-Superman-
31.08.2009 12:08:20
| Skeptik kirjutas: |
| -Superman-, see ei tohiks ju enam uudis olla, et mäng 1080p (1280x1080) resol tuleb? Prologue oli samuti. |
Ei
GT5 Prologue oli 720p
GT5 prologue demo is 1280x1080p (yamauchi know than in car game the vertical resolution is the most important for the visibility) but with MSAA 2x now ! it's a very good Compromise
they also very improved the display of grills and electric wires and aliasing problems (compare electric wires in GT-HD and in this demo, it's big big gap), the texture filtering is very clean and the HDR ligthing is awesome! All this in 60fps with 16 photorealistics cars, it's impressive the show room and the pit/garage is full 1920x1080 no AA
Gameplay ise oli 720p ja ruumis oli 1080p.
Nüüd on gameplay ise juba 1080p.
EvilKatarn
diivanilill
31.08.2009 12:10:11
Ise kirjutasid selle viimase vigase möla vä?
81 |
313 |
-Superman-
31.08.2009 13:23:49
Loe: Running at 1280×1080 scaled up to proper 1080p, Gran Turismo 5 Prologue
scaled up to proper
See pole 1080p
Native on 1280×1080p mis pole 1080p
1080p = 1920 x 1080
31.08.2009 13:45:36
-Superman-, oled nati valesti aru saanud. terminoloogias pole kindlat kokkulepet, et 1080p peaks tingimata 1920x1080 reso tähendama. 1080p võib ka 1280x1080 olla, mida ta siinkohal ka on. see näitab ainult pildi vertikaalset kõrgust.
"scaled up to proper 1080p" tähendab, et kui konsoolist on valitud 1080p mode, siis venitatakse see 1280x1080 pilt teleri poolt 1920x1080 peale.
313 |
HDTanel
Overclocker
31.08.2009 14:24:14
-Superman-, wtf sa ajad maisaaaru
Skeptik, 1920x1080 jah, mitte 1280
Telekal kui mängu tööle lõin siis näitas telekas automaatselt ära reso, millist kasutab kui mängida, selleks oli 1920x1080
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
virx
31.08.2009 14:49:17
Gran Turismo 5 does NOT have a resolution of 1920x1080p.
1920x1080p is what is traditionally termed as "1080p resolution." It is impressive because it uses all 2,073,600 pixels on a 1080p HDTV set.
1920x1080i resolution uses 1,036,800 pixels on screen at the same time.
Sony wants to try and advertise "1080p resolution" to gamers, so they have told the developers to make sure the game runs in "1080p" resolution. But the fact is that the Playstation 3 doesn't have the power to run Gran Turismo 5 in a resolution of 1920x1080p resolution with 2 million pixels.
As a result, Sony has decided to use a resolution of 960x1080p, where the vertical lines are kept at 1080p (so that Sony can use the words "1080p,") but the much larger number of horizontal lines have been cut in half. This means that only 1,036,800 pixels are being displayed on the screen. That is the exact same level of performance as 1080i.
So, when Sony says that Gran Turismo 5 is 1080p, they are not being honest, because it actually only offers the level of performance as traditional 1080i.
309 |
31.08.2009 15:21:34
| PlatoonSgtElias kirjutas: |
Telekal kui mängu tööle lõin siis näitas telekas automaatselt ära reso, millist kasutab kui mängida, selleks oli 1920x1080  |
telekas näitab sulle, mis signaal konsoolist sisse tuleb, mitte mängu native reso.
313 |
-Superman-
31.08.2009 15:31:13
| Skeptik kirjutas: |
"scaled up to proper 1080p" tähendab, et kui konsoolist on valitud 1080p mode, siis venitatakse see 1280x1080 pilt teleri poolt 1920x1080 peale. |
Ei sina ei saa aru.
1280x1080 pole 1080p native.
1920x1080 on 1080p native.
Kogu aeg oli 720p native(mitte 1080p native)
Aga nüüd sellel on 1080p native.
GT5P = 720p native
GT5 = 1080p native
31.08.2009 15:45:25
-Superman-, mis siin vaielda üldse? see ju ammu kinnitatud mitme eri allika poolt (vaata eelmist linki, mille tõin).
kui konsool 1080p mode-s, siis mäng: 1280x1080 @ 60FPS 2xAA
kui konsool 720p mode-s, siis mäng: 1280x720 @ 60FPS 4xAA
313 |
beastbeats
284 |
ivokas
09.09.2009 17:54:20
Aina paremaks läheb.
_________________ Reisijate ja fekaali vedu kahekorruselise bussiga.
Praepelmeenid ja Vana Tallinn suudavad nii mõndagi muuta! |
| Kommentaarid: 65 loe/lisa |
61 |
Cander
09.09.2009 18:11:52
| holy fuck, now that's called genius on work...uskumatult huvitav jubin
| Kommentaarid: 39 loe/lisa |
34 |
Bumer
22.09.2009 20:27:09
Peaks seda teemat ka natuke tõstama.
Praeguseks on selgunud et sellised masinad nagu Ferrari 458 Italia ja Mercedes-Benz SLS AMG on mängus esindatud.
| Kommentaarid: 51 loe/lisa |
48 |
paanz
22.09.2009 21:03:40
| Bumer kirjutas: |
Praeguseks on selgunud et sellised masinad nagu Ferrari 458 Italia ja Mercedes-Benz SLS AMG on mängus esindatud. |
Aii, ma jube mersufänn..magus maasikas mulle siis
_________________ PSN: Paanz |
| Kommentaarid: 9 loe/lisa |
weasel
23.09.2009 08:05:39
| paanz kirjutas: |
Aii, ma jube mersufänn..magus maasikas mulle siis  |
Krt see HV on ikka imelik. Sellised postitused on OK, aga kui mina ütlen, et nädala lõpus tuleb release date, siis sellised pole :S
_________________ PSN: weaselEST |
| Kommentaarid: 38 loe/lisa |
iDemon
| Kommentaarid: 122 loe/lisa |
104 |
henri200
23.09.2009 14:17:56
Too pole GT5.
| Kommentaarid: 62 loe/lisa |
59 |
iDemon
23.09.2009 14:37:24
Mis asi ei ole?
104 |
henri200
23.09.2009 14:43:06
| Koenigseggi video
59 |
aise
23.09.2009 14:46:21
kena, väga kena
| Kommentaarid: 189 loe/lisa |
172 |
virx
23.09.2009 15:11:45
| kuidas on see seotud gran turismo 5'ga? on selge et mäng ei hakka selline välja nägema.
309 |
beastbeats
23.09.2009 15:43:57
virx, miks mitte - tegemist ju "vaheklipi", mitte gameplay'ga...
M: Cannondale Tract MIPSkiiver (uus; Polar White; Large) - 40€ |
284 |
virx
23.09.2009 15:58:44
| ma ei näe põhjust miks mitte uskuda seda kommentaari. "Also the fact that is not running at 60fps proves that it's not GT5. the GT5 engine could definitely handle this render although not with these levels of reflection detail."
309 |
henri200
59 |
virx
309 |
HDTanel
Overclocker
24.09.2009 04:25:17
virx, kus krt sa võtad, et renderdatud? Ma pelan GT5P-d ja graafika on täpselt samasugune
496 |
weasel
24.09.2009 07:41:50
Märts 2010
virx
24.09.2009 12:40:21
PlatoonSgtElias, kaamera nurgad, läige või kasvõi see et ferrul laternad põlevad. kui sa näed siis mängus ei põle ühelgi autol tuled v.a. pidurdusel. tegu on täpselt samasuguse fake traileriga nagu koenigseggi omagi, kus ka öeldi et tulemus on üsna kaugel in-gamest.
viimati muutis virx 24.09.2009 21:39:07, muudetud 1 kord |
309 |
Auron
24.09.2009 14:07:17
| virx kirjutas: |
| kui sa näed siis mängus... |
Ossaraisk GT 5 juba väljas
133 |
weasel
24.09.2009 14:43:44
Mis te sonite siin. Märts 2010 ja seegi kehtib ainult Jaapani kohta.
Bumer
24.09.2009 16:07:26
| weasel kirjutas: |
| Mis te sonite siin. Märts 2010 ja seegi kehtib ainult Jaapani kohta. |
praegu jääb mulje, et Kazunori teeb täpselt risti vastupidi kõigele mis ta siiani rääkinud on mängu väljalaskmise kohta
48 |
virx
24.09.2009 17:56:36
| Auron kirjutas: |
| virx kirjutas: |
Ossaraisk GT 5 juba väljas  |
mängus.. GT5P's.. mis seal vahet on. sinusugused leiavad trollimiseks alati põhjuse. võid nüüd maha rahuneda, teie mäng on veel tegemisel pikka aega.
309 |
xeon
24.09.2009 20:39:42
fakk keema ajab see märtsiuudis mind... mis inimestel viga on?
_________________ PSN: Kilitapja |
| Kommentaarid: 26 loe/lisa |
24 |
ppg
24.09.2009 23:44:45
Kahju, et nii kaua peab ootama tõesti, egas siis midagi peab niikaua kastil Forza3-me toksima (varsti väljas )
138 |
angel
24.09.2009 23:53:32
peaasi et ei tuleks pettumus... psp peal paistab asi suht käkk olevat.
157 |
Bumer
25.09.2009 12:42:32
| angel kirjutas: |
| peaasi et ei tuleks pettumus... psp peal paistab asi suht käkk olevat. |
pettumust valmistab see, et öeldakse et on 950 autot, kuigi tegelikkuses on unikaalseid autosid sadades vähem ja praeguseks avaldatud feature listis ei ole midagi mainitud dünaamilistest ilmastikuoludest
48 |
Auron
25.09.2009 12:44:30
| virx kirjutas: |
| Auron kirjutas: |
| virx kirjutas: |
mängus.. GT5P's.. mis seal vahet on. sinusugused leiavad trollimiseks alati põhjuse. võid nüüd maha rahuneda, teie mäng on veel tegemisel pikka aega. |
No kurat ma mõütlesin,et väljas ja sul juba käes, et täpselt tead ka autol sõites tuled põlevad/saab põlema panna või mitte jne. Su enda postitused on ju eriti faktilised "ma ei näe põhjust miks mitte mingi suvalise jölli kommentaari mitte uskuda" Tõmba vs. teemasse oma ilaga.
133 |
RasmusJ
25.09.2009 17:25:04
| ma kuulsin midagi 3 tuhande autost , juba gt 4-s oli 700 autot,aint 200 rohkem pole küll midagi eriluist arvestades näiteks,et ferrarisi ja palju teisi autosi polnud gt 4-s
| Kommentaarid: 6 loe/lisa |
virx
25.09.2009 18:20:02
| Auron, no nii närvi ajab kohe et teid kuival hoitakse kuni launch päevani ja siis juhtub sama mis juhtus psp versiooniga. pre-orderite suurendamiseks näidati ainult rendertatud trailereid. kuna mäng nägi nii halb välja et seal ei olnudki midagi näidata ja välja tuli siis võiski kohe maha kanda. poliphoni ongi viimasel ajal ainult selliste fakedega välja tulnud, miks peaks seekord midagi erinema? see kuidas seal videos kaamera ala lendab üle auto koguaeg peaks andma piisava tõendusmaterjali et midagi sellist te mängus teha ei saa ja miks mitte ka juba kõike muud natuke üles kruttida et mõni sinusugune (kellele peab selgeks tegema millea tegu) peale selle vaatamist omale pre-orderi kohe ära teeb.
309 |
Sahib
26.09.2009 05:32:33
Ta ei saa ometigi halvem olla, kui välja lastud "demo".
_________________ Mõtet harutades võib jõuda mõttetuseni ... |
| Kommentaarid: 60 loe/lisa |
55 |
Auron
26.09.2009 09:49:45
Kuule virx, praktiliselt iga mängu treileris näidatakse actionit selliste kaameranurkade alt mida mängu olema ei satu - sellise lapseloogikaga ei saa siis ühtegi treilerit uskuda. Ja ära muretse, ma ei preorderda midagi, smauti ei loe igast kotakusid või mis iganes kohti, et siis saaks sopa leidmisel seda teemasse postitada. Ega kõik konsooliomanikud pole 15 aastased kellejaoks on telekamängu mängimine elu ja enda konsooli paremuse hüsteeriliselt tõestamine kuskil foorumis ristiretk - mõned on ka vanemad inimesed kellel on suht pohhui ja kes lihtsalt mõnda head mängu mängivad meelelahutuseks. Sa lihtsalt ei saa sellest aru
133 |
313 |
iDemon
26.09.2009 16:03:38
Vana asi juba. Palun vii end teemaga kurssi.
Gran Turismo 5’s Damage a “First Step”.
| His other comments are significant, claiming the Gran Turismo 5 demo shown at GamesCom “marks only the first step of what we want to achieve for damage.” |
104 |
26.09.2009 16:07:17
iDemon, kus ta siis "vana asi" on kui see video on TGS 2009 filmitud
| We’ll just have to see how – and if – the damage model has changed the next time GT5 is shown in action. |
viimati muutis SKG 26.09.2009 16:11:38, muudetud 1 kord |
313 |
virx
26.09.2009 16:14:02
Auron, kle ma ei viitsi suga enam vaielda. tõesti hakkad lahmima ja teemast kõrvale kalduma. vähem teooriaid ja rohkem loogilisust võiks sult küll oodata. esimene lause on täielikult puusse pandud, räägid risti vastupidi oma jutule. millele sa sopaga vihjad? mõni leht tagasi sai postitatud tabav kommentaar kogu tõde sellest koenigsegg trailerist ja toetuti puhtalt loogilisusele, mida võis videost välja lugeda (piisab avades oma silmad) ja hetk hiljem tuli järgi ametlik raport et tegu ei olegi millegi muuga kui sellega mida juba teati. kus on hüsteeria (vaata peeglisse), kes on 15? kus või mis on kotaku.. kui sul pohhui on, miks laamendad siis siin? ega su jutust ei saagi aru.
viimati muutis virx 26.09.2009 16:30:17, muudetud 4 korda |
309 |
iDemon
26.09.2009 16:15:03
| Skeptik kirjutas: |
Sama rada, sama auto, sama demo.
104 |
26.09.2009 16:44:06
| iDemon kirjutas: |
| Skeptik kirjutas: |
Sama rada, sama auto, sama demo.  |
so? sama build? sama kood?
edit:
samas eks neil ole seda vähemalt pool aastat aega lihvida ka
313 |
Sahib
26.09.2009 17:23:56
link :: Gran Turismo 5 - PS3 (Preorder)
Saab hakata vaikselt plaani pidama.
55 |
weasel
26.09.2009 20:35:32
2. veeb 2010. Taga targemaks. Need poed ka viitsivad oma kuupäevadega üllatada.
