlust + orc berserking + haste/wild magic pot peaks suht korraliku bursti andma nüüd
Teaq
sõnum 09.10.2009 14:27:40 vasta tsitaadiga
Trolli berserk ikka?
Ho Ho
Ho Ho
sõnum 09.10.2009 14:57:34 vasta tsitaadiga
Olaf
Olaf
sõnum 10.10.2009 18:33:52 vasta tsitaadiga
Mul vedeleb siin üks guest pass key .. Ehk 10 päeva tasuta proovimist.
Keegi soovib? Kes esimesena priva saadab, sellele annan.
Lordlesta
sõnum 10.10.2009 18:41:06 vasta tsitaadiga
Milleks see veel vajalik on? Trial kasutajaid saab ka niisama teha.
Kommentaarid: 31 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 27
variousart
sõnum 10.10.2009 21:15:59 vasta tsitaadiga
Ka mina pole aru saanud, mis vahe on sellel,kui ma teen lihtsalt triali või siis kasutan key'd...
gemini
sõnum 10.10.2009 21:46:18 vasta tsitaadiga
See guest key annab pärast recruitijale 1 kuu tasuta mänguaega.
variousart
sõnum 10.10.2009 23:29:44 vasta tsitaadiga
Ja see on üks nendest teenustest mida Eestis jällegi kasutada ei saa?
attrs
attrs
sõnum 11.10.2009 08:40:22 vasta tsitaadiga
Täpselt nii... thumbs_down.gif Invite a friend/res a friend pole Eestis kasutatav "tänu" meie suurepärastele seadustele.
Kommentaarid: 418 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 368
gloom
gloom
sõnum 11.10.2009 11:11:15 vasta tsitaadiga
Battle.neti accountist annab riigi ära vahetada ja minek icon_wink.gif Saab kõiki teenuseid kasutada.
Kommentaarid: 29 loe/lisa Kasutajad arvavad:  :: 1 :: 2 :: 23
variousart
sõnum 11.10.2009 12:02:22 vasta tsitaadiga
gloom kirjutas:
Ikka annab sama error'it, isegi kui riik näiteks UK'ks vahetada...
gloom
gloom
sõnum 11.10.2009 18:25:53 vasta tsitaadiga
Ei tea siis, mul endal ka UK peale vahetatud ning kõik toimib.
630
sõnum 12.10.2009 08:46:49 vasta tsitaadiga
Ho Ho kirjutas:
Arvestades, et praegune "top fight" on ikkagi Anub hc, pmst ainus koht kus dps loeb, teised encounterid on ikkagi suht faceroll siis..pole spriistil ka häda ikka mitte midagi. Seda enam, et spriest on hübriid klass. Raudselt top5s dpsis koos rogue ja dk ja wariga(parimad teevad 9.5k+, keskmine on raudselt 8k+ dps).
Saan aru küll miks ja kuidas aga siiski, see on ainus koht, kus dps loeb:).
Arvestades, et rogue, war ja dk on ikkagi melee, siis shadowpriest on pmst parim caster praegu. Antud fightis firemage saab ka lähedale, siis ütleme et konkureerib parima casteri kohale.
Pole ju midagi väga kurta?
Ho Ho
Ho Ho
sõnum 12.10.2009 10:07:53 vasta tsitaadiga
Anub on 100% aoe fight, pole mingi ime et OP mind sear seal ennast heast küljest näitab. Tbh siis vajab sear üsna kindlalt nerfimist, normal hitid on keskmiselt suuremad, kui maagi-locki aoe critid. Samuti burrow phassede ajal jookseb spriest ringi ja spammib kõigile dotid peale. Ehk siis suht-koht perfektne fight spriesti jaoks.
Samas kui palju on priestist kasu twinsidel mulli lõhku laskmiseks? 15s jooksul ei genereeri ta praktiliselt mingit dammi, hea kui saab kolmandiku sellest, mida roogid teevad.
dzombe
sõnum 12.10.2009 10:22:12 vasta tsitaadiga
Muide, see battle.net account, seda tavaliseks tagasi vist ei annagi muuta icon_sad.gif Mailiaadress kurask on palju pikem sisse toksida, kui vana acc nimi oli (2 acci, seega remember alati ei päästa). Samas on seal ka võimalus rohkem "vanu" accounte siduda ühe BattleNet accounti alla - kuidas siis see sisselogimine välja näeb?
Lordlesta
sõnum 12.10.2009 12:16:15 vasta tsitaadiga
Alates 12. novembrist on nagunii accounti viimine Battle.net'i kohustuslik. Siis ei saa enam vana accountiga sisse logida.
Abazel
sõnum 12.10.2009 14:19:33 vasta tsitaadiga
dzombe kirjutas:
Lihtsalt valid millise "vana" account'iga sisse logida tahad peale parooli sisestamist.
gemini
sõnum 12.10.2009 14:50:21 vasta tsitaadiga
Kas G2play.net on odavaim koht kust mänguaega osta?
eShelobik
eShelobik
sõnum 12.10.2009 14:57:02 vasta tsitaadiga
gemini kirjutas:
Täna hommikul ostsin: http://www.pcgamerusa.com/BuyTimeCardControl.aspx?t=1 <-- 288krooni. Kui oled ostu sooritanud, siis poogi nende live supporti veidi, nad küsivad sult paypali payment confirmationi emaili peale ja siis annavad instantly koodi ... kui ei viitsi oodata kuni nad processivad:D
Kommentaarid: 295 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 262
gemini
sõnum 12.10.2009 16:25:03 vasta tsitaadiga
etc_Shelob kirjutas:
gemini kirjutas:
Kinnitan et asi toimib. Läks ca. 10 min ja 60 päeva Wow-i on jälle tagatud icon_smile.gif
Sathanas
sõnum 12.10.2009 23:11:34 vasta tsitaadiga
Kalevlastel on kohati räige heali põud! Aga täna oli raidis üle kolme healeri vahelduseks jälle ja inimesed on geari ka saanud vahepeal juurde, niisiis, lasime totc25 heroicus northern beastsi, jaraxxuse ja faction championsid alla ühe õhtuga.
jaraxxuse ja faction champions siis guil first time killid.
gearitud ja oskajad mängijad on oodatud guildiga liituma, kontakteeruge ingame Redplague.
server siis al'akir lol
viimati muutis Sathanas 13.10.2009 00:20:46, muudetud 1 kord
variousart
sõnum 13.10.2009 00:14:49 vasta tsitaadiga
mis server icon_biggrin.gif?
Ho Ho
Ho Ho
sõnum 13.10.2009 00:59:11 vasta tsitaadiga
Te mõnele raidile outsidereid ei taha? Teeks palaga hea meelega totc10/25 heroicuid. Siiani olen mõlemat puginud ning parim on olnud ~5x <200k anub'i wiped 10-manis, 25-manis pole esmasestki bossist mööda saanud icon_biggrin.gif
Pala nimi siis dractor
V3rpooz
V3rpooz
sõnum 13.10.2009 09:29:18 vasta tsitaadiga
Sathanas kirjutas:
Kommentaarid: 225 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 195
Button
Button
sõnum 13.10.2009 13:10:25 vasta tsitaadiga
kas al*akir mitte full ei ole ?, v kuda see "full" endas väljendub
et kas lihtsalt sitaks rahavast, v full siis full, et keegi ei saa sisse icon_question.gif
attrs
attrs
sõnum 13.10.2009 13:21:07 vasta tsitaadiga
Full vanasti tähendas seda, et uued näod sinna enam ligi ei saa. Kui juba mingist ajast char seal olemas on võimalik ka uusi teha.
Elitegamer
Elitegamer
sõnum 13.10.2009 13:24:30 vasta tsitaadiga
Kui uusi chare teha ei saa või transferida, siis on "Locked". Full näitab lihtsalt, et seal on palju inimesi, tipptundidel on järjekorrad, ilge lag Dalaranis jne..
p2tu
p2tu
sõnum 13.10.2009 17:53:12 vasta tsitaadiga
dzombe
sõnum 13.10.2009 21:49:48 vasta tsitaadiga
http://forums.wow-europe.com/thread.html?topicId=11155757485&sid=1
Mine või naise maagiga ringi jalutama .... (veel liitmata)
Teaq
sõnum 13.10.2009 22:00:24 vasta tsitaadiga
Mul ka see connected jama krdi blizz 11111!!!11111
dzombe
sõnum 14.10.2009 00:10:00 vasta tsitaadiga
Test - Recount ja Skada võrdlus: viimane on parem kuna DPS kasvas kohe 30 võrra ISE ...
Ho Ho
Ho Ho
sõnum 14.10.2009 09:36:52 vasta tsitaadiga
[edit]
Holy s...
Shadow
Glyphs
* Glyph of Mind Flay now Increases the damage done by your Mind Flay spell by 10% when your target is afflicted with Shadow Word: Pain.
* Glyph of Shadow Word: Pain changed to - The periodic damage ticks of your Shadow Word: Pain spell restore 1% of your base mana.
* Glyph of Shadow now increase your spell power by 30% of your spirit for 10 sec. (Up from 10%)
# Improved Devouring Plague: This spell now deals 10/20/30% of its total periodic effect instantly, up from 5/10/15%.
# Shadowform: This talent also now causes Devouring Plague, Shadow Word: Pain, and Vampiric Touch to benefit from haste. Both the period length and the duration of these spells will be reduced by haste. In addition, the mana cost has been reduced from 32% to 13% of base mana.
# Vampiric Embrace: This ability is now provides a 30-minute buff that cannot be dispelled, instead of a target debuff.
Sathanas
sõnum 14.10.2009 18:16:31 vasta tsitaadiga
Ho Ho kirjutas:
teistest guildidest main raidi inimesi ei võeta, 10 man raidide 2 põhi gruppi on ka kindla kokku töötanud koosseisuga. alt 25 manidele on outsidereid kohati võetud kui rahvast on puudu jäänud.
logitech13 kirjutas:
meil on juba 3 väga hästi gearitud ja skilled DKd
Ho Ho
Ho Ho
sõnum 14.10.2009 18:30:18 vasta tsitaadiga
Aww, kahju. Toorelt ileveli järgi oleks mu alt te gildis #2 tank oma 2xilvl200 trinketiga, eile totc25 heroicus püsis suht edukalt ilma cooldownideta elus ka 6 stacki peal kui teine tank disconnectis icon_razz.gif
Aga nuh, kui tanki tarvis mõne raidi täiteks siis andke teada, hädapärast võin ka druid healerit pakkuda kes suts viletsama geariga.
Elric
sõnum 14.10.2009 21:40:45 vasta tsitaadiga
Ho Ho kirjutas:
Holy s...
[size=9]Shadow
Glyphs
# Vampiric Embrace: This ability is now provides a 30-minute buff that cannot be dispelled, instead of a target debuff.[/size]
...kus see kirjas on?!
Ho Ho
Ho Ho
sõnum 14.10.2009 23:08:58 vasta tsitaadiga
Uutes PTR patchnotedes, mmo-championis on ka kõik kirjas.
Spriest.com tundub pea iga päev tund-paar maas olevat miskipärast, peaks uurima adminidelt mis pull toimub
jaco
sõnum 15.10.2009 13:35:55 vasta tsitaadiga
Kas Outlandi servus on miski eestlaste seltskond, gild, kes pvp-le oleks orienteeritud? ja ühe noobi kampa võtaks icon_razz.gif
Elric
sõnum 15.10.2009 17:22:32 vasta tsitaadiga
Ho Ho kirjutas:
Mitte vaid paar tundi. Eilsest saadik proovinud ning pole kuhugile jõudnud.
Ho Ho
Ho Ho
sõnum 15.10.2009 17:37:49 vasta tsitaadiga
Täna tõesti terve päev maas olnud, eile õhtul veel mingi hetk sai sisse
dzombe
sõnum 17.10.2009 11:51:07 vasta tsitaadiga
Kuradi blizzard. Ma ei saa aru, kas neil seal mingeid mõtlevaid tüüpe ka on, aga kuhu ja kuidas kisada, et järgmises pätsis oleks sees parandatud "remember me" meeldejätmine. Ehk te, kes mitut accounti samas masinas kasutate, tõesti toksite igakord uue "pikema" (olgu või 5 märki aga pikem icon_smile.gif ) kontonime sisse kuna see mäleta mind kaob? Vähemalt eri kasutajanime alt WoW käivitades peaks ju meelde jääma...
PS. Rääkimata sellest, et combatlog salvestamine on ka parajalt algeline veel... Ja päris linuxi versiooni pole...
Ho Ho
Ho Ho
sõnum 17.10.2009 12:42:05 vasta tsitaadiga
Combatlogi kohta on ainult üks probleem, nimelt ei ole seal kirjas kõiksugu shieldide absorbide kohta et kelle shield siis ikka absorbis. Muu koha pealt pole sel häda midagi ning kõik info saab kätte. Linuxi versioon oleks küll tore kuid läbi wine töötab ta üsnagi hästi icon_smile.gif
Mitme konto kohta, kui bnetiga ära seod siis peaks vist tolle bneti konto nime saama meelde jätta ning peale tollega logimist viskab ette menüü kust saad valida millist konkreetset kontot mängida soovid. Ehk siis suht pseudoprobleem.
Kristoferr
Kristoferr
sõnum 17.10.2009 13:51:55 vasta tsitaadiga
630 kirjutas:
Ho Ho kirjutas:
See, et see on nüüd ainuke fight kus dps loeb on küll ülimalt vale.Alles tuhatkond guildi on killinud 25man algaoni, paarsada HC Anubi. Tuhanded guildid alles üritavad Ulduar HM, et pääseda Algaonini. 10man meil maas, aga 25man Firefigheri tegime näiteks alles üleeile.
Puhas DPS/survival encountereid on veelgi. Ei ütleks, et Hc25 beasts ja Jaraxxus just faceroll oleks. Korralikku dps vaja ikka kogu raidi poolt.
Liitu Opencode Go soodsa coding plaaniga ja saa 5€ soodust!
Liitu Wise'ga!
Kommentaarid: 268 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 219
dzombe
sõnum 17.10.2009 15:44:53 vasta tsitaadiga
Ho Ho kirjutas:
No lihtlabane "/combatlog new" käsk võiks ju ikkagi olemas olla? Ehk, kas teil laseb WoW logifaili lahti? Minul jääb locked seisu ja aitab ainult mängu sulgemine. Ei tohiks ju olla eriti raske lihtsalt logifailile counter taha panna...
Ho Ho kirjutas:
Ma ei mõtle enda kontosi. Näiteks vahetaksid sõbraga/pereliikmega tihti arvutit. Iga kord toksi seda kasutajanime, mis mul on nüüd tänu Bnetile 2x pikem. Ei ole ka listi, millest nool üles-alla valida. Pealegi, Bnet konto loomisel oli eraldi rõhutatud, et oma pereliikme jaok PEAD loome uue konto, mitte liitma WoW accounti olemasoleva Bneti külge.
Ho Ho
Ho Ho
sõnum 17.10.2009 15:51:50 vasta tsitaadiga
dzombe kirjutas:
Ho Ho kirjutas:
See on sul miski enda probleem. Minul laseb kenasti logifaili lõppu ning log lastakse bacgroundis kenasti worldoflog'i servusse. Ei mingit probleemi locked failiga ega midagi. Lihtsalt WoL klient käima, /combatlog ning nagu naksti on peale igat bossfightit log serveris üleval. Ka mängu ajal on võimalik logi vaadata suvalise redaktoriga kui isu tuleb, iseasi mida ma sealt 1G+ failist otsida viitsin.
uus teema   vasta Tarkvara »  Arvutimängude foorum »  World of Warcraft mine lehele eelmine  1, 2, 3 ... 250, 251, 252 ... 383, 384, 385  järgmine
