I.R.W
26.02.2009 00:08:45
"Intellectual Property Enforcement Entertainment Software Association"Kellelgi torrenti kaudu sellise asjaga on tegem |
Teie kasutuses oleva Kõu interneti kaudu toimunud intellektuaalse omandi ebaseadusliku väljajagamise kohta on laekunud kaebus.
Televõrgu AS, võrgu administraator.
575 7th Street, NW, Suite 300
Washington, DC 20004 USA
Title: Grand Theft Auto IV
Notice ID: 81589847
Infringement Source: BitTorrent
Infringement Timestamp: 21 Feb 2009 03:28:48 GMT
Infringement Last Documented: 21 Feb 2009 03:28:48 GMT
Infringer Username:
Infringing Filename: GTA IV PC Version
Infringing Filesize: 14868246528
Infringer IP Address: 78.28.71.178
Infringer DNS Name: 78-28-71-178.cdma.dyn.kou.ee
Infringer Port ID: 59822
Infringer URL: http://transfer-tracker.eu:2710/ed71a5eb3c2b8a4fb53d9cbf886c073b/announce
1. Notify the account holder of the Infringing Material.
2. Remove, or disable access to, the Infringing Material detailed above.
3. Take appropriate action against the account holder under your Abuse Policy/Terms of Service Agreement, including termination of a repeat offender.
Please inform us whether you will remove or disable access to the Infringing Material as requested. Televorgu AS or the account holder may contact ESA at the above-listed contact details, with email preferred. Please include the above-noted Reference Number in the subject line of all email correspondence.
Thank you for your cooperation and prompt response in this matter.
Sincerely,
Sain siis kirja/kaebuse... mis kõige parem on et ma olen seda mängu juba mingi mitu kuud tirinud aga net nii aeglane et peaks loobuma ja nüüd 21.veeb sain kaebuse... eks siis lõpetan ära... aga hea näha et andme kaitse juba töötab.
| Kommentaarid: 4 loe/lisa |
Anna tooli
26.02.2009 00:16:59
Aga sel hetkel kui tirisid, jagasid sina seda kama ka teistele ju või mis, pätt
viimati muutis Anna tooli 26.02.2009 00:18:18, muudetud 1 kord |
| Kommentaarid: 363 loe/lisa |
299 |
waux
26.02.2009 00:18:15
| kas nüüd kinniminek?
| Kommentaarid: 602 loe/lisa |
498 |
crypto
26.02.2009 00:20:30
Kasutage veel avalikke trackereid ja seedige kuni lõpmatuseni, nii need kaebused laekuma hakkavadki
_________________ 61. Logistikapataljoni võitleja
viimati muutis crypto 26.02.2009 00:33:55, muudetud 3 korda |
| Kommentaarid: 42 loe/lisa |
37 |
nah
26.02.2009 00:26:56
| I.R.W, Osta mäng poest, siis hea näidata, et enda jaoks teed koopiaid ainult, et originaalplaati mitte kulutada.
| Kommentaarid: 150 loe/lisa |
141 |
Absona
| Kommentaarid: 11 loe/lisa |
O
26.02.2009 00:31:08
Ei, pritsivad tatti lihtsalt.
_________________ PS, kui teemades ei vasta |
| Kommentaarid: 76 loe/lisa |
69 |
I.R.W
26.02.2009 00:32:58
Hea küsimus... nagu ei teagi... Kui midagi juhtuma hakkab siis infin
O
26.02.2009 00:36:13
Ole mureta, ei sul juhtu midagi, kohtuni ei viitsi nad end isegi organiseeritud scene jne grupeeringute vastu vedada enamasti... Saadavad sjuukseid kirju automaatselt paarsada k välja ja loodavad, et ehk mõni ehmatab ära, muud miskit.
69 |
I.R.W
26.02.2009 21:11:22
| eks neil natuke õnnestus ka... aga hea et vähemalt midagi tehakse juba piraatluse vastu... aga samas teenusepakkuja saab oma soovi järgi minu neti piirata.
arm2004
26.02.2009 21:16:00
huvitav, kas ikka saab? st kas selline piiramine kuidagi lepinguga vastuollu ei lähe?
_________________ nooope! |
97 |
313 |
Ivoshiee
27.02.2009 09:42:35
| arm2004 kirjutas: |
huvitav, kas ikka saab? st kas selline piiramine kuidagi lepinguga vastuollu ei lähe? |
Ei lähe, sest (kriminaal)seadust peetakse ülemaks kui miski suvaline kliendileping.
_________________ Folding@home
FAH foorum |
HacaX
27.02.2009 10:27:41
Ütle ISPile et too kaebaja pikalt saadaks. See et jänkistanis võib suvalise IP kohta süüdistusi/nõudmisi esitada ei tähenda, et sama ka Eestis kehtiks. Nad pole isegi vaevunud uurima mida meie seadusandlus asja kohta ütleb (loe: kas Eestis on üldse keelatud asja jagamine), või vähemalt pole seda "pisiasja" teates märgitud.
| arm2004 kirjutas: |
Kahjuks mitte. Kõu lepingus on terve "piiramise" osa olemas mis muuhulgas lubab piirata kui see piirang tuleneb seadusest (pirasofti levitamine on seaduses keelatud) või kui klient rikub lepingu tingimusi, juhtumisi aga on eespool ühe tingimusena just välja toodud, et "Klient ei tohi kasutada teenust illegaalse tarkvara kasutamiseks, laadimiseks või levitamiseks".
Ehk siis alus ISPi poolseteks sanktsioonideks on olemas, aga see ei tähenda, et too neid jooksult mingi suvalise USA organisatsiooni hädaldamise peale rakendama peaks/tohiks.
_________________ IMO & GPLed
viimati muutis HacaX 27.02.2009 10:46:38, muudetud 1 kord |
| Kommentaarid: 24 loe/lisa |
22 |
386
27.02.2009 10:35:29
Oot. Kui inimene ei olegi tavaari jõudnud alla tirida. Ning tal on käes 60% tavaaarist. Ning ta jagab seda tavaari laiali... Kas see on ikka piraatlus? Kasutaja tegelikkuses ei teagi mida ta alla tirib. Ning ta ei saa seda isegi ju parima tahtmise juures kontrollida. Kas nänn on legaalne või mitte.
_________________ Minu klaviatuur vihkab mind... |
| Kommentaarid: 15 loe/lisa |
HacaX
27.02.2009 10:48:29
Ta saab lähtuda vastaspoole väidetest
"Osaline" levitamine on IIRC samamoodi keelatud, ehkki ei meenu kas softi puhul see detail ekstra ära mainitud oli. Raamatute/muusika puhul IIRC oli.
22 |
