raidoroom
24.06.2009 19:21:47
Jama XP-ga arvuti taob jubedamat ERRORIT ette |
Tervist mul selline jama et eile panin oma läppari nupust kinni et ei viitsinud shutdowni
teha ja kui järgmine päev sisse lülitasin siis hakkas errorit ette taguma.
Kõige haigem asi on see et ei saa formaati ka enam teha
Kui lükkan oma windows xp plaadi sisse siis hakkab loadima neid faile ja kui
jõuab sinna maani kus tuleb tekst windows is now starting siis viskab errori ette
et ma ei saa aru isegi siis viskab errori ette kui lülitan BIOSISt kõvaketta välja
Oskab keegi kuidagi aidata
/* See on see error kui panen arvuti niisama tööle */
Windows could not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM
You can attempt to repair this file by starting Windows Setup
using the original Setup CD-ROM.
Select 'r' at the first screen to start repair.
/* Ja see error tuleb siis kui proovin cd-pealt bootida */
A problem has been detected and Windows has been shut down to prevent damage
to your computer.
If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, follow
these steps:
Check for viruses on your computer. Remove any newly installed
hard drives or hard drive controllers. Check your hard drive
to make sure it is properly configured and terminated.
Run CHKDSK /F to check for hard drive corruption, and then
Technical information:
*** STOP: 0x0000007B (0xF78D2524, 0xC0000034, 0x00000000, 0x00000000)
raido.vigur@mail.ee
thyposes
24.06.2009 20:58:23
Boot Sectori kala. Võib olla sai MBR pihta. Proovi mõnda disc tooli ja lase low level format teha . v lihtsalt diagnostikat.
_________________ DeepMix Moscow Radio http://www.deepmix.eu |
90 |
karusloom
24.06.2009 21:02:05
| hirens boot cd aitab nii ketta kontrolliga kui formatiga
| Kommentaarid: 50 loe/lisa |
48 |
raidoroom
25.06.2009 06:12:56
NOH Eile tegin siis selle hiresniga diagnostika testi ära ja see ei leidnud miskit errorit
samamoodi tegin k low-level formati
ja nüüd viskasin jälle cd sisse ja siis on täpselt saama kamm kui tuleb tekst windows is now starting
siis lendab ekraan siniseks ja
to your computer.
these steps:
sama tekst
nuunjo
