| Millises serveris ja miks hakkad mängima? |
| PVP, sest ... (täpsustan teemas) |
42% |
[ 29 ] |
| PVE, sest ... |
25% |
[ 17 ] |
| RP, sest ... |
2% |
[ 2 ] |
| RP-PVP, sest ... |
10% |
[ 7 ] |
| Vahet pole, sest ... |
19% |
[ 13 ] |
| hääli kokku : 68 |
Ho Ho
86 |
kempi
25.09.2009 15:39:05
Combat dagger:
Saved Template
Class: Rogue
Level: 60
Assassination Talents (20 points)
# Malice - 5/5 points
Increases your critical strike chance by 5%.
# Improved Slice and Dice - 3/3 points
Increases the duration of your Slice and Dice ability by 45%.
# Ruthlessness - 3/3 points
Gives your finishing moves a 60% chance to add a combo point to your target.
# Lethality - 5/5 points
Increases the critical strike damage bonus of your Sinister Strike, Gouge, Backstab, Ambush, Ghostly Strike, or Hemorrhage ability by 30%.
# Relentless Strikes - 1/1 point
Your finishing moves have a 20% chance per combo point to restore 25 energy.
# Vile Poisons - 3/5 points
Increases the damage dealt by your poisons by 9%.
Combat Talents (31 points)
# Improved Sinister Strike - 2/2 points
Reduces the Energy cost of your Sinister Strike ability by 5 Energy.
# Lightning Reflexes - 3/5 points
Increases your Dodge chance by 3%.
# Precision - 5/5 points
Increases your chance to hit with melee weapons by 5%.
# Improved Backstab - 3/3 points
Increases the critical strike chance of your Backstab ability by 30%.
# Improved Sprint - 3/3 points
Reduces the cooldown of your Sprint ability by 90 seconds.
# Dual Wield Specialization - 5/5 points
Increases the damage done by your offhand weapon by 50%.
# Dagger Specialization - 5/5 points
Increases your chance to get a critical strike with Daggers by 5%.
# Blade Flurry - 1/1 point
Increases your attack speed by 20%. In addition, attacks strike an additional nearby opponent. Lasts 15 seconds.
# Aggression - 3/3 points
Increases the damage of your Sinister Strike and Eviscerate abilities by 6%.
# Adrenaline Rush - 1/1 point
Increases your Energy regeneration rate by 100% for 15 seconds.
Subtlety Talents (0 points)
# None
Comat sword:
Saved Template
Class: Rogue
Level: 60
# Deflection - 5/5 points
Increases your Parry chance by 5%.
# Riposte - 1/1 point
A strike that becomes active after parrying an opponent's attack. This attack deals 150% weapon damage and disarms the target for 6 seconds.
# Sword Specialization - 5/5 points
Gives you a 6% chance to get an extra attack after dealing damage with your Sword.
# None
Ühesõnaga midagi sellist oli, millega ringi joosti PvE's
_________________ All there is to do - recon... |
| Kommentaarid: 34 loe/lisa |
33 |
Timberg
ööKARU
25.09.2009 17:18:33
| Kuidas hunter sellel ajal oli ja kas geared feral druid bgs suutis midagi ära teha ka?= Tean, et pves oli feral drood mõttetu
272 |
veso
25.09.2009 18:28:40
Mis sa Timberg hakkasid classic privasid mängima?
Psych0
25.09.2009 19:24:56
| Võtsin kah oma Paladini käsile. Peaks ainult professionid ära uuendama aga pappi pole -.- .
| Kommentaarid: 61 loe/lisa |
57 |
gemini
26.09.2009 17:21:18
| Hea on tõdeda et WoW-i kannatab ka 236kbps netiga mängida, mis sest et ping on ~500ms. Questimiseks käib küll hetkel.
| Kommentaarid: 75 loe/lisa |
61 |
Venturi
| Kommentaarid: 21 loe/lisa |
21 |
Timberg
ööKARU
26.09.2009 22:23:36
| veso kirjutas: |
| Mis sa Timberg hakkasid classic privasid mängima? :P |
Ei muidugi mitte :P
272 |
V3rpooz
27.09.2009 16:14:29
| Timberg kirjutas: |
| veso kirjutas: |
Mis sa Timberg hakkasid classic privasid mängima?  |
Ei muidugi mitte  |
hmmhmhmhm right
| Kommentaarid: 225 loe/lisa |
195 |
Ho Ho
27.09.2009 20:02:32
Täna sai palaga tehtud totc25 pug. Offtanki'iks oli karu ning tulemuseks oli, et sain uue vöö, shieldi ja sõrmuse. Peale raidi lõin ka mõned embleemid laiaks ning nüüd ongi alt kõrgema tasemega gearis kui priestist main ning konkureerib üsna tasavägiselt gildi maintankiga
86 |
Elric
27.09.2009 20:19:07
Nojah, nondel, kellel spriestist main, mõlgub mõttes uus leida.
(<---kaldub laserkana poole.)
Ho Ho
27.09.2009 21:22:12
| Elric kirjutas: |
| Nojah, nondel, kellel spriestist main, mõlgub mõttes uus leida. |
Kurb aga tõsi. Hetkel veel ei tea, mis chari võiks võtta. Pala sobiks üsna hästi kiud gildis on tanke suht jalaga segada, iseasi mis gearis nad on.
86 |
Sathanas
28.09.2009 01:31:44
| kalevlastes on 0 raidivat spd, tule meile!
| Kommentaarid: 37 loe/lisa |
36 |
Ho Ho
28.09.2009 08:19:47
Tundub, et saime ikka gildi enam-vähem järje peale ning eriti ei sooviks maha jätta rahvast, kellega on pea poolteist aastat koos raiditud. Viimane nädal on 25-man'is isegi üsna hästi läinud. Kui olukord oluliselt ei halvene jään sinna püsima.
Kalevlaste DKP järgi vaadates tundub, et te isegi ei ürita hardmodesid, me vähemalt punnitame ka neid teha
86 |
d-scorpion
28.09.2009 09:57:46
| Sai eile toc10 pug ära tankitud,muidu plegi raske kui ainult Jaraxxxuse juures imo,nende addidega nii palju ringitõmblemist.
Elric
28.09.2009 10:37:46
| Sathanas kirjutas: |
| kalevlastes on 0 raidivat spd, tule meile! |
Mida SP teie raididele juurde annab?
Ho Ho
28.09.2009 11:27:34
VE healing?
Boomkin annab 3% hit, 3% haste, 5% crit, bress, innervate ning kõrgema DPS'i.
[edit]
Eile pala uutele õlgadele enchanti jaoks honorit ostma minnes WG'st sattusin sinna kogemata ajal, mil see Alliance'i käes oli. Enne tähele ei pannud, kui roog+feral+ench shaman kallale hüppasid. Roog ja ench surid, feral sprintis natukese aja pärast minema. Prot pvp on suht mõnus kui on 41k hp, 2k str ning 2.5k unbuff BV
86 |
Button
28.09.2009 11:44:06
pff praeguse seisuga on gildi attendence suht pekkis, eile tuli 20 inimiest kokku, masendav.
tegime hoopis vahelduseks siis 20man EOE ja alustasime 20man naxxi
teine suurim(loe progressive) gild realmis alliance poole peal on omadega õhtal, tundub et võtame viimased
uppujad oma uppuvale laevale ja saab ehk edasi areneda.
ehk siis suht pekkis realm omadega, aga mis teha.
totc25 on küll läbitud, end heroicu jaoks ei hakka veel närve ja aega raiskama.sama lugu uld25 hardmodes.
kuni ei ole ikka enamvähem stabiilset tiimi, pole mõtet üritada.
mõned päevad tagasi sai esimest korda 10man Algaloni proovitud njah, tunnist jäi väheks ilmselgelt.
| Kommentaarid: 28 loe/lisa |
Ho Ho
28.09.2009 13:23:26
http://www.gamasutra.com/php-bin/news_index.php?story=25192
Lead world designer pajatab veidike Cataclysm'i kohta
86 |
company
28.09.2009 13:30:43
| Härrased, ehk kirjutame kiire overview Onyxia 3.2.2 alistamisest? Oleks hea kui saaks strateegia tangi vaatenurgast.
Ho Ho
28.09.2009 14:00:33
10-man 2 tanki, 25-man 3 tanki
Maintank tirib ony vastasseina ning jääb ise seljaga vastu seina. Kõik rahvas jookseb seinaääri mööda bossi külje peale. Melee seisab kusagil tagajalgadest suts eespool. Sabast tuleb kõigil hoida kaugemale, pea pool cleave'i saades oneshotib praktiliselt suvalise tegelase.
Ony virutab suht nõrgalt kuid flame breath on suht valus, ei midagi erilist. Offtank(id) dps'ivad bossi ning hoiavad külje peal olevastel koobastel silma peal juhuks, kui keegi failib sabaga ning lennutataks koopasse. Kui see juhtub korjab OT sealt tulevad whelp'id kokku ja tankib neid.
P2's tõuseb Ony lendu ning melee ei saa teda sel ajal dps'ida*. Kõik ranged dps on 100% ainult ony peal ning ignoreerib kõike muud. Rahvas võiks mõistlikult spreadida et väga paljud korraga tulepallidega pihta ei saaks. P2 alguses tankid jooksevad kahele poole külgede peale ning korjavad kokku nood mõnikümmend whelp'i kes seat riburada pidi välja lendavad. Melee aoe'b nad maha. Peale esimest suurt whelp'ide lainet tuleb uksest suuremat sorti draakon välja keda MT tankib. Too drake on nats sarnane Kolaron'ile et vahel teevad ta melee hit'id koorma kaupa lisadammi kõigile tanki lähedal olnule. Samuti castib ta kohati aoe spelli mis haiget teeb. Tank võib mõlemat asja ignoreerida kuid melee peab hoidma tankist võimalikult kaugel ning aoe casti ajal minema jooksma. Offtank'id jätkavad küljekoobastest aeg-ajalt väljuvate whelpide korjamist-tankimist. Roogid ja muud korraliku aoe'ga tegelased võiks whelpe tappa, shamaanid ja muud mitte-nii-hea aoe'ga meleed notivad suuremaid drakesid.
Aeg-ajalt teeb Ony ka deep breath'i, ehk siis castib üht spelli paar sekundit ja siis lendab otse üle koopa tekitades oma teel ~20-25k dammi kõigile, kes ette jäävad. Kui rahvas pole 100% hp peal ja/või ei saa sellega pihta saamise hetkel heali siis on see üsna kindel surm. Ehk siis kõik peavad jälgima millal see toimub ning koheselt tee pealt eest ära jooksma, ka tankidele on see ohtlik kui nad peavad samal ajal muid asju tankima.
*) Vanasti sai, hetkel tundub, et teatud klasside teatud ability'd töötavad, enamus mitte. Täit selgust mul pole selle koha pealt.
Umbes 40% kandis ony maandub ning adde enam niisama juurde ei tule. Suht-koht koheselt castib mõne sekundilise aoe feari. MT peab ony kiirkorras tagasi koopa tagaossa tirima. Sisuliselt on see P1 kordus kuid lisatud on fear. Feari ajal jätkab Ony MT taga ajamist ning tema peale nii tule purskamist kui cleavemist ja sabaga vehkimist, seega rahval tasub hoida veelgi kaugemat distantsi nii ony peast, sabast kui ka koobaste sissepääsudest Offtankid peavad kiirelt üles korjama nood whelp'id kes tekitatakse kui mõni tegelane koopasse fearitakse/visatakse.
Üldiselt suht lihte võitlus kui rahvas oskab peast-sabast eemale hoida, ranged keskendub Ony peal ning meleed oskavad suuremate addidega õigesti käituda
[edit]
Vead
viimati muutis Ho Ho 28.09.2009 14:06:55, muudetud 1 kord |
86 |
eShelobik
28.09.2009 14:04:56
| njah. esimesel päeval suvalise 10man pug'iga läksime sisse, waipisime vanade aegade mälestuseks trashi peal ja siis onyxia oneshottisime ilma, et keegi oleks mingit taktikat rääkinud. ühesõnaga, kehtib lihtne loogika, ära seisa tules ja vaata mis ümber toimub.
| Kommentaarid: 295 loe/lisa |
262 |
freestyler
28.09.2009 14:24:02
suur add relvituks on ka kasuks... damm väheneb päris palju
oma guildiga saime ony25 maha vist 5-dal katsel. täpselt niipalju läks aega, et paar lolli casterit aru saaks, et saba taga pole just kõige parem koht seismiseks.
Elric
28.09.2009 15:27:40
| Ho Ho kirjutas: |
VE healing?  |
VE 25% grupi jaoks, siis küll ^_^
Ho Ho
28.09.2009 16:55:30
| Elric kirjutas: |
| VE 25% grupi jaoks, siis küll ^_^ |
Anub'i peal kõlbab ka 5%. Hoidmaks inimesi ~1k hp peal piisab, kui priest teeb 6k dps mis on igati teostatav. Lisaks aitab ka healing stream+JoL.
[edit]
Kiirkursus arena mängimiseks:
86 |
