mine lehele eelmine  1, 2, 3 ... 421, 422, 423 ... 2347, 2348, 2349  järgmine
Jah
9%
 9%  [ 51 ]
Ei
42%
 42%  [ 225 ]
Mul juba olemas
38%
 38%  [ 202 ]
Kolin mujale
9%
 9%  [ 49 ]
hääli kokku : 527
Pailaps
sõnum 04.03.2009 22:53:08 vasta tsitaadiga
viimati muutis Pailaps 04.03.2009 22:56:30, muudetud 1 kord
ReinZ87
sõnum 04.03.2009 22:57:38 vasta tsitaadiga
patrick615 kirjutas:
indrekp, point software uuendamisel on, et ruuter kipub restarte viskama. Sai soetatud uus toiteadapter, aga see ei aita. Praegu näen sellist asja
Product Name: ST716v5
Software Release: 6.2.17.4
Mul tegi ka ruuter varem restarte. Peale uuema firmware (7.4.3.2) update pole enam teinud. Ruuteriks on ST546v6.
Firmware uuendamise õpetus:
1. Begin with the unit powered off via the power switch at the back depressed.
2. Get a pin or a pen with a long enough nose to reach the reset button and hold it in.
3. Continue holding your pin or... on the reset button and do not release it. Power the unit on by pressing the power button into the "on" state never releasing the reset.
4. Hold the reset button in for around 15 seconds. The power and Ethernet light should flash between red and green.
5. Run the SpeedTouch firmware upgrade wizard. You only have around 1min to start the wizard before the speedtouch will revert to the normal boot up.
Note: It is always recommended to run the SpeedTouch firmware upgrade wizards with a statically set IP address on your PC of the following:
IP: 10.0.0.1, Subnet: 255.0.0.0, Default Gateway: 10.0.0.138.
Kommentaarid: 26 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 24
Pätu
Pätu
sõnum 04.03.2009 23:20:23 vasta tsitaadiga
Kas ainult upgrade wizardit läheb vaja või ka uue firmware faili ? Kust seda IP aadressit muuta saab
Pailaps
sõnum 05.03.2009 01:14:15 vasta tsitaadiga
Pailaps kirjutas:
[spoiler
[/spoiler]
tundub, et hädaline sai asja korda aga natukene tuli ilmselt eelnevalt TG784 tehaseseadistusse lasta.
Mõlemat, oma arvutist vaja käsitsi peale panna
EDIT: loll jutt , sorry, ma unine juba :
ST716 puhul 6.2.17.4st uuemat ei ole, arendus lõpetatud.
Soeta uus ruuter TG 784 näiteks.
viimati muutis Pailaps 05.03.2009 02:07:00, muudetud 5 korda
oncleuno
sõnum 05.03.2009 01:22:14 vasta tsitaadiga
TG784 ruuteri probleem sai tänu Pailapse abile lahendatud, suured tänud veelkord abi eest!
raido357
sõnum 05.03.2009 09:50:29 vasta tsitaadiga
http://www.speedtouchforum.de/viewtopic.php?t=1089
6.2.29.2 on siiski viimane, kuid Elion release on jah 6.2.17.4.
lurr
lurr
sõnum 05.03.2009 09:58:46 vasta tsitaadiga
jah, tõsi raido357 - mul ST716 peal jookseb 6.2.29.2 juba üle aasta peal ja pole kunagi ühtegi anomaaliat täheldanud.
Kommentaarid: 124 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 112
allanasi
sõnum 05.03.2009 17:33:40 vasta tsitaadiga
jäin 5-nda punkti juures jänni ,et äkki keegi oskab aidata või äkki kusagil mingi pildimaterjal? ja selline küsimus , kui lihtsalt ühendan aruvi kaalbi neljandasse proti ja siis võtan vlc playeri lahti , siis ei näe enam neid kanaleid nagu kõik rikutud ainult eest kanaleid , kas see peabki nii olema?
5:Ruuteri CLIs tuleb käima lasta käsk: eth vlan delete name vlan10 ja eth vlan delete name iptv
6.Keerame ruuteril DHCP maha: dhcp server config state disabled
7.Rohkem me CLId ei vaja, salvestame kõik seaded (vastasel juhul peale restarti need kaovad; kehtivad salvestatud seaded): saveall ...ja väljume: exit
8.Avame Local Area Connectionsis TCP/IP Properties ning määrame seaded käsitsi ära.
9.IP Address - neljandast pordist saadud IP aadress
10.Subnet mask - neljandast pordist saadud Subnet mask
11.Default Gateway - ruuteri IP (192.168.1.254)
12.Preferred DNS server kasti paneme ka ruuteri IP (192.168.1.254)
13.Klikime Advanced.
14.IP Addresses —> Add
15.IP address - arvuti IP aadress LANis, näiteks 192.168.1.64, 192.168.1.66 jne
16.Subnet mask - 255.255.255.0
IP Addresses —> Add
OK —> Close
Lae alla VLC Media Player ning kanalite nimekiri. Kui muidu kasutad mõnd teist Media Playerit, võid playlisti laiendi muuta näiteks *.tv ning VLC seda avama panna, vastasel juhul avatakse see vaikimisi Media Playeriga, mis aga ei oska sellega midagi peale hakata.
flameas
flameas
sõnum 05.03.2009 18:54:27 vasta tsitaadiga
Your DSL is down.
Please...
Umbes selliseid erroreid viskab koguaeg. Ime et siia foorumisse üldse jõudsin. Ideid?
Kommentaarid: 91 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 81
sõnum 05.03.2009 18:55:57 vasta tsitaadiga
carlking kirjutas:
Mingi kogelev noor daam helistas ja uuris kuidas meeldib ja mis on hea ja mis on halb.
Siis vahepeal tuli tal selline lause:"kas see number kuhu ma praegu helistan on teil ikka veel alles" doh.gif
OT küll aga Elion seda rahuloluküsitlust läbi ei tee, see on tellitud ühelt teiselt ettevõttelt. Aga ega jah, see ettevõte oleks pidanud rahulolu küsimuste juurde jääma, tõmmati vesi ikka kolinal peale.
Kommentaarid: 261 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 227
Gunnar19
Kaevur
Gunnar19
sõnum 05.03.2009 22:59:09 vasta tsitaadiga
Ma ei saa teist kallitest kaasmaalastest siin praegu aru. Kõigil on mingi probleem koguaeg elioniga, koguaeg mingi jama käib. Miks te lihtsalt operaatorit ei vaheta ?
Endal nüüd mõlemal telekal pilt kiilub vähemalt iga 3 minuti tagant kinni koguaeg. Täiesti masendav BS käib koguaeg. Alles käis tehnik, lasi ruuterile uue softi peale ja küsis sellise asja eest 500 eeku ja nüüd mõni päev hiljem on uus jama. Kuid tunnelilõpus paistab siiski valgus...kohe kohe möödub lepingu sõlmimisest 2 aastat ja lõpuks jõuab kätte päev mil saab operaatorit vahetada!
Aga teist kallid inimesed, mina ei saa aru lihtsalt kuidas te viitsite siin koguaeg oma muredest rääkida ja jaurata oma confidega jne...
Vaadake kasvõi neid 2000 eeguseid aastast 1990 digiboxe(mis tegelikult maksavad 75 krooni). Koguaeg kaob kava ära, filmi peale vajutades lootes lähemat infot filmi kohta lugeda, jookseb asi lihtsalt kokku.
Eks vist eesti inimene ongi harjund sajandeid kannatama ja lepib sellega...
Kommentaarid: 42 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 35
xxlmaster
xxlmaster
sõnum 05.03.2009 23:01:30 vasta tsitaadiga
Gunnar19,
ot:
Gunnar19
Kaevur
Gunnar19
sõnum 05.03.2009 23:05:54 vasta tsitaadiga
xxlmaster kirjutas:
Gunnar19,
ot:
mis see siia üldse puutub geenius ?
sõnum 05.03.2009 23:14:46 vasta tsitaadiga
Gunnar19 kirjutas:
xxlmaster kirjutas:
Gunnar19,
ot:
Äge, et ühes lauses on koos nii minevik kui olevik
forint
forint
sõnum 06.03.2009 00:37:37 vasta tsitaadiga
To: darkside: võtsin teleka selga ja marssisin naabri juurde kel elioni digi tv, panin elioni digitv´le Aminet530 boxi vahele HDMI kaabliga veel, Vedasin pikenduse endalt 12 m coax kaabli naabri juurde vahel oli box CXC-200PVR > ühendus telekani scart. Telekas PIP reziimi sama kanal mängima ja usu või mitte mingisugust vahet ei olnud!!! Spetsiifika järgi võib küll olla pildi kvaliteedil teoreetiline vahe aga palja silmaga ei ole seda kohe kindlasti näha.
Kommentaarid: 369 loe/lisa Kasutajad arvavad:  :: 2 :: 6 :: 294
mattu
mattu
sõnum 06.03.2009 10:06:42 vasta tsitaadiga
minagi olen eristanud silmaga suht suurt vahet starmani ja elioni iptv vahel, viimase kasuks.
ja kuidas sa võrdlesid pipiga? nii et üks suur pilt ja teine väike?
Kommentaarid: 121 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 116
Laizk
Laizk
sõnum 06.03.2009 10:26:07 vasta tsitaadiga
jyrka20 kirjutas:
Oliverk kirjutas:
DSL ühenduse puhul jääb üleslaadimiskiirus kuni 768kbit/s icon_rolleyes.gif
1megase uploadi saavad vaid korrusmaja interneti kasutajanana ... icon_rolleyes.gif
forint
forint
sõnum 06.03.2009 10:54:05 vasta tsitaadiga
mattu kirjutas:
Double size ehk 50:50
mattu
mattu
sõnum 06.03.2009 11:02:29 vasta tsitaadiga
aa
äkki siis asukohast erinevused, elion kesklinnas ja starman ühes väikelinnas võrdlesin mina.
Oliverk
sõnum 06.03.2009 13:35:43 vasta tsitaadiga
Laizk kirjutas:
jyrka20 kirjutas:
Oliverk kirjutas:
Kas Korrusmajal upload 2 polnud? Päris hea diil ju kui 1 saavad siis icon_biggrin.gif
darkside
darkside
sõnum 06.03.2009 13:54:51 vasta tsitaadiga
forint kirjutas:
mina katsetasin raplas ja oli vahe sees, värskelt ehitatud võrk ka veel ... enam too klient starmanis pole, seega ei saa enam võrrelda... ülejäänud tuttavad kõik on elioni digi kliendid 8)
Oliverk kirjutas:
Laizk kirjutas:
jyrka20 kirjutas:
Oliverk kirjutas:
korrusmaja kliendidel oli valida kas 4/1 või 10/2 ühenduse vahel...
Kommentaarid: 72 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 71
Volum
sõnum 06.03.2009 15:29:10 vasta tsitaadiga
Tehnikul puudub ligipääs ruuterile. Kuskil pool aastat tagasi võtsin ligipääsu ise ära icon_lol.gif
Tellin originaal A-varuosasi saksast. 15-70% soodsamalt kui esindustes!
Teostan diagonstikat tehasetasemel: BMW, VAG (Audi, VW, Seat, Skoda ja kaubikud), Volvo (sõiduautod), Scania - Tartus, Põlvas ja lisatasu eest Võrus.
Pailaps
sõnum 06.03.2009 16:30:17 vasta tsitaadiga
Volum kirjutas:
kõige lihtsam speedtouchil reset ja uuestiseadistamine
aga võib ka nii :
service system ifadd name PING_RESPONDER group wan
service system ifadd name TELNET group wan
service system ipadd name TELNET ip 192.168.0.0/16
service system ipadd name TELNET ip 10.0.0.0/24
service system ipadd name TELNET ip 172.16.0.0/12
service system ipadd name TELNET ip 194.126.117.170/32
user add name Administrator password "" role Administrator defuser enabled
user add name helpdesk password helpdesk role TechnicalSupport defremadmin enabled
Volum
sõnum 06.03.2009 19:39:01 vasta tsitaadiga
Pailaps kirjutas:
Volum kirjutas:
aga võib ka nii :
"Failed to add interface group to unknown service access list."
"Failed to add ip address (range) to unknown service access list."
"[mlp] Invalid/duplicate username or user database full."
"[mlp] Current user isn't allowed to add another user with specified role."
//sain korda, pidin uue firmware peale panema...
sain siit: http://web.zone.ee/elion/firmware/
Pätu
Pätu
sõnum 07.03.2009 10:55:42 vasta tsitaadiga
Krt hing nii täis sellest ruuteri restartimisest. Järgmine nädal peaks uue soetama. Kas see sobib praeguse 716v5 asemele ? https://pood.elion.ee/epood.asp?t=eri&tt=&ttt=8801&ta=&t2=&tp=&ug=true&Smenyy=1373
uus teema   vasta Hinnavaatlus »  Andmeside ja kõnelevi »  Telia TV mine lehele eelmine  1, 2, 3 ... 421, 422, 423 ... 2347, 2348, 2349  järgmine
