Mucrop3
24.06.2009 11:17:52
Gimp 2.6.6 pangestub |
Tere
Gimp 2.6.6 pangestub Vista all kui "Värvid" menüüst erinevaid värvi sättimise asju üritan clickida.
Nii ma leidsin ühe inimese kellel 2.6.6 töötab.
Huvitav kas video driveri viga. Sest kogu süsteem sai just installitud ja värsked draiverid / Win updated peale pandud.
Aga Google Picassa on päris mugav kasutada.
Minu kasutaja all ei pangestu, aga teise kasutaja all pangestub.
Ja reinstallimine ei aita.
http://www.youtube.com/watch?v=3KoHAlqyxtU
A.S.
24.06.2009 12:35:49
Re: Gimp 2.6.6 pangestub |
Mucrop3 kirjutas: |
Ja reinstallimine ei aita. |
Selle all pead sa silmas mitte ainult
C:\Program Files\GIMP-2.0\
vaid ka
C:\Users\<probleemne kasutaja>\.gimp-2.6\
C:\Users\<probleemne kasutaja>\.gegl-0.0\
C:\Windows\Prefetch\GIMP???.pf
kustutamist?
Doctor Watson ei arva asjast midagi? Ei tea paraku, kus kohas Vista all selle logi asub.
Event Viewer ehk aitab veidi?
Kommentaarid: 33 loe/lisa |
33 |
Mucrop3
24.06.2009 14:04:44
A.S. kirjutas: |
Mucrop3 kirjutas: |
vaid ka
kustutamist?
Faulting application gimp-2.6.exe, version 0.0.0.0, time stamp 0x49c4317f, faulting module ntdll.dll, version 6.0.6002.18005, time stamp 0x49e03824, exception code 0xc0000005, fault offset 0x0002ac0f, process id 0x738, application start time 0x01c9f4ba0f042a23.
Product: Windows Operating System
Event ID: 1000
Source: Application Error
Version: 5.2
Symbolic Name: ER_USERCRASH_LOG
Message: Faulting application %1, version %2, faulting module %3, version %4, fault address 0x%5.
Explanation
The indicated program stopped unexpectedly. The message contains details on which program and module stopped. A matching event with Event ID 1001 might also appear in the event log. This matching event displays information about the specific error that occurred.
24.06.2009 14:30:29
Vistaga GIMP 2.6.6 tundub ntdll.dll crash olevat mitte ainult sinu probleemiks: http://www.google.com/search?q=ntdll.dll+crash+gimp+2.6.6
Proovi 2.6.5 - ise olen kasutanud ja pole kokku jooksnud. Loodetavasti remonditakse järgmises versioonis ära, peab siis lihtsalt ootama jääma.
A.S.
24.06.2009 14:51:30
Ei ole ise Vistat eriti käperdanud ja seega suuremat targutada ei oska. Ilmselt mingi konkreetsem veainfo kusagilt ja kuidagi kättesaadav siiski on, ent kuidas?
Aga sa kontrolli, kas sellel probleemsel kasutajal ehk midagi täiendavalt käima ei tõmmata, mõnd programmi vms.
33 |
Mucrop3
24.06.2009 15:52:45
Dogbert kirjutas: |
Proovi 2.6.5 - ise olen kasutanud ja pole kokku jooksnud. Loodetavasti remonditakse järgmises versioonis ära, peab siis lihtsalt ootama jääma. |
Ma ei leia praegu seda vanemat gimp-i. Palun linki.
Tänud!
Marduuhin
Kommentaarid: 128 loe/lisa |
108 |
Mucrop3
24.06.2009 16:03:37
A.S. kirjutas: |
Vista ei anna rohkem seda veainfot.
Regisrit ka ei viitsi analüüsida ja võrrelda toimiva kasutajaga.
Huvitav kas gimp ise ei kirjuta veateadet kuhugi.
Aga kui see on levinud probleem nagu Dogbert kirjutas siis, vast on tõsisem probleem ja lihtsam on vanem Gimp hankida.
Elagu bussireisid mis valetab reisiaegade kohta. võtan parem veel
Tänud lingi eest.
Ja head Jaani
HukkunudAlpinist
23.06.2011 10:10:32
Mul jookseb aegajalt poole töö pealt Gimp kokku ja siis pean otsast peale alustama.Kas keegi oskab äkki öelda kas Gimp salvestab pooliku töö ise kihtidena ära?Ja kui salvestab siis kuidas seda avada?
Varem kui arvutil oli peal Vista ei olnud probleeme kordagi.Nüüd kui läpakal on peal Win 7 jookseb aegajalt Gimp kokku.
Äkki oskab keegi nõu anda mis viga võib olla?
_________________ Me kõik oleme ise valinud kellena siia maailma sündida. |
Kommentaarid: 1 loe/lisa |
Mucrop3
23.06.2011 21:19:08
HukkunudAlpinist kirjutas: |
Äkki oskab keegi nõu anda mis viga võib olla? |
Ei vist ei saa, tuleb väga tihti salvestada uus koopia failist, et kui midagi nihu läheb saab taastada.
Siin on veel mingi variant aga pole lähemalt uurinud. http://registry.gimp.org/node/16911
_________________ My stroke machine roars down the lustful highway.
Keefir RUULIB. |
25.06.2011 17:26:29
Minul pole Win 7-ga GIMP kordagi kokku jooksnud ja olen kasutanud mitte just igapäevaselt, aga küllalt tihti siiski. Oled oma arvuti riistvara korrasolekus 100% kindel? Kettakontrollid, mälutestid tehtud, temperatuurid kontrollitud?
Peab ikkagi kindlaks tegema, mis seda kokkujooksmist põhjustab. Kuigi ega sagedam salvestamisenupu pressimine ka paha tee.
___________________________________________
Ja loodetavasti pole sul kasutuses ikkagi mitte enam vana GIMP 2.6.6, millest selle vana teema pealkirjas jutt. Uued GIMP-id on stabiilsed olnud.
