DeTHiCa.
20.02.2009 10:44:51
Men of War |
On saabunud järg RTS mängule "Soldiers: Heroes of World War II"
Men of War takes place in Europe during the height of World War II.
The story unfolds across three different campaigns played out through the
eyes of Soviet, Allied and German soldiers. Each campaign has its own
structured timeline bringing a different story of the war to life spanning
across Russia, North Africa, Ukraine, Greece, Germany, Italy and the
Pacific. The main Soviet campaign sees two student comrades, Smirnov and
Kuznetzov, join the army and quickly become brothers in arms as they rise
through the ranks and experience the rigors of war.
Men of War will feature 50 new units to play, including newly designed
tanks, APCs and heavy guns. Dynamic, in-game video enhances the single
player missions, while developer Best Way has given the sounds of war new
range with over one hundred new effects, recorded under real operating
conditions. The single player campaign will also feature a fully
customizable user interface so players are able to set-up their command
layout as they please. |
Men of War is the follow up of the highly successful Soldiers: Heroes of World War II, developed by Best Way . The unique gameplay and design made the predecessor standing out from the RTS genre and found very soon a large fanbase, which is still active due to the impressive mod support.
Men of War starts were Soldiers ended, it delivers improved physics which allows you to destroy whole maps on a level of detail you never saw before, the newly developed armor penetration physics calculate the impact angle of every single projectile in accordance to the historic armor value of each vehicle. Every tank has the sound of its original, dropping you in a fully cinematic and authentic sound experience, which hardly can be described. As this wouldnt be enough, you will enjoy a really useful and unique feature: Direct control! Take over the control of every single soldier you have, or drive tanks and other vehicles, set up ambushes with antitank guns and blow your enemies up with precise and deadly aimed shots at their weak spots!
Feel the adrenaline when an enemy Tiger crosses the roads, or feel the enemies fear when he hears the sound of a deadly German Panther tank, which is driven by you!
Features:
* Fully destructable environment. Get your men into cover of newly formed tank shell craters!
* Very authentic sound experience with historical accuracy!
* Unseen physics and armor penetration system.
* Each mission and battle plays out differently based on your tactical choices!
* Unseen battle scenarios to keep the WW2 setting fresh.
* Over 100 highly accurate tanks and vehicles ready to be under your command!
* Realistic fog of war
* Smart AI is searching for your men covered in bushes and calls for reinforcements, including a morale system.
* Excellent modding support and official SDK (Mapeditor, 3dsMax Plugins)!
* 6 different playable nations!
* Direct Control! Want it done right? Do it yourself!
Multiplayer:
* Up to 16 players via LAN or Network
* Ingame browser including ranked statistics
* A good bunch of well tested and intense gamemodes
* Cooperative gamemode allows you to play through the campaigns with your friends!
* NAT support, allows you to host games through routers
* 5 multiplayer nations
* Many varying multiplayer maps
* Balanced settings, the smarter wins not the faster one.
hea kvaliteediga co-op video:
http://www.youtube.com/watch?v=Mpdop4KDJsk
DEMO: (~240mb)
http://www.digitalmindsoft.eu/index.php?id=60&did=55
Skrinotte:
http://www.digitalmindsoft.eu/games/men-of-war/screenshots.html
136 |
piimaPAKK
20.02.2009 10:51:18
Re: Men of War |
| DeTHiCa. kirjutas: |
| * Direct Control! Want it done right? Do it yourself! |
Sellest ma eeldan, et AIga ei hakata vaeva nägema
DeTHiCa.
20.02.2009 11:04:18
| piimaPAKK, vaata videosi enne kui räägid. direct control on väike lisavidin "control freakide" jaoks. selles mängus on väga palju micromanagementi.
136 |
Mafia
27.02.2009 03:04:06
Proovisin ka siis. IMO tegu on väga hea mänguga :O Soldier heroes of ww2 oli väga lahe mäng, oma uuenduste poolest ala inventori, masinad võtsid kütust, direct controll jne. Ja nüüd väga tore järg asjale. Kuna see mäng on otseselt SHOWW2 moodi, kas siis codemasters müüs õigused maha, või neil pole olnudki neid ?
Edit: Devid ongi samad. Ei tore siis. Lõpuks midagi korraliku
_________________ Bawse |
| Kommentaarid: 19 loe/lisa |
17 |
Pihv
27.02.2009 08:26:49
Proovisin ka Demot mõned päevad tagasi.
Kindlasti ei jäta asi nii kvaliteetse mängu muljet nagu Soldiers omal ajal.
Graafikat on uuendatud aga tundub oleavt lihtsalt tweakitud vana gfx. Võiks olla palju detailsem.
Kogu teostus tundub odav, st. näitlejate hääled, vaheklipid jne.
Samas on gameplay läinud lihtsamaks, eriti just UI poole pealt. Olemas on kogu detailsus,st. kõik surnuid saab läbi otsida, sõidukeid parandada jne. Jookseb ka väga väga sujuvalt, no seal pole ka midagi mis ressurssi nõuaks aga siiski meedliv üllatus tänapäeva mänge vaadates et midagi kohe normaalselt jookseb.
Direct Control oli juba ka Soldiers mängus, mis nad seda nüüd nii promovad
Eks peab vaatama mis see müügihind tuleb, arvestades et 1C pundis siis väga kõrge ei tohiks tulla. Mängud on küll vähe erinevad aga WWII fixi jaoks eelistan vast kohe välja tulevat CoH: Tales of Valor.
94 |
Mafia
27.02.2009 15:52:40
| Pihv kirjutas: |
| Proovisin ka Demot mõned päevad tagasi... |
Mai saa aru mida sa vingud. Imo mäng on palju kvaliteetsem kui siin enamus mass üle haibitud strateegiad. (Ma ei mõtle COHi, mis on minu arvates parim RTS mis siiani tehtud). Samas see mäng pole nö. RTS. Väga mõnus ,et seal mängus pead palju strateegiale mõtlema. Ala arvestama palju sul kütust on, kuule jnejne. Lisaks on lahe et iga meest saab eraldi kontrollida, mis annab suure eelise kuna saad vastavalt oma soovile planeerida rünnakut või kaitset nii nagu sa soovid. Kuna SHOWW2 mulle väga meeldis, siis see mäng meeldib Samuti, ok animatsioonid on vb natuke old gen aga "Who gives a fuck?". Mai tea miks nüüd arvata kui mäng pole mingit haipi saanud kuna codeM enam õigusi ei oma, on see sitt? Eurogamer andis 9/10 sellele mängule http://www.eurogamer.net/articles/men-of-war-review Ja veel, miks vinguda direct fire promomise üle, kuna mäng on otsene SHOWW2 järg, ja see on ainuke strateegia kus selline võimalus on, siis mis ses halba on. Minu arust on just hea et see võimalus on.
Mäng on muidu väljas EU-s: http://www.game.co.uk/PC/Strategy/~r335306/Men-of-War/?recommended=SEARCH Hind on 24.46£ mis pole palju
17 |
DeTHiCa.
27.02.2009 16:08:49
| jajaaa. mõelge nüüd kui mõnus seda co-opis taguda oleks, sina oma väikse grupiga teed täpsusrünnakuid ja sõber samal ajal teeb sulle artillery katet jne.
136 |
Pihv
27.02.2009 16:11:39
| Hmm, kus kohas ma vingunud olen? Avaldasin enda arvamust mängu kohta, ja mänginud olen ma palju ja piisavalt et omada objektiivset arvamust. Soldiers meeldis mulle väga omal ajal.
94 |
margus645
27.02.2009 16:15:06
| Vingumisest on asi küll nüüd kaugel.inimene avaldas lihtsalt oma arvamust. isiklikult nõustun Pihvi arvamusega täielikult.
127 |
Pihv
02.03.2009 15:49:08
Mis vahe on sellel mängul "Faces of War" mänguga? Kas tegijad on samad?
Muuseas kui Bloom maha keerata on asi väga sarnane Soldiers graafikaga
94 |
DeTHiCa.
02.03.2009 15:57:02
| Pihv, too mõni võrdlev pilt.
136 |
Mhmh
03.03.2009 10:02:01
| Pole küll käsi külge saanud,aga ainult head kuulnud selle mängu kohta.Paistab,et hitti sest ei tule ning tegu taas ühe kehva publisheriga otsa sattunud talendika väikestuudioga.
18 |
Scart
10.04.2009 16:38:40
| Esimene osa ehk siis Soldiers tundus omal ajal kindlasti revolutsioonilisem ja löö või maha, aga Faces of War graafika on parem, kui MoWil. Mäng ise on aga mõnus laamendamine nagu ikka ja ei saa midagi halba öelda. Kergem on ta ka õnneks - FoW oli ikka üle mõistuse raske.
101 |
Tonsor
10.04.2009 16:45:20
Vaadates seda co-op videot, mulle see Jawohl hakkas küll suht kiiresti närvi käima.
| Kommentaarid: 36 loe/lisa |
j2nq
11.04.2009 11:22:07
Väga hea mäng, minuarust üldse parim strateegia mis praegu väljas. Selliseid võimalusi mis Mowis pole ühelgi mängul enne näinud. Kui natuke moddida, siis jäävad kõik laibad ja vrakid ka alles, see teeb mängu veelgi nauditavamaks, näed ikka mis sust järele jäi . Sellist majade hävinemist ei ole samuti enne nähtud, sõidad näiteks tankiga majast läbi, jääb auk maja keskele. Igastahes väga reaalne mäng. Soovitan
_________________ jott-kaks-en-kuu |
Scart
27.05.2009 20:29:03
link :: kae siit
Sajandi diil - mäng kaheteistkümne euri eest.
101 |
Angryhead
25.07.2009 12:13:31
| Scart kirjutas: |
| Sajandi diil - mäng kaheteistkümne euri eest. |
Pigem see - mäng 7 euro eest.
http://store.steampowered.com/app/7830/
Steamis demo ka olemas, kui keegi soovib proovida enne ostmist.
Pihv
25.07.2009 13:56:09
| Umbes 7 euri ongi selle eest normaalne hind, seega kõik ok.
94 |
Scart
25.07.2009 14:58:35
Vaata ka mu posti tegemise aega
101 |
Angryhead
25.07.2009 18:11:17
| Scart kirjutas: |
Vaata ka mu posti tegemise aega  |
Nägin enne postitamist
Muideks Steami lehel on kirjas et 64-bit Vista ja XP pole toetatud, aga vähemalt minu 64-bit Vistal läks ilusti tööle.
Scart
20.01.2010 11:05:48
| Angryhead kirjutas: |
Muideks Steami lehel on kirjas et 64-bit Vista ja XP pole toetatud, aga vähemalt minu 64-bit Vistal läks ilusti tööle. |
Täpselt nii. Ametlikult pole toetatud aga töötab nagu siidi
Midweek deal Steamis. Kogu kupatus 11 euri eest. Ikka väga hea diil.
101 |
KrisVr
08.06.2010 01:25:04
Tulemas kaks uut Standalone Expansionit. Arvatavasti suve lõpu poole.
Men of War: Assault Squad
Men of War: Vietnam
| Kommentaarid: 30 loe/lisa |
Cracker
16.06.2010 16:23:08
Keegi viitsib enda save game mulle saata? Tahaks ühte asja uurida.
Tegelt enam ei ole vaja.
| Kommentaarid: 10 loe/lisa |
9 |
KrisVr
31.10.2010 19:12:36
Men of War: Assault Squad Beta tuleb varsti välja. Vaja on 10k liikmeid steami gruppi!
http://steamcommunity.com/games/mowas - Liituke!
E: Rohkem kui 9700 liiget juba olemas. Natuke vee!
Mafia
17 |
