Andykas
29.05.2009 08:24:50
Brink |
Just a few scant days before the year's biggest gaming event and GameTrailers has snuck into E3's living room and unwrapped one of its biggest gifts. Oh, and it televised what it found inside, spoiling it for everyone.
So, what was inside? Namely: "Brink" the product of Bethesda and Splash Damage's collaboration, first revealed just over a year ago. And what does the teaser trailer tell us about said project? Well, for starters: it's a video game, it appears to have a science fiction theme and, if the sound of bullets are any indication, there will be shooting in it. More details? It's coming to Xbox 360, PlayStation 3, and PC (with Games for Windows support). Oh, and you'll be playing it by Spring 2010 take that, holiday shopping season!
Check out the trailer after the break, and stay tuned for more on Brink from E3 (next week!).
source
| Kommentaarid: 25 loe/lisa |
22 |
nolifer
29.05.2009 13:14:09
| tundub huvitav igatahes, mingi rpg ilmselt
aise
29.05.2009 13:42:08
see video on küll paljuütlev
| Kommentaarid: 189 loe/lisa |
172 |
madness
29.05.2009 17:22:22
| nolifer kirjutas: |
| tundub huvitav igatahes, mingi rpg ilmselt |
pidi olema revolutsiooniline FPS...
seda juttu muidugi ennegi kuuldud.
| Kommentaarid: 13 loe/lisa |
nolifer
30.05.2009 06:53:36
| bethesda ikkagi asjataga, niisiis mingi lootus ikkagi on
Andykas
30.05.2009 09:48:02
| Ei tea kas kasutavad oblivioni ja falloudi mootorit või võtavad päris uue? See oblivioni ja falloudi engine on natuke ajast maas ja liikumine on seal kuidagi uimane FPS jaoks, ma loodan, et on täiesti uus mootor. Võiks olla open world mäng nagu bethesdal ikka kombeks. 8)
22 |
madness
30.05.2009 10:52:31
| Andykas kirjutas: |
| Ei tea kas kasutavad oblivioni ja falloudi mootorit või võtavad päris uue? See oblivioni ja falloudi engine on natuke ajast maas ja liikumine on seal kuidagi uimane FPS jaoks, ma loodan, et on täiesti uus mootor. Võiks olla open world mäng nagu bethesdal ikka kombeks. 8) |
no aga sa unustad ära, et seda teevad 2 erinevat firmat. Ei pruugi olla üldse selline mäng, nagu varasemad Bethesda omad. Splash Damage on teinud varem MP FPSe ainult.
DeTHiCa.
31.05.2009 13:58:45
open world rpg + mp fps .. = darkfalli sugune mäng?
136 |
madness
03.06.2009 18:11:39
The Story
A man-made floating city called the Ark, made up of hundreds of separate floating islands, is on the brink of all-out civil war. Originally built as an experimental self-sufficient and 100% "green" habitat, the reported rapid rise of the Earth's oceans has forced the Ark to become a refuge for humanity. Crammed with the original Ark founders, their descendants, as well as tens of thousands of refugees, the Ark exists in total isolation from the rest of the world. With 25 years of social unrest, the inhabitants of the Ark have reached their breaking point. It's up to you to decide the future of the Ark and the human race.
Game Overview
BRINK is an immersive shooter that blends single-player, co-op, and multiplayer gameplay into one seamless experience, allowing you to develop your character across all modes of play. You decide the role you want to assume in the world of BRINK as you fight to save yourself and mankind's last refuge for humanity. BRINK offers a compelling mix of dynamic battlefields, extensive customization options, and an innovative control system that will keep you coming back for more.
Game Features
* Blurring the Lines Between Offline and Online
Advance your character's development across every gameplay mode: single player, co-op, and multiplayer. Gain experience points that you can spend on customizing and upgrading your skills and abilities, designing an entirely unique look and feel for your character.
* Groundbreaking Kinesthetics
BRINK uses the familiar shooter controls that youre used to, without frustrating, artificial constraints and takes advantage of a new feature: the SMART button. When you press the SMART button, the game dynamically evaluates where you're trying to get to, and makes it happen. No need to perfectly time a jump or vault, the game knows what you want to do.
* Context-Sensitive Goals and Rewards
Objectives, communications, mission generation, and inventory selection are all dynamically generated based on your role, your status, your location, your squad-mates, and the status of the battle in all gameplay modes. You'll always know exactly where to go, what to do when you get there, and what your reward will be for success.
* Virtual Texturing
BRINK's proprietary technology, Virtual Texturing, breaks new ground on current-gen consoles and PCs with an even greater focus on highly detailed characters, realistic environments, lighting, effects, and atmospherics. This competitive lead on the squad-combat genre helps thrust players into the gritty reality of the Ark's epic secluded arcology.
http://www.splashdamage.com/brink
DeTHiCa.
03.06.2009 18:21:14
| BRINK uses the familiar shooter controls that youre used to, without frustrating, artificial constraints and takes advantage of a new feature: the SMART button. When you press the SMART button, the game dynamically evaluates where you're trying to get to, and makes it happen. No need to perfectly time a jump or vault, the game knows what you want to do. |
see nüüd küll hea ei ole...
136 |
madness
03.06.2009 18:27:55
ei tea...
| In practise this means that when holding down the SMART button, youll automatically traverse the terrain without having to juggle the controls yourself. SD were quick to point out this wasnt an attempt to simplify the controls for newbies, but rather to allow more complicated manoeuvrability. So yes, holding it down and run forward, and youll automatically jump fences, dodge furniture, etc. But apply it tactically and it can let you intuitively move in an intelligent way. See an archway thats dangerous to run through? Look up as you hold down SMART and it will know you want to jump up and over it. Look down and youll feet-first slide as if stealing base. It means you can leap and glide around while focusing on combat. Theres still a hesitation here - the Assassins Creed Syndrome where you feel youre uninvolved in the more fun acrobatics could still be a problem. Again, wed have to play with it ourselves before we could know either way. |
http://www.rockpapershotgun.com/2009/06/03/e3-09-brink-revealed/
DeTHiCa.
03.06.2009 18:42:39
| loodame et nad leiavad siis kuldse kesktee skill ja fun gameplay vahel.
136 |
murka_
01.12.2009 17:40:13
Lõpuks lasti ka väike lõik gameplay-d ametlikult välja. link
Tundub, et mängumootoriga midagi viga ei ole, sest kõik ETQW-s olnud bugid peaksid olema parandatud. Väga tore tunne, et mõned mängutegijad viitsivad fänne kuulata ja mitte rahanäljas paska teha(COD:MW2, Wolfenfail jne).
| Kommentaarid: 4 loe/lisa |
madness
01.12.2009 17:53:27
| Videoga tuli ainult see jama uudis kaasa, et lükati edasi 2010 Sügisesse
murka_
01.12.2009 18:15:03
| ET:QW-ga oli jama, et ei suudetud realiseerida kõike, mis oli plaanitud. Nad üritavad mängu täiesti perfektseks teha. Natuke jama jah, et mäng nii kaugele lükati, aga võib-olla on see müügistrateegia(Ise eelistan suveks väljalaskmist, et suvel hetkekski igav ei hakkaks).
Timberg
ööKARU
01.12.2009 20:14:28
| diablo.. borderlands... loodame, et siis tuleb aänxam mäng, kui bl.
272 |
murka_
04.12.2009 14:56:38
Veel mõned videod:
S.M.A.R.T.
Container city pt1
Container city pt2
Container city pt3
Marx112
04.12.2009 15:31:17
Vididest tundub ikka päris huvitav mäng. Omamoodi lahendused, uuendused ja akrobaatika on minu maitse järgi
Andykas
22 |
middaigane
| Kommentaarid: 15 loe/lisa |
14 |
Eliit
Wiltz
15.03.2010 15:14:12
midagi revolutsioonilist siin nüüd küll ei ole mõningad head ideed ja pisut borderlandslik graafika/environment vist.
kas tõesti on vaja tervet pidet smg'st et üks vant maha võtta??? ei tundu ka, et 90% kuule suvalises suunas lendaks, aga tont muudkui täristab ja vahetab pidet
9 :: |
226 |
-Superman-
15.03.2010 15:54:41
See on siis nagu:
Mirror Edge + Killzone 2 gameplay ja Borderland system.
Dude .
17.08.2010 14:21:23
Endal üks oodatumaid mänge arvestades, et kunagi sai kõvasti ET'd taotud. Nüüd tuuakse vana hea objective'itega and erinvate class'idega gameplay tänapäeva. SMART on geniaalne ja character customization näeb kah tegija välja.
Inimesed siin ma vaatan teevad osasid asju vast ka suuremaks kui vaja. Tegu ei ole mingi suure RPG'ga (juhul kui viimased Call of Duty'd on mõne arust RPG'd) ja kindlasti ei ole tegu MMO'ga. Sama asi käib ka Mirror's Edge'i võrdluste kohta. Kuigi light body type'idega vennad on suht kiired ja ronivad igaltpoolt üle, siis ei ole see ülsdegi pea point.
Keda huvitab, siis väga hea lugemine: http://forums.bethsoft.com/index.php?/topic/1102014-brink-info-compendium-v2/
15 |
Timberg
ööKARU
17.08.2010 15:58:50
Mäng mänguks... kuid viimane trailer oli küll natuke odav minu meelest. Visuaalselt oli ju asi paigas. Kuid ülesehitus oli nii igav kui saab olla.
Stsenaarium
A tapab B, C tapab A, D tapab C jne... no come on. Kus on draama, ettearvamatu teemaarendus või midagi põnevat või kasvõi - huumor?
272 |
