| Mis pesaga Intel lauaarvuti emaplaat on kasutuses 2014 1. oktoobri seisuga? |
| Socket 478 |
2% |
[ 13 ] |
| LGA 775 |
13% |
[ 83 ] |
| LGA 1366 |
4% |
[ 30 ] |
| LGA 1155 |
32% |
[ 209 ] |
| LGA 1150 |
38% |
[ 243 ] |
| LGA 1156 |
3% |
[ 23 ] |
| LGA 2011 |
5% |
[ 35 ] |
| hääli kokku : 636 |
Cb4
29.04.2009 10:59:04
MIllal neid uue stepinguga prosei loota võib üldse? Keegi plaanib osta ka?
_________________ Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Did i ever tell you the definition of "Insanity"? |
| Kommentaarid: 113 loe/lisa |
95 |
WäntWõll
make.believe
05.05.2009 17:22:54
i7 920 SLBEJ
Tundub et uued stepid on liikuma hakanud
PS kes väga tahab siis saan tellida oma august W3520 mis on workstationi variant ja tiba kallim kui I7 920 aga kindalt D0
Total: 335,67 EUR = 5250.- Kohal Tallinnas ja seda 5-6 pävaga
I7 920 D0 reaalne saabumine on veel hämar
E: Minu DFI saaga jõudis siis lõpuni ja täna sain kinnituse
Board is here and tested ok (so we can be sure they send an OK board), i´ll get the board to the shipping dept! You should have it in a few days - sorry again for the delay, but as said before - we had to wait till DFI reacted via the Distribution .
Tundub et siin eriti keegi muid plaate ei taha peale RE, niiet müüa pole siin vist midagi
Aga kaalun siiski seda varianti.
| ot: |
Samas oleks lahe kahte highend kasti kodus pidada
Ühe käga kräunutad X58 masiant mingi D0 stepiga ja teise käega AM3-e 955BE-ga |
300 |
AJ
06.05.2009 14:37:28
Intel to phase out Core i7 940
http://www.tcmagazine.com/comments.php?shownews=26272&catid=6
Introduced in November together with the 920 and 965 EE models, the 2.93 GHz Core i7 940 has been added to Intel's discontinuance list (aka the Black list) and has received a phase out schedule. According to its maker, the tray and boxed Core i7 940 will be available for orders until September 4th, and will continue to be delivered until November 5th and December 4th, 2010, respectively.
The relative quick axing of the 940 model can be attributed to Intel's plans of releasing a higher-clocked CPU, the ($562) 3.06 GHz Core i7 950, later this quarter. |
| Kommentaarid: 37 loe/lisa |
36 |
Go Kane!
| Kommentaarid: 1842 loe/lisa |
1345 |
format666
07.05.2009 19:16:17
| suvi on. arvatavasti kolitakse 6lu ja p4ikese peale yle.
| Kommentaarid: 70 loe/lisa |
42 |
Cb4
07.05.2009 19:59:18
| format666 kirjutas: |
| suvi on. arvatavasti kolitakse 6lu ja p4ikese peale yle. |
Just, toas pole halligi teha
95 |
HDTanel
Overclocker
07.05.2009 20:08:54
Keegi teab öelda, kas LN2 all saaks paarsada MHz juurde? Nagu on reaalselt võimalik, et LN2 all bclk saab rohkem tõsta?
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
G80
07.05.2009 20:11:56
| PlatoonSgtElias kirjutas: |
| Keegi teab öelda, kas LN2 all saaks paarsada MHz juurde? Nagu on reaalselt võimalik, et LN2 all bclk saab rohkem tõsta? |
krt see nehalem ikka nii fail, et kui ikka sitt isend siis ei liigu ka külmaga aga kui hea isend siis vaja midagi karmimat kui vett, et jahutada küll.
210 |
WäntWõll
make.believe
07.05.2009 20:12:13
Ei tahaks uskuda,äkki mingi +5 on max,kuna nagu olen arusaanud siis see ei sõltu prose tembist eriti
300 |
HDTanel
Overclocker
07.05.2009 20:16:25
wanawoll, no pluss 5 oleks 30k käes Oskab keegi tõestada asja ilma, et ma proovima peaks?
496 |
WäntWõll
make.believe
07.05.2009 20:21:50
wanawoll, no pluss 5 oleks 30k käes Oskab keegi tõestada asja ilma, et ma proovima peaks? |
ma olen ammu rääkinud et see paar krammi siit ja sealt ei aita 30K tehe 06-s.
Ausalt kui palju me kõik kokku oleme katsetanud ja vat ei tule
See on ikka hea risitavara omamise taga ja siis suti õnne ka.
Jaan paugutas NV-l Tri 4890 ei tea äkki on tal skriin juba olemas 8)
Lisaks usun, et kui grammipealt täis ei tule siis seimene skoor on mingi 30600+ st. tugevalt üle.
viimati muutis WäntWõll 07.05.2009 20:22:49, muudetud 1 kord |
300 |
G80
07.05.2009 20:22:04
Palju sul siis puudu jääb hetkel 30kilost?
210 |
WäntWõll
make.believe
07.05.2009 20:23:30
| G80, 1K suti siia sinna,kõige vähem vist on olnud alla 300p
300 |
G80
07.05.2009 20:37:00
| wanawoll kirjutas: |
| G80, 1K suti siia sinna,kõige vähem vist on olnud alla 300p |
Siis päris lähedal jah, mis kelladel kaardid jooksevad?
210 |
WäntWõll
make.believe
07.05.2009 20:40:59
G80, See peaks olema 4500+ i965 + 2X295 lastud olema ja Jaan OC üritusel vaikselt nurgas kõpitses
300 |
G80
07.05.2009 21:54:13
G80, See peaks olema 4500+ i965 + 2X295 lastud olema ja Jaan OC üritusel vaikselt nurgas kõpitses  |
Sa mõtled üldse jah?
Ma küsisin palju platoonil puudu jääb.
210 |
Chidori
07.05.2009 22:14:50
| G80 kirjutas: |
| Ma küsisin palju platoonil puudu jääb. |
~900p , 200mhz cpu ja 100mhz gpu'le juurde siis teeks ära aga neid ta kätte ei saa....
99 |
WäntWõll
make.believe
07.05.2009 22:16:59
Muidugi ei saa,kõik arvavad(noh vähemalt osad) et piisab prosele 4650MHz, ei piisa
Küll aga peaks piisama kui on tri 4890
300 |
HDTanel
Overclocker
07.05.2009 22:57:58
Noo ma ei tea, kas saab siis LN2-ga takti juurde või mitte aga garanteerin, et täna tuleb 30,000p skoor ära 3DMark2006-s
Muidu väike update mu prose vee all siis.
SuperPI1M 9,265s
Core i7 920@4427MHz
6Gb PC12800 ADATA 1680MHz 6-6-6-14 1T
496 |
G80
210 |
WäntWõll
make.believe
07.05.2009 23:18:24
Edu
BTW jube volt on prosel seljas
300 |
Chidori
07.05.2009 23:19:59
BTW jube volt on prosel seljas  |
Recent ratsutas õhuga miski 1.7V juures.
99 |
WäntWõll
make.believe
07.05.2009 23:22:17
Mu 940 oli lausa ingel 1.5250 @ 4600
300 |
format666
07.05.2009 23:31:12
1.79vcore? millega seal jahutatakse?
k4rsahaisu on yle lahe tunda : >
platoon sellistel settingutel spi tulemus peaks ju ~0.15s kiirem olema?
(21x208@4.37GHz 8-8-8-24 2N - 9.23s )
viimati muutis format666 08.05.2009 00:01:28, muudetud 2 korda |
42 |
Smoking
298 |
HDTanel
Overclocker
08.05.2009 03:37:35
Voldi panin lakke kuna tahtsin kindel olla, et voldis asi pole. Proovisin ja 1.69v peal käis samahästi. Suht mõttetu prose see i7 ikka igatahes Ln2-ga ei hakanud mu i7 pm töölegi, biosis sai istuda natuke kuni pange pani jne... panin Core i7 965 sisse ja töötas ilusti 4.5GHz peal
Aga jah, andsin ühe videokaardi Jaanile, teeb 30k ära.
Ahjaa.. keegi siin väitis, et mu toiteplokk ei kannata mu masinat ära, et osta kilowatine toide jne jne jne... Noo mai tea, imege.
Sai proovitud, Core i7 965 4,4GHz 1.7v, 2.2v mälud 1680MHz, 2x4890 CF 1000\1200 ja 3DMark2006 ajal võttis stabiilselt 535W
496 |
Cb4
08.05.2009 07:54:57
Võrgust jah?
Palju su toide 12v juurev W andis? Ja nüü mõtle kui palju seal üle jääb? Nagu juba ammu teaa siis need mõõtjad on aeglased ja tippe ja suuri kõikumisi ei registreeri. Kuid just sealt see jama tuleb
E:http://www.silentpcreview.com/article676-page1.html
Umbes 135W jäi tagavaraks. Tehke mis tahate, mina olen seisukohal, et toide tagajalgadele ajades hakkavad tekkima probleemid, vähemalt minul on sedasi. Lisaks on need w-d nagunii kerge liialdusega.
Teemasse ka:
Volt tõesti jube. Mul läheb 1.59v juures kenasti 4.5ghz-i täis.
95 |
libe
kvaliteetne mees
08.05.2009 08:04:25
| Cb4 kirjutas: |
Võrgust jah?
Teemasse ka:
Volt tõesti jube. Mul läheb 1.59v juures kenasti 4.5ghz-i täis.  |
siin tuleb ka arvutada toiteploki efektiivsust, kui see on 85%, mida tõenäoliselt seasonic on, siis tegelik masina tarbimine oli oluliselt madalam
samas viisakal toitel suudab ta sellel peak koormusel ka kesta need lühikesed hüpped vägagi pädevalt ära
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
Cb4
08.05.2009 08:56:09
Noh jah, mul ka kahjuks/õnneks seasonic, miskil lehel sai teada kelle poolt toide kokku on pandud. Aga jah, suht mõttetu vaidlus. Ma ei saa garanteerida ka, kuid minul igatahes jääb toide nõrgaks. Alla 1200w mina ostma ei hakka igatahes.
95 |
G80
08.05.2009 09:07:49
| Cb4 kirjutas: |
| Noh jah, mul ka kahjuks/õnneks seasonic, miskil lehel sai teada kelle poolt toide kokku on pandud. Aga jah, suht mõttetu vaidlus. Ma ei saa garanteerida ka, kuid minul igatahes jääb toide nõrgaks. Alla 1200w mina ostma ei hakka igatahes. |
Hea on jah, kui varu olemas.
Aga videod rohkem ei lähe, kui 1GHz?
210 |
Chidori
08.05.2009 09:28:12
| Cb4 kirjutas: |
| Võrgust jah? |
Ma arvan, et Jaan mõõtis liinidelt - ega kahe single core kaardi W ei olegi kõige hullem.
99 |
Jaan
09.05.2009 18:18:37
| Chidori kirjutas: |
| Cb4 kirjutas: |
| Võrgust jah? |
Ma arvan, et Jaan mõõtis liinidelt - ega kahe single core kaardi W ei olegi kõige hullem. |
ei mõõtnud.
Aga paljas võimsus ei tee veel ilma- tähtis on et selle väljund pinged ei kuku koormusega, ei võngu (müratud) jne.
Mulle sattunud i7 940 on uute i7-te bug- see ei talu nii hästi kiiret mälu
Kõik eelmised läbikäinud i7 prosed said minu mäludega@ 1000+MHz ilusti läbi, viimane 940 aga mitte.
Kui isegi käima läheb, siis on ebastabiilne ja tulemused kehvemad.
näiteks:
wprime@800MHz:
ja sama@1000MHz mälud:
Prose @-50/1,6V biosest muidu ja teeb sellisel kellal kõike, ehk pole päris paha
123 |
WäntWõll
make.believe
09.05.2009 18:54:27
5+ täpselt sama nagu minu 940 oli.
300 |
G80
09.05.2009 19:03:35
5+ täpselt sama nagu minu 940 oli. |
See ongi sinu vana.
Huvitav kas üle 4.6GHz ei lähe, sein ees?
210 |
WäntWõll
make.believe
09.05.2009 19:05:15
See ongi sinu vana.
hehh juba otsapidi seal
300 |
Chidori
09.05.2009 19:28:52
| G80 kirjutas: |
See ongi sinu vana.  |
Kui just tal mitut ei ole siis see peaks minu käest saadud olema.
viimati muutis Chidori 09.05.2009 19:33:06, muudetud 1 kord |
99 |
G80
09.05.2009 19:32:36
| Chidori kirjutas: |
| G80 kirjutas: |
Kui just tal mitu ei ole siis see peaks minu käest saadud olema. |
Aa võib olla tõesti, et fail, sain aru ennem juttu rääkides, et tõnult saadud.
No vot.
210 |
Chidori
09.05.2009 19:33:56
Vähemalt üleeile sai ta minu käest 940 seega eeldan, et see jutt on ikka selle kohta
99 |
WäntWõll
make.believe
09.05.2009 19:51:00
Seda ma mõtlesingi et sai ta antud estnx-i kätte ja juba jaanil masinas
300 |
Estnx
206 |
Cb4
09.05.2009 22:14:00
| Estnx kirjutas: |
Minu oma on ikka veel minu käes jah.
Jaanil teine 940
Tubli töö igaljuhul Jaani poolt.
Wprime jälle tema käes  |
Njah
95 |
heff
10.05.2009 13:34:42
proovin siin oma i7-t õhu peal. Viimane kord tegin madalamatel klokkidel katset ja selle ajaga olid prose ja ruum nii kuumad, et ei julgenud rohkem proovida. Lisak sellele mäludega oli paras ajun*ss.
Praegu tahtsin 4GHz näha ja alustuseks panin 191x21. http://valid.canardpc.com/show_oc.php?id=563535
Nüüd proovin, mis teeb 20x200 ja 21x200 peale.
SPI-d proovisin ka lasta, kahjuks mälude madalama timingu tõttu oli aeg enamvähem sama, mis varem
stock jahutusega situvad tuumad idle's ~50 kraadi peal. SPi ajal läksid kuni 68 kraadini
EDIT: BCLK 200-t ei näinud, karta on, et mälud jäävad piirama. Prosele anna palju volti tahad, welcome screenil tuleb ikka BSOD
see-eest aga bclk 195 kannatas küll: http://valid.canardpc.com/show_oc.php?id=563552
Nüüd uuele ringile ja vaatan, mis mälude maksimum on.
EDIT2: kõrgema BCLK-ga oli jälle welcome screenil BSOD.
Hiljem ei saanud enam isegi BCLK 195 üles
Krt, kõik need A-Data mälud on samasse auku, vahet pole mis timing, teatud piirist ei lähe kuidagi edasi.
97 |
Cb4
10.05.2009 14:46:24
Osta uus jahutus
Mida sa selle käkiga jurad, saad prosest õige laxu kätte lõpuks
95 |
WäntWõll
make.believe
10.05.2009 15:52:44
| Cb4 kirjutas: |
Osta uus jahutus
Mida sa selle käkiga jurad, saad prosest õige laxu kätte lõpuks  |
Mis sa ajad stock cooler benchib ja laseb 3D veel 1.520v ja @ 4300Mhz
300 |
heff
11.05.2009 06:50:38
wanawoll, sinna ma ei jõuagi, mälud ei kannata seda
24/7 lasen niikuinii stock kiirusel, siis kannatab ära küll. 24/7 @ 3GHz oli enamvähem sama. Aga enam ei viitsi pärast klokkimist seadeid tagasi panna, load defaults ja valmis
97 |
Cb4
11.05.2009 07:35:20
Salvesta profiil ära ikka
Mul oli inboxiga 3.6ghz-i peal.
95 |
One
11.05.2009 09:17:00
Noo ma ei tea, kas saab siis LN2-ga takti juurde või mitte aga garanteerin, et täna tuleb 30,000p skoor ära 3DMark2006-s  |
728 |
G80
11.05.2009 14:14:09
| Winterwind kirjutas: |
Sitt garantii.
210 |
HDTanel
Overclocker
11.05.2009 14:26:49
G80, Tuli ju Jaanil ära. Ma ei öelnudki, et mul tuleb. Laenasin oma HD4890 Jaanile millega ka 30k tuli
496 |
Cb4
11.05.2009 14:47:30
Kindel et sinu oma sees oli
Tal oli neid ju 3 tükki kasutuses, ning kahega tegi tulemuse
95 |
