08.12.2008 14:44:05
| Syncmahv kirjutas: |
| tomorrow kirjutas: |
Kas keegi üldse sellest textuuride probleemist mingi valemiga lahti ka saanud on?  |
Otseselt seotud:
| Unwinder kirjutas: |
Problem description: incorrect rendering in GTA IV on NVIDIA hardware(missing textures)
Problem background: opening <Textures> tab in RivaTuner's Direct3D settings window then closing it (even without changing the settings) disables some FourCC formats support in NVIDIA driver (INTZ/RAWZ). GTA IV cannot work properly if these formats are not supported by the driver.
Temporary solution: use RivaTuner's <Reset all the driver's settings to their default values> button to re-enable these FourCC formats. Reboot is required to apply the changes. If you don't have RivaTuner installed or if you used any other tweaking tool to alter supported formats list then just start RegEdit and search and delete all D3D_54082152 registry entries. Reboot is required to apply the changes.
Until new RivaTuner version release please avoid opening <Textures> tab, because it will disable required FourCC formats again.
Full solution: New version of RivaTuner will add INTZ/RAWZ to editable list of supported FourCC formats.
I'd like to thank Josh, Kevin and Oscar @ Rockstar for quick problem report and for cooperative problem investigation. From my experience, I rarely see game developers that care about compatibility with third party software. I really wish all game developers to have such professional attitude to quality control. |
See vist ainult nVidia puhul? |
Jah
| Kommentaarid: 92 loe/lisa |
Karr000
| Kommentaarid: 95 loe/lisa |
88 |
Anna tooli
08.12.2008 14:46:04
| juku626 kirjutas: |
On mingit infot juba tulnud?  |
Pakk ei ole veel jõudnud
| Kommentaarid: 367 loe/lisa |
301 |
Antis
08.12.2008 14:52:30
| Ma söön kirjutas: |
| juku626 kirjutas: |
Pakk ei ole veel jõudnud  |
Just sain postkontorist kätte!!!! Jeee baby jeee!
Anna tooli
08.12.2008 14:53:31
| Antis, millisest kontorist?
301 |
mustkast
| Kommentaarid: 8 loe/lisa |
Antis
08.12.2008 14:55:34
| Keila!
-Kaivo-
| Kommentaarid: 16 loe/lisa |
15 |
Volum
08.12.2008 15:05:50
Nonii, sain oma kätte postiljon surma ei saanud, küll sai aga postkontori töötajad...Nolifema nüüd ;D
_________________ Tellin originaal A-varuosasi saksast. 15-70% soodsamalt kui esindustes!
Teostan diagonstikat tehasetasemel: BMW, VAG (Audi, VW, Seat, Skoda ja kaubikud), Volvo (sõiduautod), Scania - Tartus, Põlvas ja lisatasu eest Võrus. |
| Kommentaarid: 18 loe/lisa |
16 |
symmi
08.12.2008 15:11:02
krt mäng jookseb nagu siid kuid graafikat peale panna ei saa krdi jama.. Kas kuidagi ei saaks textuure mediumile ja 1280x1024 ning view distansi 20 peale??? arvuti profiilis.. nii saan ainult 1280x1024 ja medium aga sis view distance on 1.. aga mäng jookseb mingi 48 fpsil..
| Kommentaarid: 27 loe/lisa |
25 |
Evil14
08.12.2008 15:20:14
Volum, kade olen.
| Kommentaarid: 230 loe/lisa |
201 |
OskarR89
08.12.2008 15:21:54
symmi, saab ikka. Tee gta 4 folderisse fail "commandline.txt" ja kirjuta sisse "-norestrictions" ja save ära. Siis mine mängu ja saad kõiki settinguid valida
139 |
Azatris
08.12.2008 15:25:14
| Killer89 kirjutas: |
symmi, saab ikka. Tee gta 4 folderisse fail "commandline.txt" ja kirjuta sisse "-norestrictions" ja save ära. Siis mine mängu ja saad kõiki settinguid valida  |
Tänud! Just mida ma vajasin.
| Kommentaarid: 40 loe/lisa |
36 |
OskarR89
08.12.2008 15:29:14
| ArchMage kirjutas: |
Tänud! Just mida ma vajasin. |
Tools
-benchmark: Runs the benchmark tool and immediately exits game.
-help: Display list of all command line options
Graphics
-renderquality: Set the render quality of the game. (0-4)
-shadowdensity: Set the shadow density of the game. (0-16)
-texturequality: Set the texture quality of the game. (0-2)
-viewdistance: Set the view distance of the game (0-99)
-detailquality: Set the detail quality of the game. (0-99)
-novblank: Disable wait for vblank (No Vsync)
-norestrictions: Do not limit graphics settings
-width: Set width of main render window (default is 800)
-height: Set height of main render window (default is 600)
-safemode: Run the graphics in the lowest setting possible
-frameLimit: Limit frame to interval of refresh rate (ex If refreshrate is 60HZ frameLimit 1 = Locks down to 60HZ)
-refreshrate: Set the refresh rate of main render window Warning - Monitor must support (ex. refreshrate 60)
-fullscreen: Force fullscreen mode
-windowed: Force windowed mode
-availablevidmem: Set amount of physical Video Memory(ex. availablevidmem 0.9)
-percentvidmem: Percentage of video memory to make available to GTA
Audio
-fullspecaudio: Force high-end CPU audio footprint
-minspecaudio: Force low-end CPU audio footprint
System
-noprecache: Disable precache of resources
-nomemrestrict: Disable memory restrictions |
Ülejäänud käsud ka
139 |
Azatris
08.12.2008 15:32:01
| Numbrid kirjutan lihtsalt tühikuga järgi?
36 |
OskarR89
08.12.2008 15:33:02
| Numbrid kirjutan lihtsalt tühikuga järgi? |
Täpselt, kooloni jätad ära muidugi
139 |
danny
08.12.2008 15:36:52
ühesõnagi nii??
renderquality: 4 -shadowdensity: 16 -texturequality: 2 ...
edit: et mis need õigemini on -availablevidmem: Set amount of physical Video Memory(ex. –availablevidmem 0.9)
panen mõlemile järgi nt 1000???
| Kommentaarid: 49 loe/lisa |
42 |
OskarR89
08.12.2008 15:38:14
| danny kirjutas: |
ühesõnagi nii??
panen mõlemile järgi nt 1000??? |
Kooloni jätad ära
Ehk siis: renderquality 4 -shadowdensity 16 -texturequality 2 ...
No sa võid ju proovida
139 |
danny
08.12.2008 15:42:13
OT: midagi läks nihu.. tahtsin tsiterida su teksti aga muutsin !?
ma tahtsin kirjutada "Ehk siis nii: ....."
..krt ma ei saa midagi aru
Aga tahaks teada nende kahe tegurit!
42 |
Azatris
08.12.2008 15:42:36
| Aga kunagi nii palju kasutavad HD4800 series kaarti, kas on välja ka kujunenud juba mingi settingud, mis on kõige optimaalsemad? Ma pole just ise suurem katsetaja... tekitab frustratsiooni.
36 |
h2rra
08.12.2008 15:53:30
| Mul 4870ga kõik miinimumil ja kõik maxil vist umbes 10-20 fps vahet. 512mbga tuleks tekstuurid mediumi peale panna, muidu laeb neid veidi aeglaselt.
| Kommentaarid: 4 loe/lisa |
busta
08.12.2008 16:04:01
| faking, mis kuradi seadistusi peab mingi m2ngu jaoks kasutama hakkama :S FAIL
14 |
Gap
08.12.2008 16:08:04
klge väga vabandan sellest on siin juba kindlasti räägitud aga et mängu mängima hakata peab olema sinna mingi social clubi sisse logitud aga olen mingi 100 korda proovinud aga ikka sisse ei saa ütleb et Your request could not be authenticated. Your account has not been validated ??? mis ma tegema pean oskab keegi aidata palun ? ostad originaal mängu siis näe veel sellist vaeva et mängima hakata
| Kommentaarid: 21 loe/lisa |
17 |
Deadlock
08.12.2008 16:08:59
Emailile vaatasid? Sa pead aktiveerima oma social clubi konto.
_________________ "Believe you can, believe you can't; either way, you're right." - Henry Ford |
tige kala
08.12.2008 16:13:23
Nõnna, sain ka asja tööle ja peab ütlema ,et ülikõva mäng on. Raadio, ümbruskond, autod, inimesed, story, igasugu vidinad jne kõik on ülikõva. Aa ja need kes vinguvad ,et textuure ei ole siis ilmselt pingutasid oma graafika sättetega üle, algul pakkus gta mulle ka suht low reso ja low sätted aga hetkel on sellised:
Statistics
Average FPS: 44.02
Duration: 37.05 sec
CPU Usage: 86%
System memory usage: 56%
Video memory usage: 97%
Graphics Settings
Video Mode: 1152 x 864 (60 Hz)
Texture Quality: Low
Render Quality: Highest
View Distance: 22
Detail Distance: 6
Hardware
Microsoft Windows XP Professional
Service Pack 3
Video Adapter: NVIDIA GeForce 8800 GTS
Video Driver version: 175.19
Audio Adapter: SB Live! 24-bit
Intel Pentium C2D E8200
Ja mingit läggi mängus ei olnud ning 44fps on suht hea. Proovin ka nii, et view distance panin 10 peale ja textuurid mediumi peale, siis peaks kenam olema, sest low peal on ikka väga udused lähedalt vaadates texruurid. Hetkel vajas mäng resa nii ,et võtsin natuke aega ,et foorumit ka külastada
Varjud ainult sakivad, üli karvased ja imelikud on need, üritan need ka kuidagi ära siluda siis oleks super
8)
See on vist üks esimestest mängudest kus 320mb videomälu rolli mängib, mingi 512 peaks vähemalt olema, et mingite medium seadetega korralikult saaks mängida saaks suure resolutsiooniga.
Aa muidu see ümbruskond on ikka super elav. Sõitisn linnapeal tuuritades limusiinile küljepealt sisse ja see lendas katuse peale(põlema ei läinudki muide ). Kaks tüüpi roomasid välja ja... hakkasid omavahel kakklema siis tuli politsei kohale ja hakkas neid relvaga sihtima ja kamandama, nalja kui palju, ise kõndisin rahulikult minema
| Kommentaarid: 66 loe/lisa |
RassK
08.12.2008 16:16:26
Ma söön, sain ka kätte
105 |
Paaver
08.12.2008 16:16:31
Kas keegi üldse saab social clubi sisse logida? Mul browseris saab aga selles programmis ütleb ,et on vale pw.
Teine asi ,Kas siit on läbi käinud selline jama, et kui mängu alustada ,siis viskab mingi teise kurvi peal blue screeni
| Kommentaarid: 63 loe/lisa |
60 |
danny
08.12.2008 16:16:38
vot mina ei mõista kuidas saate fps 40!? kas tõesti mul siis nii pann läpakas!?
mul siis
Statistics
Average FPS: 25.78
Duration: 37.08 sec
CPU Usage: 96%
System memory usage: 71%
Video memory usage: 88%
Graphics Settings
Video Mode: 1024 x 768 (60 Hz)
Texture Quality: Medium
View Distance: 24
Detail Distance: 36
Hardware
Microsoft® Windows Vista" Home Premium
Service Pack 1
Video Adapter: NVIDIA GeForce 9600M GT
Video Driver version: 180.70
Audio Adapter: Speakers (Realtek HD Audio (With EDS))
Intel(R) Core(TM)2 Duo CPU P7350 @ 2.00GHz |
hmm..prose jääb lahjaks? kas läpakal klokkitakse?kahetuumalist?
viimati muutis danny 08.12.2008 16:17:48, muudetud 1 kord |
42 |
jacuzzy
08.12.2008 16:16:47
| Kas mingit kasiinot või kihlveo kontorit pole siin mängus? San Andreases oli see hobusekihlveokontor.
| Kommentaarid: 14 loe/lisa |
12 |
symmi
08.12.2008 16:18:27
| Krt texturid laevad jube aeglaselt lahti ennast enamus majad on udukogud,, miski aitab selle vastu???
25 |
Gap
08.12.2008 16:19:06
| Bluebull kirjutas: |
| Emailile vaatasid? Sa pead aktiveerima oma social clubi konto. |
jah vaatasin ja kirjutasin passwordi ja kõik muu täitsa õigesti ja nüüd ütleb et sinu password on ebakorrektne ja kui sul on raskusi siis saad mingi recover (ei tea mis see tähendab eesti k ei oska nii hästi kahjuks inglise keelt) oma passwordi ??? mis siis nüüd viga on ?? aga kas see aitaks kui prooviks uue kasutaja teha äkki tegin midagi valesti ?
17 |
jacuzzy
08.12.2008 16:20:52
| recover =taastama...ehk siis taastavad su salasüna
12 |
ailar915
08.12.2008 16:27:49
| Gap kirjutas: |
jah vaatasin ja kirjutasin passwordi ja kõik muu täitsa õigesti ja nüüd ütleb et sinu password on ebakorrektne ja kui sul on raskusi siis saad mingi recover (ei tea mis see tähendab eesti k ei oska nii hästi kahjuks inglise keelt) oma passwordi ??? mis siis nüüd viga on ?? aga kas see aitaks kui prooviks uue kasutaja teha äkki tegin midagi valesti ? |
tee gmail.com-i konto ja saad kohe aktiveerida. endal oli algul jama hot.ee-s, ei tulnut aktiveerimis linki. gmaili tuli kohe.
Gap
08.12.2008 16:32:11
| jacuzzy kirjutas: |
| recover =taastama...ehk siis taastavad su salasüna |
aa tänud sulle... mõtlesin ise ka et see seda vist tähendab aga kahtlesin igatahes proovin uuesti teha äkki tegin midagi valesti
ailar915 jah tegin ka alguses hoti ja ju siis midagi läks nihu nüüd tegin teise kohta ja midagi on teistmoodi küll et tuleb need gamertagida linkida jne tänud teile
aa kas see Games for Windows tuleb ka sinna linkida ja kus ma selle saan ?
17 |
danny
08.12.2008 16:33:11
| ailar915 kirjutas: |
| Gap kirjutas: |
tee gmail.com-i konto ja saad kohe aktiveerida. endal oli algul jama hot.ee-s, ei tulnut aktiveerimis linki. gmaili tuli kohe. |
ma kohe näpistasin seda gmaili infot tegin kohe sinna kasutaja ette ära! Tänud!
42 |
RassK
08.12.2008 16:33:47
Väike avastus kui keegi veel ei teadnud.
Kuna selle mängu mängimiseks on vaja 2 accounti social club + windows live, siis 90% inimestest vajab siiski aint üht kasutajat,
üllatus, Windows live MSN kasutajaga saab tolle linkimis töö ära tehtud, ehk siis pole windows live accounti vaja 8)
viimati muutis RassK 08.12.2008 16:34:26, muudetud 1 kord |
105 |
danny
08.12.2008 16:33:56
tõstan
mul siis
Statistics
Average FPS: 25.78
Duration: 37.08 sec
CPU Usage: 96%
Graphics Settings
View Distance: 24
Detail Distance: 36
Hardware
Service Pack 1
42 |
inimeseke
08.12.2008 16:35:07
Mul 4850 kaardiga nii low kui olla saab ja ikka ei loadi tekstuure ära korralikult
mõnikord sõida veerand tundi ringi seal ja ei lae ära neid.
| Kommentaarid: 9 loe/lisa |
9 |
RassK
08.12.2008 16:37:00
| FTW esimesed minutid mängu installinud ja juba CRC errorid. Keegi veel samu erroreid saanud?
105 |
08.12.2008 16:47:19
Tekstuurid pean minagi low panema.Hetkel mediumiga kannatab ära aga fps seejuures ebameeldivalt väike(autoga kimades 12fps on jama uskuge mind ).View distance hetkel 25 ja tundub talutav kuna vähendamine erilist võitu ei anna.Õhtu vaatan kui tekstuurid low ja vd 50 kas on ok.Ülejäänud sätted @max .Tekstuure laeb kohati tsipa aeglaselt aga üldiselt hullu pole imo.
Loodetavasti keegi teeb mingi tekstuuripaki kus parema kvaliteediga aga võtavad vähem mälu.Sama varjude kohta.Võiks siis olla kas täiesti teravnurksed varjud mis pole nii kenad kui hägustatud aga annavad palju parema perfi.Või siis full soft shadows.Tõesti esimene mäng kus igatsen,et mul oleks 1GB-2GB kaart masinas
Deadlock
08.12.2008 16:51:13
mul lükkas mäng automaatselt kõik miinimumile. Panin manuaalselt kõrgemale. Jookseb küll, aga tihti ei laadi tekstuure ära, aga noh, täitsa mängitav. Ahjaa, mul see x1950 pro, autod ei lähe mõlki vist ati 1900 seeriaga, loodan, et patch parandab...
harilik
08.12.2008 16:52:53
Mul sama kaart mäng jookseb ilusti.
Average FPS: 42.51
Duration: 37.48 sec
CPU Usage: 74%
System memory usage: 60%
Video memory usage: 67%
Graphics Settings
Video Mode: 1280 x 1024 (75 Hz)
View Distance: 63
Detail Distance: 100
Hardware
Microsoft® Windows Vista" Home Basic
Service Pack 1
Video Adapter: ATI Radeon HD 4800 Series
Video Driver version: 7.14.10.630
Audio Adapter: Realtek Digital Output (Realtek High Definition Audio)
AMD Phenom(tm) 9550 Quad-Core Processor @2,64
flameas
08.12.2008 16:53:08
| Bluebull, mis seadetega sa mängid? mul x1950 proga läägib minimumi peal ka räigelt ja graafika on õudne..
| Kommentaarid: 91 loe/lisa |
81 |
SibulonHEA
08.12.2008 16:56:36
Statistics
Average FPS: 47.72
Duration: 37.16 sec
CPU Usage: 52%
System memory usage: 68%
Video memory usage: 99%
Graphics Settings
Video Mode: 1280 x 1024 (60 Hz)
Texture Quality: High
View Distance: 15
Detail Distance: 70
Hardware
Service Pack 3
Video Adapter: NVIDIA GeForce 8800 GTX
Video Driver version: 180.84
Audio Adapter: Realtek HD Audio output
Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz |
Sellised settingud mul siis, ilusti jookseb .
Tahaks CPU-d natukene rohkem kasutada aint .
_________________ Täielik Noob. |
-Kaivo-
08.12.2008 17:01:42
Ega jah Quad vennad on siin vaid suurte FPS-idega.
Shadow võtke kohe maha see on surm.
15 |
RassK
08.12.2008 17:02:13
| krusu70 kirjutas: |
| FTW esimesed minutid mängu installinud ja juba CRC errorid. Keegi veel samu erroreid saanud? |
ma olen siiamaani ignore pannud. Tea krt kas pärast tööle läheb ka
105 |
symmi
08.12.2008 17:04:34
Nii lisan siis pildi kah. Jube kahtlane kõik on high peal ja reso on 1280x1024 ning pilt on selline(autod lendavad nagu õhus ja kõik asjad on udu kogud):
25 |
omgwtf
08.12.2008 17:17:46
Burger Shot Drive In
137 |
