Duckhead
11.01.2009 19:28:50
Wini paigaldamine CDromita läpakale |
Tere
Mul on spetsiifiline probleem.
On läpakas, millel ei ole muud, kui USB CDrom. Sellelt aga BIOS ei võimalda bootida.
On võimalik panna läpaka ketas teise arvuti taha ja lasta seal windowsi plaat sellele kettale.
Mis aga selle kettaga tegema peab, et sealt kettalt bootida saaks ja alustada Wini setupi. Mingeid käske v,m,s?
Aidake, kes teab.
_________________ ÄRA KOORMA PENSIONIKASSAT, SURE ÕIGEAEGSELT!!! |
| Kommentaarid: 74 loe/lisa |
68 |
Rasmus
| Kommentaarid: 49 loe/lisa |
47 |
11.01.2009 19:47:26
link
Duckhead
12.01.2009 19:12:59
dogberti lingilt leidsin ühtteist, aga millegipärast ei boodi niimoodi paigaldatud windowsXP üles, pärast installimist. Kuda seda teha? Mis faili ta tahab saada?
68 |
virks
12.01.2009 19:28:30
Läpaka ketas teise masina külge.
E - win installikas
D - läpaka ketas
E:\I386\winnt32.exe /syspart:D: /tempdrive:D: /makelocalsource /noreboot
| Kommentaarid: 526 loe/lisa |
420 |
Duckhead
12.01.2009 19:51:06
virks, kas saaks natuke lahtiseletatumalt?
68 |
313 |
virks
13.01.2009 08:29:19
1) install the hard drive as a slave in your working desktop system. I tried using a USB adaptor and it failed, i think it wants to be on an ide channel.
2) Format the drive. I just did a quick ntsf format, doesnt seem to matter.
3) insert your windows cd in the drive, and exit when it pops up asking what you want to do.
4) Go to "My Computer" and look at the drive letters of the CD-rom containing the XP disk, and also the drive letter of the hard drive you are installing to.
5) Assuming the hard drive is "D" and the XP cd is in "E:", go to the run command and type (or cut and paste):
6) setup will begin and ask you if you want to upgrade or full install, make sure it is FULL INSTALL. It will then ask you for a few more things including the CD key.
7) When it goes back to your desktop, turn off your PC and remove the slave hard drive. It is now ready for install in the new system. It will simply continue to install windows from this point |
http://www.mp3car.com/vbulletin/705955-post1.html
420 |
