uus teema   vasta Tarkvara »  Turvalisus »  Palun kontrollige HJT logi. märgi kõik teemad loetuks
Kuivati
sõnum 09.01.2009 22:17:05 Palun kontrollige HJT logi. vasta tsitaadiga
http://www.speedyshare.com/430553645.html
Väike probleem on ka selles, et arvutijookseb vahepeal kokku:
Lord Ami
Lord Ami
sõnum 09.01.2009 22:20:53 vasta tsitaadiga
O4 - HKLM\..\Run: [C:\WINDOWS\system32\kdfxx.exe] C:\WINDOWS\system32\kdfxx.exe
O4 - HKLM\..\Run: [copy bin slow 16] C:\Documents and Settings\All Users\Application Data\Send acid copy bin\Inter Test.exe
O4 - HKCU\..\Run: [BOOB BROWSE] C:\DOCUME~1\Kristian\APPLIC~1\OneHeck\Third Time.exe
O17 - HKLM\System\CCS\Services\Tcpip\..\{A38CD664-3493-45A6-9AB8-67E69A798552}: NameServer = 85.255.112.155;85.255.112.135
O17 - HKLM\System\CCS\Services\Tcpip\..\{C0F8D948-D9AD-4EB9-9759-38ED9A9F4841}: NameServer = 85.255.112.155;85.255.112.135
Fixi need.
AVZ logi ei teeks paha.
Kuivati
sõnum 09.01.2009 23:35:57 vasta tsitaadiga
AVZ logi http://www.speedyshare.com/815324267.html
Manus
Küsin veel sellist abi, et AVG ei tee uuendust ja viskab ette selle errori. Korra lasin ta maha, et panna kaspersky peale, aga siis ta utles, et AVG tuleks enne maha lasta.
sõnum 12.01.2009 13:21:05 vasta tsitaadiga
https://foorum.hinnavaatlus.ee/viewtopic.php?p=4668179#4668179
Kommentaarid: 742 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 560
Lord Ami
Lord Ami
sõnum 13.01.2009 21:35:48 vasta tsitaadiga
begin
SetAVZGuardStatus(True);
SearchRootkit(true, true);
QuarantineFile('kdfxx.exe','');
QuarantineFile('C:\WINDOWS\system32\kdfxx.exe','');
QuarantineFile('C:\DOCUME~1\Kristian\APPLIC~1\OneHeck\Third Time.exe','');
DeleteFile('C:\DOCUME~1\Kristian\APPLIC~1\OneHeck\Third Time.exe');
BC_DeleteFile('C:\DOCUME~1\Kristian\APPLIC~1\OneHeck\Third Time.exe');
DeleteFile('C:\WINDOWS\system32\kdfxx.exe');
BC_DeleteFile('C:\WINDOWS\system32\kdfxx.exe');
DeleteFile('kdfxx.exe');
BC_DeleteFile('kdfxx.exe');
BC_ImportDeletedList;
ExecuteSysClean;
BC_Activate;
RebootWindows(true);
end.
HOSTs fail tasuks ka välja vahetada
http://www.mvps.org/winhelp2002/hosts2.htm
