uus teema   vasta Tarkvara »  Tarkvara »  Win Vista Bluescreeni peale 15min töötamist... märgi kõik teemad loetuks
fifa
fifa
sõnum 31.08.2009 12:42:22 Win Vista Bluescreeni peale 15min töötamist... vasta tsitaadiga
Milles võiks probleem olla?
Temperatuurid on korras 48- 55 kraadi...
Sai ka kiire pilt ifööniga tehtud bluescreenist:
Ning antud errori dmp faili log:
Microsoft (R) Windows Debugger Version 6.6.0007.5
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [Mini083109-03.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image \SystemRoot\system32\ntkrnlpa.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntkrnlpa.exe
*** ERROR: Module load completed but symbols could not be loaded for ntkrnlpa.exe
Windows Vista Kernel Version 6001 (Service Pack 1) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Kernel base = 0x8204f000 PsLoadedModuleList = 0x82166c70
Debug session time: Mon Aug 31 11:24:48.345 2009 (GMT+3)
System Uptime: 0 days 0:10:39.049
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 9F, {3, 87a69030, 87a69030, 87be9b48}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_DEVICE_OBJECT ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : ntkrnlpa.exe ( nt+cd163 )
Followup: MachineOwner
Kommentaarid: 94 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 86
sõnum 31.08.2009 13:29:55 vasta tsitaadiga
Viimasel real ju vihje olemas - Probably caused by : ntkrnlpa.exe ( nt+cd163 )
http://www.google.com/search?client=opera&rls=en-GB&q=Probably+caused+by+:+ntkrnlpa.exe&sourceid=opera&ie=utf-8&oe=utf-8
M: Intel i5 4590 protsessorid
M: HP Elitedesk 800 G3 SFF
Kommentaarid: 755 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 567
A.S.
sõnum 31.08.2009 13:30:50 Re: Win Vista Bluescreeni peale 15min töötamist... vasta tsitaadiga
Kui sa juba hakkasid seda minidumpi analüüsima, siis teinud seda ikka korralikult. Väga vähe on abi infost stiilis
Siin ei oska muud öelda kui et mingid probleemid mingi draiveriga ja guugeldamine annaks ilmselt piisavalt lugemisainet (nagu juba eelnevaltki soovitati), näiteks
http://support.microsoft.com/kb/929762
http://support.microsoft.com/kb/943899
http://support.microsoft.com/search/default.aspx?query=Stop%200x0000009f%20Vista&catalog=LCID%3D1033
jne...
sõnum 31.08.2009 13:35:26 vasta tsitaadiga
ilmselt jah bugine draiver, mis hakkab shut down/sleep/hibernation protsessi ajal tõrkuma.
A.S.
sõnum 31.08.2009 13:55:11 vasta tsitaadiga
Skeptik kirjutas:
Tegelt dump failist peaks suutma selle (probleemse draiveri siis) hea õnne korral välja lugeda.
fifa
fifa
sõnum 31.08.2009 14:06:45 vasta tsitaadiga
SP2 ei pruugi hea õnne korral probleeme parandada?
Win on suht pees omadega... ehtne win aga ei läbi kontrolli.... ei ava control panelit jne... 150 muud häda... update ei installi jne... (fixi selllele probleemile, pean teisest pc-st downloadima ning siin ju ei installi seda...)
XYZ
XYZ
sõnum 31.08.2009 15:35:41 vasta tsitaadiga
"...ei ava control panelit..." - tüüpiliselt see on vihje kas pahalaste tegevusele või vigasele mälule/toitele ja sellest tulenevale ehk juba vigasele win installilegi....
Kõrval turvafoorumis on kohe eesotsas teema "...AVZ süsteemi-info logide kontroll", tasuks sealsed soovitused esmalt läbi teha.
