aap14
08.11.2008 16:19:16
Loobusin AMD-l baseeruvast süsteemist, sest et erinevad 790 plated on kas SB750 southbridge-iga (tulevikus Denebi kellamiseks) või täis crossfire supportiga. Mõlemat korraga ei saa :/
Oleks mingi emme, mis mõlemat teeks, siis oleks AMD peale vast läinud.
_________________ Slow is smooth and smooth is fast |
| Kommentaarid: 41 loe/lisa |
38 |
One
08.11.2008 23:07:05
ausalt öeldes ei saanud sellest viimasest postitusest(probleemist) vabsee aru
728 |
G80
08.11.2008 23:15:59
Lugesin kuskilt, et detsembris peaks tavainimestele ka 45nm prosed jõudma või saab varem?Mingit promo pole küll tehtud, seega tundub, et asi on fail.
210 |
One
08.11.2008 23:31:47
amd-l ja ati-l pole kunagi "promo" olnud.
intel on see kes pool aastat ette asju lekitama hakkab.
seekord on juba isegi palju lekitatud. see coolaler-i 4ghz jne..
728 |
andrez3d
09.11.2008 00:20:54
| Winterwind kirjutas: |
seekord on juba isegi palju lekitatud. see coolaler-i 4ghz jne.. |
Siiski, Amd Hammer põlvkonda reklaamiti ja promoti päris pikalt ette.
| Kommentaarid: 97 loe/lisa |
91 |
09.11.2008 00:53:18
| jah..alates neist 800mhz samplitest
201 |
Ho Ho
09.11.2008 10:31:32
Samamoodi räägiti ka Barcelonast ja selle ülemvõimust rohkem kui pool aastat enne softlaunchi
87 |
One
09.11.2008 11:09:19
link :: Deneb does 4.3GHz on air, launch approaching
The source even indicates that since Nehalem isn't that much of a desktop upgrade, but server mostly,
Deneb will become the gaming processor to get. We have no secondary confirmation at this time, but
we wanted to forward the information. In fact, source also says that Deneb was able to do 4.3GHz under
a Scythe Mine cooler, stable of course. It's very important to use the right motherboard though, you will
need the SB750 southbridge to begin with.
Most people should be able to hit 3.6GHz with a decent cooler, source says. The most amazing is that the
processor should still run fairly cool and consume less power than Intel equivalents. Comparing Intel's new
processors to AMD's new, Intel is gaining on the server market, while AMD will be trying to get back the
retail market. We will not have to wait long for it to happen either, mass production is well under way and launch is approaching. |
4GHz screenid on ammu liikvel, lisaks on saavutatud ka 4.3GHz.
aga jah, eks aeg näitab. igatahes asi peaks tegema 3.6GHz 24/7 lõdvalt ja olema jahedam/vähem näljasem kui inteli samaväärsed prosed
728 |
Denke
aap14
12.11.2008 22:35:26
| ausalt öeldes ei saanud sellest viimasest postitusest(probleemist) vabsee aru icon_rolleyes.gif |
Ohjah Igatahes see probleem juba lahenes. Asus-el on siiski üks emaplaat, mis toetab dual Ati videokaarte 16 kordse crossfire-iga ja samas omab SB750 southbridge-i tulevase Denebi kellamiseks. Selleks emaplaadiks on M3A79-T Deluxe.
Nüüd saan siis osta 2*4850 kaardid, selle Asuse emaplaadi, + X2 prose ja muu komplekti kuuluva ning oodata rahulikult Denebi väljatulekut järgmise aasta alguses
AMD
38 |
One
13.11.2008 11:13:21
link :: AMD Announces Widespread Availability for its 45nm Quad-Core Opteron Processors
The latest Quad-Core AMD Opteron processors at the 75-watt ACP
ranging from 2.3 to 2.7 GHz are available immediately, with enhanced
Quad-Core AMD Opteron HE (55-watt) and SE (105-watt) processors
planned to follow in Q1 2009. |
Serveri prosed(Shanghai) ametlikult launchitud.
Loodetavasti tulevad review-d ka varsti.
Aga jah, eks ta ole ikka tiba lahjem kui desktopi variant Deneb.
HT link ja muu on tunduvalt madalam. Samas TDP on juba serveri prosedel väga hea.
2.7GHz quadcore mille TDP on ainult 75w
nädala pärast kolin jälle AMD-le üle. 790GX ja X4 9550 ootavad.
Proset kannatab Deneb-i launchini kasutada küll
728 |
aap14
13.11.2008 12:00:53
Proset kannatab Deneb-i launchini kasutada küll icon_smile.gif |
Väga hea, endal plaanis sama teha, ainult teise emaplaadiga.
Mu eelmise posti kohta, siis
http://www.techpowerup.com/index.php?76075 Asus lists AM3 supportive AM2 and AM2+ motherboards
Sealt siis selle M3A79-T Deluxe välja võtsingi.
38 |
AJ
| Kommentaarid: 37 loe/lisa |
36 |
A-Circus.
| Kommentaarid: 50 loe/lisa |
48 |
One
13.11.2008 13:44:07
voolutarve on küll mõistlik
728 |
Denke
13.11.2008 13:52:38
Inteliga pole mõtet võrrelda ,sest neil FB-DIMMid aga K10ga võrreldes on asi väga ilus.
AJ
36 |
indu
13.11.2008 20:30:44
Lõpuks ometi tekib jälle konkurents ? Ootab AM3 socketeid. Liiga kaua juba intelit kasutanud
_________________ http://www.lossirestoran.eu/ |
| Kommentaarid: 63 loe/lisa |
58 |
aap14
38 |
vambola
13.11.2008 22:13:07
| Minagi varusin omale igaks juhuks ühe AM3-ready MSI toreda FAH-mobo. Oleks tore küll, kui sinna mingi kobeda prose varsti saaks peale panna.
120 |
Xenomorph
13.11.2008 23:59:05
| Kas kuskil mingit amd "ajakava" pole ? Nagu kuna midagi launchitakse ja toodetakse ?
| Kommentaarid: 30 loe/lisa |
29 |
vambola
120 |
G80
210 |
One
728 |
aap14
14.11.2008 10:27:51
Ongi, neil tundub seal kõik olevat vähemalt kolmandiku võrra soodsam
38 |
AJ
36 |
Mirkel
16.11.2008 03:12:39
omg ma oleks täna peaaegu phenomi ostnud, aga otsas oli. Polnud aimugi, et mingid uued prosed tulevad
Kas kusagil on mingi timeline ka üleval, mis prosed, mis takti, mis socketiga, millal välja tulevad?
57 |
Dolph
| Kommentaarid: 16 loe/lisa |
14 |
AJ
36 |
One
16.11.2008 17:54:34
Siin on kirjas mis millal tuleb. Fusion ehk Liano ja Ontario on mõlemad 2011.
esimene siis desktop ja mainstream notebook ja teine ultraportable läpakad..
728 |
vambola
16.11.2008 17:56:11
| Mul jäi mulje, et Deneb tuleb juba Detsembri alguses. Aga paistab, et ei tule siiski.
120 |
One
16.11.2008 17:56:55
| vambola kirjutas: |
| Mul jäi mulje, et Deneb tuleb juba Detsembri alguses. Aga paistab, et ei tule siiski. |
võib tulla küll aga official launch on jaanuari alguses.
728 |
G80
16.11.2008 17:59:13
| vambola kirjutas: |
võib tulla küll aga official launch on jaanuari alguses. |
8 jaanuar oli kuupäev, ei usu, et enne midagi saada on.
210 |
CoiL
16.11.2008 18:57:40
krt kui see Deneb tuleb normi hinnaga ja häid DDR2 platesid ka mõistliku hinnaga saada millega natuke kellata, siis tuleb küll tahtmine AMD-le tagasi kolida
| Kommentaarid: 95 loe/lisa |
83 |
Mirkel
16.11.2008 20:30:09
ah jama, ma rohkem lootsin nagu... selle kuu lõpp või midagi
esimesed denebid tulevad kõik am2+ peale siis eks? siis mul oleks plate olemas. am3 tuleb mingi aasta+ pärast?
57 |
One
16.11.2008 20:39:48
| am3 tuleb järgmine aasta
728 |
G80
16.11.2008 22:41:03
| am3 tuleb järgmine aasta |
Mis vahe sellel AM3-l ja AM2+-l on?AM3 prosed näiteks lähevad ju biosse updatega AM2+ pesasse.
210 |
vambola
16.11.2008 22:47:17
| G80 kirjutas: |
Mis vahe sellel AM3-l ja AM2+-l on?AM3 prosed näiteks lähevad ju biosse updatega AM2+ pesasse. |
Ainult AM2/AM3 prosed lähevad. Eks nad lähevad ka DDR3-le üle tasapisi. AM3 on DDR3 platvorm, Denebil on DDR2 ja DDR3 kontrollerid mõlemad pardal.
120 |
SilQ
16.11.2008 23:16:44
| vambola kirjutas: |
| G80 kirjutas: |
Ainult AM2/AM3 prosed lähevad. Eks nad lähevad ka DDR3-le üle tasapisi. AM3 on DDR3 platvorm, Denebil on DDR2 ja DDR3 kontrollerid mõlemad pardal. |
Esimesed AM3'd on ikka veel DDR2 peal
http://www.asus.com/products.aspx?l1=3&l2=149&l3=789
215 |
Mirkel
17.11.2008 03:54:28
hmm see asuse plaat täidab ka allpool oleva hinnavaatleja kriteeriumid.
| aap14 kirjutas: |
Oleks mingi emme, mis mõlemat teeks, siis oleks AMD peale vast läinud. |
57 |
G80
210 |
One
17.11.2008 10:07:46
ei tea, kuidagi kahtlane tundub see artikkel. ses mõttes, et samasugused nimed nagu intelil ja TDP on ka kuidagi kõrge
kui serveri prosedega võrrelda.
728 |
Ho Ho
17.11.2008 11:47:23
Nimed on suts imelikud tõesti. TDP'd annaks sellega seletada, et paremad prosed müüakse serveritele.
87 |
Sendler
34 |
One
17.11.2008 11:58:33
link :: Phenom II Final Nomenclature and Launch-Schedule Revealed
AMD would be releasing its 45nm silicon-based desktop CPUs, built on the Deneb, Propus, Heka, Rana and Regor cores, to bring out quad-core, triple-core and eventually dual-core processors. AMD has discarded the 5-digit number scheme that was earlier reported, and in its place, adopted a three-digit scheme. The quad-core Deneb chips get a 9xx model number and 8xx number depending on the clock-speeds and cache size, Propus-based chips get the Athlon X4 branding.
Heka-based chips get Phenom II X3 7xx branding, with Rana getting Athlon X3 4xx. Regor dual-core trails with Athlon X2 2xx. It is important to note that AMD seems to have made a critical change to the Deneb core, releasing 2 models based on cache-arrangements. The first kind features a total of 8 MB cache (4x 512K L2 + 6M L3) and one with 6 MB total cache. To learn more about the other cores, please refer to our older article getting into details |
X4 940 on lahtiste kordajatega
Veega 4+GHz..
728 |
Ho Ho
17.11.2008 12:00:16
| Veega 4+GHz.. |
Nüüd on veel puudu asjalikud benchmargid
87 |
Le Inc
17.11.2008 12:34:02
8 Mb cache'iga Phenom tundub päris jammi ... Saaks veel 4 GHz ka pääle, võiks Inteli toodangu jälle kõrvale heita.
| Kommentaarid: 56 loe/lisa |
54 |
Ho Ho
17.11.2008 12:43:44
| Le Inc kirjutas: |
| 8 Mb cache'iga Phenom tundub päris jammi |
Huvi pärast küsin et kas kusagil on näha ka olnud kuidas cache suurus AMD perfi mõjutab? K8 aegadel polnud 256k vs 1M vahel just eriti suurt vahet
87 |
AJ
36 |
CoiL
17.11.2008 13:27:24
Mis selle Phenom II X4 940 hind võiks siin eestis umbes kujuneda? See ECS plate näeb päris kobe välja imo.
83 |
