praegune kellaaeg 16.11.2025 08:43:04
note1
17.08.2008 18:42:26
Töötab PIN1 ja PIN2.
viimati muutis note1 14.03.2009 13:53:23, muudetud 1 kord |
zsz
09.09.2008 23:23:56
pika punnimise peale sain oma 64-bitisel gentool java plugina käima (icedtea6 versioon 1.2).
Hansapanga digiallkirjastamise applet aga ei tööta -- allpool on näha logisse kirjutatud info (kuna logi küllaltki pikk, pistsin kogu asja spoilerisse)
GCJ PLUGIN: thread 0x7f93e3115400: NP_Initialize
GCJ PLUGIN: thread 0x7f93e3115400: plugin_test_appletviewer
GCJ PLUGIN: thread 0x7f93e3115400: plugin_test_appletviewer return
GCJ PLUGIN: thread 0x7f93e3115400: NP_Initialize: using /usr/lib64/icedtea6-1.2/jre/lib/amd64/../../bin/pluginappletviewer
GCJ PLUGIN: thread 0x7f93e3115400: NP_Initialize return
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_New
GCJ PLUGIN: thread 0x7f93e3115400: plugin_data_new
GCJ PLUGIN: thread 0x7f93e3115400: plugin_data_new return
GCJ PLUGIN: thread 0x7f93e3115400: plugin_get_documentbase
GCJ PLUGIN: thread 0x7f93e3115400: plugin_get_documentbase return
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_New: creating input fifo: /home/zsz/.gcjwebplugin/gcj-instance-28189-0-appletviewer-to-plugin
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_New: created input fifo: /home/zsz/.gcjwebplugin/gcj-instance-28189-0-appletviewer-to-plugin
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_New: creating output fifo: /home/zsz/.gcjwebplugin/gcj-instance-28189-0-plugin-to-appletviewer
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_New: created output fifo: /home/zsz/.gcjwebplugin/gcj-instance-28189-0-plugin-to-appletviewer
GCJ PLUGIN: thread 0x7f93e3115400: plugin_start_appletviewer
GCJ PLUGIN: thread 0x7f93e3115400: plugin_start_appletviewer return
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_New: got confirmation that appletviewer is running.
GCJ PLUGIN: thread 0x7f93e3115400: plugin_create_applet_tag
GCJ PLUGIN: thread 0x7f93e3115400: plugin_create_applet_tag return
GCJ PLUGIN: thread 0x7f93e3115400: plugin_send_message_to_appletviewer
PIPE: plugin wrote: instance-28189-0
GCJ PLUGIN: thread 0x7f93e3115400: plugin_send_message_to_appletviewer return
PIPE: plugin wrote: tag https://id.hansa.ee/;jsessionid=FnYrLGkZj1vsDbknv7T4kZGppbVM4mvf9WW31Y5zRptpQBK1Twz7!-714267771 <EMBED CODE="SignatureApplet.class" ARCHIVE="https://www.hansa.ee/shared/digisign/SignApplet_sig.jar,https://www.hansa.ee/shared/digisign/iaikPkcs11Wrapper_sig.jar" HEIGHT="0" WIDTH="0" ><PARAM NAME="id" VALUE="ejSign"><PARAM NAME="type" VALUE="application/x-java-applet;version=1.4"><PARAM NAME="pluginspage" VALUE="http://java.sun.com/products/plugin/index.html#download"><PARAM NAME="name" VALUE="SignatureApplet"><PARAM NAME="mayscript" VALUE="true"><PARAM NAME="debug_level" VALUE="4"><PARAM NAME="lang" VALUE="EST"></EMBED>
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_New return
GCJ PLUGIN: thread 0x7f93e3115400: NP_GetValue
GCJ PLUGIN: thread 0x7f93e3115400: NP_GetValue: returning plugin description.
GCJ PLUGIN: thread 0x7f93e3115400: NP_GetValue return
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_GetValue
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_GetValue: returning TRUE for NeedsXEmbed.
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_GetValue return
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_SetWindow
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_SetWindow: setting window.
PIPE: plugin wrote: handle 4255691 width 0 height 0
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_SetWindow return
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_SetWindow: window already exists.
gcjwebplugin.cc:553: thread 0x7f93e3115400: Error: Unknown plugin value requested.
PIPE: appletviewer wrote: running
PIPE: appletviewer read: instance-28189-0
PIPE: appletviewer read: tag https://id.hansa.ee/;jsessionid=FnYrLGkZj1vsDbknv7T4kZGppbVM4mvf9WW31Y5zRptpQBK1Twz7!-714267771 <EMBED CODE="SignatureApplet.class" ARCHIVE="https://www.hansa.ee/shared/digisign/SignApplet_sig.jar,https://www.hansa.ee/shared/digisign/iaikPkcs11Wrapper_sig.jar" HEIGHT="0" WIDTH="0" ><PARAM NAME="id" VALUE="ejSign"><PARAM NAME="type" VALUE="application/x-java-applet;version=1.4"><PARAM NAME="pluginspage" VALUE="http://java.sun.com/products/plugin/index.html#download"><PARAM NAME="name" VALUE="SignatureApplet"><PARAM NAME="mayscript" VALUE="true"><PARAM NAME="debug_level" VALUE="4"><PARAM NAME="lang" VALUE="EST"></EMBED>
PIPE: appletviewer read: handle 4255691 width 0 height 0
PIPE: appletviewer wrote: status starting applet...
GCJ PLUGIN: thread 0x7f93e3115400: plugin_in_pipe_callback
GCJ PLUGIN: thread 0x7f93e3115400: plugin_in_pipe_callback: setting status starting applet...
PIPE: plugin read: status starting applet...
GCJ PLUGIN: thread 0x7f93e3115400: plugin_in_pipe_callback return
GCJ PLUGIN: thread 0x7f93e3115400: plugin_in_pipe_callback: setting status load: class SignatureApplet.class not found.
PIPE: plugin read: status load: class SignatureApplet.class not found.
PIPE: appletviewer wrote: status load: class SignatureApplet.class not found.
java.lang.ClassNotFoundException: SignatureApplet.class
at sun.applet.AppletClassLoader.findClass(AppletClassLoader.java:201)
at java.lang.ClassLoader.loadClass(ClassLoader.java:323)
at sun.applet.AppletClassLoader.loadClass(AppletClassLoader.java:145)
at java.lang.ClassLoader.loadClass(ClassLoader.java:268)
at sun.applet.AppletClassLoader.loadCode(AppletClassLoader.java:644)
at sun.applet.AppletPanel.createApplet(AppletPanel.java:798)
at sun.applet.AppletPanel.runLoader(AppletPanel.java:727)
at sun.applet.AppletPanel.run(AppletPanel.java:380)
at java.lang.Thread.run(Thread.java:636)
Caused by: javax.net.ssl.SSLException: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
at sun.security.ssl.Alerts.getSSLException(Alerts.java:208)
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1611)
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1574)
at sun.security.ssl.SSLSocketImpl.handleException(SSLSocketImpl.java:1557)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1150)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1127)
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:423)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:997)
at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:391)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(HttpsURLConnectionImpl.java:338)
at sun.applet.AppletClassLoader.getBytes(AppletClassLoader.java:302)
at sun.applet.AppletClassLoader.access$100(AppletClassLoader.java:62)
at sun.applet.AppletClassLoader$1.run(AppletClassLoader.java:191)
at java.security.AccessController.doPrivileged(Native Method)
at sun.applet.AppletClassLoader.findClass(AppletClassLoader.java:188)
... 8 more
Caused by: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
at sun.security.validator.PKIXValidator.<init>(PKIXValidator.java:75)
at sun.security.validator.Validator.getInstance(Validator.java:178)
at sun.security.ssl.X509TrustManagerImpl.getValidator(X509TrustManagerImpl.java:129)
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:225)
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:270)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:973)
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:142)
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:533)
at sun.security.ssl.Handshaker.process_record(Handshaker.java:471)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:904)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1116)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1143)
... 19 more
Caused by: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
at java.security.cert.PKIXParameters.setTrustAnchors(PKIXParameters.java:200)
at java.security.cert.PKIXParameters.<init>(PKIXParameters.java:120)
at java.security.cert.PKIXBuilderParameters.<init>(PKIXBuilderParameters.java:104)
at sun.security.validator.PKIXValidator.<init>(PKIXValidator.java:73)
... 30 more
GCJ PLUGIN: thread 0x7f93e3115400: plugin_in_pipe_callback: setting status Init: applet not loaded.
PIPE: plugin read: status Init: applet not loaded.
PIPE: appletviewer wrote: status Init: applet not loaded.
GCJ PLUGIN: thread 0x7f93e3115400: plugin_in_pipe_callback: setting status Start: applet not initialized.
PIPE: plugin read: status Start: applet not initialized.
PIPE: appletviewer wrote: status Start: applet not initialized.
PIPE: appletviewer wrote: status Stop: applet not started.
PIPE: appletviewer wrote: status Destroy: applet not stopped.
PIPE: appletviewer wrote: status Dispose: applet not destroyed.
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_Destroy
PIPE: plugin wrote: destroy
PIPE: appletviewer read: destroy
GCJ PLUGIN: thread 0x7f93e3115400: plugin_stop_appletviewer
GCJ PLUGIN: thread 0x7f93e3115400: plugin_stop_appletviewer return
GCJ PLUGIN: thread 0x7f93e3115400: plugin_data_destroy
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_New: deleting output fifo: /home/zsz/.gcjwebplugin/gcj-instance-28189-0-plugin-to-appletviewer
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_New: deleted output fifo: /home/zsz/.gcjwebplugin/gcj-instance-28189-0-plugin-to-appletviewer
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_New: deleting input fifo: /home/zsz/.gcjwebplugin/gcj-instance-28189-0-appletviewer-to-plugin
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_New: deleted input fifo: /home/zsz/.gcjwebplugin/gcj-instance-28189-0-appletviewer-to-plugin
GCJ PLUGIN: thread 0x7f93e3115400: plugin_data_destroy return
GCJ PLUGIN: thread 0x7f93e3115400: GCJ_Destroy return
PIPE: appletviewer read: shutdown
APPLETVIEWER: exiting appletviewer
GCJ PLUGIN: thread 0x7f93e3115400: NP_Shutdown
GCJ PLUGIN: thread 0x7f93e3115400: NP_Shutdown return |
[spoiler]
põhiprobleem paistab olevat teates
| Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty |
siit siis küsimus: mismoodi sellest veast lahti saada?
_________________ Seven dolphins were harmed in the process of making this post. |
| Kommentaarid: 9 loe/lisa |
9 |
note1
10.09.2008 09:53:03
| Ilmselt jäädki oma gentool veateateid vaatama..
kalamaja
10.09.2008 09:57:52
| zsz kirjutas: |
Hansapanga digiallkirjastamise applet aga ei tööta... |
Niipalju kui mina tean, siis digiallkirjastamise applet icedtea-ga ei tööta. Ja kui keegi suudab 64 bitise süsteemiga digiallkirjastamise käima saada, siis oleksin juhtnööride eest üsna tänulik.
Sellel lehel http://support.sk.ee/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=172 öeldakse icedtea kohta nii:
| Paljudes Linux distributsioonides on juba installeeritud Java keskkond aga sageli ei ole kasutatud Sun Microsystems Java keskkonda vaid näiteks IcedTea JVM-i. Viimane paaku ei sobi, sest IAIK Pkcs11Wrapper teek omab binaarkoodis programmi moodulit (libpkcs11wrapper.so) mis on lingitud just nimelt Sun-i JVM teekidega. IcedTea ei tohi ka samaaegselt Sun JVM-ga veebilehitsejas registreeritud olla. |
_________________ MP |
| Kommentaarid: 44 loe/lisa |
43 |
note1
14.03.2009 14:01:42
Sisuliselt tööavad kõikides linuxites opensc pluginad.
Seega on PIN1 täiesti kasutatav.
Ja samuti töötab ka opensc käsud- ideelaboris on need käsud näha maci alt.
pin muutmine ja puk muutmine.
Ja näiteks SEB pangas saab allkirjastamise välja lülitada, mis on tõsi, et see vajab veel üht (viimast) allkirjastamist.
Kuna ma javat enam ei kasuta, siis pole ka PIN2 vaja.
Pole nii rikas, et kõike allkirjastada.
korner
19.03.2009 10:32:27
Jah, Hansapank ilmselt mõnitab lihtsalt kliente. Olen olnud nendega ka kirjavahetuses, tavaliselt öeldakse, puhastage cache ja pange seadistustes - veebipõhine allkirjastamine. Muide Javaga allkirjastamine ei tööta seal korralikult ka Windowsis (juhul kui kasutada Firefoxi).
Kasutan Intrepidi, Firefoxi, Java 6-t. Allkirjastamine Digidocis toimib laitmatult, SEB-is toimib laitmatult, samuti Sampos. Swedbankis - võimatu.
Olukord on kurb, samal ajal kui inimesi sunnitakse kasutama ID-kaarti, ei suuda hädapank tagada selle normaalset kasutamist, sundides oma kliente kasutama veel lisaks ka teatud operatsioonisüsteemi ja brauserit.
Soovitan, linuxikasutajatel loobuda Swedbanki teenuste kasutamisest. SEB-is ja Sampos pole mingeid probleeme Java-põhise allkirjastamisega. Äraproovitud asi.
zsz
01.04.2009 12:46:52
Julgemad saavad juba katsetada uut id-kaardi tarkvara. Lähtekood ja pakked fedorale ja ubuntule on saadaval siin, lähemalt saab kogu asjast lugeda siit.
Igapäevaseks tarbimiseks pole asi nähtavasti veel valmis:
| Kogu siin lehel leiduv tarkvara on alfa kvaliteediga. See tähendab, et mitte midagi ei tööta, tõenäoliselt suudab see ära lukustada Sinu ID-kaardi, tappa ära naabri kassi ja kasvatada riigivõlga viie miljardi krooni jagu. Nõrganärvilistele ei soovitata! |
9 |
