Piraatluse levitamine on keelatud siin foorumis, tee seda vaikselt _________________ BMW - nimisõna, Saksamaal valmistatav toode, mis tarbib ühte naftaproduktide vedelat segu ja pikendab ostja riista vähemalt poole võrra
ATI inimestele ka mingisuguseid performance tweake on ? Sooviks ca 10-15 fps juurde saada praegusele 15fps-ile _________________ Pakkuda soodsamalt diislit & bena Huvi korral PS! NB! TARTUS!
M: Valamukapp soodsalt!
Keegi targem viitsib seletada paar asja lahti?
Märkisin punasega need kohad millele ootaks seletust et mida see konkreetne rida teeb täpsemalt.
Kopeerisin kõik need commandid siia kui keegi soovib tutvuda.
Tools:
-benchmark: Runs the benchmark tool and immediately exits game.
-help: Display list of all command line options
Graphics:
-renderquality: Set the render quality of the game. (0-4)
-shadowdensity: Set the shadow density of the game. (0-16)
-texturequality: Set the texture quality of the game. (0-2)
-viewdistance: Set the view distance of the game (0-99)
-detailquality: Set the detail quality of the game. (0-99)
-novblank: Disable wait for vblank (No Vsync)
-norestrictions: Do not limit graphics settings
-width: Set width of main render window (default is 800)
-height: Set height of main render window (default is 600)
-safemode: Run the graphics in the lowest setting possible
-frameLimit: Limit frame to interval of refresh rate
(ex If refreshrate is 60HZ frameLimit 1 = Locks down to 60HZ)
-refreshrate: Set the refresh rate of main render window
Warning - Monitor must support (ex. refreshrate 60)
-fullscreen: Force fullscreen mode
-windowed: Force windowed mode
-availablevidmem: Set amount of physical Video Memory(ex. availablevidmem 0.9)
-percentvidmem: Percentage of video memory to make available to GTA
Audio:
-fullspecaudio: Force high-end CPU audio footprint
-minspecaudio: Force low-end CPU audio footprint
System:
-noprecache: Disable precache of resources
-nomemrestrict: Disable memory restrictions
Jama siis, ei saa videokaarti seadeid tõsta, lihtsalt ei luba üle teatud piiri. Varem asi töötas, aga täna tekkis mänguga probleeme ja pidin uuesti peale installima. Näiteks madaldan reso siis resource usage langeb ja saan sedavõrd view distance tõsta jne. _________________ BMW - nimisõna, Saksamaal valmistatav toode, mis tarbib ühte naftaproduktide vedelat segu ja pikendab ostja riista vähemalt poole võrra
viimati muutis kevvu 15.12.2008 16:15:07, muudetud 1 kord
See on sellepärast, et files.txt kontrollib sinu faile ja sul peavad originaalid kindlasti alles olema, muidu on aidaa ja reinstall. Ma ise seda kogenud päris palju, nüüd juba asjad korras ja mäng ära moditud
Päris vahva on mentidega lammutada, Deaglega üks kuul ja auto põleb rahvast lendab . Sõidan siis see "Porsche"-ga Cometiga ja tollel modisin nii ära, et ühtegi mölki ei tule ja üksi auto ka kinni ei pea, Samuti ka kiirus on mõnna 4WD möllab, kõik rattad kerivad , mingit probleem pole teha selle autoga 6 tärni täis. Kui keegi tahab modida, siis otsige googlest GTA IV Magic, see fixib ära ja peale seda võite kõiki faile modida. _________________ Web3 | ERC721A
kevvu,
Tee txt fail nimega commandline ja sisse sinna kirjuta -norestrictions või -novblank ei mäletan enam kumb oli selle limiidi eemaldamiseks ja kum vsync vastu
Jätkuvalt parim tulemus on benchis 20FPS.... X2 4400+ , HD 4850, 4x1GB ram.... see peaks ju suutma 30 välja vedada ??? _________________ Pakkuda soodsamalt diislit & bena Huvi korral PS! NB! TARTUS!
i don't know if this has happened to anybody else, and i couldnt find a video on youtube for it.
but has anybody else seen another niko walking around? and when you shoot him he shoots back and adopts the 'cover position' behind like a wall or something?
its only happened to me once and i havnt heard of anybody else who has done it.
it happened by the hospital with the u shaped drive way. the hospital where you go in to do a mission
Endal võiks ka kuidagi saada mõned fps-d juurde, graafikat ei taha kohe üldse langetada (samamoodi ATI kasutaja, 3870) _________________ Räägime ilmast..... Kaua sa ilma oled olnud?
Varem jõnksas mäng mul. Aga nüüd teen alati nii, et kui mängu l2heb ära l2hen alt+tab-iga explorerile ja panen rockstarsi social clubi kinni. Fps tõusis silma järgi öeldes +10.
Ma reinstallin & vaatan mis fps saan fresh-iga ... esmase installiga oli mul veel nvidia kaart kah... _________________ Pakkuda soodsamalt diislit & bena Huvi korral PS! NB! TARTUS!
Tools:
Graphics:
Audio:
System:
need kaks alumist on need et mäng ei tuvasta palju sul arvutis on videomälu ja RAM ja saad panna ise nii kõrged settingud kui tahad _________________ Chuck Norris võib ka keerdukse pauguga kinni lüüa!
sellest enamat pole suutnud benchis saada veel
ja on näha, et prose jääb jalgu
Statistics
Average FPS: 51.15
Duration: 37.28 sec
CPU Usage: 88%
System memory usage: 55%
Video memory usage: 96%
Graphics Settings
Video Mode: 1680 x 1050 (60 Hz)
Texture Quality: Medium
Render Quality: Medium
View Distance: 22
Detail Distance: 22
Hardware
Microsoft® Windows Vista" Ultimate
Service Pack 1
Video Adapter: ATI Radeon HD 4800 Series
Video Driver version: 7.14.10.630
Audio Adapter: Speakers (Realtek High Definition Audio)
Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
Vajaks abi..
hetkel vist üks viimaseid missioone...
Pidin valima kas tapan Dimitri või teen mingi hea diili, roman käis peale, et teeks diili,
kuid siiski läksin Dimitrit tapma..
nüüd tapsin kõik laeva tühjaks..
käseb mul kuhugi cargo hold'i minna...
ei leia seda kohta üles.. ülevalt kange liigutasin.. all nagu luugid kõik kinni..
mehed laevas kõik tapetud.
viimati muutis Maaaaark 15.12.2008 18:37:21, muudetud 2 korda
Mul tegi patch asja paremaks küll, aga ega mul enne seda polnud eriti võimalik mängida ka. Nüüd linnas sõites 15-20
Endale on kõige rohkem nalja pakkunud Romaniga joomas käimine, sest baarist väljudes tuli kallale nii 6-8 matsi, kes kõik mõlemat peksma kukkusid. Naersin nii kõvasti, et ei taibanud isegi autosse istuda ja ära sealt sõita _________________ Both the universe and stupidity are infinite. I'm not so sure about the former. - A. Einstein
Vajaks abi..
kuid siiski läksid Dimitrit tapma..
Spoiler tag-id võiks ikkagi panna, et need ei saaks ebameeldivaid üllatusi kes pole nii kaugel
See missioon Vlad-ile pead mingi tüübi ära killima, siis ajasin teda taga, ning seal ehituse juures sõitsin suure hooga tuletõrje hüdrandile otsa, see viskas mu auto 2-e kvartali kaugusele, ning kui maja katusel maandusin siis jätkus vee purskamine
Pärast reinstalli ei tea,,, aga fps on 25 ... benchi järgi.... _________________ Pakkuda soodsamalt diislit & bena Huvi korral PS! NB! TARTUS!
