sessa
25.06.2009 18:20:26
n0bzter antud lingit tõmbasin faili ja mul toimib kõik kenasti täna oli uus update ka muidu
Updates to America's Army 3 have been released. The updates will be applied automatically when your Steam client is restarted. The specific changes include:
America's Army 3
Removes Password from AA3Launch.log
Fix for MBS not working after server changes to a new map
Fixes TeamReady in Mission Preplanning
Updated authentication SDK to improve reliability and performance
Fix for freezing on training mission load
Improved performance on loading maps/training missions
Fixed several small memory leaks
Fixed performance issue with server that caused it to load UI elements into the server (where they aren't needed) and thus use up additional CPU and memory.
Modified training authentication so it is more efficient
Modified AMD negative delta time exception handling so it no longer stops the server or client, but just logs the event
Fixed Admin add Player Admin
Fixed Admin kicking of players. Now works properly with Soldier name and has optional kick by player ID
Add new AdminListPlayers to get list of players and their player ID's
Removes most of the server log spam, especially that tied to missions and mission setup and ROE
Fixes several issues related to ROE firing off when player is bleeding, asphyxiating, or falling after being wounded by ROE
You can now strafe on ladders so you don't get stuck in Pipeline or Obstacle Course. Strafe too far and you fall off, just like AA 2.x
Modified program startup to clear out any old ATS temporary files
Improved scoring messaging support for training missions
Fixes several scoring issues
Optimizes more of the authentication code and adds better exception handling in it
Adjusts STS (stats) integration to better detect invalid objects to avoid crashes
Fixes issues with single player stats not correctly initializing all of the time
Adds feedback to UI when player purchases training until purchase is complete (says "Purchasing")
Modifies MBS to track how many players are playing vs. how many players are on the server (player + Spectators) and now MBS browser only shows the number of players (so the count won't exceed max players)
Turns HUD off whenever menu is activated (still an issue with battle planner activation the first time, however)
Adjusts the close menu logic to always close properly so double menus should no longer happen
| Kommentaarid: 75 loe/lisa |
63 |
DelMar
27.06.2009 16:40:53
| Mängib keegi ka seda veel? Ise suht tihti mängus ja hetkel honor 10. Leida võib mind ranch ja alley servudest ja nimi on kindral.
sessa
28.06.2009 11:49:06
ise ka mängin ikka aeg ajalt võiks vahest õhtuti tiimi kokku panna või midagi üksi suht raske rassida
63 |
Gunnar19
Kaevur
30.06.2009 16:52:25
Kas mäng enam kokku ei jookse ? Praegu ei julge mängu töölegi panna
| Kommentaarid: 42 loe/lisa |
DelMar
30.06.2009 18:03:16
| Peale viimast patchi pole endal vähemalt tähele pannud ühtegi kokku jooksmist.
marex
30.06.2009 19:22:13
| Mis selle mängu normaalne fps peaks olema? Endal kõigub ta 15 - 20 vahel..
| Kommentaarid: 22 loe/lisa |
20 |
Marduuhin
30.06.2009 19:41:14
marex, kas sinu jaoks on pilt piisavalt sujuv? Kui jah, siis on normaalne fps käes. Mõne jaoks ei kõlba alla 30, teisele 60, 100 jne..
_________________ Eesti õigekeelsussõnaraamat ÕS 2018 |
108 |
marex
30.06.2009 23:20:51
| Marduuhin kirjutas: |
| marex, kas sinu jaoks on pilt piisavalt sujuv? Kui jah, siis on normaalne fps käes. Mõne jaoks ei kõlba alla 30, teisele 60, 100 jne.. |
Niikaua on sujuv kuni tegudeks läheb siis on vahepeal venima hakanud.
20 |
DelMar
01.07.2009 02:22:52
| Kui v-sync i maha võtad siis jutu järgi pidi see fpsi parandama.
aanz
01.07.2009 11:56:44
keegi oskab öelda, mis toimub?
| Kommentaarid: 21 loe/lisa |
20 |
jeanman
01.07.2009 15:43:41
| aanz kirjutas: |
Kusjuures mul sama pull
| Kommentaarid: 39 loe/lisa |
36 |
aanz
01.07.2009 17:46:11
mingi 1-2 tundi tegin tööd siis mõtlesin, et pohh proovin, kas online saab. näitas, et on tehtud... see training süsteem laseb veel suht villast aga las olla:P netis saab mängida
E: saaks nad bugidest ka veel lahti oleks väga-väga õnnestunud mäng ja veel tasuta ka:D
20 |
Ernits
01.07.2009 19:16:54
Minul lasi küll treeningud ilusti ära teha. Need olid küll ette tehtud, aga kõige madalama skooriga mis läbi saab. Tegin üle ja sain achievemendid ka lahti
Mäng ise liigub võrdlemisi normaalselt. Põhiliselt Ranchi ja Bridge peal, seal fps 35-50 keskmiselt, täitsa mängitav. Pipeline on mingil põhjusel VÄGA läägine, hea kui 20 FPS näeb.
Paar bugi käivad küll närvidele - vahepeal granaadid nähtamatud, siis ei taha grana pealt relva peale tagasi vahetada, vahel muutub relv nähtamatuks ja ei tulista (siis on raund piixus pmst, kui just meleema tüüpe ei lähe ..)
Lapsehaigused ära siluda, natuke veel optimiseerida ja asi on tipp-topp imo
| Kommentaarid: 99 loe/lisa |
86 |
Cracker
01.07.2009 20:02:45
| Mul on vahel nii, et hoiab granaati ja relva korraga käes :O
| Kommentaarid: 10 loe/lisa |
9 |
jeanman
01.07.2009 22:39:53
| Mis ma valesti teen,ronin serverisse vajutan join mingi tiimiga aga ei miskit, vajutan auto - select ja ka ei miskit, kuigi teised kes serverisse tulevad, saavad küll joinida mingisse tiimi, mina aga mitte
36 |
Ernits
02.07.2009 11:51:36
| jeanman kirjutas: |
| Mis ma valesti teen,ronin serverisse vajutan join mingi tiimiga aga ei miskit, vajutan auto - select ja ka ei miskit, kuigi teised kes serverisse tulevad, saavad küll joinida mingisse tiimi, mina aga mitte |
Sul on PB updatemata. Siin õpetus
86 |
-RaiTz-
02.07.2009 12:07:58
Kuidagi väga toores tundub alles olevat.
| Kommentaarid: 35 loe/lisa |
29 |
aanz
04.07.2009 08:14:28
Täna/eile tuli siis uus Update AA3-ele
Improved console help
Added Clan support. Add clan tag in Account Settings. You must change information while in single player mode for now.
Admin VOIP Improvements
New "version" console command to see the current version
Server browser performance improvements
Fixes joining password protected servers so it no longer selects the server underneath the mouse cursor when clicking on the "Join" button in the password entry dialog.
Fix for settings menu improperly closing when ESC pressed and leaving the player stuck with no UI and limited control
Mission generation optimizations
Fixed issue with logging into game servers that sometimes used another player's soldier profile.
New TS3 SDK integrated
Improves how server manages authentication objects
Fixes issue with players being added to the scoring system not having all of their scoring data written.
Fixes issue where players not logged into MBS were being logged out if they left the server prior to authenticating
M320 grenade attaching issue resolved.
Dedicated server title bar now shows mission and player details
Fixes the "Waiting for other players" UI so it now appears again.
Removes some server logging
Increased communications handling to support when all players use heavy load outs. This may correct many instances where players didn't spawn correctly or get the correct load out.
Fixes the M320 getting an extra round of ammo
Fixes the Account Settings password changing not working properly
Fixes the IRC link not working
Fixes the displayed mission type (assault/defense/etc.) shown in the battle planner so it displays properly after side-swapping
Tundub, et asi hakkab ilmet võtma vaikselt
20 |
sessa
63 |
aanz
04.07.2009 15:42:07
| hmmm, kas kellelgil veel on selline probla, et ükskõik kuhu serverisse joinides, viskab lobby eest minema ja mäng hangub?
20 |
iir
04.07.2009 16:29:59
huvitav et ma ei saa vana acountiga sisse, on see üldse võimalik?
| Kommentaarid: 90 loe/lisa |
fgth
04.07.2009 18:16:56
| jesus99 kirjutas: |
| huvitav et ma ei saa vana acountiga sisse, on see üldse võimalik? |
pead uue konto tegema
| Kommentaarid: 69 loe/lisa |
67 |
Pihv
11.07.2009 17:11:29
| Kas nad mingi aeg nendele treeningutele reseti ka teevad? Et saaks ise neid teha. Või nüüd jääbki nii, et kõigil kõik tehtud.
94 |
sessa
11.07.2009 18:33:34
| sa tee need üle tehtud on nad ainult minimum punktidega tee paremini siis saad stuffi lahti
63 |
Valvejoodik
11.07.2009 21:56:32
| Mille kaudu te tõmbasite?
| Kommentaarid: 16 loe/lisa |
15 |
