Dijital
05.01.2009 23:13:51
Ülevaade: Arion AT-2410VHD digiboks |
Kui eelmises ülevaates, mida saab lugeda SIIT, sai Digi-tv'd arvutisse meelitatud, siis nüüd sai ostetud kastike, mis võimaldab meie taevani kiidetud digi viia telekasse. Peategelaseks on Arion AT-2410VHD digiboks. Valik sai tehtud suht-puht-juhuslikult, kuna ega tegelikult väga palju valikut turul polegi. Oli vaja kindlasti enne jõule mingi pill hankida. Starmani pakutavat Kaoni karpi ma põhimõtteliselt ei osta. Ostetud sai see karp Serigo Elektroonikast, hinnaks 2194.- EEK
Tehniline spetsifikatsioon olla järgmine:
Technical specification:
* Main Features
MPEG-2 / MPEG-4 Part 10 AVC HD/H.264 compliant
DVB-T Terrestrial Standard compliant
Tuner & DVB-T COFDM Demodulator Compliant ETSI EN 300 744 & Nordig Unified 1.0.2
Tuner Loop-Through output(Full band) Compliant with Nordig Specification
Support External Antenna Power Supply(5V/50mA Max.) with Short Circuit Protection
MP Layer I and II, CD quality audio sound
S/PDIF for Dolby Digital Audio Output
Mono, Left, Right, Stereo, Audio Output Support
Dolby AC-3(Pass-Through) Audio Output Support
Easy And Fast Auto Programming, Intuitive User Interface
Various Video Display Format With PAL 576i/576p/720p/1080i 50 Support
Various Video Aspect Ratio With 4:3, Letter Box, Full Screen And 16:9 Support
CVBS, HDMI, SCART Video Output Support
4-Digit 7-Segments Front LED Numerical Display For Service Number and Time Display
Software Upgrade Via USB 2.0
Separated TV/Radio/All List & Favorite Group List
Multi-language Support(Customer Option)
* General Features
Powerful and easy functions for editing (Lock, Delete, Move, Rename Channel & Favorite group)
Electronic Program Guide (EPG) for On Screen Channel Information
Multi-language Function
Auto searching & manual searching function
Parental lock function
Teletext and subtitle supported by VBI and OSD
Ilus tugev karp avatud ning vaatame siis, mis seal sees ka on:
+ Pult, mille suurus, kuju ja visuaalne mulje muide olid ühed ostuotsuse tegemise juures määravaks, ja patareid.
+ Komposiitkaabel koos audiokaabliga
+ Komponentkaabel koos audiokaabliga
+ Ingliskeelne kasutusjuhend
+ Digiboks
Välimus tagasihoidlik hõbehall, esipaneelil keskel neljakohaline 7 segmendiga LED ekraan, kuhu kuvatakse vaikeolekus kellaaeg, mis apnnakse automaatselt õigeks kui digiboks on korra juba sisse lülitatud. Kui digiboks töös, siis kuvatakse seal programmi numbrit. Infoekraani all on IR-vastuvõtja ning selle kõrval programmide liikumise nupud P+ ja P-. Infopaneelist paremal aga avaneb pisike uks, mille taga ainuke kasutatav asi, on kaardipesa, mis võimaldab siis ka vaatajakaardi olemasolul vaadata tasulisi kanaleid, Eestis siis Zuum.
Digiboksi ümber keerates aga näeme, et ei tohiks olla telekat, millega seda boksi ühendada ei saaks. Video ja audio edastamiseks on võimalikud variandid SCART, komponent, komposiit, HDMI, S/PDIF. Lisaks siis veel USB pesa tarkvara uuenduste tegemiseks.
Kui kõik ühendatud, on aeg aparaadile elektrone anda. Esipaneeli ledid löövad plinkima ja toimub pisikene värvimuusika ja masin läheb käima. Teleri ekraanile ilmub Arioni logo ning esmakordsel käivitamisel tuleb läbida ka pisikene Setup, kus saab määrata vajalikud sättungid ühenduse, ekraaniformaadi, audio ja subtiitrite valikud. Ja muideks, aparaadi menüü keeleks on võimalik valida ka eesti keel, mis teeb seadistamise lihtsaks ka neile, kes väljamaa keeli ei mõista.
Kanalite otsingus on võimalik valida kas automaatne, kus siis uuritakse kõik kanalid läbi, või siis juba kindla kanali/sageduse pealt. Filtrina on valikus kas ainult tasuta kanalid või kõik kanalid. Kui kanalid leitud, siis on võimalik ka nendega manipuleerida: Lisada lemmikute nimekirja, kokku on neid 4 ning nende nimesid saab muuta oma äranägemise järgi. Samuti saab muuta ka kanalite nimesid, järjekorda. võimalik on panna kanalitele 4-kohaline PIN-kood, kui on soov, et väikesed lapsed ei vaataks näiteks Kanal2 või TV3 pealt imalaid seebikaid, mis võib nende ajutegevust pärssida.
Kanalit valides kuvatakse pisike infoaken, mis on suht kena, tagasihoidlik ent informatiivne: Vasakul pool on kanali number ja nimi, allpool info käimasoleva saate kohta, algus ja lõpuaeg ning visuaalne riba nägemaks, kui kaugele saade on juba omadega jõudnud. Nupuvajutusega on võimalik saada ka infot järgmise saate kohta. Paremal pool on kellaaeg ja kuupäev, selle all tehniline info: signaali tugevus ja kvaliteet, videoväljundi seaded ning kui kanalil on teletekst, subtiitrid, siis ka vastav ikoon on seal juures.
Kanalivahetus on suhteliselt kiire, kui kasutada puldil P+ või P- nuppe. Kui aga valida mingi kanali number numbriklahvidega, siis on kanalivahetus veidi aeglasem. Aga seda lihtsal põhjusel, digiboks ootab veidi, et kas vajutatakse veel mingit numbrinuppu või mitte, et saaks ikka kanalit number 593 ka kuidagi vaadata
Digiajastu üheks märksõnaks on EPG ehk siis elektrooniline telekava. Ka seda oskab antud digiboks vaatajale pakkuda. Ning kui leiad telekavast mõne saate, mille kohta tahaks rohkem infot, siis ka see on võimalik nn pop-up aknas ette manada. Muidugi juhul, kui info ka olemas on. Ning kui mõni saade on meeltmööda, siis on võimalik vastav saade ka "tellida". Ehk siis kui märgitud saate aeg on kätte jõudnud, siis lülitakse automaatselt ümber vastavale kanalile. Ning kui digiboks on juhtumisi stand-by olekus, siis lülitakse digiboks ka sisse ja vastavale kanalile.
Digiboksil on ka taimer, mis võimaldab kas igapäevaselt, ühekordselt või teatud nädalapäevadel masina sisse ja teatud kanalile lülitada, teatud ajaks sisse lülitada või siis välja lülitada. Ühesõnaga, valikuid on.
Süsteemist ka. Asukohaks ca 25 km Koeru mastist, antenni tõugu täpselt ei tea, aga on mingi hübriid, kanalitele 5-69, ca 1,5 m pikk, elementide arvu ei tea täpselt, aga neid seal ikka mõnikümmend. Ning, mis kõige tähtsam, antenn ei asu katusel, vaid pööningul, mis veel suht madal, hari on umbes 1,3m kõrgusel põrandast. Ideaalne koht kõikvõimalikele häiretele ja peegeldustele. Antenn ise on umbes 6m kõrgusel maapinnast. Otsasein, mis masti poole, on kivist ning seal veel selliseid kivimaju ees. Signaali tugevus 80 ning kvaliteet 60. Kaablit, mis on küll paarkümmend aastat vana ent korraliku 1mm soonega, on antennil järgi ca 25-30m kokku. Pilt ees ja silmnähatvaid pildivigu ei täheldanud. Aga kuna tahtsin kindla peale minna, siis panin vahele ka pisikese võimendi. Antennist ca 5m kaablit, siis võimendi ning seejärel ülejäänud kaabel. Võimendiks SEE. Toite 5V saab ta digiboksist, kus see on võimalik sisse lülitada. Signaali tugevuseks tuli 99 ja kvaliteet 80. Pole paha.
Mis veel? Hääkene küll, mõningad miinused ka siis siia. Kahjuks pole kaasasolev pult universaalpult ja telekat ei juhi. Seega peab teleka käima ja seisma panemiseks kasutama teleka pulti. Samuti läheb karp toiteploki juurest suhteliselt soojaks ning on seda ka stand-by olekus. Käe järgi katsudes vast mingi 45 kraadi umbes.
Ning kuna teleriks on 10a vana 21" ning kodumastiks Koeru, siis puudsid ka võimalused testida HD kanaleid pädevama teleriga. Ning kuna ka pole Zuum'i klient (veel?), siis ei olnud võimalik ka neid kanaleid vaadata.
Kokkuvõtteks siis võiks öelda, et tegu on väga korraliku riistapuuga, millel palju seadistamis- ja ühendusvõimalusi.
+ Eesti keel
+ Mugav pult (ei pea käes edasi-tagasi liigutama, et kõiki nuppe kasutada)
+ HD võimeline
+ Palju ühendamisvõimalusi
+ Võimalik uuendada tarkvara
+ Lihtne ja loogiline
- Suhteliselt soe korpus
- Pult ei ole universaalpult
Kui miskit tarka veel meelde tuleb või on küsimusi, millele mälu järgi vastata oskan, eks siis lisan juurde.
Over and out
Edit: xs.to käru tõttu panin pildid mujale
viimati muutis Dijital 28.06.2014 19:24:56, muudetud 6 korda |
| Kommentaarid: 41 loe/lisa |
Aivar88
06.01.2009 00:46:33
| tulevikus kui dtv hd peale üle läheb siis vist tuleb midagi sellist muretseda
| Kommentaarid: 77 loe/lisa |
58 |
Noname
06.01.2009 00:50:24
miks see kast nii suur olema peab
edit: või mulle tundub suur sest võrdluseks pole midagi pandud..
_________________ "Olukord on sitt, aga see on meie tuleviku väetis." - Lennart Meri
"Edu on kehv õpetaja. See ahvatleb tarku inimesi mõtlema, et nad ei saagi kaotada" - B. Gates |
| Kommentaarid: 372 loe/lisa |
321 |
Aivar88
06.01.2009 00:53:23
| Noname kirjutas: |
edit: või mulle tundub suur sest võrdluseks pole midagi pandud.. |
eks vast ikka ühendusliideste pärast, kuhu sa tikutopsile ikka kõik need ühendusvõimalused monteerid ?
58 |
06.01.2009 00:54:54
Noname, selle pildi järgi on ju näha kiipkaardi ava suurus
7 :: |
360 |
HDvurle
HV pensionär
06.01.2009 09:00:23
Kuidas pilt tundus, pehme või terav?
_________________ Teie küsimused on vastatavad, kuid meie vastused on küsitavad.
IT uudissõnad. Pihuarvuti - pihkar, pihuarvuti kasutaja - pihkur. |
| Kommentaarid: 21 loe/lisa |
16 |
Dijital
06.01.2009 10:42:19
Mõõdud on 26x18x5,5cm, ehk siis pikim külg on esipaneel vasakult paremale.
Pildi kohta niipalju, et kuna enne püüdis sama antennisüsteem seal analoogi ning vaadata sai 2,5 kanalit (Kanal2 oli alati kehva), siis sellega võrreldes oli pilt super. Ma pigem arvan, et pilt on vast teravapoolne. Ühendus üle scardi. Nagu enne ka öeldud, polnud testimiseks olev telekas just kõige parem. Pisikese CRT peal tundub nagunii meie digi väga ilus vaadata
blas
06.01.2009 10:48:37
valiku koha pealt soovitan mergesse vaadata, hetkel on hinnakirjas sellised terra tüünerid (nimetus, saadavus, hind km-ga)
Tuuner Digiality T-2000 FTA MKII Terrestrial 0 1180.00
Tuuner GeneralSatellite TE8310 DVB-T FTA Terr. MP4 5+ 1190.00
Tuuner Humax F2-1000T Terrestrial 0 1419.00
Tuuner Jacobson`s T5 DVB-T ConaxTerrestrialMPEG4 0 1490.00
Tuuner LMG T101 DVB-T FTATerr.MP4(Scart,3RCA,must) 5+ 1490.00
Tuuner Maximum DVB-T USB 2,0/1,1 Terrestrial 1 1089.00
Tuuner Samsung DTB9401F Terrestrial 1 1419.00
TuunerHD Arion AT-2410DVB-T Conax Terrestrial HDMI 5+ 2090.00
TuunerHD Jacobson`sT6 DVB-T Conax Terrest.HDMI+CI 2 2090.00
TuunerHD Jacobson`sT6 DVB-T Conax Terrestrial HDMI 5+ 2090.00
TuunerHD Jacobson`sT6 DVB-T ConaxTerrestrialMPEG4 5+ 1950.00
ise ostsin maale vanematele jacobson's T5-e (SD), elavad metsas, valgjärve mastini on linnulennult 60km ja toimib täitsa kenasti
_________________ The truth is out there |
| Kommentaarid: 79 loe/lisa |
76 |
Noname
06.01.2009 16:00:45
| Tanel kirjutas: |
ei pannud tähele jah, suur ikkagi natuke
ise vaatan ka millegi sarnase poole, s-video tollel vist puudb. võimalikult väike võiks ka olla
321 |
1dumbpcuser
06.01.2009 20:56:33
| Noname kirjutas: |
ise vaatan ka millegi sarnase poole, s-video tollel vist puudub. |
SCART-> S-Video üleminek ei sobi?
Ja miks teemaalgatajale Tähemehe boks ei sobi(nud)? Kuna uued vaid SD? Vanu, HD-võimelisi Kaone peaks veel leiduma, endale hakkas nädal-poolteist tagasi Klicki salongis paar säärast silma...Või ei meeldi starmani bokside pilt?
_________________ M: MSI B660M MORTAR |
97 |
Azex
06.01.2009 20:58:31
Re: Arion AT-2410VHD digiboks |
| Dijital kirjutas: |
Luxe TV HD (enne aastavahetust MelodyZen) on FTA, nii et zuumi kaarti pole vaja. Tõsi, levitatakse ainult Tallinna ja Valgjärve telemastist, seega Koeru kandis vastuvõtt raskendatud.
raudjalg
07.01.2009 23:57:09
See box on väiksem kui tähemehe Kaoni HD mudel. Tegelikult tal üks näpuviga veel... see käib puht isiklikult minu kapsaaeda, nimelt eesti- ja venekeelses menüüs on antennivõimendi toite aktiveerimise käsklus kirjaga /raketikandja, raketonasitel/ juhtus nii et menüü tõlke tegin mõlemas keeles mina, et aparaati ees polnud ja tootja saatis vaid exeli tabelis faili ingliskeelsete sõnadega arvasin et sõna /booster/ tähendab mingisugust mängu mis tihtipeale selliste aparaatide menüüdes mudilaste meeleheaks leidub. Nii saigi väga vajalik lülituskäsk endale nimeks raketikandja Kokkuvõtteks luban pühalikult et mõne aja pärast ilmuvas softiuuenduses on see viga parandatud. Muuseas, korralikult saab Kaonil softi vahetada ikka COM pordi kaudu, usb on tegelikult mõeldud salvestusfunktsiooni lisamiseks, eks elu näitab kas tootja softitreialid saavad hakkama ja teevad lubatud tarkvara.
| Kommentaarid: 11 loe/lisa |
7 :: |
360 |
Dijital
08.01.2009 12:58:46
Kuskohas see on? Mul küll seda silma ei hakanud. Mul on kanalite otsingu valikus ilusti "Võimendi"
Tarkvara ver 1.1, 29. oktoober 2008 (svn-673)
Või oli raketikandja Kaoni massinas?
08.01.2009 17:20:17
| Kuigi võiks eeldada(Starman), kuid peate siiski pettuma-pole Kaoni kummaski boxis raketikandjat
130 |
raudjalg
08.01.2009 21:30:10
Mnjah, no juhtub... ekslikult olen üllitise lõpus kribanud Arioni asemel Kaon, algus oli ju õige aga lõpp kiskus käest.
| See box on väiksem kui tähemehe Kaoni HD mudel |
triippriit
08.01.2009 23:33:59
Asjalik ülevaade!
Aparaat tundub ka päris korralik olevat. Ühendusvõimalused on üüratud ja ekraanigraafika paistab olevat õnnestunud.
_________________  |
| Kommentaarid: 12 loe/lisa |
ready
09.01.2009 01:48:59
Ülevaate eest , kuid sellise 21 tollise telku peal on ilmselt iga juust hea pildiga.
Kuidas on lugu nende teletexti põhiste subtiitritega, näitab? Mõtlen neid Foxi kanaleid mida näeb küll vist ainult Starmani kaardiga.
raudjalg
09.01.2009 22:48:00
| Näitab ka teleteksti põhiseid subtiitreid.
mattu
12.01.2009 18:06:27
| blas kirjutas: |
kus sa hinnakirja leidsid?
ise ostsin maale vanematele jacobson's T5-e (SD), elavad metsas, valgjärve mastini on linnulennult 60km ja toimib täitsa kenasti |
| Kommentaarid: 121 loe/lisa |
116 |
blas
13.01.2009 13:16:24
http://www.llmerge.ee/
sisened etteantud tunnustega, so kirjutad samad asjad mis seal kastides on:P
76 |
Dijital
21.01.2009 10:22:34
Lisan juurde infoks, kuna mõned on seda küsinud, kas letterbox'imine töötab, kui telku on 4:3, aga programm on 16:9. ETV2 ning TV6 peal näiteks Stargate'i ajal töötab ilusti, st tekitab ise mustad ribad üles ja alla ning pildisuhe ei muutu, kui boksi settingutest letterbox valida ja ekraan määrata 4:3. Teleris endas tuleks ka määrata ekraaniks 4:3 (kui see valikuvõimalus muidugi seal on). Sai ka ühe teise 4:3 teleri peal testitud ja algul ma ei tabanud ära, miks ta mööda näitas, venitas ekraanist välja isegi. Siis aga avastasin, et sellel teleril endal saab ka neid suhteid määrata ja seal oli letterbox miskipärast ning seega letterboxitud pilti üritati veelkord letterboxida. Panin telku 4:3 peale paika ja kõik korras.
aise
10.02.2009 12:37:54
sai ka see eelmine nädal ostetud ja täna hommikul kõik 3 led´i põlevad ja triip jookseb edasi tagasi... poes vahetati välja. mis värk olla võis, muidu kui esimene boot on siis ka need 3 led´i põlevad ja triip jookseb (numbrite asemel) aga mul jäidki nad põlema...
mis uusim soft on muidu? on keegi uuendanud üldse
| Kommentaarid: 189 loe/lisa |
172 |
10.02.2009 13:17:38
| Green Line of Death 8)
| Kommentaarid: 85 loe/lisa |
psixder
13.02.2009 12:16:56
| aise kirjutas: |
mis uusim soft on muidu? on keegi uuendanud üldse |
Oled nüüd boksi tööle saanud? Mis kommentaarid on? Hooliamta sellisest ebameeldivusest, kas oled teise boskiga rahul?
| Kommentaarid: 9 loe/lisa |
9 |
