uus teema   vasta Tarkvara »  WWW »  Ei saa hot.ee-sse! märgi kõik teemad loetuks
danny
danny
sõnum 12.10.2008 15:49:04 Ei saa hot.ee-sse! vasta tsitaadiga
tere on mingi jama, et ma ei pääse hot.ee ja soov.ee sse. üritades siseneda hoti ytleb mulle nii.
www.hot.ee esilehele saan aga kui panen et sisene jäebki kinni ja annab selle teate
You tried to access the address https://epass.elion.ee/do?service=external/IPizza, which is currently unavailable. Please make sure that the Web address (URL) is correctly spelled and punctuated, then try reloading the page.
Secure connection: fatal error (40)
Failed to connect to server. The reason may be that the encryption methods supported by server are not enabled in the security preferences.
Make sure your Internet connection is active and check whether other applications that rely on the same connection are working.
Check that the setup of any Internet security software is correct and does not interfere with ordinary Web browsing.
If you are behind a firewall on a Local Area Network and think this may be causing problems, talk to your systems administrator.
Try pressing the F12 key on your keyboard and disabling proxy servers, unless you know that you are required to use a proxy to connect to the Internet. Reload the page.
Ja kui tahan minna www.soov.ee siis viskab mu speedtoutchi lehele ja kostab mulle
SpeedTouch Diagnostics...
Your SpeedTouch encountered problems to connect to the requested website. Server might be temporarily unreachable. Click on the link below to retry.
If the problem persists, you may want to look at the diagnostics page to further investigate the issue.
Try Again
Check Connectivity
Mis kamm on!? oskab keegi aidata! läpakas seisab wifi modemi taga.Ja seal on veel personaal arvuti.ka sealt ei pääse hoti.
Kommentaarid: 49 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 42
waux
waux
sõnum 12.10.2008 16:12:17 vasta tsitaadiga
vee vahemälu puhtaks ja/või proovi teist lehitsejat.
hoti või soovi kala see pole,sest need avanevad ilusti.
isp jonnib vist.
Kommentaarid: 602 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 498
danny
danny
sõnum 12.10.2008 16:15:22 vasta tsitaadiga
opera ega IE ga ei avanud. mälu tühjendamine kasutu.
gnoom
sõnum 12.10.2008 16:21:36 Re: Ei saa hot.ee-sse! vasta tsitaadiga
danny kirjutas:
No aga alustagi selles, et kontrollid oma seebikarbi seaded üle.
Kommentaarid: 67 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 64
danny
danny
sõnum 12.10.2008 16:24:13 vasta tsitaadiga
hull võhik olen selle seebikarbiga.pole varem kokku puutunud sellega.tavaliselt kui näppima hakkan kaob üldse nett ära icon_razz.gif
