uus teema   vasta Uudised »  Pressiteated »  Kuulutati välja uus HDMI 1.4 spetsifikatsioon märgi kõik teemad loetuks
sõnum 29.05.2009 00:01:16 Kuulutati välja uus HDMI 1.4 spetsifikatsioon vasta tsitaadiga
27. mail kuulutati välja uue HDMI standardi versioon 1.4 spetsifikatsioon. Kõige märkimisväärsemaks uuenduseks on vast see, et nüüd toimub üle sama audio-videokaabli ka võrguliiklus. See eeldab muidugi seda, et ka seadmed ise uut 1.4 versiooni toetavad. Kiiruseks esialgu 100Mb/s.
HDMI Ethernet Channel
The HDMI 1.4 specification will add a data channel to the HDMI cable and will enable high-speed bi-directional communication. Connected devices that include this feature will be able to send and receive data via 100 Mb/sec Ethernet, making them instantly ready for any IP-based application.
The HDMI Ethernet Channel will allow an Internet-enabled HDMI device to share its Internet connection with other HDMI devices without the need for a separate Ethernet cable. The new feature will also provide the connection platform to allow HDMI-enabled devices to share content between devices.
Audio Return Channel
The new specification will add an Audio Return Channel that will reduce the number of cables required to deliver audio upstream for processing and playback. In cases where HDTVs are directly receiving audio and video content, this new Audio Return Channel allows the HDTV to send the audio stream to the A/V receiver over the HDMI cable, eliminating the need for an extra cable.
3D Over HDMI
The 1.4 version of the specification will define common 3D formats and resolutions for HDMI-enabled devices. The specification will standardize the input/output portion of the home 3D system and will specify up to dual-stream 1080p resolution.
4K x 2K Resolution Support
The new specification will enable HDMI devices to support high-definition (HD) resolutions four times beyond the resolution of 1080p. Support for 4K x 2K will allow the HDMI interface to transmit content at the same resolution as many digital theaters. Formats supported include:
3840x2160 24Hz/25Hz/30Hz
4096x2160 24Hz
Expanded Support For Color Spaces
HDMI technology now supports color spaces designed specifically for digital still cameras. By supporting sYCC601, Adobe RGB and AdobeYCC601, HDMI-enabled display devices will be capable of reproducing more accurate life-like colors when connected to a digital still camera.
Micro HDMI Connector
The Micro HDMI Connector is a significantly smaller 19-pin connector that supports up to 1080p resolutions for portable devices. This new connector is approximately 50% smaller than the size of the existing HDMI Mini Connector.
Automotive Connection System
The Automotive Connection System is a cabling specification designed to be used as the basis for in-vehicle HD content distribution. The HDMI 1.4 specification will provide a solution designed to meet the rigors and environmental issues commonly found in automobiles, such as heat, vibration and noise. Using the Automotive Connection System, automobile manufactures will now have a viable solution for distributing HD content within the car.
allikas: http://www.hdmi.org/press/press_release.aspx?prid=101
viimati muutis SKG 29.05.2009 09:04:40, muudetud 1 kord
MacRein
MacRein
sõnum 29.05.2009 08:53:19 Re: Kuulutati välja uus HDMI 1.4 spetsifikatsioon vasta tsitaadiga
Skeptik kirjutas:
See on ilmselgelt helesinine unistus ja selleks see jääbki. Juhtmed on ju lahedad icon_lol.gif
Om Kriya Babaji Nama Aum
Kommentaarid: 234 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 201
sõnum 29.05.2009 09:02:24 vasta tsitaadiga
Skeptik: Tere. Jah, tulevikus läheb kõik ühte CAT-kaablisse. Ja tundub, et ka siin teemas "mängitakse" tuntud asjale, nagu HDMI Over LAN.
Ja selliseid seadmeid on juba praegugi olemas, kus HDMI-d üle LAN-i edasi-tagasi "lohistatakse".
http://www.atlona.com/Atlona-HDMI-Extender-over-single-Cat5-6-with-LAN-Loop-Out.-Receiver-Unit-p-17792.html
sõnum 29.05.2009 09:03:28 vasta tsitaadiga
1.4 on pigem LAN over HDMI, mitte vastupidi
meybo
meybo
sõnum 29.05.2009 09:19:18 vasta tsitaadiga
tahanteada, kuidas sa jaksad igas teemas oma ila ajada?
www.meybo.ee
Kommentaarid: 22 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 20
sõnum 29.05.2009 10:01:50 vasta tsitaadiga
Skeptik: Vaata - HDMI elu lõppeb HDMI-kaabliga, mille maksimaalne pikkus on Sul piiratud a 3-5 meetriga. Over LAN tehnoloogiaga on Sul seadmete omavaheline kaugus praktiliselt piiramatu. Ja lisaks siis veel ka sama info ülekanne üle WiFi.
Wireless variant siis:
http://www.zantech.com.au/extender/video/mpx.html
Igasuguste pikkade, müravabade audio ja viodekaablite tootmine on maailmas peavalu teonud juba üle saja aasta. Ja seetõttu ongi viimastel aastatel pilgud pööratud CAT-kaablile, kuna mööda seda on tuhniliselt lihtsam ja ka odavam signaale edastada, kui imematerjalidest ja spetsiifiliste varjestustega kaetud "tavakaableid" valmistada.
Ning veel ka see, et mida suuremaid sagedusi ja kiiremaid kiiruseid vaja on, seda mitmeid - või ka kümneid kordi keerukamaks osutub vastava "tavalise" Data-kaabli valmistamine.
Lp. Oponent: djstallion: Need, kes pole kunagi oma käega ühtki varjestatud kaablit kunagi valmistanud, ega need ei tea kah, kui keeruline ja neetult aeganõudev on ühe korraliku, müravaba, varjestatud kaabli tegemine. 8)
sõnum 29.05.2009 10:34:27 vasta tsitaadiga
tahanteada, esiteks, sa hakkad jälle aiaaugust rääkima. teiseks, HDMI kaabli pikkus ei ole piiratud 3-5 meetriga.
libe
kvaliteetne mees
libe
sõnum 29.05.2009 16:37:56 vasta tsitaadiga
tahanteada kirjutas:
suudad sa nüüd oma jutu selgituseks tuua, mis on see cat kaabli ja hdmi kaabli erinevus, et cat kaablit saab pikemaks otsaks kasutada, kui HDMI kaablit icon_question.gif
miks üldse HDMI kaablil varjestust kasutatakse
Prozer
Prozer
sõnum 29.05.2009 16:47:00 vasta tsitaadiga
endal kodus Philips 7603 42tollise ja 4870 ATI vahel 10m HDMI (ei mäleta täpselt kas 1.1 või 1.2 versioon). pole mingi probleem telekast 1920x1080 Bluray filme vaadata. samas.. ei tea kas pikkusest sõltuvalt aga mängides on ca 500ms viide sees, häirib väga tugevalt ja teeb mängimise võimatuks. noaga mida sa ikka 450eegu eest tahad. asi oomipoes müügil ja võin kõigile filmisõpradele soovitada.
Sidevõrkude ja tehnilise infra arendus.
Kommentaarid: 69 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 68
sõnum 29.05.2009 19:09:56 vasta tsitaadiga
Prozer kirjutas:
see on osade Philips LCD telerite probleem. proovi kõik pildiparandusfunktsioonid välja lülitada, siis läheb nati paremaks.
KillerXP
KillerXP
sõnum 29.05.2009 23:04:16 vasta tsitaadiga
hmm ma lugesin sarnast uudist täna engadgetist... ja sel "üüber v1.4" lahendusel pidi olema suht naljakas puudujääk. Vähemasti kui uskuda engadgetit... pole nagu asja ise süvenenud.
...All fine and good, right? Sure, until you get to the part about having to choose between five different HDMI 1.4 cables, something that the suits at Monster just had to have a hand in. For a detailed look at what you'll need to study up on before buying your next HDMI cable, clinch your fists and hit the read link.
http://www.engadgethd.com/2009/05/28/hdmi-1-4-officially-detailed-ethernet-audio-return-channels/
ja tsitaat järgmisest kohast:
Consumers will have a choice of the following HDMI cables:
Standard HDMI Cable – supports data rates up to 1080i/60;
High Speed HDMI Cable – supports data rates beyond 1080p, including Deep Color and all 3D formats of the new 1.4 specification;
Standard HDMI Cable with Ethernet – includes Ethernet connectivity;
High Speed HDMI Cable with Ethernet – includes Ethernet connectivity;
Automotive HDMI Cable – allows the connection of external HDMI-enabled devices to an in-vehicle HDMI device.
http://www.businesswire.com/portal/site/home/permalink/?ndmViewId=news_view&newsId=20090527005265&newsLang=en
**ehk siis jääme ootama HDMI 1.5 standardi väljakuulutamist kus need erifunktsioonid lõpuks ühendatud on icon_lol.gif 8)
Kommentaarid: 98 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 93
DVDRW
DVDRW
sõnum 02.06.2009 07:46:33 vasta tsitaadiga
Kallid kaablid, ühilduvusprobleemid, puudujäägid, koopiakaitse, vaja uusimat kallist videokaarti... minuarust on HDMI suht mõttetu. DVI-st (palju rohkem levinud) saab sama hea pildi anyway. Mis annab HDMI mulle rohkem võrreldes DVI-video ja koaksiaalaudioga? Ei saa aru kui mul on vaja pilt saata telerisse ja heli eraldi võimendisse, kuidas seda HDMI puhul küll tehakse?
sõnum 02.06.2009 08:26:47 vasta tsitaadiga
Optical Passthrough abil (signaal sisse HDMI'ga, välja optikaga) näiteks.
DanielLoorits
DanielLoorits
sõnum 09.06.2009 07:46:45 vasta tsitaadiga
ot:
Abiks poodi minna ja osta see kaabel kodanikult, kes (erinevalt Sinust) ei leia, et selle tegemine on raske/keeruline/aeganõudev.
Vingu vähem, näed targem välja.
Annan kuni 400.- mälude eest - https://foorum.hinnavaatlus.ee/viewtopic.php?t=874952
Kommentaarid: 71 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 52
1dumbpcuser
sõnum 19.08.2009 12:54:24 vasta tsitaadiga
10 things you need to know about HDMI 1.4
TechRadar
1. HDMI 1.4 features an integrated Ethernet channel
The new version of HDMI adds a bi-directional IP data channel to allow devices to send and receive data at full Ethernet speeds (ie up to 100Mbps). This basically eliminates the need for a separate Ethernet cable and enables web-capable devices (with HDMI 1.4 connectors) to share their internet connection with other HDMI gadgets. For example, an HDMI 1.4-equipped amp could act as the internet hub of a home cinema system, sharing its broadband access with a connected TV or set-top box.
2. There's support for dual-stream 1080p 3D
HDMI 1.4 defines several 3D formats for HDMI-enabled devices, including 'frame alternative', 'line alternative' and 'field alternative' methods, 'Side by side' methods (full and half) and '2D plus depth' methods. The new specification is also capable of handling dual-stream 3D resolutions up to 1080p. Having already made an impact on the big screen, 3D TV is arguably the 'next big thing' in home entertainment. Sky has recently announced its intention to launch a 3D channel, while 3D gaming experiments have already been conducted on the PC and PS3.
3. HDMI 1.4 supports "extremely high HD resolutions"
Specifically, HDMI 1.4 provides support for 4K x 2K resolutions, which is effectively four times the pixel-perfection of a current 1080p device. This allows HDMI 1.4 to handle digital video in the same resolution as current digital cinema systems. Formats supported by HDMI 1.4 include: 3840 x 2160 pixels at 24Hz, 25Hz and 30Hz; and 4096 x 2160 pixels at 24Hz.
4. There's a new Audio Return Channel...
According to HDMI.org, "in cases where a TV features an internal content source, such as a built-in tuner or DVD player, the Audio Return Channel allows the TV to send audio data upstream to the A/V receiver via the HDMI cable, eliminating the need for an extra cable."
5. … And extended support for color spaces
Specifically, HDMI 1.4 includes support for sYCC601, Adobe RGB, and Adobe YCC601 to enable colours to be more accurately reproduced when viewing digital photos on your digital telly.
6. HDMI 1.4 boasts two new connection options
The first new HDMI format is a Micro Connector aimed at bringing HDMI connectivity to dinky devices such as mobile phones, digital cameras and portable media players. The HDMI Micro Connector (designated Type D) retains the original HDMI Connector's 19-pin interface. HDMI 1.4 also specifies a Type E Automotive Connection System to be used in distributing HD content around a vehicle.
7. HDMI 1.4 won't work with your existing HDMI-equipped gear
The official word from HDMI.org is that "most of the new features introduced in HDMI 1.4 will require a new HDMI chip to enable, and cannot be upgraded via firmware." That said, with 3D TV in its infancy and 720p/1080p HD TV only just gaining a consumer foothold, HDMI 1.3 still delivers the goods. You could argue that you don't even need an integrated data channel, as new TVs and set-top boxes are now including Ethernet jacks as standard.
8. You'll need to buy a new high-def TV
It's all very well providing support for 4K x 2K resolutions and 3D, but this means that your current 1080p telly just won't cut it in tomorrow's Ultra HD/3D future.
9. You'll need to buy new HDMI cables
The new HDMI 1.4 spec will muddy the waters with new cables – a Standard HDMI Cable with Ethernet (which supports data rates up to 720p/1080i) and a High Speed HDMI Cable with Ethernet (featuring 1080p support, Deep Color and 3D support). An Automotive HDMI cable will also be available for in-vehicle video distribution. Oh, and don't expect them to come cheap.
10. We won't see HDMI 1.4 devices until mid-2010
Next year's Consumer Electronics Show should see several HDMI 1.4-compatible devices introduced from the big CE manufacturers. We might even see HDMI 1.4 on show at IFA in Berlin. Bizarrely, NXG has already announced a Black Pearl Series HDMI 1.4 cable, despite the fact that there's absolutely nothing to plug it into.
M: MSI B660M MORTAR
O: AM5 ITX emaplaat
Kommentaarid: 104 loe/lisa Kasutajad arvavad:  :: 1 :: 2 :: 97
